Table | Name | Description |
C1_CS_REQ_TYPE_QSTN_RELOBJ | CS Request Type Question Related Object | Child of the CS Request Type Question table, used to store related objects |
C1_CS_REQ_TYPE_QUESTION | CS Request Type Question | Used to store configuration data representing questions that can be asked as part of a request type |
C1_CS_REQ_TYPE_QUESTION_REL | CS Request Type Question Relationship | Child of the CS Request Type Question table, used to store relationships between questions and other objects |
Table_Name | Index_Name |
C1_CS_REQ_TYPE_QSTN_RELOBJ | C1C167P0 |
C1_CS_REQ_TYPE_QSTN_RELOBJ | C1C167S1 |
C1_CS_REQ_TYPE_QUESTION | C1C165P0 |
C1_CS_REQ_TYPE_QUESTION | C1C165S1 |
C1_CS_REQ_TYPE_QUESTION | C1C165S2 |
C1_CS_REQ_TYPE_QUESTION_REL | C1C166P0 |
C1_MKTMSG_CHG_DTL | C1T137S5 |
Table_Name | Column_Name | Data Type | Data Length |
C1_BI_FT_VW | XFER_TO_GL_DT | Date | 10 |
C1_CS_REQ_TYPE_QSTN_RELOBJ | CS_REQ_TYPE_CD | VARCHAR | 30 |
C1_CS_REQ_TYPE_QSTN_RELOBJ | MAINT_OBJ_CD | CHAR | 12 |
C1_CS_REQ_TYPE_QSTN_RELOBJ | PK_VALUE1 | VARCHAR | 254 |
C1_CS_REQ_TYPE_QSTN_RELOBJ | PK_VALUE2 | VARCHAR | 254 |
C1_CS_REQ_TYPE_QSTN_RELOBJ | PK_VALUE3 | VARCHAR | 254 |
C1_CS_REQ_TYPE_QSTN_RELOBJ | PK_VALUE4 | VARCHAR | 254 |
C1_CS_REQ_TYPE_QSTN_RELOBJ | PK_VALUE5 | VARCHAR | 254 |
C1_CS_REQ_TYPE_QSTN_RELOBJ | QSTN_REL_OBJ_SEQ_NUM | NUMB | 3 |
C1_CS_REQ_TYPE_QSTN_RELOBJ | QSTN_REL_OBJ_TYPE_FLG | CHAR | 4 |
C1_CS_REQ_TYPE_QSTN_RELOBJ | QUESTION_APPL_FLG | CHAR | 4 |
C1_CS_REQ_TYPE_QSTN_RELOBJ | SEQ_NUM | NUMB | 3 |
C1_CS_REQ_TYPE_QSTN_RELOBJ | VERSION | NUMB | 5 |
C1_CS_REQ_TYPE_QUESTION | BO_XML_DATA_AREA | XML | 1073741824 |
C1_CS_REQ_TYPE_QUESTION | BUS_OBJ_CD | CHAR | 30 |
C1_CS_REQ_TYPE_QUESTION | C1_ANSWER_CD | VARCHAR | 30 |
C1_CS_REQ_TYPE_QUESTION | C1_QUESTION_CD | VARCHAR | 30 |
C1_CS_REQ_TYPE_QUESTION | CS_REQ_TYPE_CD | VARCHAR | 30 |
C1_CS_REQ_TYPE_QUESTION | CS_REQ_TYPE_QSTN_STAT_FLG | CHAR | 4 |
C1_CS_REQ_TYPE_QUESTION | CUST_CL_CD | CHAR | 8 |
C1_CS_REQ_TYPE_QUESTION | PERS_BUS_QSTN_APPL_FLG | CHAR | 4 |
C1_CS_REQ_TYPE_QUESTION | QUESTION_APPL_FLG | CHAR | 4 |
C1_CS_REQ_TYPE_QUESTION | QUESTION_PLACE_GRP | VARCHAR | 254 |
C1_CS_REQ_TYPE_QUESTION | SEQ_NUM | NUMB | 3 |
C1_CS_REQ_TYPE_QUESTION | SORT_SEQ5 | NUMB | 5 |
C1_CS_REQ_TYPE_QUESTION | VERSION | NUMB | 5 |
C1_CS_REQ_TYPE_QUESTION_REL | C1_ANSWER_CD | VARCHAR | 30 |
C1_CS_REQ_TYPE_QUESTION_REL | C1_QUESTION_CD | VARCHAR | 30 |
C1_CS_REQ_TYPE_QUESTION_REL | CS_REQ_TYPE_CD | VARCHAR | 30 |
C1_CS_REQ_TYPE_QUESTION_REL | REL_QSTN_SEQ_NUM | NUMB | 3 |
C1_CS_REQ_TYPE_QUESTION_REL | SEQ_NUM | NUMB | 3 |
C1_CS_REQ_TYPE_QUESTION_REL | VERSION | NUMB | 5 |
C1_QUESTION_ANSWER | CHAR_TYPE_CD | CHAR | 8 |
