Table | Name | Description |
CI_MD_FLD_ADDTL | Field Additional Attributes | This is an extension of the CI_MD_FLD table and is used to capture additional information about a field. |
F1_MO_UPD_BACKUP | Entity Key Backup Table | This table is part of generalized export batch it is used to keep a backup of all entity keys exported by a specific batch run number |
F1_MIGR_OBJ_DATA | Migration Object Data | This is a child table to store Migration Object Content that is currently stored directly on the migration object itself |
F1_BATCH_RUN_ANALYTICS_SNAP* | Batch Run Analytics Snapshot | Reserved for future use. |
F1_BATCH_THD_ANALYTICS_SNAP* | Batch Thread Analytics Snapshot | Reserved for future use. |
Table | Comments |
F1_CRYPTO_KEY_RING_LINK | This table was created in a previous release in anticipation of a future feature. It was not used in any product functionality. Subsequently the design changed such that this table is not longer needed. |
Table_Name | Index_Name |
F1_MIGR_OBJ | F1T188S3 |
F1_SVC_TASK | F1C474S3 |
F1_MKTMSG_IN | F1T759S3 |
Table_Name | Column_Name | Data Type | Data Length |
F1_MIGR_DATA_ST | REDACT_OPT_FLG | CHAR | 4 |
F1_MIGR_DATA_ST | INSERT_ONLY_FLG | CHAR | 4 |
F1_MIGR_DATA_ST | BULK_IMPORT_FLG | CHAR | 4 |
F1_MIGR_OBJ | ENTITIES_CNT | NUMBER | 6 |
F1_MIGR_OBJ_SQL | PK_VALUE1 | VARCHAR2 | 254 |
F1_MIGR_OBJ_SQL | PK_VALUE2 | VARCHAR2 | 254 |
F1_MIGR_OBJ_SQL | PK_VALUE3 | VARCHAR2 | 254 |
F1_MIGR_OBJ_SQL | PK_VALUE4 | VARCHAR2 | 254 |
F1_MIGR_OBJ_SQL | PK_VALUE5 | VARCHAR2 | 254 |
SC_APP_SERVICE_L | DESCRLONG | VARCHAR2 | 4000 |
F1_CRYPTO_KEY_RING | KEY_RING_CAT_FLG | CHAR | 4 |
CI_CURRENCY_CD | EXT_CURRENCY_CD | CHAR | 36 |
F1_ETL_MP_CTRL | F1_BI_TYPE_FLD | CHAR | 30 |
F1_ETL_MP_CTRL | F1_BI_TYPE_VALUE | CHAR | 4 |
Table_Name | Column_Name | From | To |
F1_CRYPTO_KEY | PUBLIC_KEY | VARCHAR (2000) | VARCHAR (4000) |
View_Name | Changes |
CI_TD_ENTRY_OPEN_VW | /*+ no_unnest */ hint added |
