Maintaining Customer Code
The system supports a process to import custom Java code to be deployed in the cloud under certain use cases.
Refer to the Cloud Services Implementation Guide for information
about how to use this functionality.
The Customer Code portal allows you to review the status of the lifecycle of the process to import code and allows you to review errors that may have been received.
To view a customer code record, navigate using You are brought to a query portal with options for searching for customer code. Once a record has been selected, you are brought to the maintenance portal to view and maintain the selected record.
