Configuration Tasks for the Adapter for Itron OpenWay
This section describes the tasks that should be taken after installing Oracle Utilities Smart Grid Gateway Adapter for Itron OpenWay, including:
Note: Oracle Enterprise Manager may be required for some of the security setups and for monitoring SOA. If Oracle Enterprise Manager is required, you need to extend the example SOA WebLogic domain and enable Enterprise Manager using WebLogic's configuration utility.
Deploying the OSB Adapter for the Itron OpenWay
The OSB adapter can be deployed on the bundled WebLogic example server instance or on a separate WebLogic server instance. To deploy the OSB adapter, use the following procedures:
To Deploy on the Example WebLogic Instance
1. Create the following directories under <OSB_LOG_DIR>:
itronxml
itronxml-arch
itronxml-error
itronexcpetion
itronexception-arch
itronexception-error
2. Start the example OSB WebLogic instance.
UNIX
cd $SPLEBASE/osbapp
./startWebLogic.sh
Windows
cd %SPLEBASE%\osbapp startWebLogic.cmd
3. Create JMS queues and target them to the OSB admin server.
a. Create a JMS server “OSB-JMSServer” and target it to admin server.
b. Create a JMS module “D8-SystemModule”.
c. Under “D8-SystemModule” create a sub-deployment “D8-JMSFAServer” and target it to “OSB-JMSServer”.
4. Create the following JMS queues.
Queue Name: DestinationQueue-D8
JNDI Name: DestinationQueue-D8
Sub-deployment: D8-JMSFAServer
Targets: OSB-JMSServer
Queue Name: IMDDestinationQueue-D8
JNDI Name: IMDDestinationQueue-D8
Queue Name: NotificationQueue-D8
JNDI Name: NotificationQueue-D8
5. Deploy the OSB adapter on the example WebLogic instance.
For SSL deployment, please refer to the section Deploying OSB adapter on SSL.
UNIX
cd $SPLEBASE/osbapp
$SPLEBASE/product/apache-ant/bin/ant -buildfile deploy- osb_D8.xml
-Dadmin.user=<ADMIN_USER> -Dadmin.password=<OSB_ADMIN_PASSWORD> -Douaf.user=<JMS_USER> -Douaf.password=<JMS_PASSWORD> -Dprocessing.archive=true -Dosb.user=<OSB_USER> -Dosb.password=<OSB_PASSWORD> -Douaf.filter.user=<JMS_USER> -Douaf.filter.password=<JMS_PASSWORD>
Note: Use the following command if this is an upgrade from a previous version:
cd $SPLEBASE/osbapp
$SPLEBASE/product/apache-ant/bin/ant -buildfile deploy-osb_D8.xml update_osb -Dadmin.user=<ADMIN_USER> -Dadmin.user=<ADMIN_USER> -Dadmin.password=<OSB_ADMIN_PASSWORD> -Douaf.user=<JMS_USER> -Douaf.password=<JMS_PASSWORD> -Dprocessing.archive=true -Dosb.user=<OSB_USER> -Dosb.password=<OSB_PASSWORD> -Douaf.filter.user=<JMS_USER> -Douaf.filter.password=<JMS_PASSWORD>
This will not override any OSB custom changes.
Windows
%SPLEBASE%\product\apache-ant\bin\ant -buildfile deploy-osb_D8.xml
Note: Use the following command if this is an upgrade from a previous version.
%SPLEBASE%/product/apache-ant/bin/ant -buildfile deploy-osb_D8.xml -Dadmin.user=<ADMIN_USER> -Dadmin.password=<OSB_ADMIN_PASSWORD> -Douaf.user=<JMS_USER> -Douaf.password=<JMS_PASSWORD> -Dprocessing.archive=true -Dosb.user=<OSB_USER> -Dosb.password=<OSB_PASSWORD> -Douaf.filter.user=<JMS_USER> -Douaf.filter.password=<JMS_PASSWORD>
Create the following JMS configuration in the Oracle Utilities Meter Data Management application Admin Server:
1. Create a JMS module “D8-SystemModule” and target it to the Managed Server where the Oracle Utilities Meter Data Management application is running.
2. Under the JMS module, create a new Foreign Server "OSBForeignServer-D8" and accept the default targets.
3. Under the Foreign Server, navigate to the General tab and configure the following:
a. JNDI Initial Context Factory: weblogic.jndi.WLInitialContextFactory
b. JNDI Connection URL: URL for OSB Sever in the format - t3://<osb hostname>:<osb port number> (Use t3s for SSL)
c. JNDI Properties Credential: Credentials for user with access to OSB server
d. Confirm JNDI Properties Credential: Same as JNDI Properties Credential
e. JNDI Properties: java.naming.security.principal=<User with access to OSB server for which credentials were provided>
4. Under Destinations, create the following foreign destinations:
• Name: DestinationQueue-D8
Local JNDI Name: ForegnDestinationQueue-D8
Remote JNDI Name: DestinationQueue-D8
• Name: IMDDestinationQueue-D8
Local JNDI Name: ForegnIMDDestinationQueue-D8
Remote JNDI Name: IMDDestinationQueue-D8
• Name: NotificationQueue-D8
Local JNDI Name: ForegnNotificationQueue-D8
Remote JNDI Name: NotificationQueue-D8
5. Under Connection Factories, create the following foreign connection factories:
• Name: DestinationQueueConnectionFactory-D8
Local JNDI Name: ForegnDestinationQueueConnectionFactory-D8
Remote JNDI Name: weblogic.jms.XAConnectionFactory
• Name: IMDDestinationQueueConnectionFactory-D8
Local JNDI Name: ForegnIMDDestinationQueueConnectionFactory-D8
• Name: NotificationQueueConnectionFactory-D8
Local JNDI Name: ForegnNotificationQueueConnectionFactory-D8
To Deploy on a Separate WebLogic Instance
Refer to Configuring Oracle Fusion Middleware Components on a Separate Server from Oracle Utilities Meter Data Management for more information about deploying OSB components on a separate WebLogic server.
1. Create the following directories under <OSB_LOG_DIR>.
itronxml
itronxml-arch
itronxml-error
itronexception
itronexception-arch
2. Copy the following jars to the lib folder under the WebLogic's domain directory.
spl-d1-osb-2.5.0.2.0.jar
This jar is present under the following location:
UNIX: $SPLEBASE/etc/lib
Windows: %SPLEBASE%\etc\lib
3. Start the separate WebLogic instance.
4. Create JMS queues and target them to the OSB admin server.
a. Create a JMS server “OSB-JMSServer” and target it to admin server. Create a JMS module “D8-SystemModule”.
b. Under “D8-SystemModule” create a sub-deployment “D8-JMSFAServer” and target it to “OSB-JMSServer”
c. Create the following JMS queues.
5. Deploy the OSB adapter on the separate WebLogic instance.
Note: Modify the OSB Host Server,OSB Port Number according to Standalone domain using “OSB Configuration Menu item 8”.
UNIX
cd $SPLEBASE/osbapp
cd $SPLEBASE/osbapp
Windows
%SPLEBASE%/product/apache-ant/bin/ant -buildfile deploy-osb_D8.xml update_osb -Dadmin.user=<ADMIN_USER> -Dadmin.password=<OSB_ADMIN_PASSWORD> -Douaf.user=<JMS_USER> -Douaf.password=<JMS_PASSWORD> -Dprocessing.archive=true -Dosb.user=<OSB_USER> -Dosb.password=<OSB_PASSWORD> -Douaf.filter.user=<JMS_USER> -Douaf.filter.password=<JMS_PASSWORD>
Deploying the SOA Adapter for the Itron OpenWay
The SOA adapter can be deployed on the bundled WebLogic example server instance or on a separate WebLogic server instance.
1. Edit the startWeblogic script located at below locations for JAVA_OPTIONS.
UNIX
cd $SPLEBASE/soaapp
./startWebLogic.sh
Windows
cd %SPLEBASE%\soaapp startWebLogic.cmd
2. Add “-Djava.security.auth.login.config=${DOMAIN_HOME}/config/SGGLogin.config -Djavax.net.ssl.trustStore=<<JAVA_TRUST_STORE_LOCATION>>” to the JAVA_OPTIONS
3. Start the example SOA WebLogic instance.
UNIX
cd $SPLEBASE/soaapp
./startWebLogic.sh
Windows
4. Create JMS queues and target them to the SOA admin server.
a. Create the “SGGJMSServer” JMS server and target it to the SOA server.
b. Create an “SGGJMSModule” JMS module.
c. Under “SGGJMSModule” create a sub-deployment “SGGSubDeployment” and target it to “SGGJMSServer”.
5. Create a Connection Factory “D8-TestHarnessConnectionFactory” with the JNDI name “sgg/jms/D8-TestHarnessConnFactory”.
6. Create the following JMS queue.
Queue Name: D8-TestHarnessAsyncOpQueue
JNDI Name: sgg/jms/D8-TestHarnessAsyncOpQueue
Sub-deployment: SGGSubDeployment
Targets: SGGJMSServer
7. Deploy the SOA adapter on the example WebLogic instance.
UNIX
cd $SPLEBASE/soaapp
$SPLEBASE/product/apache-ant/bin/ant -buildfile deploy-soa_MDF.xml
-Dserver.user=<SOA_USER> -Dserver.password=<SOA_PASSWORD> -DsysPropFile=soa.properties
$SPLEBASE/product/apache-ant/bin/ant -buildfile deploy-soa_D8.xml
Windows
-soa_MDF.xml
%SPLEBASE%\product\apache-ant\bin\ant -buildfile deploy-soa_D8.xml
8. Deploy the TestHarness SOA composites on example WebLogic instance.
For the SSL deployment procedure, refer to the Deploying SOA Composites on SSL section.
UNIX
cd $SPLEBASE/soaapp
$SPLEBASE/product/apache-ant/bin/ant -buildfile deploy-soa_D8.xml deployTestHarness -Dserver.password=<SOA_USER>
Windows
Note: Open the command prompt as Administrative mode and then select the environment to deploy SOA.
cd %SPLEBASE%/soaapp
Refer to Configuring Oracle Fusion Middleware Components on a Separate Server from Oracle Utilities Meter Data Management for more information about deploying SOA components on a separate WebLogic server.
1. Create WebLogic SOA Domain and select Enterprise Manager option also.
2. Copy the following jar file to the lib folder under the WebLogic domain directory, spl-d1-soa- security.jar.
This jar is present under the following location.
UNIX
$SPLEBASE/etc/lib
Windows
%SPLEBASE%\etc\lib
3. Add system permissions for Smart Grid Gateway security policies.
a. Login to Oracle Enterprise Manager as an administrative user.
b. Select WebLogic Domain, then Security, then System Policies.
The System Policies page opens.
c. Search for an existing permission for the Smart Grid Gateway security jar as follows:
a. Select "Codebase" from the Type drop-down list (you should not have to change this).
b. Select "Includes" from the Name drop-down list.
c. Enter "spl-d1-soa-security.jar" into the search field.
d. Click the arrow button.
e. No policies should be found:
d. Click Create.
The Create System Grant page opens.
e. Select "Codebase" from the Grant To drop-down list.
f. Enter the complete path to the security jar in the Codebase field as follows:
"file:${domain.home}/lib/spl-d1-soa-security.jar"
g. Click Add (under Permissions).
The Add Permission window opens.
h. Select the "Select here to enter details for a new permission checkbox.
The following fields appear:
• Permission Class
• Resource Name
• Permission Actions
i. Enter the following details into the three fields:
Field
Value
Permission Class
oracle.security.jps.service.credstore.CredentialAccessPermission
Resource Name
context=SYSTEM,mapName=*,keyName=*
Permission Actions
j. Click OK to close the Add Permission window.
k. Click OK (on the Create System Grant page) to save the system grant.
l. Repeat the search from step 2 to confirm the new system policy exists:
This search should return the system policy you just added.
4. Copy the SGGLogin.config file from below location to the config directory of WebLogic SOA domain and edit the startWeblogic script located of WebLogic SOA domain-> bin for JAVA_OPTIONS.
This SGGLogin.config is present under the following location.
UNIX: $SPLEBASE/soaapp/config
Windows: %SOA_HOME%\soaapp\config
a. Copy the file.
Unix :<Weblogic_SOA_domain>/config
Windows: <Weblogic_SOA_domain>\config
b. Add “-Djava.security.auth.login.config=${DOMAIN_HOME}/config/SGGLogin.config -Djavax.net.ssl.trustStore=<<JAVA_TRUST_STORE_LOCATION>>” to the JAVA_OPTIONS to:
Unix: <Weblogic_SOA_domain>/bin/startWeblogic.sh
Windows:<Weblogic_SOA_domain>\bin\startWeblogic.cmd
5. Start the separate SOA WebLogic instance.
a. Create JMS queues and target them to the SOA admin server.
b. Create a JMS server “SGGJMSServer” and target it to the SOA server.
c. Create a JMS module “SGGJMSModule”.
d. Under “SGGJMSModule” create a sub-deployment “SGGSubDeployment” and target it to “SGGJMSServer”.
6. Create a Connection Factory “D8-TestHarnessConnectionFactory” with JNDI name “sgg/jms/D8-TestHarnessConnFactory”.
7. Create the following JMS queue.
8. Deploy the SOA cartridge on the separate WebLogic instance.
Note: Modify the SOA Host Server, SOA Port Number, SOA WebLogic User Name, SOA WebLogic User Password and Endpoint URLs menu items according to separate domain using “SOA Configuration Menu item 9”.
The steps to deploy SSL are described in the Deploying SOA Composites on SSL section.
UNIX
cd $SPLEBASE/soaapp
For WebLogic 14c:
-Dserver.user=<ADMIN_USER> -Dserver.password=<ADMIN_PASSWORD> -DsysPropFile=soa.properties
Windows
For WebLogic 14c:
-soa_MDF.xml
9. Deploy the TestHarness SOA composites on the separate WebLogic instance.
UNIX
cd $SPLEBASE/soaapp
For WebLogic 14c:
deployTestHarness -Dserver.user=<ADMIN_USER>
Windows
For WebLogic 14c:
%SPLEBASE%\product\apache-ant\bin\ant -buildfile deploy-soa_D8.xml deployTestHarness -Dserver.user=<ADMIN_USER>
Configuring Security for the SOA System
This section describes how to configure security credentials for the SOA system, including:
Configuring Security for the SOA System to Communicate with the Application Framework
Configuring security for the SOA system involves using Oracle Enterprise Manager to create the following security credentials:
• A Credential Map
• A Credential Key for the WebLogic Server
• A Credential Key for the Oracle Utilities Application Framework
Use the following procedure to create the security credentials:
1. In Oracle Enterprise Manager, expand the WebLogic domain, right-click the domain, and choose Security, Credentials.
2. On the Credentials page click Create Map.
3. In the Create Map dialog, name the map oracle.wsm.security and click OK.
4. Click Create Key and enter the following values:
• Select Map: oracle.wsm.security
• Key: sgg.d8.credentials
• Type: Password
• Username: A valid WebLogic user name
• Password: A valid WebLogic password
5. Click OK.
6. Click Create Key again and enter the following values:
• Key: sgg.d8.ouaf.credentials
• Type: Password
• Username: A valid OUAF user name
• Password: A valid OUAF password
7. Click OK.
Configuring Security for the SOA System to Communicate with the Head-End System
According to the Itron OpenWay Web Service Reference Guide, the head end system can accommodate many different types of security schemes including Basic HTTP, HTTPS, and X.509. Oracle SOA Server supports these, as well. By default, Basic HTTP is enabled, but as always users should evaluate the most appropriate type of security for their environment. Please refer to the Oracle SOA Server product documentation for detailed instructions on securing web services.
Importing the Policy Templates and Policies
Follow the procedure below to import the policy templates and policies:
1. Import the policy template jar using Enterprise Manager.
a. For Linux:
cd $SPLEBASE/soaapp
$SPLEBASE/product/apache-ant/bin/ant -buildfileant package-soa-policy.xml –Dproduct=d1
For Windows
$SPLEBASE/product/apache-ant/bin/ant -buildfile package-soa-policy.xml –Dproduct=d1
b. In Oracle Enterprise Manager, navigate to WebLogic Domain and select the required SOA domain.
c. Right-click the domain and navigate to Web Services, WSM Policies.
d. Click Web Services Assertion Templates at the top of the page.
e. Click Import and import the sgg-d1-policy.jar zip.
This file is located in the following directory:
UNIX: $SPLEBASE/soaapp/policies/jars
Windows: %SPLEBASE%\soaapp\policies\jars
2. Import the policy template jar using Enterprise Manager.
a. For Linux
cd $SPLEBASE/soaapp
$SPLEBASE/product/apache-ant/bin/ant -buildfile package-soa-policy.xml –Dproduct=d8
For Windows
d. Click Import and import the sgg-d8-policy.jar zip.
Starting the Application
The OSB WebLogic server instance should be up and running before starting the main application.
Creating WebLogic Domain
Create the WebLogic native domain and deploy the application. For instructions refer to the Native Installation Oracle Utilities Application Framework (Doc ID: 1544969.1) document on My Oracle Support.
The MDB user configured in Menu 3 during the Oracle Utilities Application Framework installation has to be created in the Oracle Utilities Application Framework application and WebLogic console, and should be part of the “cisusers” group.
Note: The first time you start Oracle Utilities Meter Data Management, you need to log into the WebLogic console and give system access to cisusers role. The WebLogic console application can be accessed through the following URL: http://<hostname>:<portname>/ console.
