Field | Description |
Userid | This is the unique user identifier used within the Oracle Utilities Cloud Service for authorization activities. Limited to eight characters. |
Login Id | This is the unique user identifier used within the Oracle Utilities Cloud Service for authentication purposes. This must match the value used in the security repository to successfully use the Oracle Utilities Cloud Service. Limited to 256 characters, which can be similar or different from Userid. |
Last Name | Last name of the user. Limited to 50 characters. |
First Name | First name of the user. Limited to 50 characters. |
User Enable | Indicates whether the user is active or inactive in the security system. Valid values are Yes (default) and No. Yes indicates the user is active and can use the system while No indicates the user is inactive and cannot use the system. Refer to User Enable and Disable for more information. |
User Type | Describes the type of user. Valid values are Blank and Template. Blank refers to normal users. Refer to Template Users for more information about the Template user type. |
Language | Default language used by user. For non-English languages, the Language pack must be installed. |
Display Profile Id | The display profile associated with the user that controls the displayed currency, dates, and so on. |
Time Zone | Time zone assigned to the user account. This is only applicable to specific services. Refer to Oracle Utilities Cloud Service online documentation for more information about its applicability. |
Email Address | Optional email address associated with the user that can be used for interfaces requiring email addresses. |
Dashboard Width | Describes the default width of the Dashboard portal. Setting the value to “0” disables the dashboard. |
Dashboard Location | Indicates the preferred location of the Dashboard portal. This is only enabled for use with the Screen Layout Profile user experience. |
Dashboard State | Indicates the preferred initial state of the Dashboard portal. This is only enabled for use with the Screen Layout Profile user experience. |
Home Page | The default home page associated with the user. |
Portals Profile User Id | The user identifier from which to inherit portal definitions. For more information, refer to Template Users. |
Favorites Profile User Id | The user identifier from which to inherit favorite definitions. For more information, refer to Template Users. |
To Do Summary Age Bar | The color schemes for the To Do Summary portal in the Dashboard. This can be used to indicate relative age of To Do entries. |
User Groups | This is a list of user groups and their associated expiry dates. Refer to Define Users to User Groups for more information. |
Display | Indicates whether to include the zone or exclude it from the portal. Refer to Zone Visibility of the online Administration Guide for more information. |
Initially Collapsed | Indicates whether to display the zone in collapse or expand mode during the initial load. Zones are collapsed only when expanded Marking zones as “initially collapsed” speeds up the portal loading time. |
Sequence | Defines the relative order of the zones within the portal. A value of zero takes the default sequence from the portal definition. |
Refresh Seconds | Defines the zone automatic refresh rate but is only applicable to a subset of zone types. A value of zero disables auto-refresh. |
Security Access | Indicates whether the zone is accessible or not to the user. It is possible to for a zone to have zones that are not accessible to an individual user. |
Sequence | Internal sequence used for sorting. |
Name | The name of the bookmark. The URL for the bookmark is hidden and is not editable. |
Sequence | The relative sequence number of the favorite link used for sorting purposes. |
Navigation Option | The navigation option to display the favorite links. This can reference the zone or maintenance function to display after selecting the favorite link. |
Security Access | Indicates whether the Navigation Option is accessible or not to the user. |
Sequence | The relative sequence number of the favorite used for sorting purposes. |
Script | The BPA script to use to display the favorite function or menu items. |
Security Access | Indicates whether the BPA script is accessible or not to the user. |
Characteristic Type | The characteristic type associated with the User object. |
Sequence | The relative sequence number of the characteristic used for processing purposes. |
Characteristic Value | Depending on the configuration of the characteristic type, the characteristic value may be free-formatted, an attachment, in a specific format, or a specific set of values. |
Application Service | The unique identifier of the Application Service used in configuration of security on objects, menus, services, and so on. For custom definitions, Oracle recommends adding a “CM” prefix to distinguish these from Application Services provided by OUCS. |
Description | A brief description for documentation purposes that appears on security screens when the Application Service is specified. |
Access Modes | Lists the valid access modes for the Application Service. The modes must match the internal actions supported by the objects used by the Application Service. Use the Add icon to insert an access mode. Note that an access mode can only be defined once on an Application Service. Use the Delete icon to remove an existing access mode from the list. The Access Mode link to the Application Service is ownership-controlled and by default, all created links are owned as Customer Modifications. Refer to Data Ownership Rules for more information. |
Application Service Details | Summarizes the access modes and security types of the Application Service. |
User Groups With Access | Lists the user groups with access to the Application Service, along with the associated expiry dates, access modes, security types, and associated authorization levels. Use the Deny Access function to limit the access of user groups to the Application Service. |
User Groups Without Access | Lists the user groups without access to the Application Service. Use the Grant Access function to allow user groups to access the Application Service. |
Expiry Date | Specifies the date when access to the user group expires. |
Access Mode | Shows the access mode defined on the Application Service definition. Use the Add icon to insert an access mode or use the Delete icon to remove an existing access mode from the list. |
Owner | Ownership of the link. Refer to Data Ownership Rules for more information. |
Security Type | The security type code associated with the Application Service. Use the Add icon to insert a security type or use the Delete icon to remove an existing security type from the list. |
Authorization Level | The authorization level assigned to the user group when running the Application Service for the security type. |
User | The authorization user identifier to associate with the user group. |
Expiration Date | Indicates the date when the association between the user and user group expires. |
Default Access Group | The default access group for a new user-created object that is subject to Access Security. This can be overridden by logic within the object if necessary. |
Data Access Role | Lists of data access roles to which the user is attached. |
Expiration Date | The date when the association between the user and data access role will expire. |
Value | Implications |
Enable | • The user can access the system. • The user can process records according to the authorization model. • The user must be active in the Security Repository to fully access Oracle Utilities Cloud Service. |
Disable | • The user cannot access the system regardless of the security setup. • The user record is retained for audit purposes only. • The user does not have to exist in the Security Repository. The key use cases for this option are as follows: • Support for personnel (permanent or temporary) leaving: Manually deactivate users once they leave the organization and keep their information for auditing purposes. • Logical deletion: If the user record needs to be deleted for any reason, selecting this option logically removes the user record, preventing access to the system. • Temporary disablement: If business rules need to isolate the user record, selecting this option for the appropriate users can effectively deactivate their access to Oracle Utilities Cloud Service. Note: Deactivation of the user record will take effect when the user logs in to the system or after the security cache refreshes. |
