Installation Types
The first step in the installation procedure is to determine the installation type that meets your business requirements. The following are the possible installation types:
• Demo Installation: A base installation with pre-populated demo data, typically used for demonstration or training purposes.
• Upgrade Installation: An upgrade installation from v2.2.0.2.0, v2.2.0.3.0, v2.3.0.2.0 and v2.4.0.0.0 to v2.5.0.0.0.
Initial Installation
This installation type is applicable when installing Oracle Utilities Smart Grid Gateway for the first time or from scratch. For an initial install, you must install all of the following components:
• Database components
Refer to the Initial Install section in the Oracle Utilities Smart Grid Gateway Database Administrator’s Guide for more information.
• Application components
• Oracle Utilities Application Framework application
• Oracle Utilities Meter Data Management application
Demo Installation
This installation type is applicable when installing a demo application of Oracle Utilities Smart Grid Gateway for demonstration or training purposes. For a demo install, you must install all of the following components:
• Demo Database components
Refer to the Demo Install section in the Oracle Utilities Smart Grid Gateway Database Administrator’s Guide for more information.
This installation type is applicable when upgrading Oracle Utilities Smart Grid Gateway from V2.2.0.2.0, V2.2.0.3.0, V2.3.0.2.0 and V2.4.0.0.0 to V2.5.0.0.0.
Note: If you have a version prior to 2.2.0.2.0, you must install 2.2.0.2.0 before upgrading to 2.5.0.0.0.
If you have V2.3.0.0.0 installed, you must install V2.3.0.2.0 before upgrading to V2.5.0.0.0.
For an upgrade, you must upgrade all of the following components:
Refer to the “Upgrade Install” section of the Oracle Utilities Smart Grid Gateway Database Administrator’s Guide for more information.
See
Upgrading Oracle Utilities Smart Grid Gateway for instructions to install these components.
