Request for DNS Address to be Added to Outbound Allow List
The customer or system integrator can request a DNS (Domain name service) name to be added in the allow list for outbound interface communication. An allow list provides access to specified DNS addresses that the Oracle network would otherwise prevent access to. For Oracle Utilities cloud services, a customer or system integrator must request a DNS to be added to allow list for outbound communication to all external systems available on either a public or private network. To access an external system that resides on a private network, an additional step of creating a Private Endpoint (PE) / Reverse Connection Endpoint (RCE) is a prerequisite step (Please refer to Request for Private Endpoint (PE) or Request for Reverse Connection Endpoint (RCE) sections below). There are multiple network access options supported, including:
- Access the endpoint DNS via public internet
- Access the endpoint DNS via Service Gateway (for accessing other Oracle cloud services within the same region, such as Oracle Integration Cloud).
- Access the endpoint DNS via Private Endpoint (PE) or Reverse Connection Endpoint (RCE).
This section describes the process to for customers or system integrators to request a DNS allow list.
Request Specifications
- A single request to allow a named DNS or a list of named DNS will ensure allowing the same DNS in all customer environments. Customers need not request per environment (Dev, Test, Prod).
Customer Obligations
- The customer must provide the named DNS or a list of named DNS along with the environment URLs where to implement the request.
- The customer must provide a detailed business justification for DNS being allowlisted. For example:
- <Company> requests that the DNS address <...> be added to the outbound allow list for the following <..prod/stage/dev..> environments.
Business Justification:
- Access to <...> is required to enable automatic delivery of <...> to our customers through <...>. Allowlisting this address ensures support for following business objectives:
- a. <objective 1>
- b. <objective 2>
- c. and so on
- No wildcard (*) should be used in the DNS . The full DNS must be provided.
- The SSL port 443 must be used.
- TLS / SSL Certificate should be issued by a trusted public certificate authority (Digicert, Symantec/VeriSign, Comodo, on so on)
- Certificate's name(s) must match the server / endpoint name.
- Installation of TLS / SSL Certificate should include complete authentication chain.
- Initial and ongoing expiry / validation of TLS / SSL Certificate of the endpoint.
- Support minimum of TLS 1.2.
- Multiple DNS Lists can be requested via a single My Oracle Support (MOS) Service Request.
- The customer must maintain a record of what is being requested for the allow list. Oracle doesn't provide this record.
Customers may use TLS / SSL validation tools such as openssl, TLS / SSL verification websites (such as https://www.ssllabs.com/ or others) to validate the compliance requirements mentioned above.Oracle Cloud Ops Team Obligations
- Acknowledge and schedule the execution of the service request
- Submit the ticket with internal security team for approval
- Coordinate with Infrastructure teams (if needed) for completion of the service request
- Communicate the status upon completion of the service request
Service Level Objective
- Advanced Notice: 7 business days
- Acknowledge/Schedule: 2 business days
- Execution Time: 2 business days
- Outage Expected: No
