Connect / Disconnect
The ConnectDisconnect composite is responsible for starting and stopping the recording of usage data for a meter.
Composite Properties
| Property Name | Default Value | Description |
| CB_CDCallbackEndpoint | http://[SERVER_NAME]/soa-infra/services/DG/ConnectDisconnect/CB_ServerService | The default endpoint to which MultiSpeak should send the asynchronous CB_Server callback. |
| isExecutingCDReceivedCallout | true | Controls whether the Request Received callout executes. |
| isExecutingCDCompletedCallout | true | Controls whether the Request Received Completed callout executes. |
| isExecutingCDStatesChangedArrivedCallout | true | Controls whether the CD States Changed Notification arrival callout executes. |
| CallbackTimeoutYears | 0 | The number of years to await a response from the MultiSpeak server. This property only takes effect when the expTime element is not supplied in the input to the service. |
| CallbackTimeoutMonths | 0 | The number of months to await a response from the MultiSpeak server. This property only takes effect when the expTime element is not supplied in the input to the service. |
| CallbackTimeoutDays | 0 | The number of days to await a response from the MultiSpeak server. This property only takes effect when the expTime element is not supplied in the input to the service. |
| CallbackTimeoutHours | 0 | The number of hours to await a response from the MultiSpeak server. This property only takes effect when the expTime element is not supplied in the input to the service. |
| CallbackTimeoutMinutes | 0 | The number of minutes to await a response from the MultiSpeak server. This property only takes effect when the expTime element is not supplied in the input to the service. |
| CallbackTimeoutSeconds | 45 | The number of seconds to await a response from the MultiSpeak server. This property only takes effect when the expTime element is not supplied in the input to the service. |
Composite WSDLs
| Composite | Description |
| ConnectDisconnectService | Entry point for the ConnectDisconnect operation. After a synchronous reply, further updates will be sent to the specified location asynchronously using DG-ConnectDisconnectStateChgNotification. |
| CB_ServerService | MultiSpeak WSDL hosted to receive asynchronous CDStatesChangedNotification callbacks from the head end system. |
| CB_ServerCallout | Reference describing the process callout used when the asynchronous callback from the head end system arrives. |
| CD_ServerCallout | Reference describing the process callout. |
| CD_ServerProxy | Reference describing the proxy used to invoke the head end system. |
| AuxiliaryRoutines | Reference to common helper routines in the Common composite. |
| DG-ConnectDisconnectStateChgNotification | A reference to an inbound web service capable of processing asynchronous results from a Connect/Disconnect request. |
Process Flow
SGG/OUAF invokes InitiateConnectDisconnect operation using ConnectDisconnectService.
Composite properties are loaded and local variables are initialized.
Test whether the input includes a expiration time -
If Yes: Use AuxilaryRoutines to compute timeout.
If No: Use composite properties and AuxiliaryRoutines to compute expiration time.
Both the Header and Body inputs are transformed to MultiSpeak format.
If required, execute a process callout in CD_ServerCallout. Assign updated data to head end request.
Add a callback URL to the head end request. This is the endpoint the head end will use to send the results.
Invoke InitiateConnectDisconnect via the CD_ServerProxy to the head end system.
If required, execute a process callout in CD_ServerCallout. Assign updated data to head end response.
Transform Header and Body head end responses to SGG/OUAF format.
Reply to SGG/OUAF with synchronous results.
Check for ErrorObject in the head end response.
If error object not found: Await asynchronous response from head-end system for the period of expiration time calculated during start of this flow: -
Receive CDStatesChangeNotification from CB_ServiceService.
Generate reply with no errors for CDStatesChangeNotification
Synchronously reply to the head end.
If required, execute a process callout in CB_ServerCallout. Assign updated data to the incoming request.
Transform Header and Body of incoming request to OUAF inbound web service format described in DG-ConnectDisconnectStateChgNotification.
If request contains responseURL -
Invoke the inbound web service on given responseURL with the transformed incoming request.
Else -
Invoke the inbound web service on definedURL with the transformed incoming request.
