Language Pack Setup (Optional)
English (with the locale en-US) is provided as the default language by the system and all system metadata is delivered with English descriptions and labels. The system provides support for defining other languages and supports multiple languages in a single environment.
System users can use the system in their preferred language, as long as a translation into that language has been provided. A user sees the system in the language defined on their user record. If enabled, users can use the Switch Language zone to switch to another supported language real time.
Available Languages with Cloud Services
The following table lists languages available with Oracle Utilities cloud services.
Release
Product
User Interface / Online Help
Language
24C
Oracle Utilities Customer Cloud Service
User Interface
Arabic, Latin American Spanish, Brazilian Portuguese, Traditional Chinese
Online Help
Arabic, Brazilian Portuguese, Traditional Chinese
Oracle Utilities Testing Accelerator
User Interface
Arabic, Latin American Spanish, Brazilian Portuguese, and Traditional Chinese
24B
User Interface
Online Help
User Interface
24A
User Interface
Arabic, Latin American Spanish, and Brazilian Portuguese
Online Help
Oracle Utilities Work and Asset Cloud Service
User Interface
Traditional Chinese
Online Help
Traditional Chinese
User Interface
23C
User Interface
Online Help
User Interface
Traditional Chinese
Online Help
Traditional Chinese
User Interface
Setup Instructions
Use the following procedure to set up a language an Oracle Utilities cloud service.
1. Define the Language Code for the language to be added and indicate that it is enabled. For details on this procedure, see Defining Languages in the Administrative User Guide.
Note: Please use 'ARA', 'PTB', or 'ESA', as the Language Code for Arabic, Brazilian Portuguese, or Latin American Spanish, respectively, when defining language codes for those languages.
2. Confirm that the desired language code is listed in the Available Languages with Cloud Services section above.
3. Run the "F1-LANG" batch control.
• This process copies descriptions of all language-enabled tables from an existing translation (e.g., English). The copied values act as placeholders while the strings are translated into the new language. It is necessary to do this as a first step in order to create records using the new language code created in the previous step.
• The batch process also updates the new language rows with the translated metadata descriptions from the language pack, if installed.
Note: The language pack updates all language entries for base owned system data. If your implementation updates base owned labels and descriptions after applying a language pack, they will be overwritten the next time an updated language pack is applied. Note that most user facing labels and messages support defining an Override Label or Override Description. This information is not updated by the base product and should be utilized if your implementation desires a specific label or description.
