Non-Interval 'Plain' XML to IMD Mapping
The following table outlines how non-interval data in the "plain" XML format is mapped to the InitialLoadIMD format when the Landis+Gyr record type is set to "EMED01" (non-interval usage).
"Plain" XML Element |
InitialLoadIMD element |
Notes |
RecordType |
N/A |
Premise |
N/A |
ESIID |
N/A |
Provisioned |
N/A |
MeterID |
dvcIdN |
as is |
kWh |
enQty |
as is |
uom |
KWH |
TimeStamp |
enDt |
Convert to OUAF date/time format This should be mapped to enDt. Relevant only to non-interval data. |
Peak |
enQty |
as is A separate IMD Seeder will be created with |
PeakDateTime |
enDt |
Convert to OUAF date/time format |
Dmd |
enQty |
TouA |
enQty |
TouB |
enQty |
TouC |
enQty |
TouD |
enQty |
TouE |
enQty |
Volts |
enQty |
PF |
enQty |
N/A |
imdType |
D1IL |
Origin |
externalId |
the origin element in "Plain" XML (incoming file name) |
N/A |
serviceProviderExternalId |
L+G This is a constant. There is no such field in incoming structure. |
RawData |
rawData |
Vendor-specific "raw" data When the "populateRawIMD" parameters in the EnvironmentSettings.xq file is set to true. |
