Plug-In Scripts
This section assumes you are familiar with the notion of plug-in
spots (algorithm entities) and plug-ins. See  The Big Picture Of Algorithms for more information.
As an alternative to writing a java program for a plug-in spot, the framework supports creating plug-ins using the defined script steps, Xpath commands, Groovy code or a combination of these three options.
The following topics describe basic concepts related to plug-in scripts.
