Maintaining Interval Snapshot Mapping
You use the Interval Snapshot Mapping portal to view and maintain Interval Snapshot Mapping entries.
You can access the portal by selecting Main, then Settlement, then Interval Snapshot Mapping. You are brought to a query portal with options for searching. You can search by:
  • Seconds Per Interval
  • Date/Time From
  • Date/Time To
The search results include all of the mapping entries that match the provided Seconds Per Interval (if provided) and that fall within the specified date range (if provided).
Creating Interval Snapshot Mapping Entries
The Interval Snapshot Mapping (D1-IntervalSnapMapping) business service is used to create Interval Snapshot Mapping entries based on the installation time zone. This service can be invoked from the Interval Snapshot Mapping portal.
To create new Interval Snapshot Mapping entries, either select Main, then Settlement, then Interval Snapshot Mapping, and then Add, or click Add in the Interval Snapshot Mapping portal. The Create Interval Snapshot Mapping Entries page opens.
Enter parameters to specify the mapping entries to create, including:
  • Date/Time From
  • Date/Time To
Click OK.
Enter appropriate parameters in the search portal to view the new entries.
