Business Object - Schema
Use this page to maintain a business object's schema. Open this page using and then navigate to the Schema tab.
Description of Page
The contents of this section describe the zones that are available on this portal.
The General Information zone displays main attributes of the business object.
Click the View Schema hyperlink to view the business object's expanded schema definition. Doing this opens the schema viewer window.
Click the View XSD hyperlink to view the business object's expanded schema definition in XSD format.
The Schema Designer zone allows you to edit the business object's schema. The purpose of the schema is to describe the business object's properties and map them to corresponding maintenance object fields.
The Schema Usage Tree zone summarizes all cross-references to this schema. These may be other schemas, scripts, and web services. For each type of referencing entity, the tree displays a summary node showing a total count of referencing items. The summary node appears if at least one referencing item exists. Expand the node to list the referencing items and use their description to navigate to their corresponding pages.
