Table | Name | Description |
F1_MST_CONFIG_CHAR | Master Configuration Characteristics | Future use only. |
F1_BUS_OBJ_STATUS_VW | Business Object Status View | New view populates status description with the override description (if populated) otherwise with the description. SQLs that need the BO status description can use this view instead of doing the work to check the override description. |
F1_BUS_OBJ_STATUS_RSN_VW | Status Reason View | New view populates status reason description with the override description (if populated) otherwise with the description. SQLs that need the BO status reason description can use this view instead of doing the work to check the override description. |
Table | Description | Description |
Table_Name | Column_Name | Data Type | Data Length |
F1_BUS_OBJ_STATUS_L | DESCR_OVRD | VARCHAR2 | 60 |
F1_BUS_OBJ_STATUS_RSN_L | DESCR_OVRD | VARCHAR2 | 60 |
F1_BUS_OBJ_TR_RULE_L | BO_NEXT_STATUS_OVRD_LBL | VARCHAR2 | 60 |
F1_MST_CONFIG | CONFIG_PART_NAME | VARCHAR2 | 254 |
F1_MST_CONFIG | CONFIG_CLS_FLG | CHAR | 4 |
Table_Name | Column_Name | Old Configuration | New Configuration |
F1_BUS_OBJ_STATUS_L | DESCR | Null | Space as default |
F1_BUS_OBJ_STATUS_L | OWNER_FLG | Null | Space as default |
F1_BUS_OBJ_STATUS_L | DESCRLONG | Null | Space as default |
F1_BUS_OBJ_STATUS_L | DESCR_OVRD | Null | Space as default |
F1_BUS_OBJ_STATUS_RSN_L | DESCR | Null | Space as default |
F1_BUS_OBJ_STATUS_RSN_L | OWNER_FLG | Null | Space as default |
F1_BUS_OBJ_STATUS_RSN_L | DESCRLONG | Null | Space as default |
F1_BUS_OBJ_STATUS_RSN_L | DESCR_OVRD | Null | Space as default |
F1_BUS_OBJ_TR_RULE_L | BO_NEXT_STATUS_LBL | Null | Space as default |
F1_BUS_OBJ_TR_RULE_L | OWNER_FLG | Null | Space as default |
F1_BUS_OBJ_TR_RULE_L | BO_NEXT_STATUS_OVRD_LBL | Null | Space as default |
