Report Definition - Labels
Navigate to this page using Labels tab.
and go to theNote:
Company name and logo. Note the company name used as
a title in the sample reports is defined as a message on the installation options. For information about installing the
company logo, refer to your product's Installation Guide or
the Optional Products Installation Guide.
Description of Page
In order to provide multi-language capability for each report, the labels used for the report must support multiple language definitions. For each label used by your report, indicate a unique Sequence and the Field used to define the Label. The label defined here should be the same label that is defined in your report layout defined in the external reporting tool.
When rendering an image of the report, the external reporting tool retrieves the appropriate label based on the language used for the report.
