Menu Option | Name Used in this Documentation | Customer Install Value |
DG SOA Partition Name | SOA_PARTITION_DG | DG |
MR Server Endpoint URI | Headend_MR_Server_DG | |
CD Server Endpoint URI | Headend_CD_Server_DG | |
OD Server Endpoint URI | Headend_OD_Server_DG | |
Headend Http Read Timeout | Headend_http_read_timeout_DG | |
Headend Http Connection Timeout | Headend_http_conn_timeout_DG |
NES endpoint URI | HEADEND_NES | |
The SOA partition to which the application is installed | SOA_PARTITION_D4 | Echelon |
The path to the NES EventManager web service on the head end system | HEADEND_EVENTMANAGER_D4 | |
The path to the NES GatewayManager web service | HEADEND_GATEWAYMANAGER_D4 | |
The path to the NES DeviceManager web service on the head end system | HEADEND_DEVICEMANAGER_D4 | |
The path to the NES SettingManager web service on the head end system | HEADEND_SETTINGMANAGER_D4 | |
The path to the NES UserManager web service on the head end system | HEADEND_USERMANAGER_D4 | |
The name of the OWSM policy to use when SOA calls a head end system | D4_SOA_HE_ CLIENT_POLICY | |
The name of the OWSM policy to use when SOA is called by a head end system | D4_SOA_HE_ SERVICE_POLICY |
Itron SOA Partition Name | SOA_PARTITION_D8 | Itron |
Headend Http Read Timeout | HEADEND_HTTP_READ_TIMEOUT_D8 | |
Headend Http Connection Timeout | HEADEND_HTTP_CONN_TIMEOUT_D8 | |
DataSubscriberService Output Path | DATASUBSCRIBER_OUTPUT_PATH_D8 | |
ExceptionSubscriberService Output Path | EXCEPTIONSUBSCRIBER_OUTPUT_PATH_D8 | |
Itron Headend DataService Endpoint URI | Headend_DataService_D8 | |
Itron Headend DiagnosticService Endpoint URI | Headend_DiagnosticService_D8 | |
Itron Headend UtilService Endpoint URI | Headend_UtilService_D8 | |
Itron Headend ControlService Endpoint URI | Headend_ControlService_D8 | |
Itron Headend ProvisioningService Endpoint URI | Headend_ProvisioningService_D8 | |
Itron Headend ProvisioningService370 Endpoint URI | Headend_ProvisioningService370_ D8 | |
Itron Headend ControlService370 Endpoint URI | Headend_ControlService370_D8 | |
The name of the OWSM policy to use when SOA calls a head end system | D8_SOA_HE_ CLIENT_POLICY | |
The name of the OWSM policy to use when SOA is called by a head end system | D8_SOA_HE_ SERVICE_POLICY |
LG SOA Partition Name | SOA_PARTITION_D3 | LG |
LG SOA TestHarness Partition Name | SOA_PARTITION_TEST_D3 | |
AMI Event Subscriber Output Path | AMIEVENTSUBSCRIBER_ OUTPUT_PATH_D3 | |
MR_Server endpoint URI | Headend_ MR_Server_D3 | |
CD_Server endpoint URI | Headend_ CD_Server_D3 | |
CIM endpoint URI | Headend_ CIM_Server_D3 | |
Metering Server endpoint URI | Headend_Metering_Server_D3 | |
Security policy attached to outbound web service calls to a CIM interface | SOA_HE_CIM_ CLIENT_POLICY | |
Security policy attached to inbound web service calls from a CIM interface | SOA_HE_CIM_ SERVICE_POLICY | |
The name of the OWSM policy to use when SOA calls a head end system | D3_SOA_HE_ CLIENT_POLICY | |
The name of the OWSM policy to use when SOA is called by a head end system | D3_SOA_HE_ SERVICE_POLICY |
Sensus SOA Partition Name | SOA_PARTITION_D6 | Sensus |
MR Server Endpoint URI | HEADEND_MR_D6 | |
CD Server Endpoint URI | HEADEND_CD_D6 | |
OD Server Endpoint URI | HEADEND_OD_D6 | |
Headend Http Read Timeout | Headend_http_read_timeout_D6 | |
Headend Http Connection Timeout | Headend_http_ conn_timeout_D6 | |
The name of the OWSM policy to use when SOA calls a head end system | D6_SOA_HE_ CLIENT_POLICY | |
The name of the OWSM policy to use when SOA is called by a head end system | D6_SOA_HE_ SERVICE_POLICY |
SSN SOA Partition Name | SSN | |
SOA Weblogic User Name | ||
SSN SOA Queue JNDI Name | queue/SSNODRQ | |
SSN Headend DataAggregation Endpoint URI | ||
The URL for the SSN 4.7 DataAggregation service (DataAggregation.asmx) | http://127.0.0.1/CoreServices/DataAggregation.asmx | |
The URL for the SSN 4.10 DataAggregation service | https://ssn.ssnsgs.net:3000/amm/webservice/v2_1/DataAggregat... | |
The url for the SSN 4.14 DataAggregation service | https://ssn.ssnsgs.net:3000/amm/webservice/v2_5_1/DataAggregationPort | |
The url for the SSN 5.1 DataAggregation service | https://ssn.ssnsgs.net:3000/amm/webservice/v2_7/DataAggregationPort | |
SSN Headend DeviceManager Endpoint URI | ||
The URL for the SSN 4.7 DeviceManager service (DeviceManager.asmx) | http://127.0.0.1/CoreServices/DeviceManager.asmx | |
The URL for the SSN 4.10 DeviceManager service | https://ssn.ssnsgs.net:3000/amm/webservice/v2_1/DeviceManage... | |
URL for the SSN 5.1 DeviceManager service | https://ssn.ssnsgs.net:3000/amm/webservice/v2_7/DeviceManagerPort | |
SN Headend DeviceResults Endpoint URI | ||
The URL for the SSN 4.7 DeviceResults service (DeviceResults.asmx) | http://127.0.0.1/CoreServices/DeviceResults.asmx | |
The URL for the SSN 4.10 DeviceResults service | https://ssn.ssnsgs.net:3000/amm/webservice/v2_1/DeviceResult... | |
The URL for the SSN 5.1 DeviceResults service | https://ssn.ssnsgs.net:3000/amm/webservice/v2_7/DeviceResults | |
SSN Headend JobManager Endpoint URI | ||
The URL for the SSN 4.7 JobManager service (JobManager.asmx) | http://127.0.0.1/CoreServices/JobManager.asmx | |
The URL for the SSN 4.10 JobManager service | https://ssn.ssnsgs.net:3000/amm/webservice/v2_7/JobManagerPort | |
The URL for the SSN 5.1 JobManager service | https://ssn.ssnsgs.net:3000/amm/webservice/v2_7/JobManagerPort | |
The name of the OWSM policy to use when SOA calls a head end system | oracle/http_basic_auth_over_ssl_client_ policy | |
The name of the OWSM policy to use when SOA is called by a head end system | oracle/http_basic_auth_over_ssl_service_ policy |
Parameter Description | Name Used in this Documentation | Customer Install Value |
Source Bridge Destination Name | SRC_BRG_NAME_D7 | |
Classpath | SRC_BRG_CLASSPATH_D7 | |
Connection URL | SRC_BRG_CONN_URL_D7 | |
Initial Context Factory | SRC_BRG_INITIAL_CONTEXT_D7 | |
Connection Factory JNDI Name | SRC_BRG_CONN_FACTORY_D7 | |
Destination Queue JNDI Name | SRC_BRG_QUEUE_JNDI_D7 | |
JMS Provider User Name | SRC_BRD_WLS_USER_D7 | |
JMS Provider User Password | SRC_BRD_WLS_PASS_D7 |
Parameter Description | Name used in this Document | Customer Install Value |
TestHarness SOA Host Server | SOA_HOST_TEST_D7 | |
TestHarness SOA Port Server | SOA_PORT_NUMBER_TEST_D7 | |
SOA TestHarness Partition Name | SOA_PARTITION_TEST_D7 | |
SOA TestHarness Queue JNDI Name | SOA_QUEUE_TEST_D7 |
