Oracle Utilities Operational Device Management Components
This section lists the starter components available in Oracle Utilities Operational Device Management.
Pre-requisites: The Inbound Web Service using the respective business object should be available in the application.
Additional Notes: Failure while creating, reading, or updating the component is logged to the test execution report, facilitating debugging/analysis of the problem.
The components are categorized under the following functional areas:
Cloud
Administration Data
Component
Description
W1- AssetAgeBktConfig
Used to create, update, read, or delete AssetAgeBktConfig in the WAM application.
This component calls the W1- AssetAgeBktConfig business object using the Inbound Web Service.
W1- BasicActivityType
Used to create, update, read, or delete BasicActivityType in the WAM application.
This component calls the W1- BasicActivityType business object using the Inbound Web Service.
W1- BIExtractParameters
Used to create, update, read, or delete BIExtractParameters in the WAM application.
This component calls the W1- BIExtractParameters business object using the Inbound Web Service.
W1- ConfigType
Used to create, update, read, or delete ConfigType in the WAM application.
This component calls the W1- ConfigType business object using the Inbound Web Service.
W1- OutboundActivityType
Used to create, update, read, or delete OutboundActivityType in the WAM application.
This component calls the W1-OutboundActivityType business object using the Inbound Web Service.
W1- GeneralCommunicationType
Used to create, update, read, or delete GeneralCommunicationType in the WAM application.
This component calls the W1-GeneralCommunicationType business object using the Inbound Web Service.
W1- AssetInstallAgeBktConfig
Used to create, update, read, or delete AssetInstallAgeBktConfig in the WAM application.
This component calls the W1-AssetInstallAgeBktConfig business object using the Inbound Web Service.
W1- AssetInstoreAgeBktConfig
Used to create, update, read, or delete AssetInstoreAgeBktConfig in the WAM application.
This component calls the W1-AssetInstoreAgeBktConfig business object using the Inbound Web Service.
W1- AssetSearchMasterConfig
Used to create, update, read, or delete AssetSearchMasterConfig in the WAM application.
This component calls the W1-AssetSearchMasterConfig business object using the Inbound Web Service.
Asset Management
Component
Description
W1- Business
Used to create, update, read, or delete Business in the WAM application.
This component calls the W1- Business business object using the Inbound Web Service.
W1- MDMAsset
Used to create, update, read, or delete MDMAsset in the WAM application.
This component calls the W1- MDMAsset business object using the Inbound Web Service.
W1-MaintenanceSpecGeneral
Used to create, update, read, or delete MaintenanceSpecGeneral in the WAM application.
This component calls the W1-MaintenanceSpecGeneral business object using the Inbound Web Service.
W1-AssetTypeConv
Used to create, update, read, or delete AssetTypeConv in the WAM application.
This component calls the W1-AssetTypeConv business object using the Inbound Web Service.
W1-AssetDposHistInstallations
Used to create, update, read, or delete AssetDposHistInstallations in the WAM application.
This component calls the W1-AssetDposHistInstallations business object using the Inbound Web Service.
W1-SHInspectionGenrlWeighted
Used to create, update, read, or delete SHInspectionGenrlWeighted in the WAM application.
This component calls the W1-SHInspectionGenrlWeighted business object using the Inbound Web Service.
W1- Person
Used to create, update, read, or delete Person in the WAM application.
This component calls the W1- Person business object using the Inbound Web Service.
W1- SynchronizationAddContact
Used to create, update, read, or delete SynchronizationAddContact in the WAM application.
This component calls the W1-SynchronizationAddContact business object using the Inbound Web Service.
W1- BasicTest
Used to create, update, read, or delete BasicTest in the WAM application.
This component calls the W1- BasicTest business object using the Inbound Web Service.
W2-SmartTest
Used to create, update, read, or delete SmartTest in the WAM application.
This component calls the W2- SmartTest business object using the Inbound Web Service.
W1-PeerSpecification
Used to create, update, read, or delete PeerSpecification in the WAM application.
This component calls the W2- PeerSpecification business object using the Inbound Web Service.
Configuration Management
Component
Description
W1- AssetCompCfgRpt
Used to create, update, read, or delete AssetCompCfgRpt in the WAM application.
This component calls the W1- AssetCompCfgRpt business object using the Inbound Web Service.
W1- AssetCompCfgWO
Used to create, update, read, or delete AssetCompCfgWO in the WAM application.
This component calls the W1- AssetCompCfgWO business object using the Inbound Web Service.
W1- AssetCompToAssetCfgRpt
Used to create, update, read, or delete AssetCompToAssetCfgRpt in the WAM application.
This component calls the W1-AssetCompToAssetCfgRpt business object using the Inbound Web Service.
W1- AssetCompToAssetCfgWO
Used to create, update, read, or delete AssetCompToAssetCfgWO in the WAM application.
This component calls the W1-AssetCompToAssetCfgWO business object using the Inbound Web Service.
W1- AssetCompToAssetCompCfgRpt
Used to create, update, read, or delete AssetCompToAssetCompCfgRpt in the WAM application.
This component calls the W1-AssetCompToAssetCompCfgRpt business object using the Inbound Web Service.
W1- AssetCompToAssetCompCfgWO
Used to create, update, read, or delete AssetCompToAssetCompCfgWO in the WAM application.
This component calls the W1-AssetCompToAssetCompCfgWO business object using the Inbound Web Service.
W1- AssetCompToAssetCompConfig
Used to create, update, read, or delete AssetCompToAssetCompConfig in the WAM application.
This component calls the W1-AssetCompToAssetCompConfig business object using the Inbound Web Service.
W1- AssetCompToAssetConfig
Used to create, update, read, or delete AssetCompToAssetConfig in the WAM application.
This component calls the W1-AssetCompToAssetConfig business object using the Inbound Web Service.
W1- AssetToAssetCfgRpt
Used to create, update, read, or delete AssetToAssetCfgRpt in the WAM application.
This component calls the W1- AssetToAssetCfgRpt business object using the Inbound Web Service.
W1- AssetToAssetCfgWO
Used to create, update, read, or delete AssetToAssetCfgWO in the WAM application.
This component calls the W1- AssetToAssetCfgWO business object using the Inbound Web Service.
W1- AssetToAssetCompCfgRpt
Used to create, update, read, or delete AssetToAssetCompCfgRpt in the WAM application.
This component calls the W1-AssetToAssetCompCfgRpt business object using the Inbound Web Service.
W1- AssetToAssetCompCfgWO
Used to create, update, read, or delete AssetToAssetCompCfgWO in the WAM application.
This component calls the W1-AssetToAssetCompCfgWO business object using the Inbound Web Service.
W1- AssetToAssetCompConfig
Used to create, update, read, or delete AssetToAssetCompConfig in the WAM application.
This component calls the W1-AssetToAssetCompConfig business object using the Inbound Web Service.
W1- AssetToAssetConfig
Used to create, update, read, or delete AssetToAssetConfig in the WAM application.
This component calls the W1- AssetToAssetConfig business object using the Inbound Web Service.
W1- SingleAssetCfgRpt
Used to create, update, read, or delete SingleAssetCfgRpt in the WAM application.
This component calls the W1- SingleAssetCfgRpt business object using the Inbound Web Service.
W1- SingleAssetCfgWO
Used to create, update, read, or delete SingleAssetCfgWO in the WAM application.
This component calls the W1- SingleAssetCfgWO business object using the Inbound Web Service.
W1- SingleAssetConfig
Used to create, update, read, or delete SingleAssetConfig in the WAM application.
This component calls the W1- SingleAssetConfig business object using the Inbound Web Service.
W1- AssetCompConfig
Used to create, update, read, or delete AssetCompConfig in the WAM application.
This component calls the W1- AssetCompConfig business object using the Inbound Web Service.
Work Management
Component
Description
W1- ActivityComplInboundComm
Used to create, update, read, or delete ActivityComplInboundComm in the WAM application.
This component calls the W1-ActivityComplInboundComm business object using the Inbound Web Service.
W1- AdHocActivityCore
Used to create, update, read, or delete AdHocActivityCore in the WAM application.
This component calls the W1- AdHocActivityCore business object using the Inbound Web Service.
W1- AssetCriteriaActGenerator
Used to create, update, read, or delete AssetCriteriaActGenerator in the WAM application.
This component calls the W1-AssetCriteriaActGenerator business object using the Inbound Web Service.
W1- AssetListActGenerator
Used to create, update, read, or delete AssetListActGenerator in the WAM application.
This component calls the W1-AssetListActGenerator business object using the Inbound Web Service.
W1- BasicWorkOrder
Used to create, update, read, or delete BasicWorkOrder in the WAM application.
This component calls the W1- BasicWorkOrder business object using the Inbound Web Service.
W1- CompnAssetListActGenerator
Used to create, update, read, or delete CompnAssetListActGenerator in the WAM application.
This component calls the W1-CompnAssetListActGenerator business object using the Inbound Web Service.
W1- CompnCriteriaActGenerator
Used to create, update, read, or delete CompnCriteriaActGenerator in the WAM application.
This component calls the W1-CompnCriteriaActGenerator business object using the Inbound Web Service.
W1- CreComActivityInboundComm
Used to create, update, read, or delete CreComActivityInboundComm in the WAM application.
This component calls the W1-CreComActivityInboundComm business object using the Inbound Web Service.
W1- CreateActivityInboundComm
Used to create, update, read, or delete CreateActivityInboundComm in the WAM application.
This component calls the W1-CreateActivityInboundComm business object using the Inbound Web Service.
W1- LocalActivityCore
Used to create, update, read, or delete LocalActivityCore in the WAM application.
This component calls the W1- LocalActivityCore business object using the Inbound Web Service.
W1- NodeCriteriaActGenerator
Used to create, update, read, or delete NodeCriteriaActGenerator in the WAM application.
This component calls the W1-NodeCriteriaActGenerator business object using the Inbound Web Service.
W2-FirmwareCommandLocal
Used to create, update, read, or delete FirmwareCommandLocal in the WAM application.
This component calls the W2-FirmwareCommandLocal business object using the Inbound Web Service.
W2-ACfgFirmwareUpgrade
Used to create, update, read, or delete ACfgFirmwareUpgrade in the WAM application.
This component calls the W2-ACfgFirmwareUpgrade business object using the Inbound Web Service.
W2-ACCfgFirmwareUpgrade
Used to create, update, read, or delete ACCfgFirmwareUpgrade in the WAM application.
This component calls the W2-ACCfgFirmwareUpgrade business object using the Inbound Web Service.
W2-ACACfgFirmwareUpgrade
Used to create, update, read, or delete ACACfgFirmwareUpgrade in the WAM application.
This component calls the W2-ACACfgFirmwareUpgrade business object using the Inbound Web Service.
W2-ACACCfgFirmwareUpgrade
Used to create, update, read, or delete ACACCfgFirmwareUpgrade in the WAM application.
This component calls the W2-ACACCfgFirmwareUpgrade business object using the Inbound Web Service.
W2-AACfgFirmwareUpgrade
Used to create, update, read, or delete AACfgFirmwareUpgrade in the WAM application.
This component calls the W2-AACfgFirmwareUpgrade business object using the Inbound Web Service.
W2-AACCfgFirmwareUpgrade
Used to create, update, read, or delete AACCfgFirmwareUpgrade in the WAM application.
This component calls the W2-AACCfgFirmwareUpgrade business object using the Inbound Web Service.
W1-WorkLocation
Used to create, update, read, or delete WorkLocation in the WAM application.
This component calls the W1-WorkLocation business object using the Inbound Web Service.
W1- OutboundActivityCore
Used to create, update, read, or delete OutboundActivityCore in the WAM application.
This component calls the W1-OutboundActivityCore business object using the Inbound Web Service.
W1- RTSVSCWOSQL
Used to retrieve/read ServiceSchedule Work Order against the ODM Work Order in the WAM application.
This component calls the CM-RTSVSCWO business service using the ATW1RTSVSCWOSQL Inbound Web Service.
Cloud
Component
Description
W1-Lookup
Used to create, update, read, or delete Lookup in the WAM application.
This component calls the W1-Lookup business object using the Inbound Web Service.
W1-InstallationOptions
Used to createInstallationOptions in the WAM application.
This component calls the W1-InstallationOptions business object using the Inbound Web Service.
