Preparing Legacy Data Extract for Upload
The legacy data mapping and extract will vary from one customer to another. The files created as a result of the extract process should conform to the specifications generated above. The resulting data extract files should be:
Created according to the specifications
Named according to the naming convention (see the online help and the specifications for more details)
Optionally, the file might be compressed with gzip or zip (see the online help for details)
Special Data Considerations:
Oracle Utilities Cloud Services provide support for Information Lifecycle Management (ILM) and Data Archiving.
All ILM-enabled objects contain the following fields:
ILM Date (ILM_DT)
ILM Archive Switch (ILM_ARCH_SW).
The ILM and Data Archiving functionality is controlled by the combination of these two fields.
The ILM Date field is used in conjunction with partitioning to group data by age.
The ILM Archive Switch is set by a background process when a record meets the business rules specific to the record’s Maintenance Object that indicates the record is eligible to be archived.
See Information Lifecycle Management in the application’s Administrative User Guide for more information about how these fields are used.
When preparing the legacy data extract for a target table, perform the following steps:
Access the Oracle Utilities application, search for a Conversion Instructions Conversion Task Type (see Conversion Task Types in the Oracle Utilities Cloud Service Foundation Administrative User Guide) for the target table or maintenance object and review the input data specifications. Determine if the field list contains the fields named ILM_DT and ILM_ARCH_SW.
In the data extract, populate the ILM_ARCH_SW field as follows:
Set the field with a value of "Y" for high-volume tables. In specific, the ILM_ARCH_SW field MUST be set to "Y" for the following tables used with Oracle Utilities Customer Cloud Service and Oracle Utilities Meter Solution Cloud Service:
D1_DVC_EVT (Device Event)
D1_INIT_MSRMT_DATA (Initial Measurement Data)
D1_USAGE (Usage Transaction)
Set the field with a value of "N" for all other tables
For the ILM_DT field, the ILM Date Fields table below lists the recommended column whose value should be used to populate the ILM _DT for conversion data upload.
Locate your target table name in the list and determine how the ILM_DT field should be populated
If the table is not listed, please contact Oracle Utilities support.
ILM Date Fields
Table Name
ILM DT Initial Load
CI_TD_ENTRY
CI_TD_ENTRY.CRE_DTTM
F1_SYNC_REQ_IN
F1_SYNC_REQ_IN.CRE_DTTM
F1_OUTMSG
F1_OUTMSG.CRE_DTTM
F1_SVC_TASK
F1_SVC_TASK.CRE_DTTM
F1_OBJ_REV
F1_OBJ_REV.STATUS_UPD_DTTM
F1_BUS_FLG
F1_BUS_FLG.CRE_DTTM
F1_REMOTE_MSG
F1_REMOTE_MSG.CRE_DTTM
F1_STATS_SNPSHT
F1_STATS_SNPSHT.CRE_DTTM
F1_ERASURE_SCHED
F1_ERASURE_SCHED.STATUS_UPD_DTTM
F1_PROC_STORE
F1_PROC_STORE.STATUS_UPD_DTTM
F1_GNRL_AUDIT
F1_GNRL_AUDIT.CRE_DTTM
D1_ACTIVITY
D1_ACTIVITY.CRE_DTTM
D1_COMM_IN
D1_COMM_IN.CRE_DTTM
D1_COMM_OUT
D1_COMM_OUT.CRE_DTTM
D1_DVC_EVT
D1_DVC_EVT.CRE_DTTM
D1_COMPL_EVT
D1_COMPL_EVT.CRE_DTTM
D1_INIT_MSRMT_DATA
D1_INIT_MSRMT_DATA.CRE_DTTM
D1_USAGE
D1_USAGE.CRE_DTTM
D1_USAGE_EXCP
D1_USAGE_EXCP.CRE_DTTM
D1_VEE_EXCP
D1_VEE_EXCP.CRE_DTTM
D1_ACTIVITY
CI_ADJ
CI_ADJ.CRE_DT
CI_APPR_REQ
MIN(LOG_DTTM) on CI_APPR_REQ_LOG for given APPR_REQ_ID
CI_BILL
CI_BILL.CRE_DTTM
CI_BSEG
CI_BSEG.CRE_DTTM
CI_STM
CI_STM.STM_DT
C1_OFFCYC_BGEN
C1_OFFCYC_BGEN.STATUS_UPD_DTTM
CI_BILL_CHG
CI_BILL_CHG.START_DT
CI_CASE
MIN(LOG_DTTM) on CI_CASE_LOG table for given CASE_ID
CI_FA
CI_FA.CRE_DTTM
CI_ENRL
CI_ENRL.START_DT
CI_PAY_EVENT
CI_PAY_EVENT.PAY_DT
CI_PAY
CI_PAY_EVENT.PAY_DT
CI_MATCH_EVT
CI_MATCH_EVT.CREATE_DT
C1_USAGE
C1_USAGE.CRE_DTTM
C1_CUST_REL_REQ
C1_CUST_REL_REQ.CRE_DTTM
CI_CC
CI_CC.CC_DTTM or CI_CC.LETTER_PRINT_DTTM
CI_MR
CI_MR.READ_DTTM
C1_PA_RQST
C1_PA_RQST.CRE_DTTM
C1_CS_RQST
C1_CS_RQST.CRE_DTTM
C1_CS_REQ_ACCT
C1_CS_REQ_ACCT.?
C1_CS_REQ_CONT
C1_CS_REQ_CONT.CRE_DTTM
C1_CS_RQST_CONT_PROD
C1_CS_RQST_CONT_PROD.CRE_DTTM
C1_CS_REQ_PER
C1_CS_REQ_PER.CRE_DTTM
C1_CS_REQ_CVS_LOC
C1_CS_REQ_CVS_LOC.CRE_DTTM
C1_CS_REQ_PREM
C1_CS_REQ_PREM.CRE_DTTM
C1_MKTMSG_CHG
C1_MKTMSG_CHG.MKT_CHG_DT
C1_MKTMSG_PAY
C1_MKTMSG_PAY.MKT_PAY_DT
C1_MKTMSG_USG
C1_MKTMSG_USG.MKT_USG_DT
