Configuring Machine Learning Anomaly Scoring
Machine Learning Anomaly Scoring is a method of processing incoming initial measurement data designed to use Artificial Intelligence and Machine Learning neural network models to recognize "normal" versus anomalous measurement values, and only perform Validation, Editing, and Estimation (VEE) processing for measurements deemed to be anomalous.
Configuring the system for Machine Learning Anomaly Scoring involves the following:
NOTE: Machine Learning Anomaly Scoring relies on machine learning models that must be deployed as part of your cloud service implementation. Please contact your Oracle Customer Success Manager if you wish to use Machine Learning Anomaly Scoring.
Measuring Components and Measuring Component Types
Specific measuring components and/or measuring component types are enabled for Machine Learning Anomaly Scoring using the Enable ML Based Validation or Enable ML Based Validation (Fallback) flag (respectively).
MDM Master Configuration
The Machine Learning Configuring section of the MDM Master Configuration defines how results coming back from machine learning scoring are processed.
- Exception Type: specifies the VEE exception to be created when the machine learning anomaly score is higher than the Anomaly Score Threshold or when there was an error during the scoring process.
- Anomaly Score Threshold: the limit for the anomaly score of any measurement within an initial measurement data. If the anomaly score (the difference between the Pre-VEE measurement value and the machine learning value) for one or more initial measurement data measurements is equal to or higher than this threshold then the initial measurement data will be considered anomalous and will be processed through VEE rules. Any initial measurements where all anomaly scores are below this threshold skip VEE processing and move to finalizing the initial measurement data to the measurement table.
Configure Payload Processing Extendable Lookups
To configure Payload Processing for use with Machine Learning Anomaly Scoring, you need to create two types of Payload Processing Extendable Lookup values:
- Initial Payload Processing: These are standard SGG Payload Processing Configuration (D1-SGGPayloadProcessing) extendable lookup values. You need to create one of these for each head end system from which you intend to process data using Machine Learning Anomaly Scoring. See Creating SGG Payload Processing Extendable Lookup Values for more information.
Machine Learning Payload Processing: These are values for the SGG ML
Payload Processing Configuration (D1-SGGMLPayloadProcessing) extendable lookup.
to process data using Machine Learning Anomaly Scoring. Values for this
extendable lookup include the following:
- Payload Handler Class Name: The Java class name for the processing handler to be used. This should be "com.splwg.d1.domain.sgg.ml.processing.MLResultPayloadHandler".
- Head-End System: The head end system for which the configuration will apply. Select from the drop-down list.
- Load All ML Results: A checkbox that indicates if Post VEE data should be created in the IMD regardless of anomalous status. This should be avoided in production environments as it increases the storage requirement for each Initial Measurement Data record which can lead to slower transaction processing.
- Payload Processing Result Type: The type of payload to which the configuration applies. Machine Learning Anomaly Scoring is only supported for Initial Measurements at this time.
Batch Processing
Batch processing is used with Machine Learning Anomaly Scoring for both initial payload processing as well as processing data returned from the machine learning model. See Creating Payload Processing Batch Controls for more information about creating Payload Processing batch processes.
Machine Learning Anomaly Scoring receives initial measurement payloads via Payload Processing batch processes based on the following templates:
- Payload Processing Monitor Template with Export (D1-PLPSO)
This is used to send initial measurements to Object Storage for machine learning processing.
Processing Data Returned from the Machine Learning Model
Machine Learning Anomaly Scoring processing data returned from the machine learning model using Payload Processing batch processes based on the following templates:
- SGG ML Payload Processing Monitor Template (D1-PLMLP)
This is used to retrieve measurements following machine learning processing, populate the IMD with machine learning values and the Anomaly Score Threshold, and calculate the Anomaly Score for each measurement value. Batch processes based in this template require an SGG ML Payload Processing Extendable Lookup value.
