Table | Name | Description |
D1_IMD_CTRL_STAGE | IMD Control Staging | Used to stage IMD control records |
D1_IMD_CTRL_STAGE_K | IMD Control Staging Key | Used to store keys for staged IMD control records |
D1_IMD_TYPE | Initial Measurement Data Type | Used to capture details about types of initial measurement data |
D1_IMD_TYPE_ALG | Initial Measurement Data Type Algorithm | Used to capture algorithms related to types of initial measurement data |
D1_IMD_TYPE_L | Initial Measurement Data Type Language | Language table for Initial Measurement Data Type |
D1_MSRMT_AUDIT | Measurement Audit | Used to capture changes made to measurement data |
D1_RULE_PARM* | Rule Parameters | Used to capture parameters used by Digital Asset program rules |
D1_SPR_PROG* | Service Provider Program | Used to capture relationship between Digital Asset service providers and programs |
Table_Name | Column_Name | Data Type | Data Length |
D1_CONTACT | ADDRESS1 | VARCHAR2 | 1016 |
D1_CONTACT | ADDRESS1_UPPER | VARCHAR2 | 1016 |
D1_CONTACT | ADDRESS2 | VARCHAR2 | 1016 |
D1_CONTACT | ADDRESS3 | VARCHAR2 | 1016 |
D1_CONTACT | ADDRESS4 | VARCHAR2 | 1016 |
D1_CONTACT | CITY | VARCHAR2 | 360 |
D1_CONTACT | CITY_UPPER | VARCHAR2 | 360 |
D1_CONTACT | COUNTRY | CHAR | 12 |
D1_CONTACT | COUNTY | VARCHAR2 | 360 |
D1_CONTACT | GEO_CODE | CHAR | 44 |
D1_CONTACT | HOUSE_TYPE | CHAR | 8 |
D1_CONTACT | IN_CITY_LIMIT | CHAR | 4 |
D1_CONTACT | NUM1 | CHAR | 24 |
D1_CONTACT | NUM2 | CHAR | 16 |
D1_CONTACT | POSTAL | CHAR | 48 |
D1_CONTACT | STATE | CHAR | 24 |
D1_CONTACT_TYPE | CONTACT_USE_FLG | CHAR | 16 |
D1_DVC | DER_AGG_SPR_CD* | VARCHAR2 | 120 |
D1_IMD_CTRL_STAGE | ALG_CD | CHAR | 48 |
D1_IMD_CTRL_STAGE | D1_FROM_DTTM | DATE | 7 |
D1_IMD_CTRL_STAGE | D1_TO_DTTM | DATE | 7 |
D1_IMD_CTRL_STAGE | IMD_CTRL_DC_ID | CHAR | 48 |
D1_IMD_CTRL_STAGE | IMD_CTRL_MC_ID | CHAR | 48 |
D1_IMD_CTRL_STAGE | IMD_CTRL_STAGE_ID | CHAR | 56 |
D1_IMD_CTRL_STAGE | IMD_STAGE_PAYLOAD_XML | CLOB | 4000 |
D1_IMD_CTRL_STAGE | IMD_STAGE_STATUS_FLG | CHAR | 16 |
D1_IMD_CTRL_STAGE | IMD_TYPE_CD | VARCHAR2 | 120 |
D1_IMD_CTRL_STAGE_K | ENV_ID | NUMBER | 22 |
D1_IMD_CTRL_STAGE_K | IMD_CTRL_STAGE_ID | CHAR | 56 |
D1_IMD_TYPE | BO_DATA_AREA | CLOB | 4000 |
D1_IMD_TYPE | BUS_OBJ_CD | CHAR | 120 |
D1_IMD_TYPE | IMD_BUS_OBJ_CD | CHAR | 120 |
D1_IMD_TYPE | IMD_SEEDER_FLG | CHAR | 16 |
D1_IMD_TYPE | IMD_TYPE_CD | VARCHAR2 | 120 |
D1_IMD_TYPE | IMD_TYPE_STATUS_FLG | CHAR | 16 |
D1_IMD_TYPE | OWNER_FLG | CHAR | 16 |
D1_IMD_TYPE | VERSION | NUMBER | 22 |
D1_IMD_TYPE_ALG | ALG_CD | CHAR | 48 |
D1_IMD_TYPE_ALG | ERROR_BO_STATUS_CD | CHAR | 48 |
D1_IMD_TYPE_ALG | IMD_TYPE_ALG_STATUS_FLG | CHAR | 16 |
D1_IMD_TYPE_ALG | IMD_TYPE_CD | VARCHAR2 | 120 |
D1_IMD_TYPE_ALG | IMD_TYPE_SEVT_FLG | CHAR | 16 |
D1_IMD_TYPE_ALG | OWNER_FLG | CHAR | 16 |
D1_IMD_TYPE_ALG | SEQ_NUM | NUMBER | 22 |
D1_IMD_TYPE_ALG | VERSION | NUMBER | 22 |
D1_IMD_TYPE_L | DESCR100 | VARCHAR2 | 400 |
D1_IMD_TYPE_L | DESCRLONG | VARCHAR2 | 16000 |
D1_IMD_TYPE_L | IMD_TYPE_CD | VARCHAR2 | 120 |
D1_IMD_TYPE_L | LANGUAGE_CD | CHAR | 12 |
D1_IMD_TYPE_L | OWNER_FLG | CHAR | 16 |
D1_IMD_TYPE_L | VERSION | NUMBER | 22 |
D1_MSRMT_AUDIT | COMBINED_MULTIPLIER | NUMBER | 22 |
D1_MSRMT_AUDIT | LOG_DTTM | DATE | 7 |
D1_MSRMT_AUDIT | MEASR_COMP_ID | CHAR | 48 |
D1_MSRMT_AUDIT | MSRMT_AUDIT_ENTRY_TYPE_FLG | CHAR | 16 |
D1_MSRMT_AUDIT | MSRMT_COND_FLG | CHAR | 24 |
D1_MSRMT_AUDIT | MSRMT_DTTM | DATE | 7 |
D1_MSRMT_AUDIT | MSRMT_USE_FLG | CHAR | 16 |
D1_MSRMT_AUDIT | MSRMT_VAL | NUMBER | 22 |
D1_MSRMT_AUDIT | PREVEE_MSRMT_COND_FLG | CHAR | 24 |
D1_MSRMT_AUDIT | PREVEE_MSRMT_VAL | NUMBER | 22 |
D1_MSRMT_AUDIT | PREVEE_READING_COND_FLG | CHAR | 24 |
D1_MSRMT_AUDIT | PREVEE_READING_VAL | NUMBER | 22 |
D1_MSRMT_AUDIT | PREV_MSRMT_DTTM | DATE | 7 |
D1_MSRMT_AUDIT | READING_COND_FLG | CHAR | 24 |
D1_MSRMT_AUDIT | READING_VAL | NUMBER | 22 |
D1_MSRMT_AUDIT | SEQNO | NUMBER | 22 |
D1_MSRMT_AUDIT | USER_ID | CHAR | 32 |
D1_NW_LOC | NETWORK_NODE_1 | CHAR | 56 |
D1_NW_LOC | NETWORK_NODE_2 | CHAR | 56 |
D1_RULE_PARM | CALC_FREQUENCY* | VARCHAR2 | 1016 |
D1_RULE_PARM | D1_SEASONAL_FLG* | CHAR | 16 |
D1_RULE_PARM | ELIG_ALG_CD* | CHAR | 48 |
D1_RULE_PARM | LINE_EXT_ID* | VARCHAR2 | 1016 |
D1_RULE_PARM | MIN_DAYS* | NUMBER | 22 |
D1_RULE_PARM | PRORATE_OPTION_FLG* | CHAR | 16 |
D1_RULE_PARM | RULE_CD* | VARCHAR2 | 120 |
D1_RULE_PARM | RULE_TYPE_CATEGORY* | VARCHAR2 | 1016 |
D1_RULE_PARM | SEASON_END* | CHAR | 16 |
D1_RULE_PARM | SEASON_START* | CHAR | 16 |
D1_RULE_PARM | SEQNO* | NUMBER | 22 |
D1_RULE_PARM | SETT_FREQ_FLG* | CHAR | 16 |
D1_RULE_PARM | USG_GRP_CD* | VARCHAR2 | 120 |
D1_RULE_PARM | VERSION* | NUMBER | 22 |
D1_SPR | ACTIVE_INACTIVE_FLG* | CHAR | 16 |
D1_SPR | CONTACT_ID* | CHAR | 48 |
D1_SPR | END_DT* | DATE | 7 |
D1_SPR | START_DT* | DATE | 7 |
D1_SPR_PROG | D1_SPR_CD* | VARCHAR2 | 120 |
D1_SPR_PROG | DYN_OPT_ID* | CHAR | 48 |
D1_SPR_PROG | END_DT* | DATE | 7 |
D1_SPR_PROG | SPR_LFDI* | VARCHAR2 | 1016 |
D1_SPR_PROG | START_DT* | DATE | 7 |
D1_USAGE | RULE_CD* | VARCHAR2 | 120 |
D1_USAGE | RULE_TYPE_CATEGORY* | VARCHAR2 | 1016 |
Table_Name | Index_Name |
D1_CONTACT | D1M180S0 |
D1_IMD_CTRL_STAGE | D1T661P0 |
D1_IMD_CTRL_STAGE | D1T661S0 |
D1_IMD_CTRL_STAGE | D1T661S1 |
D1_IMD_CTRL_STAGE_K | D1T663P0 |
D1_IMD_TYPE | D1C664P0 |
D1_IMD_TYPE_ALG | D1C666P0 |
D1_IMD_TYPE_L | D1C665P0 |
D1_MSRMT_AUDIT | D1T662P0 |
D1_RULE_PARM | D1C667P0 |
D1_SPR_PROG | D1C668P0 |
Table_Name | Old_Index_Name | New_Index_Name |
D1_DYN_OPT_TYPE_QTY_TYPE | D1660CP0 | D1C660P0 |
