Validate
The Validate state is an opportunity to check whether the
command should execute.
Check Device Command Eligibility: Checks whether the command
request is eligible for the device by calling the Determine Eligible
Commands Business Service (D1-DetermineEligibleCommands). The command
request is considered eligible if it exists in the eligible commands
list returned by the business service.
Validate Head End’s Capability to Perform Activity: This algorithm
checks to ensure that the head end system has the capability to support
the command requested. It accomplishes this by invoking the Determine
Service Providers and Methods Business Service.
Check for Existing Active Request: This algorithm looks for
non-Final Activities with the same Device and of the same type. This
prevents duplicate requests from being sent to the head end system.
Validation Error
If the Activity fails validation, it transitions to the
Validation Error state. From this state the activity can be retried
and create To Do entriesto notify users of the error.
Retry BO In Error: Reprocesses the BO by transitioning it to
its original state.
Create To Do Entry for BO in Error: This algorithm attempts
to create a To Do entry using the To Do type and role specified by
the algorithm parameters.
Generic To Do Completion for BOs: This algorithm completes
all To Do entries with Drill Keys = Current Business Object's prime
keys except for To Do Types with Characteristic Type and Value as
specified by algorithm parameters. This prevents the existence of
multiple To Do entries for the same command and device.
Waiting For Effective Date
Prior to sending the request to the head end system, the
activity enters this state.
Wait Time Out - Transition to Rejection: This algorithm rejects
the business object if the expiration date time has been reached.
Wait for Effective Date: When the required date is reached,
this algorithm transitions the business object to the next configured
state.
Send Response to External Requester: This algorithm sends an
acknowledging received response outbound message to the requester
if the business object is configured to do so.
Connection Ready
The Connection Ready state shows that the activity can be
executed and creates the proper outbound communication business object.
This state can be re-entered when there are multiple outbound communications
that are required by the head end system’s API.
Create Outbound Communication: This algorithm creates an outbound
communication instance if the value of the completion flag specified
by an algorithm parameter is false.
Create Results Outbound based on Completion Flag: This algorithm
triggers a secondary communication to the head end system based on
the value of an algorithm parameter. Typically, this indicates the
successful completion of an initial outbound communication.
Communication In Progress
This lifecycle state indicates that an outbound communication
is in-progress.
Wait Time Out - Transition to Exception: If the business object
has been in the In Progress state too long, this algorithm transitions
the business object to an exception state.
Check Children Communications: If all of the outbound communication
business object instances related to this activity have completed,
the algorithm transitions the business object to the next state.
Communication Error
An error-handling lifecycle state to which the business
object transitions when the communication encounters a problem.
The algorithms are similar to those in the Validation Error state.
Wait Time Out - Transition to Rejection: If the business object
the business object to a rejection state.
Retry BO In Error: This algorithm reprocesses the business
object by transitioning it to its original state.
Retry
The lifecycle state responsible for discarding existing
outbound communications and transitioning the activity back to Connection
Ready.
Execute Completion Events
This lifecycle state collates the information acquired by
the communications and creates some result. For example, in a DeviceStatusCheck,
the overall results are set.
Completion Event Error
This is another error-handling state similar to the Validation
Error and the Communication Error states. The algorithms are the same
as in those states.
Completed
This is the final state representing a successful activity.
Finishing tasks are performed and external requesters are notified.
Discarded
Similarly to the Completed state, the Discarded state finishes
the activity and indicates an overall failure. External requesters
are notified of the failure and other finishing tasks are performed.
