Installation Types
The first step in the installation procedure is to determine the installation type that meets your business requirements. The following are the possible installation types:
• Initial Installation: A base installation, typically used for a production environment.
• Demo Installation: A base installation with pre-populated demo data, typically used for demonstration or training purposes.
• Upgrade Installation: An upgrade installation from V2.5.0.1.1 to V2.5.0.2.0.
This installation type is applicable when installing Oracle Utilities Smart Grid Gateway for the first time or from scratch. For an initial install, you must install all of the following components:
• Database components
Refer to the Initial Install section in the Oracle Utilities Smart Grid Gateway Database Administrator’s Guide for more information.
• Application components
• Oracle Utilities Application Framework application
• Oracle Utilities Meter Data Management application
See Installing Oracle Utilities Smart Grid Gateway - Initial Installation for instructions to install these components.
Demo Installation
This installation type is applicable when installing a demo application of Oracle Utilities Smart Grid Gateway for demonstration or training purposes. For a demo install, you must install all of the following components:
• Demo Database components
Refer to the Demo Install section in the Oracle Utilities Smart Grid Gateway Database Administrator’s Guide for more information.
See Installing Oracle Utilities Smart Grid Gateway - Demo Installation for instructions to install these components.
This installation type is applicable when upgrading Oracle Utilities Smart Grid Gateway from V2.5.0.1.1 to V2.5.0.2.0.
Note: If you have a version prior to 2.5.0.1.1, you must install 2.5.0.1.1 before upgrading to V2.5.0.2.0.
For an upgrade, you must upgrade all of the following components:
Refer to the “Upgrade Install” section of the Oracle Utilities Smart Grid Gateway Database Administrator’s Guide for more information.
See Upgrading Oracle Utilities Smart Grid Gateway for instructions to install these components.
