Meter Administration Services
This section describes the meter administration services of the Adapter Development Kit test harness composite.
AddMeters
This web service adds a set of meters to the in-memory data store. This will not permanently add it to the control file.
Input: AddMetersInput
Part: payload
Element: AddMetersRequest
| Parameter | Description |
| id | The identification code for the meter. |
| utility | An informational string. |
| serviceType | One of the valid ServiceType values (see schema). "Electric" is the only option at this time. |
| isCommissioned | Whether or not the meter is in a commissioned state. |
| loadActionCode | One of the possible LoadActionCode values used in Connect and Disconnect (see schema). |
| outageEventType | One of the possible OutageEventType values used in Device Status Check (see schema). |
| executionStatus | One of the possible ExecutionStates (see schema). These values control how the meter will respond to commands. |
| updateIfExisting | Whether or not to update the meter with the provided values if it already exists in the index. |
| Comment | An informational string describing the purpose of the meter. |
| Channels | A listing of unit of measures supported by this meter. |
| uomCode | A code describing the unit of measure for the channel. |
| uomName | A short string containing the name of the unit of measure. |
| decimals | The number of digits to the right of the decimal that should be generated when reading the meter. |
| description | A longer description of the unit of measure. |
Output: AddMetersOutput
Part: payload
Element: AddMetersResult
Whether or not each meter was added to the index.
Fault: See UtilityFault.
RemoveMeter
This web service removes a meter from the in-memory data store. This will not permanently remove it from the control file.
Input: RemoveMeterInput
Part: payload
Element: RemoveMeterRequest
| id | The ID for the meter to be removed. |
Output: RemoveMeterOutput
Part: payload
Element: RemoveMeterResult
Whether or not the meter was removed from the index.
Fault: See UtilityFault. Thrown when meter id is not found.
AddMeterChannel
This web service adds a new channel to a single meter.
Input: AddMeterChannelInput
Part: payload
Element: AddMeterChannelRequest
Output: AddMeterChannelOutput
Part: payload
Element: AddMeterChannelResult
Whether or not the channel was added to the index.
RemoveMeterChannel
This web service removes a Channel from a meter.
Input: RemoveMeterChannelInput
Part: payload
Element: RemoveMeterChannelRequest
These three parameters are combined to locate a unique channel
Output: RemoveMeterChannelOutput
Part: payload
Element: RemoveMeterChannelResult
Whether or not the channel was removed from the meter.
ReadScalarMeter
This web service generates a scalar reading for each channel of a given meter.
Input: ReadScalarMeterInput
Part: payload
Element: ReadScalarMeterRequest
| id | The ID for the meter to be read. |
Output: ReadScalarMeterOutput
Part: payload
Element: ReadScalarMeterResult
Zero or more scalar readings for the given meter.
| value | A random number representing the scalar reading. |
