Outage Information File
Outage information must be sent in two files: Outages and Outage Customers.
The Outages file contains information about outage steps. An outage step is a set of customers affected by an outage who have identical outage start and restoration times. Utilities often restore power in multiple steps, where some outages are restored to one set of customers in one step, and another set of customers is restored in the next step.
The Outage Customers file contains lists of affected customers for each outage step presented in the first file.
Outages
The outages file is meant to be a list of outage steps.
Column Description
OUTAGE_ID
Outage identifier.
Type: NUMBER
Can be empty?: No.
STEP_ID
Outage step identifier (starts at 1).
Type: NUMBER
Can be empty?: No.
OUTAGE_TIME
Outage step start time.
Type: DATE. See Date and Time Handling for details.
Can be empty?: No.
RESTORE_TIME
Outage step restoration time.
Can be empty?: No.
NUM_CUST_OUT
Number of affected customers.
Type: NUMBER
Can be empty?: No.
DEVICE_TYPE
Outage device type (device class name). This is the device that the customer's meter is attached to, or what point of the electrical network is serving the customer. For most customers, it is a supply transformer.
Example Values:
  • Example 1
  • Example 2
Type: VARCHAR2(32)
Can be empty?: Yes.
LATITUDE
Latitude of the outage device location.
Type: NUMBER
Can be empty?: Yes. However, it is recommended that you complete this field. Otherwise, the outage device location will not be known.
LONGITUDE
Longitude of the outage device location.
Type: NUMBER
CREWS
Comma-separated list of crews that worked on this outage.
Type: VARCHAR2(4000)
Can be empty?: Yes. However, it is recommended that you complete this field. Otherwise, the application will not be able to use this data to calculate accurate restoration rates.
ENROUTE_TIME
Time when the first crew was placed en-route to this outage.
Can be empty?: Yes. However, it is recommended that you complete this field if you are not populating ONSITE_TIME. Otherwise, the application will not be able to use this data to calculate accurate restoration rates.
ONSITE_TIME
Time when the first crew arrived onsite for this outage.
Can be empty?: Yes. However, it is recommended that you complete this field if you are not populating ENROUTE_TIME. Otherwise, the application will not be able to use this data to calculate accurate restoration rates.
ZONE1
Level 1 control zone for the outage.
Type: VARCHAR2(64)
Can be empty?: No.
ZONE2
Level 2 control zone for the outage.
Type: VARCHAR2(64)
Can be empty?: Yes.
ZONE3
Level 3 control zone for the outage.
Type: VARCHAR2(64)
Can be empty?: Yes.
ZONE4
Level 4 control zone for the outage.
Type: VARCHAR2(64)
Can be empty?: Yes.
ZONE5
Level 5 control zone for the outage.
Type: VARCHAR2(64)
Can be empty?: Yes.
ZONE6
Level 6 control zone for the outage.
Type: VARCHAR2(64)
Can be empty?: Yes.
ZONE7
Level 7 control zone for the outage.
Type: VARCHAR2(64)
Can be empty?: Yes.
ZONE8
Level 8 control zone for the outage.
Type: VARCHAR2(64)
Can be empty?: Yes.
ZONE9
Level 9 control zone for the outage.
Type: VARCHAR2(64)
Can be empty?: Yes.
ZONE10
Level 10 control zone for the outage.
Type: VARCHAR2(64)
Can be empty?: Yes.
W_CUST_OUT
Weighted number of affected customers.
Type: NUMBER
Can be empty?: Yes. However, it is recommended that you complete this field. Otherwise, the application will not be able to identify the number of weighted customers who are without power. Weighted customers are those who are given a higher priority due to special circumstances (such as customers in a hospital or school).
FEEDER_NAME
Feeder name for the outage device.
Type: VARCHAR2(64)
Can be empty?: No.
Example Outages File
"OUTAGE_ID"|"STEP_ID"|"OUTAGE_TIME"|"RESTORE_TIME"|"NUM_CUST_OUT"|"DEVICE_CLS"|"DEVICE_IDX"|"DEVICE_NAME"|"DEVICE_TYPE"|"LATITUDE"|"LONGITUDE"|"CREWS"|"ENROUTE_TIME"|"ONSITE_TIME"|"ZONE1"|"ZONE2"|"ZONE3"|"ZONE4"|"ZONE5"|"ZONE6"|"ZONE7"|"ZONE8"|"ZONE9"|"ZONE10"|"W_CUST_OUT"|"FEEDER_NAME"
0101010|1|"2024-05-28 11:21:00"||7|123|1234567890|"L20:32AI:69395:BSV:1234567890"|"bldg_towr"|||"56443"|"2024-06-28 16:01:46"||"UtilCo"|"Oracle City"|"Oracle Village"|"o-ov"|"l20"||||||5|"321"
0101011|1|"2024-05-28 11:46:00"||3|123|1234567891|"SN:58AB:T182:BSV:1234567891"|"bldg_towr"||||||"UtilCo"|"Oracle City"|"Oracle Town"|"o-ot"|"o_ot_ot21s"||||||1|"or_ac_le23"
0101012|1|"2024-05-28 12:46:00"||4|123|1234567892|"PS:23M:56447:BSV:1234567892"|"bldg_towr"|||"54773"|"2024-06-28 16:15:06"|"2024-06-28 16:57:34"|"UtilCo"|"Oracle City"|"Oracle Village"|"o-ov"|"o_ov_20s"||||||2|"or_ac_le35
Outage Customers
List of customers associated with a row in the outages extract file.
Column Description
CID
Unique customer identifier.
Type: VARCHAR2(64)
Can be empty?: No.
OUTAGE_ID
Outage identifier.
Type: NUMBER
Can be empty?: No.
STEP_ID
Outage step identifier.
Type: NUMBER
Can be empty?: No.
Example Outage Customers File
"CID"|"OUTAGE_ID"|"STEP_ID"
"0987654321"|0101010|1
"0987654322"|0101011|1
"0987654323"|0101012|1
