Find Constituents
The Find Constituents process finds all source data to be aggregated for a given aggregation measuring component, based on the Aggregation Measuring Component’s dimensions. The queries used for this process are based on data source template SQL extended by attributes defined on the Aggregation Measuring Components being processed.
The Find Constituents process is initiated by the aggregation algorithm on the Aggregation Measuring Component (each type of Aggregation Measuring Component — interval, item, billed quantities — has its own aggregation algorithm), and is performed by algorithms defined for the Find Constituents system event on the Aggregation Measuring Component business object.
This process differs slightly when finding constituents for interval and scalar measurements stored on measuring components, item data, and billed quantities.
Attributes on the Aggregation Measuring Component based on the Measuring Component Set configuration
Measuring Component Types on the Data Source
Measuring Component ID
Horizon Start Date/Time
Horizon End Date/Time
Time Zone
Items
Attributes on the Measuring Component based on the Measuring Component Set configuration
Item Types / Service Point Types on the Data Source (for badged vs. unbadged items, respectively)
Maintenance Object (Device or Service Point)
Device Type: Item Type
Item Count
Time Zone
Billed Quantities
Usage Subscription Types on the Data Source
Usage Subscription ID
Usage ID
Time Zone
