Smart Grid Gateway Installation and Configuration Worksheets
During the installation and configuration of the application you will need to provide a variety of system values. These worksheets will assist you in providing that information. They should be completed before installing the application framework, as described in Installing Application Components. No Customer Install Value fields should be left blank.
Note: Some web application server information will not be available until the software installation steps have been completed as described in Installing Application Server Prerequisite Software.
This section includes worksheets for the following adapters:
For the Adapter Development Kit
The DG reference implementation SOA configurations include:
Menu Option
Name Used in this Documentation
DG SOA Partition Name
SOA_PARTITION_DG
DG
MR Server Endpoint URI
Headend_MR_Server_DG
CD Server Endpoint URI
Headend_CD_Server_DG
OD Server Endpoint URI
Headend_OD_Server_DG
Headend Http Read Timeout
Headend_http_read_timeout_DG
Headend Http Connection Timeout
Headend_http_conn_timeout_DG
For the Networked Energy Services Adapter
The SOA configuration plan for Networked Energy Services (NES) includes:
Menu Option
NES endpoint URI
HEADEND_NES
The SOA partition to which the application is installed
SOA_PARTITION_D4
Echelon
The path to the NES EventManager web service on the head end system
HEADEND_EVENTMANAGER_D4
The path to the NES GatewayManager web service
HEADEND_GATEWAYMANAGER_D4
The path to the NES DeviceManager web service on the head end system
HEADEND_DEVICEMANAGER_D4
The path to the NES SettingManager web service on the head end system
HEADEND_SETTINGMANAGER_D4
The path to the NES UserManager web service on the head end system
HEADEND_USERMANAGER_D4
The name of the OWSM policy to use when SOA calls a head end system
D4_SOA_HE_
CLIENT_POLICY
The name of the OWSM policy to use when SOA is called by a head end system
D4_SOA_HE_
SERVICE_POLICY
For the Itron OpenWay Adapter
The SOA configuration plan for Itron OpenWay includes the following menu options.
Note: Replace localhost and port with respective host and port for the below mentioned Endpoint URLs.
Menu Option
Itron SOA Partition Name
SOA_PARTITION_D8
Itron
HEADEND_HTTP_READ_TIMEOUT_D8
HEADEND_HTTP_CONN_TIMEOUT_D8
DataSubscriberService Output Path
DATASUBSCRIBER_OUTPUT_PATH_D8
ExceptionSubscriberService Output Path
EXCEPTIONSUBSCRIBER_OUTPUT_PATH_D8
Itron Headend DataService Endpoint URI
Headend_DataService_D8
Itron Headend DiagnosticService Endpoint URI
Headend_DiagnosticService_D8
Itron Headend UtilService Endpoint URI
Headend_UtilService_D8
Itron Headend ControlService Endpoint URI
Headend_ControlService_D8
Itron Headend ProvisioningService Endpoint URI
Headend_ProvisioningService_D8
Itron Headend ProvisioningService370 Endpoint URI
Headend_ProvisioningService370_
D8
Itron Headend ControlService370 Endpoint URI
Headend_ControlService370_D8
D8_SOA_HE_
CLIENT_POLICY
D8_SOA_HE_
SERVICE_POLICY
For the Landis+Gyr Adapter
The SOA configuration plan for Landis+Gyr includes:
Menu Option
LG SOA Partition Name
SOA_PARTITION_D3
LG
LG SOA TestHarness Partition Name
SOA_PARTITION_TEST_D3
AMI Event Subscriber Output Path
AMIEVENTSUBSCRIBER_
OUTPUT_PATH_D3
MR_Server endpoint URI
Headend_
MR_Server_D3
CD_Server endpoint URI
Headend_
CD_Server_D3
CIM endpoint URI
Headend_
CIM_Server_D3
Metering Server endpoint URI
Headend_Metering_Server_D3
Security policy attached to outbound web service calls to a CIM interface
SOA_HE_CIM_
CLIENT_POLICY
Security policy attached to inbound web service calls from a CIM interface
SOA_HE_CIM_
SERVICE_POLICY
D3_SOA_HE_
CLIENT_POLICY
D3_SOA_HE_
SERVICE_POLICY
For the Sensus RNI Adapter
The SOA configuration plan for Sensus RNI includes:
Menu Option
Sensus SOA
Partition Name
SOA_PARTITION_D6
Sensus
HEADEND_MR_D6
HEADEND_CD_D6
HEADEND_OD_D6
Headend_http_read_timeout_D6
Headend_http_
conn_timeout_D6
D6_SOA_HE_
CLIENT_POLICY
D6_SOA_HE_
SERVICE_POLICY
For the Silver Spring Networks Adapter
SOA Configuration Plan (SSN)
The SOA configuration plan for SSN includes the following menu options.
Note: Replace localhost and port with your respective host and port for the Endpoint URLs listed below.
Menu Option
SSN SOA Partition Name
SSN
SOA Weblogic User Name
SSN SOA Queue JNDI Name
queue/SSNODRQ
SSN Headend DataAggregation Endpoint URI
The URL for the SSN 4.7 DataAggregation service (DataAggregation.asmx)
http://127.0.0.1/CoreServices/DataAggregation.asmx
The URL for the SSN 4.10 DataAggregation service
https://ssn.ssnsgs.net:3000/amm/webservice/v2_1/DataAggregat...
The url for the SSN 4.14 DataAggregation service
https://ssn.ssnsgs.net:3000/amm/webservice/v2_5_1/DataAggregationPort
The url for the SSN 5.1 DataAggregation service
https://ssn.ssnsgs.net:3000/amm/webservice/v2_7/DataAggregationPort
SSN Headend DeviceManager Endpoint URI
The URL for the SSN 4.7 DeviceManager service (DeviceManager.asmx)
http://127.0.0.1/CoreServices/DeviceManager.asmx
The URL for the SSN 4.10 DeviceManager service
https://ssn.ssnsgs.net:3000/amm/webservice/v2_1/DeviceManage...
URL for the SSN 5.1 DeviceManager service
https://ssn.ssnsgs.net:3000/amm/webservice/v2_7/DeviceManagerPort
SN Headend DeviceResults Endpoint URI
The URL for the SSN 4.7 DeviceResults service (DeviceResults.asmx)
http://127.0.0.1/CoreServices/DeviceResults.asmx
The URL for the SSN 4.10 DeviceResults service
https://ssn.ssnsgs.net:3000/amm/webservice/v2_1/DeviceResult...
The URL for the SSN 5.1 DeviceResults service
https://ssn.ssnsgs.net:3000/amm/webservice/v2_7/DeviceResults
SSN Headend JobManager Endpoint URI
The URL for the SSN 4.7 JobManager service (JobManager.asmx)
http://127.0.0.1/CoreServices/JobManager.asmx
The URL for the SSN 4.10 JobManager service
https://ssn.ssnsgs.net:3000/amm/webservice/v2_7/JobManagerPort
The URL for the SSN 5.1 JobManager service
oracle/http_basic_auth_over_ssl_client_
policy
oracle/http_basic_auth_over_ssl_service_
policy
SSN JMS Source Destination Bridge Configuration
The SSN JMS source destination bridge configuration includes:
Parameter Description
Source Bridge Destination Name
SRC_BRG_NAME_D7
Classpath
SRC_BRG_CLASSPATH_D7
Connection URL
SRC_BRG_CONN_URL_D7
Initial Context Factory
SRC_BRG_INITIAL_CONTEXT_D7
Connection Factory JNDI Name
SRC_BRG_CONN_FACTORY_D7
Destination Queue JNDI Name
SRC_BRG_QUEUE_JNDI_D7
JMS Provider User Name
SRC_BRD_WLS_USER_D7
JMS Provider User Password
SRC_BRD_WLS_PASS_D7
Advance Menu Option for Test Harness Configuration
The advanced menu options are not available during installation. These options can be accessed after installation using the following commands:
UNIX
$SPLEBASE/bin/configureEnv.sh -a
Windows
%SPLEBASE%\bin\configureEnv.cmd -a
The SSN SOA testharness configurations include:
Name used in this Document
TestHarness SOA Host Server
SOA_HOST_TEST_D7
TestHarness SOA Port Server
SOA_PORT_NUMBER_TEST_D7
SOA_PARTITION_TEST_D7
SOA TestHarness Queue JNDI Name
SOA_QUEUE_TEST_D7
