Viewing a Completed Scheduler Batch Stream
A Scheduler Batch Stream is considered Completed if it is one of the following statuses.
• Ended
• Canceled
You can view completed Scheduler Batch Stream by broadcasting it from the Completed search by option search results. The broadcasted zone “View Stream Steps” shows status of the stream such as what steps have already completed and their status, what is the currently running step(s) along with steps that have not yet started. You can monitor the progress of the stream by refreshing the page or by configuring the page to refresh automatically. To configure automatic page refresh, refer to the User Portal Preferences for this portal.
The “View Streams Steps” zone also has information on when the step started and completed, the duration the step ran for and the option to view the batch job run. Clicking on the “View” button displays the batch run details of the batch job.
The stream steps can be in one of the following states:
• Not Submitted
• Submitted
• Ended
• Failed
• Skipped
• Canceled
