Maintaining TOU Maps
This portal is used to display and maintain a TOU Map.
Refer to About TOU Maps for additional functional information.
You can access the portal from Menu > Usage > TOU Map. You are brought to a query portal with options for searching. Once your record has been selected you are brought to the maintenance portal to view and maintain the selected record.
- TOU Map: Defines basic information about the TOU map, including dynamic options
- TOU Map Data List: Lists TOU map data created from the TOU map
The Time Of Use Map Data Generation Monitor batch (D1-TOUTR) is used to generate TOU Map data automatically based on the TOU Configuration. TOU Map data can also be generated manually through the TOU Map Portal in the UI.
