Oracle Utilities Work and Asset Management Components
This section lists the starter components available in Oracle Utilities Work and Asset Management.
Prerequisites: The Inbound Web Service using the respective business object should be available in the application.
Additional Notes: Failure while creating, reading, or updating the component is logged to the test execution report, facilitating debugging/analysis of the problem.
The components are categorized under the following functional areas:
General
Administration Data
Component
Description
W1-AccountingCalendar
Used to create, update, read, or delete AccountingCalendar in the WAM application.
This component calls the W1-AccountingCalendar business object using the Inbound Web Service.
W1-StatusReason
Used to create, update, read, or delete StatusReason in the WAM application.
This component calls the W1-StatusReason business object using the Inbound Web Service.
W1-PERMITCLS
Used to create, update, read, or delete PERMITCLS in the WAM application.
This component calls the W1-PERMITCLS business object using the Inbound Web Service.
W1-NormalizationDeficiency
Used to create, update, read, or delete NormalizationDeficiency in the WAM application.
This component calls the W1-NormalizationDeficiency business object using the Inbound Web Service.
W1-MDMIntegrationMasterConfig
Used to create, update, read, or delete MDMIntegrationMasterConfig in the WAM application.
This component calls the W1-MDMIntegrationMasterConfig business object using the Inbound Web Service.
F1-EsriMapMasterConfig
Used to create, update, read, or delete EsriMapMasterConfig in the WAM application.
This component calls the F1-EsriMapMasterConfig business object using the Inbound Web Service.
F1-EsriWebMap
Used to create, update, read, or delete EsriWebMap in the WAM application.
This component calls the F1-EsriWebMap business object using the Inbound Web Service.
W1-CCBIntegrationMasterConfig
Used to create, update, read, or delete CCBIntegrationMasterConfig in the WAM application.
This component calls the W1-CCBIntegrationMasterConfig business object using the Inbound Web Service.
W1-ConfigClass
Used to create, update, read, or delete ConfigClass in the WAM application.
This component calls the W1-ConfigClass business object using the Inbound Web Service.
W1-DSIIdentifierMap
Used to create, update, read, or delete DSIIdentifierMap in the WAM application.
This component calls the W1-DSIIdentifierMap business object using the Inbound Web Service.
W1-ErasureScheduleContact
Used to create, update, read, or delete ErasureScheduleContact in the WAM application.
This component calls the W1-ErasureScheduleContact business object using the Inbound Web Service.
W1-EsriWAMIntegMasterConfig
Used to create, update, read, or delete EsriWAMIntegMasterConfig in the WAM application.
This component calls the W1-EsriWAMIntegMasterConfig business object using the Inbound Web Service.
W1-ExternalPermitTemplate
Used to create, update, read, or delete ExternalPermitTemplate in the WAM application.
This component calls the W1-ExternalPermitTemplate business object using the Inbound Web Service.
W1-FailureDowntimeSHTCmpEvtTyp
Used to create, update, read, or delete FailureDowntimeSHTCmpEvtTyp in the WAM application.
This component calls the W1-FailureDowntimeSHTCmpEvtTyp business object using the Inbound Web Service.
W1-FailureProfFailureRepair
Used to create, update, read, or delete FailureProfFailureRepair in the WAM application.
This component calls the W1-FailureProfFailureRepair business object using the Inbound Web Service.
W1-GISProjectedCoordinateSys
Used to create, update, read, or delete GISProjectedCoordinateSys in the WAM application.
This component calls the W1-GISProjectedCoordinateSys business object using the Inbound Web Service.
W1-GISToWAMSyncMapping
Used to create, update, read, or delete GISToWAMSyncMapping in the WAM application.
This component calls the W1-GISToWAMSyncMapping business object using the Inbound Web Service.
W1-GaugeRdWtThresholdMsrType
Used to create, update, read, or delete GaugeRdWtThresholdMsrType in the WAM application.
This component calls the W1-GaugeRdWtThresholdMsrType business object using the Inbound Web Service.
W1-GaugeReadRange
Used to create, update, read, or delete GaugeReadRange in the WAM application.
This component calls the W1-GaugeReadRange business object using the Inbound Web Service.
W1-HomepageMasterConfig
Used to create, update, read, or delete HomepageMasterConfig in the WAM application.
This component calls the W1-HomepageMasterConfig business object using the Inbound Web Service.
W1-InspectionTypeGenrlWeighted
Used to create, update, read, or delete InspectionTypeGenrlWeighted in the WAM application.
This component calls the W1-InspectionTypeGenrlWeighted business object using the Inbound Web Service.
W1-InternalPermitTemplate
Used to create, update, read, or delete InternalPermitTemplate in the WAM application.
This component calls the W1-InternalPermitTemplate business object using the Inbound Web Service.
W1-InventoryLocationType
Used to create, update, read, or delete InventoryLocationType in the WAM application.
This component calls the W1-InventoryLocationType business object using the Inbound Web Service.
W1-MeterRdWithRollOverMeasType
Used to create, update, read, or delete MeterRdWithRollOverMeasType in the WAM application.
This component calls the W1-MeterRdWithRollOverMeasType business object using the Inbound Web Service.
W1-MeteredReadRollover
Used to create, update, read, or delete MeteredReadRollover in the WAM application.
This component calls the W1-MeteredReadRollover business object using the Inbound Web Service.
W1-MsrmtNumericGaugeReason
Used to create, update, read, or delete MsrmtNumericGaugeReason in the WAM application.
This component calls the W1-MsrmtNumericGaugeReason business object using the Inbound Web Service.
W1-MsrmtNumericMeterReason
Used to create, update, read, or delete MsrmtNumericMeterReason in the WAM application.
This component calls the W1-MsrmtNumericMeterReason business object using the Inbound Web Service.
W1-MsrtQuckEntryCmplEvtType
Used to create, update, read, or delete MsrtQuckEntryCmplEvtType in the WAM application.
This component calls the W1-MsrtQuckEntryCmplEvtType business object using the Inbound Web Service.
W1-NormalizationGenrlWeighted
Used to create, update, read, or delete NormalizationGenrlWeighted in the WAM application.
This component calls the W1-NormalizationGenrlWeighted business object using the Inbound Web Service.
W1-NormalizationPercentOfNew
Used to create, update, read, or delete NormalizationPercentOfNew in the WAM application.
This component calls the W1-NormalizationPercentOfNew business object using the Inbound Web Service.
W1-PermitOnlyChecklistType
Used to create, update, read, or delete PermitOnlyChecklistType in the WAM application.
This component calls the W1-PermitOnlyChecklistType business object using the Inbound Web Service.
W1-SeederSyncReqMasterConfig
Used to create, update, read, or delete SeederSyncReqMasterConfig in the WAM application.
This component calls the W1-SeederSyncReqMasterConfig business object using the Inbound Web Service.
W1-SrvHistFromActTyCmplEvtType
Used to create, update, read, or delete SrvHistFromActTyCmplEvtType in the WAM application.
This component calls the W1-SrvHistFromActTyCmplEvtType business object using the Inbound Web Service.
W2-ServicePointWarning
Used to create, update, read, or delete ServicePointWarning in the WAM application.
This component calls the W2-ServicePointWarning business object using the Inbound Web Service.
W2-Key
Used to create, update, read, or delete Key in the WAM application.
This component calls the W2-Key business object using the Inbound Web Service
W2-SynchronizationAddSP
Used to create, update, read, or delete SynchronizationAddSP in the WAM application.
This component calls the W2-SynchronizationAddSP business object using the Inbound Web Service.
W1-ActivityCompletionEventType
Used to create, update, read, or delete ActivityCompletionEventType in the WAM application.
This component calls the W1-ActivityCompletionEventType business object using the Inbound Web Service.
W1- AssetCompletionEventType
Used to create, update, read, or delete AssetCompletionEventType in the WAM application.
This component calls the W1-AssetCompletionEventType business object using the Inbound Web Service.
W1- AssetDposCmpEvtType
Used to create, update, read, or delete AssetDposCmpEvtType in the WAM application.
This component calls the W1- AssetDposCmpEvtType business object using the Inbound Web Service.
W1- AssetLocationType
Used to create, update, read, or delete AssetLocationType in the WAM application.
This component calls the W1- AssetLocationType business object using the Inbound Web Service.
W1- AssetType
Used to create, update, read, or delete AssetType in the WAM application.
This component calls the W1-AssetType business object using the Inbound Web Service.
W1- ComponentType
Used to create, update, read, or delete ComponentType in the WAM application.
This component calls the W1-ComponentType business object using the Inbound Web Service
W1- DataAreaCmpEvtType
Used to create, update, read, or delete DataAreaCmpEvtType in the WAM application.
This component calls the W1- DataAreaCmpEvtType business object using the Inbound Web Service.
W1- GeneralCompletionEventType
Used to create, update, read, or delete GeneralCompletionEventType in the WAM application.
This component calls the W1- GeneralCompletionEventType business object using the Inbound Web Service.
W1-OrganizationType
Used to create, update, read, or delete OrganizationType in the WAM application.
This component calls the W1-OrganizationType business object using the Inbound Web Service.
W1- ReplicationComplEventType
Used to create, update, read, or delete ReplicationComplEventType in the WAM application.
This component calls the W1- ReplicationComplEventType business object using the Inbound Web Service.
W1-AmtBasedAppvlProf
Used to create, update, read, or delete AmtBasedAppvlProf in the WAM application.
This component calls the W1-AmtBasedAppvlProf business object using the Inbound Web Service.
W1-AssessmentClass
Used to create, update, read, or delete AssessmentClass in the WAM application.
This component calls the W1-AssessmentClass business object using the Inbound Web Service.
W1-AssessmentGroup
Used to create, update, read, or delete AssessmentGroup in the WAM application.
This component calls the W1-AssessmentGroup business object using the Inbound Web Service.
W1-AssetTypeAverageCost
Used to create, update, read, or delete AssetTypeAverageCost in the WAM application.
This component calls the W1-AssetTypeAverageCost business object using the Inbound Web Service.
W1-BillableRate
Used to create, update, read, or delete BillableRate in the WAM application.
This component calls the W1-BillableRate business object using the Inbound Web Service.
W1-BusinessUnit
Used to create, update, read, or delete BusinessUnit in the WAM application.
This component calls the W1-BusinessUnit business object using the Inbound Web Service.
W1-Buyer
Used to create, update, read, or delete Buyer in the WAM application.
This component calls the W1-Buyer business object using the Inbound Web Service.
W1-CalendarAnniversary
Used to create, update, read, or delete CalendarAnniversary in the WAM application.
This component calls the W1-CalendarAnniversary business object using the Inbound Web Service.
W1-CalendarInterval
Used to create, update, read, or delete CalendarInterval in the WAM application.
This component calls the W1-CalendarInterval business object using the Inbound Web Service.
W1-CapabilityType
Used to create, update, read, or delete CapabilityType in the WAM application.
This component calls the W1-CapabilityType business object using the Inbound Web Service.
W1-Circle
Used to create, update, read, or delete Circle in the WAM application.
This component calls the W1-Circle business object using the Inbound Web Service.
W1-Color
Used to create, update, read, or delete Color in the WAM application.
This component calls the W1-Color business object using the Inbound Web Service.
W1-CommodityCategory
Used to create, update, read, or delete CommodityCategory in the WAM application.
This component calls the W1-CommodityCategory business object using the Inbound Web Service.
W1-CommodityName
Used to create, update, read, or delete CommodityName in the WAM application.
This component calls the W1-CommodityName business object using the Inbound Web Service.
W1-CommodityType
Used to create, update, read, or delete CommodityType in the WAM application.
This component calls the W1-CommodityType business object using the Inbound Web Service.
W1-ComponentTypeAverageCost
Used to create, update, read, or delete ComponentTypeAverageCost the in WAM application.
This component calls the W1-ComponentTypeAverageCost business object using the Inbound Web Service.
W1-ContactType
Used to create, update, read, or delete ContactType in the WAM application.
This component calls the W1-ContactType business object using the Inbound Web Service.
W1-CostCategory
Used to create, update, read, or delete CostCategory in the WAM application.
This component calls the W1-CostCategory business object using the Inbound Web Service.
W1-CostCenter
Used to create, update, read, or delete CostCenter in the WAM application.
This component calls the W1-CostCenter business object Inbound Web Service.
W1-Course
Used to create, update, read, or delete Course in the WAM application.
This component calls the W1-Course business object using the Inbound Web Service.
W1-CrewType
Used to create, update, read, or delete CrewType in the WAM application.
This component calls the W1-CrewType business object using the Inbound Web Service.
W1-DailyScheduleType
Used to create, update, read, or delete DailyScheduleType in the WAM application.
This component calls the W1-DailyScheduleType business object using the Inbound Web Service.
W1-DistributionCode
Used to create, update, read, or delete DistributionCode in the WAM application.
This component calls the W1-DistributionCode business object using the Inbound Web Service.
W1-DocActType
Used to create, update, read, or delete DocActType in the WAM application.
This component calls the W1-DocActType business object using the Inbound Web Service.
W1-DocCmplEvntType
Used to create, update, read, or delete DocCmplEvntType in the WAM application.
This component calls the W1-DocCmplEvntType business object using the Inbound Web Service.
W1-DocumentType
Used to create, update, read, or delete DocumentType in the WAM application.
This component calls the W1-DocumentType business object using the Inbound Web Service.
W1-EmployeeType
Used to create, update, read, or delete EmployeeType in the WAM application.
This component calls the W1-EmployeeType business object using the Inbound Web Service.
W1-Equipment
Used to create, update, read, or delete Equipment in the WAM application.
This component calls the W1-Equipment business object using the Inbound Web Service.
W1-ExpenseCode
Used to create, update, read, or delete ExpenseCode in the WAM application.
This component calls the W1-ExpenseCode business object using the Inbound Web Service.
W1-Factor
Used to create, update, read, or delete Factor in the WAM application.
This component calls the W1-Factor business object using the Inbound Web Service.
W1-FactorValue
Used to create, update, read, or delete FactorValue in the WAM application.
This component calls the W1-FactorValue business object using the Inbound Web Service.
W1-FailureComponent
Used to create, update, read, or delete FailureComponent in the WAM application.
This component calls the W1-FailureComponent business object using the Inbound Web Service.
W1-FailureMode
Used to create, update, read, or delete FailureMode in the WAM application.
This component calls the W1-FailureMode business object using the Inbound Web Service.
W1-FailureProfile
Used to create, update, read, or delete FailureProfile in the WAM application.
This component calls the W1-FailureProfile business object using the Inbound Web Service.
W1-FailureProfileFailureComp
Used to create, update, read, or delete FailureProfileFailureComp in the WAM application.
This component calls the W1-FailureProfileFailureComp business object using the Inbound Web Service.
W1-FailureProfileFailureMode
Used to create, update, read, or delete FailureProfileFailureMode in the WAM application.
This component calls the W1-FailureProfileFailureMode business object using the Inbound Web Service.
W1-FailureProfileFailureRepair
Used to create, update, read, or delete FailureProfileFailureRepair in the WAM application.
This component calls the W1-FailureProfileFailureRepair business object using the Inbound Web Service.
W1-FailureProfileFailureType
This component can be used to create/update/read/delete FailureProfileFailureType in WAM application.
This component calls the business object W1-FailureProfileFailureType using the Inbound Web Service.
W1-FailureRepair
Used to create, update, read, or delete FailureRepair in the WAM application.
This component calls the W1-FailureRepair business object using the Inbound Web Service.
W1-FailureType
Used to create, update, read, or delete FailureType in the WAM application.
This component calls the W1-FailureType business object using the Inbound Web Service.
W1-FinancialMasterConfig
Used to create, update, read, or delete FinancialMasterConfig in the WAM application.
This component calls the W1-FinancialMasterConfig business object using the Inbound Web Service.
W2-Key
This component calls the W2-Key business object using the Inbound Web Service.
W1-Fob
Used to create, update, read, or delete Fob in the WAM application.
This component calls the W1-Fob business object using the Inbound Web Service.
W1-Function
Used to create, update, read, or delete Function in the WAM application.
This component calls the W1-Function business object using the Inbound Web Service.
W1-FunctionType
Used to create, update, read, or delete FunctionType in the WAM application.
This component calls the W1-FunctionType business object using the Inbound Web Service.
W1-GaugeReadWithThresholdMeasType
Used to create, update, read, or delete GaugeReadWithThresholdMeasType in the WAM application.
This component calls the W1-GaugeReadWithThresholdMeasType business object using the Inbound Web Service.
W1-GeneralAssetLocationType
This component can be used to create/update/read/delete GeneralAssetLocationType in WAM application. This component calls the business object Inbound Web Service.
W1-GeneralCompletionEventType
This component calls the W1-GeneralCompletionEventType business object using the Inbound Web Service.
W1-InventoryMgmtMasterConfig
Used to create, update, read, or delete InventoryMgmtMasterConfig in the WAM application.
This component calls the W1-InventoryMgmtMasterConfig business object using the Inbound Web Service.
W1-LaborEarningType
Used to create, update, read, or delete LaborEarningType in the WAM application.
This component calls the W1-LaborEarningType business object using the Inbound Web Service.
W1-LeaveType
Used to create, update, read, or delete LeaveType in the WAM application.
This component calls the W1-LeaveType business object using the Inbound Web Service.
W1-Line
Used to create, update, read, or delete Line in the WAM application.
This component calls the W1-Line business object using the Inbound Web Service.
W1-LinearAssetLocationType
Used to create, update, read, or delete LinearAssetLocationType in the WAM application.
This component calls the W1-LinearAssetLocationType business object using the Inbound Web Service.
W1-MeasurementUOM
Used to create, update, read, or delete MeasurementUOM in the WAM application.
This component calls the W1-MeasurementUOM business object using the Inbound Web Service.
W1-MeterReadWithRollOverMeasType
Used to create, update, read, or delete MeterReadWithRollOverMeasType in the WAM application.
This component calls the W1-MeterReadWithRollOverMeasType business object using the Inbound Web Service.
Used to create, update, read, or delete MsrtQuckEntryCmplEvtTyp in the WAM application.
This component calls the W1-MsrtQuckEntryCmplEvtTyp business object using the Inbound Web Service.
W1-MTBFMTTRBuckets
Used to create, update, read, or delete MTBFMTTRBuckets in the WAM application.
This component calls the W1-MTBFMTTRBuckets business object using the Inbound Web Service.
W1-NoAppvlRequiredProf
Used to create, update, read, or delete NoAppvlRequiredProf in the WAM application.
This component calls the W1-NoAppvlRequiredProf business object using the Inbound Web Service.
W1-NonAmtBasedAppvlProf
Used to create, update, read, or delete NonAmtBasedAppvlProf in the WAM application.
This component calls the W1-NonAmtBasedAppvlProf business object using the Inbound Web Service.
W1-NumericGauge
Used to create, update, read, or delete NumericGauge in the WAM application.
This component calls the W1-NumericGauge business object using the Inbound Web Service.
W1-NumericMeter
Used to create, update, read, or delete NumericMeter in the WAM application.
This component calls the W1-NumericMeter business object using the Inbound Web Service.
W1-OrganizationType
W1-OutboundActivityType
Used to create, update, read, or delete OutboundActivityType in the WAM application.
This component calls the W1-OutboundActivityType business object using the Inbound Web Service.
W1-Planner
Used to create, update, or delete Planner in the WAM application.
This component calls W1-Planner business object using the Inbound Web Service ATW1Planner.
W1-OvertimeType
Used to create, update, read, or delete OvertimeType in the WAM application.
This component calls the W1-OvertimeType business object using the Inbound Web Service.
W1-PaymentTerm
Used to create, update, read, or delete PaymentTerm in the WAM application.
This component calls the W1-PaymentTerm business object using the Inbound Web Service.
W1-PersonWAM
Used to create, update, read, or delete PersonWAM in the WAM application.
This component calls the W1-PersonWAM business object using the Inbound Web Service.
W1-PlantAssetLocationType
Used to create, update, read, or delete PlantAssetLocationType in the WAM application.
This component calls the W1-PlantAssetLocationType business object using the Inbound Web Service.
W1-ProjectCategory
Used to create, update, read, or delete ProjectCategory in the WAM application.
This component calls the W1-ProjectCategory business object using the Inbound Web Service
W1-PurchaseCommodity
Used to create, update, read, or delete PurchaseCommodity in the WAM application.
This component calls the W1-PurchaseCommodity business object using the Inbound Web Service.
W1-PurchasingMasterConfig
Used to create, update, read, or delete PurchasingMasterConfig in the WAM application.
This component calls the W1-PurchasingMasterConfig business object using the Inbound Web Service.
W1-Question
Used to create, update, read, or delete Question in the WAM application.
This component calls the W1-Question business object using the Inbound Web Service.
W1-ReadLogEntry
Used to read ReadLogEntry in the WAM application.
This component uses the W1-ReadLogEntry business Service using the Inbound Web Service.
W1-ReadWithNoEvaluateMeasType
Used to create, update, read, or delete ReadWithNoEvaluateMeasType in the WAM application.
This component calls the W1-ReadWithNoEvaluateMeasType business object using the Inbound Web Service.
W1-ResourceUOM
Used to create, update, read, or delete ResourceUOM in the WAM application.
This component calls the W1-ResourceUOM business object using the Inbound Web Service.
W1-ScheduledActivityType
Used to create, update, read, or delete ScheduledActivityType in the WAM application.
This component calls the W1-ScheduledActivityType business object using the Inbound Web Service.
W1-ScheduledActivityTypeWAM
Used to create, update, read, or delete ScheduledActivityTypeWAM in the WAM application.
This component calls the W1-ScheduledActivityTypeWAM business object using the Inbound Web Service.
W1-SchedulePlanType
Used to create, update, read, or delete SchedulePlanType in the WAM application.
This component calls the W1-SchedulePlanType business object using the Inbound Web Service.
W1-ServHistFromActTypeCmplEvntType
Used to create, update, read, or delete ServHistFromActTypeCmplEvntType in the WAM application.
This component calls the W1-ServHistFromActTypeCmplEvntType business object using the Inbound Web Service.
W1-ServiceArea
Used to create, update, read, or delete ServiceArea in the WAM application.
This component calls the W1-ServiceArea business object using the Inbound Web Service.
W1-ServiceClass
Used to create, update, read, or delete ServiceClass in the WAM application.
This component calls the W1-ServiceClass business object using the Inbound Web Service.
W1-ShiftPlanTemplate
Used to create, update, or delete Shift Plan Template in the WAM application.
This component calls the business object W1- ShiftPlanTemplate using the Inbound Web Service.
W1-ServiceHistoryType
Used to create, update, read, or delete ServiceHistoryType in the WAM application.
This component calls the W1-ServiceHistoryType business object using the Inbound Web Service.
W1-ServiceHistTypeCmpEvtType
Used to create, update, read, or delete ServiceHistTypeCmpEvtType in the WAM application.
This component calls the W1-ServiceHistTypeCmpEvtType business object using the Inbound Web Service.
W1-StorageLocationType
Used to create, update, read, or delete StorageLocationType in the WAM application.
This component calls the W1-StorageLocationType business object using the Inbound Web Service.
W1-TaxRateSchedule
Used to create, update, read, or delete TaxRateSchedule in the WAM application.
This component calls the W1-TaxRateSchedule business object using the Inbound Web Service.
W1-TimePeriod
Used to create, update, read, or delete TimePeriod in the WAM application.
This component calls the W1-TimePeriod business object using the Inbound Web Service.
W1-WorkCalendar
Used to create, update, read, or delete WorkCalendar in the WAM application.
This component calls the W1-WorkCalendar business object using the Inbound Web Service.
W1-WorkManagementMasterConfig
Used to create, update, read, or delete WorkManagementMasterConfig in the WAM application.
This component calls the W1-WorkManagementMasterConfig business object using the Inbound Web Service.
W1-WorkPriorityBuckets
Used to create, update, read, or delete WorkPriorityBuckets in the WAM application.
This component calls the W1-WorkPriorityBuckets business object using the Inbound Web Service.
W1-WorkReqCompletionEventType
Used to create, update, read, or delete WorkReqCompletionEventType in the WAM application.
This component calls the W1-WorkReqCompletionEventType business object using the Inbound Web Service.
W1-WAssetInstallAgeBuckets
Used to create, update, read, or delete WAssetInstallAgeBuckets in the WAM application.
This component calls the W1-WAssetInstallAgeBuckets business object using the Inbound Web Service.
W1-WAssetAgeBuckets
Used to create, update, read, or delete WAssetAgeBuckets in the WAM application.
This component calls the W1-WAssetAgeBuckets business object using the Inbound Web Service.
W1-WAMBIExtractParameters
Used to create, update, read, or delete WAMBIExtractParameters in the WAM application.
This component calls the W1-WAMBIExtractParameters business object using the Inbound Web Service.
W1-QuestionnaireSvcHistType
Used to create, update, read, or delete QuestionnaireSvcHistType in the WAM application.
This component calls the W1-QuestionnaireSvcHistType business object using the Inbound Web Service.
W1-NumberOfCyclesOverdueBucket
Used to create, update, read, or delete NumberOfCyclesOverdueBucket in the WAM application.
This component calls the W1-NumberOfCyclesOverdueBucket business object using the Inbound Web Service.
W1-AssetCriticalityBuckets
Used to create, update, read, or delete AssetCriticalityBuckets in the WAM application.
This component calls the W1-AssetCriticalityBuckets business object using the Inbound Web Service.
W1-AssetConditionScoreBuckets
Used to create, update, read, or delete AssetConditionScoreBuckets in the WAM application.
This component calls the W1-AssetConditionScoreBuckets business object using the Inbound Web Service.
W1- ResourceMgmntMasterConfig
Used to create, update, read, or delete ResourceMgmntMasterConfigin the WAM application.
This component calls the W1-ResourceMgmntMasterConfig business object using the Inbound Web Service.
W1-NUMGAUGESQL
Used to read/retrieve an Asset ID using Measurement ID.
This component calls the CM-NUMGAUGE business service using the ATW1NUMGAUGESQL Inbound Web Service.
W1-NUMMETERSQL
Used to read/retrieve Measurement ID by using Measurement Type and Asset ID.
This component calls the CM- NUMMETER business service using the ATW1NUMMETERSQL Inbound Web Service.
W1-SVCHSTWAMSQL
Used to read/retrieve Service History ID using Act ID.
This component calls the CM-SVCHSTWAM business service using the ATW1SVCHSTWAMSQL Inbound Web Service.
W2-SmartMeterConfiguration
Used to create, update, read, or delete SmartMeterConfiguration in the WAM application.
This component calls the W2-SmartMeterConfiguration business object using the Inbound Web Service.
W2-SiteLocation
Used to create, update, read, or delete SiteLocation in the WAM Apalication.
This component calls the W2-SiteLocation business object using the Inbound Web Service.
W2-ServicePointInstruction
Used to create, update, read, or delete ServicePointInstruction in the WAM application.
This component calls the W2-ServicePointInstruction business object using the Inbound Web Service.
W2-ManualMeterConfiguration
Used to create, update, read, or delete ManualMeterConfiguration in the WAM application.
This component calls the W2-ManualMeterConfiguration business object using the Inbound Web Service.
W2-CommunicationComponentCfg
Used to create, update, read, or delete CommunicationComponentCfg in the WAM application.
This component calls the W2-CommunicationComponentCfg business object using the Inbound Web Service.
W1-WAMToGISSyncMapping
Used to create, update, read, or delete WAMToGISSyncMapping in the WAM application.
This component calls the W1-WAMToGISSyncMapping business object using the Inbound Web Service.
W1-SOMActivityType
SOMActivityTypein the WAM Application
W1-SOMActivityType business object using
W1- PlannerWOSummary
Used to create, update, read, or delete PlannerWOSummary in the WAM application.
This component calls the W1-PlannerWOSummary business object using the Inbound Web Service.
W1- AdjustmentType
Used to create, update, read, or delete AdjustmentType in the WAM application.
This component calls the W1-AdjustmentType business object using the Inbound Web Service.
W1- BatchLoaderRequestType
Used to create, update, read, or delete BatchLoaderRequestType in the WAM application.
This component calls the W1- BatchLoaderRequestType business object using the Inbound Web Service.
W1- ChangeRequestType
Used to create, update, read, or delete ChangeRequestType in the WAM application.
This component calls the W1- ChangeRequestType business object using the ATW1ChangeRequestType Inbound Web Service.
W1- ChangeRequestRelatedObject
Used to create, update, read, or delete ChangeRequestRelatedObject in the WAM application.
This component calls the W1- ChangeRequestRelatedObject business object using the ATW1 ChangeRequestRelatedObject Inbound Web Service.
W1-AccessGroupTables
Used to create, update, read, or delete AccessGroupTables in the WAM application.
This component calls the W1-AccessGroupTables business object using the ATW1AccessGroupTables Inbound Web Service.
W1-AssetDisposition
Used to create, update, read, or delete AssetDisposition in the WAM application.
This component calls the W1- AssetDisposition business object using the ATW1AssetDisposition Inbound Web Service.
W1-ERPIntegrationMasterConfig
Used to create, update, read, or delete ERPIntegrationMasterConfig in the WAM application.
This component calls the W1-ERPIntegrationMasterConfig business object using the ATW1ERPIntegrationMasterConfig Inbound Web Service.
W1-HCMIntegrationMasterConfig
Used to create, update, read, or delete HCMIntegrationMasterConfig in the WAM application.
This component calls the W1-HCMIntegrationMasterConfig business object using the ATW1HCMIntegrationMasterConfigInbound Web Service.
W1-TimShtQuickEntryCmplEvtType
Used to create, update, read, or delete Time Sheet Quick Entry Completion Event Types in the WAM application.
This component calls the W1-TimShtQuickEntryCmplEvtType business object using the ATW1TimShtQuickEntryCmplEvtType Inbound Web Service.
W1-InspectionTypeDeficiency
Used to create, update, read, or delete InspectionTypeDeficiency in the WAM application.
This component calls the W1-InspectionTypeDeficiency business object using the ATW1InspectionTypeDeficiency Inbound Web Service.
W1-InspectionTypePercentOfNew
Used to create, update, read, or delete InspectionTypePercentOfNew in the WAM application.
This component calls the W1-InspectionTypePercentOfNew business object using the ATW1InspectionTypePercentOfNew Inbound Web Service.
W1-ResetAssetConditionRatinSHT
Used to create, update, read, or delete ResetAssetConditionRatinSHT in the WAM application.
This component calls the W1-ResetAssetConditionRatinSHT business object using the ATW1ResetAssetConditionRatinSHT Inbound Web Service.
W1- ItemConfiguration
Used to create, update, read, or delete ItemConfiguration in the WAM application.
This component calls the W1-ItemConfiguration business object using the ATW1ItemConfiguration Inbound Web Service.
W1-Timekeeper
Used to create, update, read, or delete Timekeeper in the WAM application.
This component calls the W1-Timekeeper business object using the ATW1Timekeeper Inbound Web Service.
Asset Management
Component
Description
W1-CalendarWarranty
Used to create, update, read, or delete CalendarWarranty in the WAM application.
This component calls the W1-CalendarWarranty business object using the Inbound Web Service.
W1-CalendarWarrantyTerm
Used to create, update, read, or delete CalendarWarrantyTerm in the WAM application.
This component calls the W1-CalendarWarrantyTerm business object using the Inbound Web Service.
Used to create, update, read, or delete CommunicationComponent in the WAM application.
This component calls the W2- CommunicationComponent business object using the Inbound Web Service.
W2-CommunicationRelay
Used to create, update, read, or delete CommunicationRelay in the WAM application.
This component calls the W2-CommunicationRelay business object using the Inbound Web Service.
W2-ServicePoint
Used to create, update, read, or delete ServicePoint in the WAM application.
This component calls the W2-ServicePoint business object using the Inbound Web Service.
W2-SmartMeter
Used to create, update, read, or delete SmartMeter in the WAM application.
This component calls the W2-SmartMeter business object using the Inbound Web Service.
W2-CommunicationComponentSpec
Used to create, update, read, or delete CommunicationComponentSpec in the WAM application.
This component calls the W2-CommunicationComponentSpec business object using the Inbound Web Service.
W2-CommunicationRelaySpec
Used to create, update, read, or delete CommunicationRelaySpec in the WAM application.
This component calls the W2-CommunicationRelaySpec business object using the Inbound Web Service.
W1-FailureServiceHistory
Used to create, update, read, or delete FailureServiceHistory in the WAM application.
This component calls the W1-FailureServiceHistory business object using the Inbound Web Service.
W2-FirmwareSpecification
Used to create, update, read, or delete FirmwareSpecification in the WAM application.
This component calls the W2-FirmwareSpecification business object using the Inbound Web Service.
W1-FirmwareVersion
Used to create, update, read, or delete FirmwareVersion in the WAM application.
This component calls the W1-FirmwareVersion business object using the Inbound Web Service.
Used to create, update, read, or delete GeneralAssetLocation in the WAM application.
This component calls the W1-GeneralAssetLocation business object using the Inbound Web Service.
W1-InOutofServiceGeneralAsset
Used to create, update, read, or delete InOutofServiceGeneralAsset in the WAM application.
This component calls the W1-InOutofServiceGeneralAsset business object using the Inbound Web Service.
W1-IOSvcGeneralComponent
Used to create, update, read, or delete InOutofServiceGeneralComponent in the WAM application.
This component calls the W1-IOSvcGeneralComponent business object using the Inbound Web Service.
W1-IOSvcFleetAsset
Used to create, update, read, or delete IOSvcFleetAsset in the WAM application.
This component calls the W1-IOSvcFleetAsset business object using the Inbound Web Service.
W1-IOSvcInfrastructureAsset
Used to create, update, read, or delete IOSvcInfrastructureAsset in the WAM application.
This component calls the W1-IOSvcInfrastructureAsset business object using the Inbound Web Service.
W1-IOSvcITAsset
Used to create, update, read, or delete IOSvcITAsset in WAM the application.
This component calls the W1-IOSvcITAsset business object using the Inbound Web Service.
W1-InOutSvcAsset
Used to create, update, read, or delete W1-InOutSvcAsset in WAM the application.
This component calls the W1-InOutSvcAsset business object using the Inbound Web Service.
W1-InOutSvcComponent
Used to create, update, read, or delete W1-InOutSvcComponent in WAM the application.
This component calls the W1-InOutSvcComponent business object using the Inbound Web Service.
W1-AssetLocation
Used to create, update, read, or delete W1-AssetLocation in WAM the application.
This component calls the W1-AssetLocation business object using the Inbound Web Service.
W1-ServiceHistory
Used to create, update, read, or delete ServiceHistory in the WAM application.
This component calls the W1-ServiceHistory business object using the Inbound Web Service.
W1-ServiceHistoryWAM
This component calls the W1-ServiceHistory(Deficiency/General Weighted/ Percent of New)business object using the Inbound Web Service.
W1-StoreroomInventoryMgmt
Used to create, update, read, or delete StoreroomInventoryMgmt in the WAM application.
This component calls the W1-StoreroomInventoryMgmt business object using the Inbound Web Service.
W1-TrackedFleetSpecification
Used to create, update, read, or delete TrackedFleetSpecification in the WAM application.
This component calls the W1-TrackedFleetSpecification business object using the Inbound Web Service.
W1-TrackedITSpecification
Used to create, update, read, or delete TrackedITSpecification in the WAM application.
This component calls the W1-TrackedITSpecification business object using the Inbound Web Service.
W1-TrackedInfrastructureSpec
Used to create, update, read, or delete TrackedInfrastructureSpec in the WAM application.
This component calls the W1-TrackedInfrastructureSpec business object using the Inbound Web Service.
W1-MsrmtQuickEntryCmplEvt
MsrmtQuickEntryCmplEvt in the WAM application.
This component calls the W1- MsrmtQuickEntryCmplEvt business object using the Inbound Web Service.
W1-IOSvcITComponent
Used to create, update, read, or delete IOSvcITComponent in the WAM application.
This component calls the W1-IOSvcITComponent business object using the Inbound Web Service.
Used to create, update, read, or delete LinearAssetLocation in the WAM application.
This component calls the W1-LinearAssetLocation business object using the Inbound Web Service.
W2-ManualMeterSpecification
Used to create, update, read, or delete ManualMeterSpecification in the WAM application.
This component calls the W2-ManualMeterSpecification business object using the Inbound Web Service.
W1-Manufacturer
Used to create, update, read, or delete Manufacturer in the WAM application.
This component calls the W1-Manufacturer business object using the Inbound Web Service.
W1-MsrmtQuickEntryActivity
Used to create, update, read, or delete MsrmtQuickEntryActivity in the WAM application.
This component calls the W1-MsrmtQuickEntryActivity business object using the Inbound Web Service.
W1-Organization
Used to create, update, read, or delete Organization in the WAM application.
This component calls the W1-Organization business object using the Inbound Web Service.
Used to create, update, read, or delete PlantAssetLocation in the WAM application.
This component calls the W1-PlantAssetLocation business object using the Inbound Web Service.
Used to create, update, read, or delete QuestionnaireSvcHist in the WAM application.
This component calls the W1-QuestionnaireSvcHist business object using the Inbound Web Service.
W1-RuntimeAnniversary
Used to create, update, read, or delete RuntimeAnniversary in the WAM application.
This component calls the W1-RuntimeAnniversary business object using the Inbound Web Service.
W1-RuntimeInterval
Used to create, update, read, or delete RuntimeInterval in the WAM application.
This component calls the W1-RuntimeInterval business object using the Inbound Web Service.
W1-RuntimeWarranty
Used to create, update, read, or delete RuntimeWarranty in the WAM application.
This component calls the W1-RuntimeWarranty business object using the Inbound Web Service.
W1-RuntimeWarrantyTerm
Used to create, update, read, or delete RuntimeWarrantyTerm in the WAM application.
This component calls the W1-RuntimeWarrantyTerm business object using the Inbound Web Service.
W2-ServicePoint
W2-SmartMeterSpecification
Used to create, update, read, or delete SmartMeterSpecification in the WAM application.
This component calls the W2-SmartMeterSpecification business object using the Inbound Web Service.
W1-StorageLocation
Used to create, update, read, or delete StorageLocation in the WAM application.
This component calls the W1-StorageLocation business object using the Inbound Web Service.
W1-TrackedGeneralAsset
Used to create, update, read, or delete TrackedGeneralAsset in the WAM application.
This component calls the W1-TrackedGeneralAsset business object using the Inbound Web Service.
W1-TrackedGeneralComponent
Used to create, update, read, or delete TrackedGeneralComponent in the WAM application.
This component calls the W1-TrackedGeneralComponent business object using the Inbound Web Service.
W1-TrackedGeneralSpecification
Used to create, update, read, or delete TrackedGeneralSpecification in the WAM application.
This component calls the W1-TrackedGeneralSpecification business object using the Inbound Web Service.
W1-TrackedITAsset
Used to create, update, read, or delete TrackedITAsset in the WAM application.
This component calls the W1-TrackedITAsset business object using the Inbound Web Service.
W1-TrackedITComponent
Used to create, update, read, or delete TrackedITComponent in the WAM application.
This component calls the W1-TrackedITComponent business object using the Inbound Web Service.
W2-Vehicle
Used to create, update, read, or delete Vehicle in the WAM application.
This component calls the W2-Vehicle business object using the Inbound Web Service.
W1-ServiceCondition
Used to create, update, read, or delete ServiceCondition in the WAM Application.
This component calls the W1-ServiceCondition business object using the ATW1ServiceCondition Inbound Web Service.
W1- AssetTypePerformance
Used to update or read, AssetTypePerformance in the WAM application.
This component calls the W2- AssetTypePerformance business object using the Inbound Web Service.
W1- AssetPerformance
Used to update, read, or delete AssetPerformance in the WAM application.
This component calls the W1- AssetPerformance business object using the ATW1 AssetPerformance Inbound Web Service.
W2- ManualMeter
Used to update, read, or delete ManualMeter in the WAM application.
This component calls the W2- ManualMeter business object using the ATW2ManualMeter Inbound Web Service.
W1- Specification
Used to update, read, or delete Specificationin the WAM application.
This component calls the W1- Specification business object using the ATW2ManualMeter Inbound Web Service.
W1- SiteLocation
Used to update, read, or delete SiteLocation the WAM application.
This component calls the W1- SiteLocation business object using the ATW1SiteLocation Inbound Web Service.
W1-ResetAssetConditionRatingSH
Used to update, read, or delete ResetAssetConditionRatingServiceHistory in the WAM application.
This component calls the W1-ResetAssetConditionRatingSH business object using the ATW1ResetAssetConditionRatingSH Inbound Web Service.
W1- Item
Used to update, read, or delete Item in the WAM application.
This component calls the W1-Item business object using the ATW1Item Inbound Web Service.
W1- AssetDownTime
Used to update, read, or delete AssetDownTime in the WAM application.
This component calls the W1-AssetDownTime business object using the ATW1AssetDownTime Inbound Web Service.
W1-InspectionDeficiency
Used to update, read, or delete InspectionDeficiency in the WAM application.
This component calls the W1-InspectionDeficiency business object using the ATW1InspectionDeficiency Inbound Web Service.
W1-InspectionPercentOfNew
Used to update, read, or delete InspectionPercentOfNew in the WAM application.
This component calls the W1-InspectionPercentOfNew business object using the ATW1InspectionPercentOfNew Inbound Web Service.
W1- ItemSpecification
Used to update, read, or delete ItemSpecification in the WAM application.
This component calls the W1-ItemSpecification business object using the ATW1ItemSpecification Inbound Web Service.
W1- ProcessType
Used to update, read, or delete ProcessType in theWAM application.
This component calls the W1- ProcessType business object using the ATW1 ProcessType Inbound Web Service.
W1- MobileUpdWorkedAssetCmpEvt
Used to update, read, or delete MobileUpdWorkedAssetCmpEvt in the WAM application.
This component calls the W1- MobileUpdWorkedAssetCmpEvt business object using the ATW1MobileUpdWorkedAssetCmpEvt Inbound Web Service.
W1- Process
Used to update, read, or delete Process in the WAM application.
This component calls the W1- Process business object using the ATW1Process Inbound Web Service.
W1- ASTATT
Used to update, read, or delete ASTATT in the WAM application.
This component calls the W1- ASTATT business Service using the ATW1ATATT Inbound Web Service.
W1- ItemServicePoint
Used to update, read, or delete ItemServicePoint in the WAM application.
This component calls the W1-ItemServicePoint business Service using the ATW1ItemServicePoint Inbound Web Service.
W1-CMAssetInformation
Used to search asset details through Asset information in the WAM application.
This component calls the CM-ASSETQ1 business process using Inbound Web Service.
W1-CMAssetIdentifier
Used to search asset details using asset identifier in the WAM application.
This component calls the CM-ASSETQ2 business Service using Inbound Web Service.
W1-CMAssetDisposition
Used to search asset using asset disposition details in the WAM application.
This component calls the CM-ASSETQ3 business service using Inbound Web Service.
W1-CMAssetSpecification
Used to search asset using asset specification details in the WAM application.
This component calls the CM-ASSETQ4 business service using Inbound Web Service.
W1-CMEmployeeInformation
Used to search asset using employee information details in the WAM application.
This component calls the CM-ASSETQ5 business service using Inbound Web Service.
W1-CMInstallDate
Used to search asset using install date details in the WAM application.
This component calls the CM-ASSETQ6 business service using Inbound Web Service.
W1-CMAssetMaintenanceSpecification
Used to search asset using asset maintenance specification details in the WAM application.
This component calls the CM-ASSETQ7 business service using Inbound web service.
W1-CMAssetAttribute
Used to search asset using asset attributes details in the WAM application.
This component calls the CM-ASSETQ8 business service using Inbound web service.
W1-CMAssetLocationByAssetLocation
Information
Used to search asset location details using asset location Information in the WAM application.
This component calls the CM-ASLOQ1 business Service using Inbound Web Service.
W1-AssetComponentHistory
Used to fetch asset component history using system information in the WAM application.
This component calls the CM-ASTCMPHST business service using Inbound web service.
W1-CMAssetLocationByContactName
Used to search asset location using contact information in the WAM application.
This component calls the CM-ASLOQ3 business service using Inbound web service.
W1-CMAssetLocationByLatitudeand
Longitude
Used to search asset location using latitude and longitude information in the WAM application.
This component calls the CM-ASLOQ5 business service using Inbound web service.
W1-CMAssetLocationBySystem
Used to search asset location details using system information in the WAM application.
This component calls the CM-ASLOQ6 business service using Inbound web service.
W1- GeneralProcess
Used to update, read, or delete GeneralProcess in the WAM application.
This component calls the W1-GeneralProcess business Service using the ATW1GeneralProcess Inbound Web Service.
W1-RetAstCostCatSum
Used to fetch Asset Cost category information like maintenance amount, operational amount, etc using Asset ID.
This component calls the W1-RetAsCstCatSum business Service using the ATW1RetAsCstCatSum Inbound Web Service.
W1-RetAstCostCatSum
Used to fetch Asset Cost category information, such as maintenance amount, operational amount, etc using Asset ID.
General
Component
Description
W1-ApprovalRequest
Used to create, update, read, or delete ApprovalRequest in the WAM application.
This component calls the W1-ApprovalRequest business object using the Inbound Web Service.
W1-CreLocationDocumentCmpEvt
Used to create, update, read, or delete CreLocationDocumentCmpEvt in the WAM application.
This component calls the W1-CreLocationDocumentCmpEvt business object using the Inbound Web Service.
W1-DocAttachment
Used to create, update, read, or delete DocAttachment in the WAM application.
This component calls the W1-DocAttachment business object using the Inbound Web Service.
W1-CreDocumentPayCmpEvt
Used to create, update, read, or delete CreDocumentPayCmpEvt in the WAM application.
This component calls the W1-CreDocumentPayCmpEvt business object using the Inbound Web Service
W1-DocUrl
Used to create, update, read, or delete DocUrl in the WAM application.
This component calls the W1-DocUrl business object using the Inbound Web Service.
W1-FinancialTransaction
Used to create, update, read, or delete FinancialTransaction in the WAM application.
This component calls the W1-FinancialTransaction business object using the Inbound Web Service.
W1-StandardNote
Used to create, update, read, or delete StandardNote in the WAM application.
This component calls the W1-StandardNote business object using the Inbound Web Service.
W1-ARSQL
Used to read an Approval Request ID using an External ID.
This component calls the CM-ARSQL business service using the ATW1ARSQL Inbound Web Service.
W1-FTSQL
Used to read an FT ID using TimeSheet Detail ID.
This component calls the CM-FTSQL business service using the ATW1FTSQL Inbound Web Service.
W1-Fact
Used to create, update, read, or delete a fact in the WAM application.
This component calls the W1-Fact business object using the ATW1FACT Inbound Web Service.
W1- OnlineLoaderReq
Used to create, update, read, or delete OnlineLoaderReq in the WAM application.
This component calls the W1- OnlineLoaderReq business object using the ATWLOnlineLoaderReq Inbound Web Service.
W1- OnlineLoaderRequestType
Used to create, update, read, or delete OnlineLoaderRequestType in the WAM application.
This component calls the W1- OnlineLoaderRequestType business object using the ATW1OnlineLoaderRequesrType Inbound Web Service.
W1-GenericAttachmentLite
Used to create, update, read, or delete GenericAttachmentLite in the WAM application.
This component calls the W1- GenericAttachmentLite business object using the ATW1 GenericAttachmentLite Inbound Web Service.
W1-Adjustment
Used to create, update, read, or delete Adjustment in the WAM application.
This component calls the W1-Adjustment business object using the ATW1Adjustment Inbound Web Service.
W1-RETCEVT
Used to retrieve completion events for a measurement in the WAM application.
This component calls the W1-RETCEVT business service using the ATW1RETCEVT Inbound Web service.
W1-CMRETREFATT
Used to retrieve all the referenced attachments of an Object.
This component calls the W1-RETREFATT business service using the ATW1RETREFATT Inbound Web Service.
W1-CMDeleteMODocument
Used to delete document entry on a Maintenance Object.
This component calls the W1-DeleteMODocument business service using the ATW1DeleteMODocument Inbound Web Service.
W1-CMAddMODocument
Used to add document entry to a maintenance object.
This component calls W1-AddMODocument business service using the ATW1AddMODocument Inbound Web service.
W1-AttachmentUrl
Used to create, update, read, or delete AttachmentUrl in the WAM application.
This component calls the W1-AttachmentUrl business object using the ATW1AttachmentUrl Web Service.
Inventory Management
Component
Description
W1-AcceptLineMaterial
Used to create, update, read, or delete AcceptLineMaterial in the WAM application.
This component calls the W1-AcceptLineMaterial business object using the Inbound Web Service.
W1-PhysicalInvCountMaster
Used to create, update, read, or delete PhysicalInvCountMaster in the WAM application.
This component calls the W1-PhysicalInvCountMaster business object using the Inbound Web Service.
W1-InventoryAdjustmentILM
Used to create, update, read, or delete Inventory Adjustment Lot Management in the WAM application.
This component calls the W1-InventoryAdjustmentILM business object using the Inbound Web Service.
W1-MaterialReturnLine
Used to create, update, read, or delete MaterialReturnLine in the WAM application.
This component calls the W1-MaterialReturnLine business object using the Inbound Web Service.
W1-IsSPAStLn
Used to execute IsSPAStLn in the WAM application.
This component calls the W1-IsSPAStLnservice script using the Inbound Web Service.
W1-GenericDataLoaderSync
Used to create, update, read, or delete GenericDataLoaderSync in the WAM application.
This component calls the W1-GenericDataLoaderSync business object using the Inbound Web Service.
W1-CMUpdCntLin
Used to execute CMUpdCntLin in the WAM application.
This component calls the W1-CMUpdCntLin service script using the Inbound Web Service.
W1-CMRETCNTLIN
Used to read CMRETCNTLIN in the WAM application.
This component calls the W1-CMRETCNTLIN business service using the Inbound Web Service.
W1-AddSPAIsLn
Used to execute AddSPAIsLn in the WAM application.
This component calls the W1-AddSPAIsLn service script using the Inbound Web Service.
W1-AcceptlineSQL
Used to create, update, read, or delete AcceptlineSQL in the WAM application.
This component calls the W1-AcceptlineSQL business object using the Inbound Web Service.
W1-AcceptLineCraft
Used to create, update, read, or delete AcceptLineCraft in the WAM application.
This component calls the W1-AcceptLineCraft business object using the Inbound Web Service.
W1-StockTransaction
Used to create, update, read, or delete StockTransaction in the WAM application.
This component calls the W1-StockTransaction business object using the Inbound Web Service.
W1-BOMGenStockItem
Used to create, update, read, or delete BOMGenStockItem in the WAM application.
This component calls the W1-BOMGenStockItem business object using the Inbound Web Service.
W1-IndependentPartBOM
Used to create, update, read, or delete IndependentPartBOM in the WAM application.
This component calls the W1-IndependentPartBOM business object using the Inbound Web Service.
W1-BOMGENSISQL
Used to read a BOM Part ID using Resource Type ID.
This component calls the CM-BOMGENSI business service using the ATW1BOMGENSISQL Inbound Web Service.
W1-ReorderReviewSQL
Used to read/retrieve the ReviewReorder ID using Stock Item Detail ID.
This component calls the CM- RRSQL business service using the ATW1RRSQL Inbound Web Service.
W1-InvAdjustInvTracked
Used to create, update, read, or delete InvAdjustInvTracked in the WAM application.
This component calls the W1-InvAdjustInvTracked business object using the Inbound Web Service.
W1-InvAdjLotManaged
Used to create, update, read, or delete InvAdjLotManaged in the WAM application.
This component calls the W1-InvAdjLotManaged business object using the Inbound Web Service.
W1-InvAdjRegularInventory
Used to create, update, read, or delete InvAdjRegularInventory in the WAM application.
This component calls the W1-InvAdjRegularInventory business object using the Inbound Web Service.
W1-MaterialRequestHeader
Used to create, update, read, or delete MaterialRequestHeader in the WAM application.
This component calls the W1-MaterialRequestHeader business object using the Inbound Web Service.
W1-MaterialRequestLine
Used to create, update, read, or delete MaterialRequestLine in the WAM application.
This component calls the W1-MaterialRequestLine business object using the Inbound Web Service.
W1-MaterialRequestTemplate
Used to create, update, read, or delete MaterialRequestTemplate in the WAM application.
This component calls the W1-MaterialRequestTemplate business object using the Inbound Web Service.
W1-MaterialReturnHeader
Used to create, update, read, or delete MaterialReturnHeader in the WAM application.
This component calls the W1-MaterialReturnHeader business object using the Inbound Web Service.
W1-PhysicalInventoryCountLine
Used to create, update, read, or delete PhysicalInventoryCountLine in the WAM application.
This component calls the W1-PhysicalInventoryCountLine business object using the Inbound Web Service.
W1-PhysicalInventoryCountMaster
Used to create, update, read, or delete PhysicalInventoryCountMaster in the WAM application.
This component calls the W1-PhysicalInventoryCountMaster business object using the Inbound Web Service.
W1-PhysicalInventoryHeader
Used to create, update, read, or delete PhysicalInventoryHeader in the WAM application.
This component calls the W1-PhysicalInventoryHeader business object using the Inbound Web Service.
W1-ReceiptHeader
Used to create, update, read, or delete ReceiptHeader in the WAM application.
This component calls the W1-ReceiptHeader business object using the Inbound Web Service.
W1-ReceiptLine
Used to create, update, read, or delete ReceiptLine in the WAM application.
This component calls the W1-ReceiptLine business object using the Inbound Web Service.
W1-ReceiptLineCraft
Used to create, update, read, or delete ReceiptLineCraft in the WAM application.
This component calls the W1-ReceiptLineCraft business object using the Inbound Web Service.
W1-ReorderReview
Used to create, update, read, or delete ReorderReview in the WAM application.
This component calls the W1-ReorderReview business object using the Inbound Web Service.
W1-ReturnLine
Used to create, update, read, or delete ReturnLine in the WAM application.
This component calls the W1-ReturnLine business object using the Inbound Web Service.
W1-SIDDirectPurchase
Used to create, update, read, or delete SIDDirectPurchase in the WAM application.
This component calls the W1-SIDDirectPurchase business object using the Inbound Web Service.
W1-SIDSpecifiDirectPurchase
Used to create, update, read, or delete SIDSpecifiDirectPurchase in the WAM application.
This component calls the W1-SIDSpecifiDirectPurchase business object using the Inbound Web Service
W1-SIDExpensedAtReceipt
Used to create, update, read, or delete SIDExpensedAtReceipt in the WAM application.
This component calls the W1-SIDExpensedAtReceipt business object using the Inbound Web Service.
W1-SIDInventory
Used to create, update, read, or delete SIDInventory in the WAM application.
This component calls the W1-SIDInventory business object using the Inbound Web Service.
W1-SIDSpecificLot
Used to create, update, read, or delete SIDSpecificLot in the WAM application.
This component calls the W1-SIDSpecificLot business object using the Inbound Web Service.
W1-StockItem
Used to create, update, read, or delete StockItem in the WAM application.
This component calls the W1-StockItem business object using the Inbound Web Service.
W1-StockTransferHeader
Used to create, update, read, or delete StockTransferHeader in the WAM application.
This component calls the W1-StockTransferHeader business object using the Inbound Web Service.
W1-StockTransferIssueLine
Used to create, update, read, or delete StockTransferIssueLine in the WAM application.
This component calls the W1-StockTransferIssueLine business object using the Inbound Web Service.
W1-StockTransferReceiptHeader
Used to create, update, read, or delete StockTransferReceiptHeader in the WAM application.
This component calls the W1-StockTransferReceiptHeader business object using the Inbound Web Service.
W1-StockTransferReceiptLine
Used to create, update, read, or delete StockTransferReceiptLine in the WAM application.
This component calls the W1-StockTransferReceiptLine business object using the Inbound Web Service.
W1-StockTransferRequestLine
Used to create, update, read, or delete StockTransferRequestLine in the WAM application.
This component calls the W1-StockTransferRequestLine business object using the Inbound Web Service.
W1-AcceptLineSQL
Used to read Acceptline from the receipt line.
This component calls the ACPT_LINE_ID business service using the (ATW1AcceptLineSQL) Inbound Web Service.
W1-TransferShippingMemo
Used to create, update, read, or delete TransferShippingMemo in the WAM application.
This component calls the W1-TransferShippingMemo business object using the Inbound Web Service.
W1-TrackedStockShippingLine
Used to create, update, read, or delete TrackedStockShippingLine in the WAM application.
This component calls the W1-TrackedStockShippingLine Business object using the Inbound Web Service.
W1-StockShippingLine
Used to create, update, read, or delete StockShippingLine in the WAM application.
This component calls the W1-StockShippingLine Business object using the Inbound Web Service.
W1-ReturnShippingMemo
Used to create, update, read, or delete ReturnShippingMemoin in the WAM application.
This component calls the W1-ReturnShippingMemo business object using the Inbound Web Service.
W1- RepairShippingMemo
Used to create, update, read, or delete RepairShippingMemo the WAM application.
This component calls the W1-ReturnShippingMemo Business object using the Inbound Web Service.
W1-LotStockShippingLine
Used to create, update, read, or delete LotStockShippingLine the WAM application.
This component calls the W1-LotStockShippingLine Business object using the Inbound Web Service.
W1- MaterialIssueLine
Used to create, update, read, or delete MaterialIssueLine in the WAM application.
This component calls the W1- MaterialIssueLine Business object using the Inbound Web Service.
W1- GeneralShippingMemo
Used to create, update, read, or delete GeneralShippingMemo in the WAM application.
This component calls the W1- GeneralShippingMemo Business object using the Inbound Web Service.
W1- ShipmentDeficiencyType
Used to create, update, read, or delete ShipmentDeficiencyType in the WAM application.
This component calls the W1- ShipmentDeficiencyType Business object using the Inbound Web Service.
W1-CMStockItemInformation
Used to search stock item information with all search parameters like Stock Item search screen in WAM application.
This component calls the CM-STKITMQ1 business service using the Inbound Web Service.
W1-CMStockItemIdentifier
Used to search stock item information based on stock item identifier like Stock identifier search screen in WAM application.
This component calls the CM-STKITMQ2 business service using the Inbound Web Service.
W1- CMStockItemDetailByStockItem
DetailInfo
Used to search stock item details using various parameters like WAM application.
This component calls the CM-SIDQ1 business service using the Inbound Web Service.
DetailID
This component calls the CM-SIDQ2 business service using the Inbound Web Service.
W1-CMStockItemDetailByStockItemInfo
This component calls the CM-SIDSTRQRY business service using the Inbound Web Service.
W1- CMRETPOLINEID
Used to retrieve PO Line ID using PO Header ID and PO Line Business Object.
This component calls the CM-RETPOLINE business service using the Inbound Web Service.
W1-CMRETPRLINEID
Used to retrieve PR Line ID using PR Header ID and PR Line Business Object.
This component calls the CM-RETPRLINE business service using the Inbound Web Service.
W1-CMMaterialRequestHeader
Information
Used to search Material request header information.
This component calls the CM-MTRQHDQ1 business service using the Inbound Web Service.
W1-CMMaterialRequestHeaderID
Used to search Material request header ID.
This component calls the CM-MTRQHDQ2 business service using the Inbound Web Service.
W1-CMShippingMemoByShipping
MemoInfo
Used to search Shipping Memo Information.
This component calls the CM-SHPMMQ1 business service using the Inbound Web Service.
MemoID
Used to search Shipping Memo ID.
This component calls the CM-SHPMMQ2 business service using the Inbound Web Service.
W1-CMRecvAllnPartial
Used to receive all or partial stock items.
This component calls the CM-RcvAllPar script using the Inbound Web Service.
W1-RetriveInventoryDetails
Used to retrieve/read the stocks inventory details.
This component calls the W1-RetInvDtl script using the Inbound Web Service.
Purchasing
Component
Description
W1-BCAccessList
Used to create, update, read, or delete BCAccessList in the WAM application.
This component calls the W1-BCAccessList business object using the Inbound Web Service.
W1-BCCraftLine
Used to create, update, read, or delete BCCraftLine in the WAM application.
This component calls the W1-BCCraftLine business object using the Inbound Web Service.
W1-CMBCLNS
Used to fetch all blanket contract lines from active blanket contract in the WAM application.
This component calls W1-CMBCLNS business service using the Inbound Web Service.
W1-CrePOFrBC
Used to create purchase order from blanket contract in the WAM application.
This component calls W1CrePOFrBC service script using the Inbound Web Service.
W1-CrePORev
Used to create new revision for purchase order in the WAM application.
This component calls W1CrePORev service script using the Inbound Web Service.
W1-InvoiceGroup
Used to create, update, read, or delete InvoiceGroup in the WAM application.
This component calls the W1-InvoiceGroup business object using the Inbound Web Service.
W1-CMCrtPORev
Used to execute CMCrtPORev in the WAM application.
This component calls the W1-CMCrtPORevservice script using the Inbound Web Service.
W1-BCLineIntegration
Used to create, update, read, or delete BCLineIntegration in the WAM application.
This component calls the W1-BCLineIntegration business object using the Inbound Web Service.
W1-BCEquipmentLine
Used to create, update, read, or delete BCEquipmentLine in the WAM application.
This component calls the W1-BCEquipmentLine business object using the Inbound Web Service.
W1-BCHeader
Used to create, update, read, or delete BCHeader in the WAM application.
This component calls the W1-BCHeader business object using the Inbound Web Service.
W1-BCHeaderIntegration
Used to create, update, read, or delete BCHeaderIntegration in the WAM application.
This component calls the W1-BCHeaderIntegration business object using the Inbound Web Service.
W1-BCOtherLine
Used to create, update, read, or delete BCOtherLine in the WAM application.
This component calls the W1-BCOtherLine business object using the Inbound Web Service.
W1-BCStockItemLine
Used to create, update, read, or delete BCStockItemLine in the WAM application.
This component calls the W1-BCStockItemLine business object using the Inbound Web Service.
W1-CraftPOLine
Used to create, update, read, or delete CraftPOLine in the WAM application.
This component calls the W1-CraftPOLine business object using the Inbound Web Service.
W1-EquipmentPOLine
Used to create, update, read, or delete EquipmentPOLine in the WAM application.
This component calls the W1-EquipmentPOLine business object using the Inbound Web Service.
W1-EquipmentPRLine
Used to create, update, read, or delete EquipmentPRLine in the WAM application.
This component calls the W1-EquipmentPRLine business object using the Inbound Web Service.
W1-Expedite
Used to create, update, read, or delete Expedite in the WAM application.
This component calls the W1-Expedite business object using the Inbound Web Service.
W1-OtherResourcePOLine
Used to create, update, read, or delete OtherResourcePOLine in the WAM application.
This component calls the W1-OtherResourcePOLine business object using the Inbound Web Service.
W1-POLineIntegration
Used to create, update, read, or delete POLineIntegration in the WAM application.
This component calls the W1-POLineIntegration business object using the Inbound Web Service.
W1-POHeaderIntegration
Used to create, update, read, or delete POHeaderIntegration in the WAM application.
This component calls the W1-POHeaderIntegration business object using the Inbound Web Service.
W1-PRCreBC
Used to create, update, read, or delete PRCreBC in the WAM application.
This component calls the W1-PRCreBC business object using the Inbound Web Service.
W1-PRCrLine
Used to create, update, read, or delete PRCrLine in the WAM application.
This component calls the W1-PRCrLine business object using the Inbound Web Service.
W1-PREqLine
Used to create, update, read, or delete PREqLine in the WAM application.
This component calls the W1- PREqLine business object using the Inbound Web Service.
W1-PRHeader
Used to create, update, read, or delete PRHeader in the WAM application.
This component calls the W1-PRHeader business object using the Inbound Web Service.
W1-PRORLine
Used to create, update, read, or delete PRORLine in the WAM application.
This component calls the W1-PRORLine business object using the Inbound Web Service.
W1-PRSILine
Used to create, update, read, or delete PRSILine in the WAM application.
This component calls the W1-PRSILine business object using the Inbound Web Service.
W1-PurchaseOrderHeader
Used to create, update, read, or delete PurchaseOrderHeader in the WAM application.
This component calls the W1-PurchaseOrderHeader business object using the Inbound Web Service.
W1-StockItemPOLine
Used to create, update, read, or delete StockItemPOLine in the WAM application.
This component calls the W1-StockItemPOLine business object using the Inbound Web Service.
W1-Vendor
Used to create, update, read, or delete Vendor in the WAM application.
This component calls the W1-Vendor business object using the Inbound Web Service.
W1-VendorLocation
Used to create, update, read, or delete VendorLocation in the WAM application.
This component calls the W1-VendorLocation business object using the Inbound Web Service.
W1-CMPOHSQL
Used to read a Purchase Order ID using an External ID.
This component calls the CM-POHSQL business service using the ATW1CMPOHSQL Inbound Web Service.
W1-CMBlanketContractByBlanket
ContractHeaderInfo
Used to search Blanket contract by Blanket Contract Header Information.
This component calls the CM-BCHDQ1 business service using Inbound Web Service.
ContractHeaderID
Used to search Blanket contract by Blanket Contract Header ID.
This component calls the CM-BCHDQ2 business service using Inbound Web Service.
ContractHeaderResourceType
Used to search Blanket contract by Blanket Contract Resource type details.
This component calls the CM-BCHDQ3 business service using Inbound Web Service.
W1-CMPOByHeaderInfo
Used to search purchase order by header information.
This component calls the CM-POQ1 business service using Inbound Web Service.
W1-CMPOByLineInfo
Used to search purchase order by line information.
This component calls the CM-POQ2 business service using Inbound Web Service.
W1-CMPOByHeaderId
Used to search purchase order information using header ID.
This component calls the CM-POQ3 business service using Inbound Web Service.
W1-CMPOByWorkOrder
Used to search purchase order by work order details.
This component calls the CM-POQ4 business service using Inbound Web Service.
W1-PRPOHSQL
Used to fetch PO details for a specific PR.
This component calls the CM-PRPOHSQL business service using Inbound Web Service.
W1-CMPRByHeaderInfo
Used to search purchase request by header information.
This component calls the CM-PRHQ1 business service using Inbound Web Service.
W1-CMPRByLineInfo
Used to search purchase request by line information.
This component calls the CM-PRHQ2 business service using Inbound Web Service.
W1-CMPRById
Used to search purchase request using identifiers.
This component calls the CM-PRHQ3 business service using Inbound Web Service.
W1-CMPRByWOInfo
Used to search purchase request by work order information.
This component calls the CM-PRHQ4 business service using Inbound Web Service.
Work Management
Component
Description
W1-ActivityComplInboundComm
Used to create, update, read, or delete ActivityComplInboundComm in the WAM application.
This component calls the W1-ActivityComplInboundComm business object using the Inbound Web Service.
W1-ServiceHistoryParticipant
ServiceHistoryParticipant in the WAM application.
This component calls the W1-ServiceHistoryParticipant business object using the Inbound Web Service.
W1-ShiftHours
Used to read ShiftHours in the WAM application.
This component calls the W1-ShiftHours business service using the Inbound Web Service.
W1-RCMSchedule
Used to create, update, read, or delete RCMSchedule in the WAM application.
This component calls the W1-RCMSchedule business object using the Inbound Web Service.
W1-PtNotes
Used to create, update, read, or delete PtNotes in the WAM application.
This component calls the W1-PtNotes business object using the Inbound Web Service.
W1-ProjectMgmntIntegMstConfig
Used to create, update, read, or delete ProjectMgmntIntegMstConfig in the WAM application.
This component calls the W1-ProjectMgmntIntegMstConfig business object using the Inbound Web Service.
W1-PmtNotes
Used to create, update, read, or delete PmtNotes in the WAM application.
This component calls the W1-PmtNotes business object using the Inbound Web Service.
W1-PermitChecklist
Used to create, update, read, or delete PermitChecklist in the WAM application.
This component calls the W1-PermitChecklist business object using the Inbound Web Service.
W1-PRJWD
Used to read PRJWD in the WAM application.
This component calls the W1-PRJWDbusiness service using the Inbound Web Service.
W1-PRJTMST
Used to read PRJTMST in the WAM application.
This component calls the W1-PRJTMSTbusiness service using the Inbound Web Service.
W1-PRJPOLINE
Used to read PRJPOLINE in the WAM application.
This component calls the W1-PRJPOLINEbusiness service using the Inbound Web Service.
W1-PIHeader
Used to create, update, read, or delete PIHeader in the WAM application.
This component calls the W1-PIHeader business object using the Inbound Web Service.
W1-InternalPermit
Used to create, update, read, or delete InternalPermit in the WAM application.
This component calls the W1-InternalPermit business object using the Inbound Web Service.
W1-FollowUpSkippedAssetsCmpEvt
Used to create, update, read, or delete FollowUpSkippedAssetsCmpEvt in the WAM application.
This component calls the W1-FollowUpSkippedAssetsCmpEvt business object using the Inbound Web Service.
W1-ExternalPermit
Used to create, update, read, or delete ExternalPermit in the WAM application.
This component calls the W1-ExternalPermit business object using the Inbound Web Service.
W1-EventTrigger
Used to create, update, read, or delete EventTrigger in the WAM application.
This component calls the W1-EventTrigger business object using the Inbound Web Service.
W1-OperationMaintSpec
Used to create, update, read, or delete OperationMaintSpec in the WAM application.
This component calls the W1-OperationMaintSpec business object using the Inbound Web Service.
W1-MobileStoreroomInventory
Used to create, update, read, or delete MobileStoreroomInventory in the WAM application.
This component calls the W1-MobileStoreroomInventory business object using the Inbound Web Service.
W1-MassUpd
Used to createMassUpd in the WAM application.
This component calls the W1-MassUpd service script using the Inbound Web Service.
W1-InternalPermit
W1-EventSchedule
Used to create, update, read, or delete EventSchedule in the WAM application.
This component calls the W1-EventSchedule business object using the Inbound Web Service.
W1-DowntimeFailureRuntimCmpEvt
Used to create, update, read, or delete DowntimeFailureRuntimCmpEvt in the WAM application.
This component calls the W1-DowntimeFailureRuntimCmpEvt business object using the Inbound Web Service.
W1-ActivityEquipRequirement
Used to create, update, read, or delete ActivityEquipRequirement in the WAM application.
This component calls the W1-ActivityEquipRequirement business object using the Inbound Web Service.
W1-TrnAssetRcdMsrmtCmplEvt
Used to create, update, read, or delete TrnAssetRcdMsrmtCmplEvt in the WAM application.
This component calls the W1-TrnAssetRcdMsrmtCmplEvt business object using the Inbound Web Service.
W1-ActivityLaborRequirement
Used to create, update, read, or delete ActivityLaborRequirement in the WAM application.
This component calls the W1-ActivityLaborRequirement business object using the Inbound Web Service.
W1-SynchronizeMobileStoreroomDetails
SynchronizeMobileStoreroomDetails in the WAM application.
This component calls the W1-SynchronizeMobileStoreroomDetails business object using the Inbound Web Service.
W1-DetermineMaintTrigger
Used to read DetermineMaintTrigger in the WAM application.
This component calls the W1-DetermineMaintTrigger business object using the Inbound Web Service.
W1-CreSvcHstDocumentCmpEvt
Used to create, update, read, or delete CreSvcHstDocumentCmpEvt in the WAM application.
This component calls the W1-CreSvcHstDocumentCmpEvt business object using the Inbound Web Service.
W1-CMWorkReqInformation
Used to read CMWorkReqInformation in the WAM application.
This component calls the W1-CMWorkReqInformation business service using the Inbound Web Service.
W1-CMWorkReqIdentifier
Used to read CMWorkReqIdentifier in the WAM application.
This component calls the W1-CMWorkReqIdentifier business service using the Inbound Web Service.
W1-CMWorkActivityInformation
Used to read CMWorkActivityInformation in the WAM application.
This component calls the W1-CMWorkActivityInformation business object using the Inbound Web Service.
W1-CMWRWORKDUP
Used to read CMWRWORKDUP in the WAM application.
This component calls the W1-CMWRWORKDUP business service using the Inbound Web Service.
W1-CMWOWASHSQL
Used to read CMWOWASHSQL in the WAM application.
This component calls the W1-CMWOWASHSQL business service using the Inbound Web Service.
W1-CMWOWASCSQL
Used to read CMWOWASCSQL in the WAM application.
This component calls the W1-CMWOWASCSQL business service using the Inbound Web Service.
W1-CMWOWAPMSQL
Used to read CMWOWAPMSQL in the WAM application.
This component calls the W1-CMWOWAPMSQL business service using the Inbound Web Service.
W1-CMWOByInformation
Used to read CMWOByInformation in the WAM application.
This component calls the W1-CMWOByInformation business service using the Inbound Web Service.
W1-CMWOBYID
Used to read CMWOBYID in the WAM application.
This component calls the W1-CMWOBYID business service using the Inbound Web Service.
W1-CMServiceCallInformation
Used to read CMServiceCallInformation in the WAM application.
This component calls the W1-CMServiceCallInformation business service using the Inbound Web Service.
W1-CMServiceCallIdentifier
Used to read CMServiceCallIdentifier in the WAM application.
This component calls the W1-CMServiceCallIdentifier business service using the Inbound Web Service.
W1-CMPRJWO
Used to read CMPRJWO in the WAM application.
This component calls the W1-CMPRJWO business service using the Inbound Web Service.
W1-CMPRJWACT
Used to read CMPRJWACT in the WAM application.
This component calls the W1-CMPRJWACT business service using the Inbound Web Service.
W1-CMLnkPmCkls
Used to execute CMLnkPmCkls in the WAM application.
This component calls the W1-CMLnkPmCklsservice script using the Inbound Web Service.
W1-CMActivityWorkWindow
Used to read CMActivityWorkWindow in the WAM application.
This component calls the W1-CMActivityWorkWindow business service using the Inbound Web Service.
W1-CMActivityLocation
Used to read CMActivityLocation in the WAM application.
This component calls the W1-CMActivityLocation business service using the Inbound Web Service.
W1-CMActivityIdentifier
Used to read CMActivityIdentifier in the WAM application.
This component calls the W1-CMActivityIdentifier business service using the Inbound Web Service.
W1-CMAcNoteMnt
Used to execute CMAcNoteMnt in the WAM application.
This component calls the W1-CMAcNoteMnt service script using the Inbound Web Service.
W1-ActivityNotes
Used to update, read, or delete ActivityNotes in the WAM application.
This component calls the W1-ActivityNotes business object using the Inbound Web Service.
W1-ActivityMaterialUsage
Used to execute ActivityMaterialUsage in the WAM application.
This component calls the W1-ActivityMaterialUsage service script using the Inbound Web Service.
W1-ActAstLst
Used to execute ActAstLst in the WAM application.
This component calls the W1-ActAstLst service script using the Inbound Web Service.
W1-ACfgDeviceUpgrade
Used to create, update, read, or delete ACfgDeviceUpgrade in the WAM application.
This component calls the W1-ACfgDeviceUpgrade business object using the Inbound Web Service.
W1-ActivityMaterialRequirement
Used to create, update, read, or delete ActivityMaterialRequirement in the WAM application.
This component calls the W1-ActivityMaterialRequirement business object using the Inbound Web Service.
W1-ACCfgDeviceUpgrade
Used to create, update, read, or delete ACCfgDeviceUpgrade in the WAM application.
This component calls the W1-ACCfgDeviceUpgrade business object using the Inbound Web Service.
W1-ACACfgDeviceUpgrade
Used to create, update, read, or delete ACACfgDeviceUpgrade in the WAM application.
This component calls the W1-ACACfgDeviceUpgrade business object using the Inbound Web Service.
W1-ACACCfgDeviceUpgrade
Used to create, update, read, or delete ACACCfgDeviceUpgrade in the WAM application.
This component calls the W1-ACACCfgDeviceUpgrade business object using the Inbound Web Service.
W1-AACfgDeviceUpgrade
Used to create, update, read, or delete AACfgDeviceUpgrade in the WAM application.
This component calls the W1-AACfgDeviceUpgrade business object using the Inbound Web Service.
W1-AACCfgDeviceUpgrade
Used to create, update, read, or delete AACCfgDeviceUpgrade in the WAM application.
This component calls the W1-AACCfgDeviceUpgrade business object using the Inbound Web Service.
W1-ActivityOtherRequirement
Used to create, update, read, or delete ActivityOtherRequirement in the WAM application.
This component calls the W1-ActivityOtherRequirement business object using the Inbound Web Service.
W1-AdHocActivityCore
Used to create, update, read, or delete AdHocActivityCore in the WAM application.
This component calls the W1-AdHocActivityCore business object using the Inbound Web Service.
W1-
AssetLocationSpecificTempl
Used to create, update, read, or delete AssetLocationSpecificTempl in the WAM application.
This component calls the W1-AssetLocationSpecificTempl business object using the Inbound Web Service.
W1-AssetLocSpecTemplWorkOrder
Used to create, update, read, or delete AssetLocSpecTemplWorkOrder in the WAM application.
This component calls the W1-AssetLocSpecTemplWorkOrder business object using the Inbound Web Service.
W1-AssetLocSpecTemplateAct
Used to create, update, read, or delete AssetLocSpecTemplateAct in the WAM application.
This component calls the W1-AssetLocSpecTemplateAct business object using the Inbound Web Service.
W1-AssetReplicationActivity
Used to create, update, read, or delete AssetReplicationActivity in the WAM application.
This component calls the W1-AssetReplicationActivity business object using the Inbound Web Service.
W1-AssetReplicationComplEvent
Used to create, update, read, or delete AssetReplicationComplEvent in the WAM application.
This component calls the W1-AssetReplicationComplEvent business object using the Inbound Web Service.
W1-CreAssetAttachCmpEvt
Used to create, update, read, or delete CreAssetAttachCmpEvt in the WAM application.
This component calls the W1-CreAssetAttachCmpEvt business object using the Inbound Web Service.
W1-CreAssetDocumentCmpEvt
CreAssetDocumentCmpEvt in the WAM application.
This component calls the W1-CreAssetDocumentCmpEvt business object using the Inbound Web Service.
W1-CreAssetPayCmpEvt
Used to create, update, read, or delete CreAssetPayCmpEvt in the WAM application.
This component calls the W1-CreAssetPayCmpEvt business object using the Inbound Web Service.
W1-CreNodeAttachCmpEvt
Used to create, update, read, or delete CreNodeAttachCmpEvt in the WAM application.
This component calls the W1-CreNodeAttachCmpEvt business object using the Inbound Web Service.
W1-CreServiceHistoryAttCmpEvt
Used to create, update, read, or delete CreServiceHistoryAttCmpEvt in the WAM application.
This component calls the W1-CreServiceHistoryAttCmpEvt business object using the Inbound Web Service.
W1-SubscriptionShiftPlanTemp
Used to create, update, read, or delete SubscriptionShiftPlanTemp in the WAM application.
This component calls the W1-SubscriptionShiftPlanTemp business object using the Inbound Web Service.
W1-CommonShiftPlanTemplate
Used to create, update, read, or delete CommonShiftPlanTemplate in the WAM application.
This component calls the W1-CommonShiftPlanTemplate business object using the Inbound Web Service.
W1-Craft
Used to create, update, read, or delete Craft in the WAM application.
This component calls the W1-Craft business object using the Inbound Web Service.
W1-CreActivityPayCmpEvt
Used to create, update, read, or delete CreActivityPayCmpEvt in the WAM application.
This component calls the W1-CreActivityPayCmpEvt business object using the Inbound Web Service.
W1-CreateActivityInboundComm
Used to create, update, read, or delete CreateActivityInboundComm in the WAM application.
This component calls the W1-CreateActivityInboundComm business object using the Inbound Web Service.
W1-CreComActivityInboundComm
Used to create, update, read, or delete CreComActivityInboundComm in the WAM application.
This component calls the W1-CreComActivityInboundComm business object using the Inbound Web Service.
W1-CreServiceHistoryPayCmpEvt
Used to create, update, read, or delete CreServiceHistoryPayCmpEvt in the WAM application.
This component calls the W1-CreServiceHistoryPayCmpEvt business object using the Inbound Web Service.
W1-Crew
Used to create, update, read, or delete Crew in the WAM application.
This component calls the W1-Crew business object using the Inbound Web Service.
W1-CreWorkReqDocumentCmpEvt
Used to create, update, read, or delete CreWorkReqDocumentCmpEvt in the WAM application.
This component calls the W1-CreWorkReqDocumentCmpEvt business object using the Inbound Web Service.
W1-CreWorkRequestPayCmpEvt
Used to create, update, read, or delete CreWorkRequestPayCmpEvt in the WAM application.
This component calls the W1-CreWorkRequestPayCmpEvt business object using the Inbound Web Service.
W1-CrewShiftTemplate
Used to create, update, read, or delete CrewShiftTemplate in the WAM application.
This component calls the W1-CrewShiftTemplate business object using the Inbound Web Service.
W1-CrewWithCraft
Used to create, update, read, or delete CrewWithCraft in the WAM application.
This component calls the W1-CrewWithCraft business object using the Inbound Web Service.
W1-CreSvcHistCmpEvt
Used to create, update, read, or delete CreSvcHistCmpEvt in the WAM application.
This component calls the W1-CreSvcHistCmpEvt business object using the Inbound Web Service.
W1-CreAssetCmpEvt
Used to create, update, read, or delete CreAssetCmpEvt in the WAM application.
This component calls the W1-CreAssetCmpEvt business object using the Inbound Web Service.
W1-CreActivityCmpEvt
Used to create, update, read, or delete CreActivityCmpEvt in the WAM application.
This component calls the W1-CreActivityCmpEvt business object using the Inbound Web Service.
W1- CreAssetDocumentCmpEvt
Used to create, update, read, or delete CreAssetDocumentCmpEvt in the WAM application.
W1- MeasQuckEntryActivityType
Used to create, update, read, or delete MeasQuckEntryActivityType in the WAM application.
This component calls the W1-MeasQuckEntryActivityType business object using the Inbound Web Service.
W-RCMCalendarInterval
Used to create, update, read, or delete RCMCalendarInterval in the WAM application.
This component calls the W1- RCMCalendarInterval business object using the Inbound Web Service.
W1-RCMRuntimeAnniversary
Used to create, update, read, or delete RCMRuntimeAnniversary in the WAM application.
This component calls the W1-RCMRuntimeAnniversary business object using the Inbound Web Service.
W1-RCMRuntimeInterval
Used to create, update, read, or delete RCMRuntimeIntervalin the WAM application.
This component calls the W1- RCMRuntimeInterval business object using the Inbound Web Service.
W1-DailySchedule
Used to create, update, read, or delete DailySchedule in the WAM application.
This component calls the W1-DailySchedule business object using the Inbound Web Service.
W1-Employee
Used to create, update, read, or delete Employee in the WAM application.
This component calls the W1-Employee business object using the Inbound Web Service.
W1-EquipForTemplateAct
Used to create, update, read, or delete EquipForTemplateAct in the WAM application.
This component calls the W1-EquipForTemplateAct business object using the Inbound Web Service.
W1-GeneralTemplateActivity
Used to create, update, read, or delete GeneralTemplateActivity in the WAM application.
This component calls the W1-GeneralTemplateActivity business object using the Inbound Web Service.
W1-GeneralTemplateWorkOrder
Used to create, update, read, or delete GeneralTemplateWorkOrder in the WAM application.
This component calls the W1-GeneralTemplateWorkOrder business object using the Inbound Web Service.
W1-LaborForTemplateAct
Used to create, update, read, or delete LaborForTemplateAct in the WAM application.
This component calls the W1-LaborForTemplateAct business object using the Inbound Web Service.
W1-Leave
Used to create, update, read, or delete Leave in the WAM application.
This component calls the W1-Leave business object using the Inbound Web Service.
W1-LocalActivityCoreWAM
Used to create, update, read, or delete LocalActivityCoreWAM in the WAM application.
This component calls the W1-LocalActivityCoreWAM business object using the Inbound Web Service.
W1-MaintenanceSchedule
Used to create, update, read, or delete MaintenanceSchedule in the WAM application.
This component calls the W1-MaintenanceSchedule business object using the Inbound Web Service.
W1-ODCEquipment
Used to create, update, read, or delete ODCEquipment in the WAM application.
This component calls the W1-ODCEquipment business object using the Inbound Web Service.
W1-OperationalReadingCmpEvt
Used to create, update, read, or delete OperationalReadingCmpEvt in the WAM application.
This component calls the W1-OperationalReadingCmpEvt business object using the Inbound Web Service.
W1-Other
Used to create, update, read, or delete Other in the WAM application.
This component calls the W1-Other business object using the Inbound Web Service.
W1-OtherDirectCharges
Used to create, update, read, or delete OtherDirectCharges in the WAM application.
This component calls the W1-OtherDirectCharges business object using the Inbound Web Service.
W1-OtherDirectChargesOther
Used to create, update, read, or delete OtherDirectChargesOther in the WAM application.
This component calls the W1-OtherDirectChargesOther business object using the Inbound Web Service.
W1-OtherForTemplateAct
Used to create, update, read, or delete OtherForTemplateAct in the WAM application.
This component calls the W1-OtherForTemplateAct business object using the Inbound Web Service.
W1-Project
Used to create, update, read, or delete Project in the WAM application.
This component calls the W1-Project business object using the Inbound Web Service.
W1-RCMCalendarAnniversary
Used to create, update, read, or delete RCMCalendarAnniversary in the WAM application.
This component calls the W1-RCMCalendarAnniversary business object using the Inbound Web Service.
W1-RetrieveComplEvents
Used to retrieve the completion events from an activity.
This component calls the W1-RETCEVT business service using the Inbound Web Service.
W1-SchedulePlan
Used to create, update, read, or delete SchedulePlan in the WAM application.
This component calls the W1-SchedulePlan business object using the Inbound Web Service.
W1-TemplateActivityLaborReq
Used to create, update, read, or delete TemplateActivityLaborReq in the WAM application.
This component calls the W1-TemplateActivityLaborReq business object using the Inbound Web Service.
W1-TempActMaterialReq
Used to create, update, read, or delete TemplateActMaterialReq in the WAM application.
This component calls the W1-TempActMaterialReq business object using the Inbound Web Service.
W1-Timesheet
Used to create, update, read, or delete Timesheet in the WAM application.
This component calls the W1-Timesheet business object using the Inbound Web Service.
W1-TimesheetDetail
Used to create, update, read, or delete TimesheetDetail in the WAM application.
This component calls the W1-TimesheetDetail business object using the Inbound Web Service.
W1-TrnAssetCmpEvent
Used to create, update, read, or delete TrnAssetCmpEvent in the WAM application.
This component calls the W1-TrnAssetCmpEvent business object using the Inbound Web Service.
W1- UpdAssetPayCmpEvt
Used to create, update, read, or delete UpdAssetPayCmpEvtin the WAM application.
This component calls the W1- UpdAssetPayCmpEvt business object using the Inbound Web Service.
W1- UpdNodePayCmpEvt
Used to create, update, read, or delete UpdNodePayCmpEvtthe WAM application.
This component calls the W1-UpdNodePayCmpEvt business object using the Inbound Web Service.
W1-WorkOrder
Used to create, update, read, or delete WorkOrder in the WAM application.
This component calls the W1-WorkOrder business object using the Inbound Web Service.
W1-WorkRequest
Used to create, update, read, or delete WorkRequest in the WAM application.
This component calls the W1-WorkRequest business object using the Inbound Web Service.
W1-WorkRequestComplEvt
Used to create, update, read, or delete WorkRequestComplEvt in the WAM application.
This component calls the W1-WorkRequestComplEvt business object using the Inbound Web Service.
W1-RetriveAERID
Used to read/retrieve Activity Equipment requirement ID from Act in the WAM application.
This component calls the ATW1RTAERID business service using the ATW1RTAERID Inbound Web Service.
W1-RetriveALRID
Used to read/retrieve Activity Labor Requirement ID from Activity in the WAM application.
This component calls the ATW1RTALRID business service using the ATW1RTALRID Inbound Web Service.
W1-RetriveAMRID
Used to read/retrieve Activity Material Requirement ID from Activity in the WAM application.
This component calls the ATW1RTAMRID business service using the ATW1RTAMRID Inbound Web Service.
W1-RetriveAORID
Used to read/retrieve Activity Other Requirement ID from Activity in the WAM application.
This component calls the ATW1RTAORID business service using the ATW1RTAORID Inbound Web Service.
W1-ActivityChecklist
Used to create, update, read, or delete ActivityChecklist in the WAM application.
This component calls the W1-ActivityChecklist business object using ATW1ActivityChecklist Inbound Web Service.
W1-ChecklistType
Used to create, update, read, or delete W1-ChecklistType in the WAM application.
This component calls the W1-ChecklistType business object using ATW1ChecklistType Inbound Web Service.
W1-WOActivityActiveOutboundMsg
Used to add/update WOActivityActive Outbound message BO in the WAM Application.
This component calls the W1-WOActivityActiveOutboundMsg business service using the ATW1WOActivityActiveOutboundMsg Inbound WebService.
W1-WOActivityFinalOutboundMsg
Used to cancel/complete WOActivityFinalOutboundMessage BO in the WAM application.
This component calls the W1-WOActivityFinalOutboundMsg business service using the ATW1WOActivityFinalOutboundMsg Inbound Web Service.
W1-WorkCategory
Used to create, update, read, or delete WorkCategory in the WAM application.
This component calls the W1-WorkCategory business object using the ATW1WorkCategory Inbound Web Service.
W1-WorkCategoryBundlingAddBO
Used to create, update, read, or delete WorkCategoryBundlingAddBO in the WAM application.
This component calls the W1-WorkCategoryBundlingAddBO business object using the Inbound Web Service.
W1-WorkCategoryPhysicalBO
WorkCategoryPhysicalBO in the WAM application.
This component calls the W1- WorkCategoryPhysicalBO business object using the ATW1 WorkCategoryPhysicalBO Inbound Web Service.
W1-WorkClass
Used to create, update, read, or delete WorkClass in the WAM application.
This component calls the W1-WorkClass business object using the ATW1WorkClass Inbound Web Service.
W1-WorkClassBundlingAddBO
Used to create, update, read, or delete WorkClassBundlingAddBO in the WAM application.
This component calls the W1-WorkClassBundlingAddBO business object using the ATW1WorkClassBundlingAddBO Inbound Web Service.
W1-WorkClassPhysicalBO
Used to create, update, read, or delete WorkClassPhysicalBO in the WAM application.
This component calls the W1- WorkClassPhysicalBO business object using ATW1WorkClassPhysicalBO Inbound Web Service.
W1-ActivityGenerator
Used to create, update, read, or delete ActivityGeneratorin the WAM application.
This component calls the W1- W1-ActivityGenerator business object using ATW1ActivityGenerator Inbound Web Service.
W1-ComplianceCategory
Used to create, update, read, or delete ComplianceCategory in the WAM application.
This component calls the W1-ComplianceCategory business object using the ATW1ComplianceCategory Inbound Web Service.
W1-ComplianceType
Used to create, update, read, or delete ComplianceType in the WAM application.
This component calls the W1-ComplianceType business object using ATW1ComplianceType Inbound Web Service.
W1-CrAnyServiceHistoryCmplEvt
Used to create, update, read, or delete W1-CrAnyServiceHistoryCmplEvt the WAM application.
This component calls the W1-CrAnyServiceHistoryCmplEvt business object using ATW1ActivityGenerator Inbound Web Service.
W1- CorrectiveComplianceType
Used to create, update, read, or delete W1- CorrectiveComplianceType the WAM application.
This component calls the W1- CorrectiveComplianceType business object using ATW1 CorrectiveComplianceType Inbound Web Service.
W1- ServiceCode
Used to create, update, read, or delete ServiceCode in the WAM application.
This component calls the W1- ServiceCode business object using ATW1 ServiceCode Inbound Web Service.
W1- ServiceCallCategory
Used to create, update, read, or delete W1- ServiceCallCategory the WAM application.
This component calls the W1- ServiceCallCategory business object using ATW1 ServiceCallCategory Inbound Web Service.
W1- ServiceCall
Used to create, update, read, or delete W1-ServiceCall the WAM application.
This component calls the W1-serviceCall business object using ATW1ServiceCall Inbound Web Service.
W1- Communication
Used to create, update, read, or delete W1-Communication the WAM application.
This component calls the W1-Communication business object using ATW1Communication l Inbound Web Service.
W1-ProjectActOutboundSyncReq
Used to update or read delete W1-ProjectActOutboundSyncReq the WAM application.
This component calls the W1-ProjectActOutboundSyncReq business object using ATW1 ProjectActOutboundSyncReq Inbound Web Service.
W1- ProjectActOutboundMsg
Used to update or read, W1-ProjectActOutboundMsg in the WAM application.
This component calls the W1- ProjectActOutboundMsg object using ATW1 ProjectActOutboundMsg Inbound Web Service.
Used to create, update, read, or delete W1-ProjectActOutboundMsg the WAM application.
This component calls the W1- ProjectActOutboundMsg business object using ATW1 ProjectActOutboundMsg Inbound Web Service.
W1-SOMActivity
Used to create, update, read, or delete W1-SOMActivity the WAM application.
This component calls the W1-SOMActivity business object using ATW1SOMActivity Inbound Web Service.
W1- ReplaceAssetOutbound
Used to create, update, read, or delete W1- ReplaceAssetOutbound the WAM application.
This component calls the W1-ReplaceAssetOutbound business object using ATW1ReplaceAssetOutbound Inbound Web Service.
W1-ReplaceAssetLocal
Used to create, update, read, or delete W1-ReplaceAssetLocalthe WAM application.
This component calls the W1-ReplaceAssetLocalbusiness object using ATW1ReplaceAssetLocal Inbound Web Service.
W1- Document
Used to create, update, read, or delete W1- Document in the WAM application.
This component calls the W1- Document business object using ATW1Document Inbound Web Service.
W1- CrewWOSummary
Used to create, update, read, or delete W1- CrewWOSummary in the WAM application.
This component calls the W1- CrewWOSummary business object using ATW1 CrewWOSummary Inbound Web Service.
W1- BatchLoaderRequest
Used to create, update, read, or delete W1- BatchLoaderRequest in the WAM application.
This component calls the W1- BatchLoaderRequest business object using ATW1BatchLoaderRequest Inbound Web Service.
W1- ChangeRequest
Used to create, update, read, or delete W1- ChangeRequest in the WAM application.
This component calls the W1- ChangeRequest business object using ATW1 ChangeRequest Inbound Web Service.
W1- RETSYNID
Used to create, update, read, or delete W1- RETSYNID in the WAM application.
This component calls the W1- RETSYNID business Service using ATW1 RETSYNID Inbound Web Service.
W1-RETOUTID
Used to create, update, read, or delete W1- RETOUTID in the WAM application.
This component calls the W1- RETOUTID business service using ATW1 RETOUTID Inbound Web Service.
W1-MaintenanceEvent
Used to create, update, read, or delete W1-MaintenanceEvent in the WAM application.
This component calls the W1-MaintenanceEvent business object using ATW1MaintenanceEvent Inbound Web Service.
W1-GenMaterialDisposition
Used to create, update, read, or delete W1-GenMaterialDisposition in the WAM application.
This component calls the W1-GenMaterialDisposition business object using ATW1GenMaterialDisposition Inbound Web Service.
W1-MaintenanceManager
Used to create, update, read, or delete W1-MaintenanceManager in the WAM application.
This component calls the W1-MaintenanceManager business object using ATW1MaintenanceManager Web Service.
W1-SEARCHOTHRESREQBY
ACTIVITYID
Used to find all other resource requirements associated with a work activity.
This component calls the ATW1RTAORID business service using the Inbound Web Service.
W1-SEARCHEQURESREQBY
ACTIVITYID
Used to find all equipment requirements associated with a work activity.
This component calls the ATW1RTAERID business service using the Inbound Web Service.
W1-SEARCHLABRESREQBY
ACTIVITYID
Used to find all labor resource requirements associated with a work activity.
This component calls the ATW1RTALRID business service using the Inbound Web Service.
W1-SEARCHMATRESREQBY
ACTIVITYID
Used to find all Material resource requirements associated with a work activity.
This component calls the ATW1RTAMRID business service using the Inbound Web Service.
W1-TSDBYACTID
Used to retrieve all Time sheet details associated with a work activity.
This component calls the ATW1TIMESHEETDETAILBYACTIVITYI business service using the Inbound Web Service.
W1-RETTSTPEM
Used to retrieve Timesheet using employee ID and time period.
This component calls the W1-RETTSTPEM business service using the Inbound Web Service.
W1- RETTSDET
Used to retrieve Timesheet details.
This component calls the W1-RETTSDET business service using the Inbound Web Service.
W1-RETINCOMM
Used to retrieve inbound communication details based on an activity.
This component calls the W1-RETINCOMM business service using the Inbound Web Service.
W1-RETSHACT
Used to retrieve Service History Details using Activity ID.
This component calls the ATW1RETSHACT business service using the Inbound Web Service.
W1-RetrieveComplEventsDtlByActId
Used to Retrieve Completion Events by Activity ID.
This component calls the CM-RETCEVT business service using the Inbound Web Service.
W1-SEARCHEMPIDBYEXTID
Used to search employees by using external ID.
This component calls 'W1-RETEMPLID' business service using the inbound web service.
W1-CMFieldActivityIdentifier
Used to search field activities by Activity identifier.
This component calls the CM-ActivityIdentifier business service using the Inbound Web Service.
W1-CMFieldActivityWorkWindow
Used to search field activities by Activity work window.
This component calls CM-ActivityWorkWindow business service using the inbound web service.
W1-CMFieldActivityLocation
Used to search field activities by Activity location.
This component calls the CM-ActivityLocation business service using the Inbound Web Service.
W1-CMFieldActivityInformation
Used to search field activities by Activity information.
This component calls CM-FieldActivityInformation business service using the inbound web service.
W1-CMPermitByInfo
Used to search permit by information.
This component calls the CM-PERMITQ1 business service using the Inbound Web Service.
W1-CMPermitByIdentifier
Used to search permit by identifier.
This component calls CM-PERMITQ2 business service using the inbound web service.
W1-CMActivityGenByInfo
Used to search activity generator data by information.
This component calls the CM-WOQ1 business service using the Inbound Web Service.
W1-CMActivityGenByIdentifier
Used to search activity generator by identifier.
This component calls CM-WOQ2 business service using the inbound web service.
W1-CMActivityGenByTemplateInfo
Used to search activity generator by template information.
This component calls CM-WOQ3 business service using the inbound web service.
W1-CMActivityGenBySrvSchdInfo
Used to search activity generator using Service schedule information.
This component calls the CM-WOQ4 business service using the Inbound Web Service.
W1-CMCopyNRebalanceActAstList
Used to perform Copy and Rebalance of Work Activity Asset List.
This component calls 'CM-CPNRBAST' service script using the inbound web service.
W1-CMSCHEDULEDCREWSHIFTBYACTIVITYID
Used to search crew shit using a activity ID.
This component calls CM-ACTSCHLRQ business service using the inbound web service.
W1-CMWorkActivityByMaintSchedule
Trigger
Used to search work activity details associated with a maintenance schedule trigger.
This component calls CM-WAMSMT business service using the inbound web service.
W1-CMCommonWoActCostCalc
Used to fetch cost details for a Construction Work Activity.
This component calls W1-CommonWoActCostCalc business service using the inbound web service.
W1-GetWOFrmAssetId
Used to fetch Workorder ID from Asset ID.
This component calls CM-WACTQ1-WO business service using the inbound web service.
Resource Management
Component
Description
W1-CMCrewShiftByServiceInfo
Used to search crew shift by service info in the WAM application.
This component calls the CM-CRSHFQ1 business service using thee Inbound web service.
W1-CMCrewShiftByCrewInfo
Used to search crew shift by crew info in the WAM application.
This component calls the CM-CRSHFQ2 business service using thee Inbound web service.
W1-CMCrewShiftByIndentifier
Used to search crew shift by identifier in the WAM application.
This component calls the CM-CRSHFQ3 business service using thee Inbound web service.
W1-CMCrewShiftBySchdPlanInfo
Used to search crew shift by scheduled Plan information in the WAM application.
This component calls the CM-CRSHFQ4 business service using thee Inbound web service.
W1-CMChangeReqByInfo
Used to search change request by information in the WAM application.
This component calls the CM-CHGREQQ1 business service using thee Inbound web service.
W1-CMChangeReqByRelatedObj
Used to search change request by related object information in the WAM application.
This component calls the CM-CHGREQQ2 business service using thee Inbound web service.
W1-CMChangeReqByIdentifier
Used to search change request by identifier in the WAM application.
This component calls the CM-CHGREQQ3 business service using thee Inbound web service.
Invoicing
Component
Description
W1-InvoiceHeader
Used to create, update, read, or delete InvoiceHeader in the WAM application.
This component calls the W1-InvoiceHeader business object using the Inbound Web Service.
W1-InvoiceLine
Used to create, update, read, or delete InvoiceLine in the WAM application.
This component calls the W1-InvoiceLine business object using the Inbound Web Service.
W1-CMInvoiceHeaderInformation
Used to search Invoice header information in the WAM application.
This component calls the CM-INVCHDRQ1 business service using the Inbound Web Service.
W1-CMInvoiceHeaderIdentifier
Used to search invoice using identifier in the WAM application.
This component calls the CM-INVCHDRQ2 business service using the Inbound Web Service.
W1-CMInvoiceLineInformation
Used to search invoice using line information in the WAM application.
This component calls the CM-INVCHDRQ3 business service using the Inbound Web Service.
Integration
Component
Description
W1- ReadAssetLocationId
Used to read an Asset Location ID (asset node) using an External ID.
This component calls the CM-ASTLOCID business service using the Inbound Web Service (ATW1READASSETLOCID).
W1-SIDIntegInbound
Used to create, update, read, or delete SIDIntegInbound in the WAM application.
This component calls the W1-SIDIntegInbound business object using the Inbound Web Service.
W1-CMAssetQuery
Used to for fetching asset location, asset details using GIS ID, Asset and Node information in the WAM application.
This component calls the W1-AssetQry business service using the Inbound Web Service.
W1-ServiceHistoryWAMConv
Used to create, update, read, or delete ServiceHistoryWAMConv in the WAM application.
This component calls the W1-ServiceHistoryWAMConv business object using the Inbound Web Service.
W1-CMRETCOMIDSQL
Used to fetch the latest Inbound Communication ID based communication type in the WAM application.
This component calls the CM-RETCOMID business service using the Inbound Web Service.
W1-ReadServiceHistoryId
Used to read an Service History ID (install event from Oracle Utilities Meter Data Management) using an External ID.
This component calls the CM-READSRVHSTID business service using the Inbound Web Service (ATW1READSRVHSTID).
W1- ReadContact
Used to read a Contact using an External ID.
This component calls the CM-READCNCT business service using the Inbound Web Service (ATW1READCONTACT).
W1-CMActivityMaterialUsage
Used to create, update and read an Activity Material Usage in the WAM application.
This component calls the It calls W1-ActivityMaterialUsage BO internally.
W1-VendorLocIntegOutbound
Used to create, update, read, or delete VendorLocIntegOutbound in the WAM application.
This component calls the W1-VendorLocIntegOutbound business object using the Inbound Web Service.
W2-FirmwareUpgradeOutboundMsg
Used to create, update, read, or delete FirmwareUpgradeOutboundMsg in the WAM application.
This component calls the W2-FirmwareUpgradeOutboundMsg business object using the Inbound Web Service.
W1-SynchronizationAddExpCode
Used to create, update, read, or delete SynchronizationAddExpCode in the WAM application.
This component calls the W1-SynchronizationAddExpCode business object using the Inbound Web Service.
W1-SynchronizationAddEmployee
Used to create, update, read, or delete SynchronizationAddEmployee in the WAM application.
This component calls the W1-SynchronizationAddEmployee business object using the Inbound Web Service.
W1-SynchronizationAddCostCtr
Used to create, update, read, or delete SynchronizationAddCostCtr in the WAM application.
This component calls the W1-SynchronizationAddCostCtr business object using the Inbound Web Service.
W1-SyncRequestSeeder
Used to create, update, read, or delete SyncRequestSeeder in the WAM application.
This component calls the W1-SyncRequestSeeder business object using the Inbound Web Service.
W1-SynchronizationAddVendorLoc
Used to create, update, read, or delete SynchronizationAddVendorLoc in the WAM application.
This component calls the W1-SynchronizationAddVendorLoc business object using the Inbound Web Service.
W1-SyncRequest
Used to create, update, read, or delete SyncRequest in the WAM application.
This component calls the W1-SyncRequest business object using the Inbound Web Service.
W1-StockTransIntegInbound
Used to create, update, read, or delete StockTransIntegInbound in the WAM application.
This component calls the W1-StockTransIntegInbound business object using the Inbound Web Service.
W1-SIDIntegInbound
W1-ReceiptHeaderIntegration
Used to create, update, read, or delete ReceiptHeaderIntegration in the WAM application.
This component calls the W1-ReceiptHeaderIntegration business object using the Inbound Web Service.
W1-PurchaseReturnLineInteg
Used to create, update, read, or delete PurchaseReturnLineInteg in the WAM application.
This component calls the W1-PurchaseReturnLineInteg business object using the Inbound Web Service.
W1-PurchaseReturnIntegInbound
Used to create, update, read, or delete PurchaseReturnIntegInbound in the WAM application.
This component calls the W1-PurchaseReturnIntegInbound business object using the Inbound Web Service.
W1-PurchaseReqIntegOutbound
Used to create, update, read, or delete PurchaseReqIntegOutbound in the WAM application.
This component calls the W1-PurchaseReqIntegOutbound business object using the Inbound Web Service.
W1-PurReqIntegOutMsg
Used to create, update, read, or delete PurReqIntegOutMsg in the WAM application.
This component calls the W1-PurReqIntegOutMsg business object using the Inbound Web Service.
W1-OutboundAcknowledgeMessage
Used to create, update, read, or delete OutboundAcknowledgeMessage in the WAM application.
This component calls the W1-OutboundAcknowledgeMessage business object using the Inbound Web Service.
W1-OngoingSyncRequestLocation
Used to create, update, read, or delete OngoingSyncRequestLocation in the WAM application.
This component calls the W1-OngoingSyncRequestLocation business object using the Inbound Web Service.
W1-OngoingSyncRequestAsset
Used to create, update, read, or delete OngoingSyncRequestAsset in the WAM application.
This component calls the W1-OngoingSyncRequestAsset business object using the Inbound Web Service.
W1-NdAsAttToAsOutboundMessage
Used to create, update, read, or delete NdAsAttToAsOutboundMessage in the WAM application.
This component calls the W1-NdAsAttToAsOutboundMessage business object using the Inbound Web Service.
W1-MatlReqIntegOutMsg
Used to create, update, read, or delete MatlReqIntegOutMsg in the WAM application.
This component calls the W1-MatlReqIntegOutMsg business object using the Inbound Web Service.
W1-MaterialReturnHeaderInteg
Used to create, update, read, or delete MaterialReturnHeaderInteg in the WAM application.
This component calls the W1-MaterialReturnHeaderInteg business object using the Inbound Web Service.
W1-MaterialReturnIntegInbound
Used to create, update, read, or delete MaterialReturnIntegInbound in the WAM application.
This component calls the W1-MaterialReturnIntegInbound business object using the Inbound Web Service.
W1-MaterialReturnLineInteg
Used to create, update, read, or delete MaterialReturnLineInteg in the WAM application.
This component calls the W1-MaterialReturnLineInteg business object using the Inbound Web Service.
W1-OngoingSyncRequestContact
Used to create, update, read, or delete OngoingSyncRequestContact in the WAM application.
This component calls the W1-OngoingSyncRequestContact business object using the Inbound Web Service.
W1-OngoingSyncRequestVendorLoc
Used to create, update, read, or delete OngoingSyncRequestVendorLoc in the WAM application.
This component calls the W1-OngoingSyncRequestVendorLoc business object using the Inbound Web Service.
W1-MaterialIssueLineInteg
Used to create, update, read, or delete MaterialIssueLineInteg in the WAM application.
This component calls the W1-MaterialIssueLineInteg business object using the Inbound Web Service.
W1-MaterialIssueIntegInbound
Used to create, update, read, or delete MaterialIssueIntegInbound in the WAM application.
This component calls the W1-MaterialIssueIntegInbound business object using the Inbound Web Service.
W1-InvoiceLineIntegration
Used to create, update, read, or delete InvoiceLineIntegration in the WAM application.
This component calls the W1-InvoiceLineIntegration business object using the Inbound Web Service.
W1-InvoiceIntegOutbound
Used to create, update, read, or delete InvoiceIntegOutbound in the WAM application.
This component calls the W1-InvoiceIntegOutbound business object using the Inbound Web Service.
W1-InvoicePaymentIntegInbound
Used to create, update, read, or delete InvoicePaymentIntegInbound in the WAM application.
This component calls the W1-InvoicePaymentIntegInbound business object using the Inbound Web Service.
W1-InvoiceIntegOutMsg
Used to create, update, read, or delete InvoiceIntegOutMsg in the WAM application.
This component calls the W1-InvoiceIntegOutMsg business object using the Inbound Web Service.
W1-InititialSyncReqWorkLoc
Used to create, update, read, or delete InititialSyncReqWorkLoc in the WAM application.
This component calls the W1-InititialSyncReqWorkLoc business object using the Inbound Web Service.
W1-AcceptLineIntegration
Used to create, update, read, or delete AcceptLineIntegration in the WAM application.
This component calls the W1-AcceptLineIntegration business object using the Inbound Web Service.
W1-ActivityOutboundSyncRequest
Used to create, update, read, or delete ActivityOutboundSyncRequest in the WAM application.
This component calls the W1-ActivityOutboundSyncRequest business object using the Inbound Web Service.
W1-AssessGrpConv
Used to create, update, read, or delete AssessGrpConv in the WAM application.
This component calls the W1-AssessGrpConv business object using the Inbound Web Service.
W1-AssetBusinessFlag
Used to create, update, read, or delete AssetBusinessFlag in the WAM application.
This component calls the W1-AssetBusinessFlag business object using the Inbound Web Service.
W1-BlanketContractIntegInbound
Used to create, update, read, or delete BlanketContractIntegInbound in the WAM application.
This component calls the W1-BlanketContractIntegInbound business object using the Inbound Web Service.
W1-BusinessFlagType
Used to create, update, read, or delete BusinessFlagType in the WAM application.
This component calls the W1-BusinessFlagType business object using the Inbound Web Service.
W1-CMRTBFIDEXT
Used to read CMRTBFIDEXT in the WAM application.
This component calls the W1-CMRTBFIDEXT business service using the Inbound Web Service.
W1-CompositeSyncReqCmdtyName
Used to create, update, read, or delete CompositeSyncReqCmdtyName in the WAM application.
This component calls the W1-CompositeSyncReqCmdtyName business object using the Inbound Web Service.
W1-CompositeSyncReqCmdtyType
CompositeSyncReqCmdtyType in the WAM application.
This component calls the W1-CompositeSyncReqCmdtyType business object using the Inbound Web Service.
W1-CompositeSyncReqGISAsset
Used to create, update, read, or delete CompositeSyncReqGISAsset in the WAM application.
This component calls the W1-CompositeSyncReqGISAsset business object using the Inbound Web Service.
W1-CreateMobileWOInboundComm
Used to create, update, read, or delete CreateMobileWOInboundComm in the WAM application.
This component calls the W1-CreateMobileWOInboundComm business object using the Inbound Web Service.
W1-ErpIntegration
Used to create, update, read, or delete ErpIntegration in the WAM application.
This component calls the W1-ErpIntegration business object using the Inbound Web Service.
W1-FinancialTransIntegInbound
Used to create, update, read, or delete FinancialTransIntegInbound in the WAM application.
This component calls the W1-FinancialTransIntegInbound business object using the Inbound Web Service.
W1-FinancialTransIntegOutMsg
Used to create, update, read, or delete FinancialTransIntegOutMsg in the WAM application.
This component calls the W1-FinancialTransIntegOutMsg business object using the Inbound Web Service.
W1-FinancialTransIntegOutbound
Used to create, update, read, or delete FinancialTransIntegOutbound in the WAM application.
This component calls the W1-FinancialTransIntegOutbound business object using the Inbound Web Service.
W1-FldwrkPIPActFinalOutMsg
Used to create, update, read, or delete FldwrkPIPActFinalOutMsg in the WAM application.
This component calls the W1-FldwrkPIPActFinalOutMsg business object using the Inbound Web Service.
W1-FldwrkPIPActMaintOutMsg
Used to create, update, read, or delete FldwrkPIPActMaintOutMsg in the WAM application.
This component calls the W1-FldwrkPIPActMaintOutMsg business object using the Inbound Web Service.
W1-GISAssetSyncReqOutMsg
Used to create, update, read, or delete GISAssetSyncReqOutMsg in the WAM application.
This component calls the W1-GISAssetSyncReqOutMsg business object using the Inbound Web Service.
W1-GISAssetSyncRequest
GISAssetSyncRequest in the WAM application.
This component calls the W1-GISAssetSyncRequest business object using the Inbound Web Service.
W1-GISWorkLocSyncReqOutMsg
Used to create, update, read, or delete GISWorkLocSyncReqOutMsg in the WAM application.
This component calls the W1-GISWorkLocSyncReqOutMsg business object using the Inbound Web Service.
W1-GISWorkLocSyncRequest
Used to create, update, read, or delete GISWorkLocSyncRequest in the WAM application.
This component calls the W1-GISWorkLocSyncRequest business object using the Inbound Web Service.
W1-InitialSyncReqActivity
InitialSyncReqActivity in the WAM application.
This component calls the W1-InitialSyncReqActivity business object using the Inbound Web Service.
W1-InitialSyncReqCommodityCat
Used to create, update, read, or delete InitialSyncReqCommodityCat in the WAM application.
This component calls the W1-InitialSyncReqCommodityCat business object using the Inbound Web Service.
W1-InitialSyncReqCommodityName
Used to create, update, read, or delete InitialSyncReqCommodityName in the WAM application.
This component calls the W1-InitialSyncReqCommodityName business object using the Inbound Web Service.
W1-InitialSyncReqCommodityType
Used to create, update, read, or delete InitialSyncReqCommodityType in the WAM application.
This component calls the W1-InitialSyncReqCommodityType business object using the Inbound Web Service.
W1-InitialSyncReqCostCenter
Used to create, update, read, or delete InitialSyncReqCostCenter in the WAM application.
This component calls the W1-InitialSyncReqCostCenter business object using the Inbound Web Service.
W1-InitialSyncReqExpenseCode
Used to create, update, read, or delete InitialSyncReqExpenseCode in the WAM application.
This component calls the W1-InitialSyncReqExpenseCode business object using the Inbound Web Service.
W1-InitialSyncReqMaintSchedule
Used to create, update, read, or delete InitialSyncReqMaintSchedule in the WAM application.
This component calls the W1-InitialSyncReqMaintSchedule business object using the Inbound Web Service.
W1-InitialSyncReqManufacturer
Used to create, update, read, or delete InitialSyncReqManufacturer in the WAM application.
This component calls the W1-InitialSyncReqManufacturer business object using the Inbound Web Service.
W1-InitialSyncReqPMTrigger
Used to create, update, read, or delete InitialSyncReqPMTrigger in the WAM application.
This component calls the W1-InitialSyncReqPMTrigger business object using the Inbound Web Service.
W1-InitialSyncReqPlanner
Used to create, update, read, or delete InitialSyncReqPlanner in the WAM application.
This component calls the W1-InitialSyncReqPlanner business object using the Inbound Web Service.
W1-InitialSyncReqProject
Used to create, update, read, or delete InitialSyncReqProject in the WAM application.
This component calls the W1-InitialSyncReqProject business object using the Inbound Web Service.
W1-InitialSyncReqServiceHist
Used to create, update, read, or delete InitialSyncReqServiceHist in the WAM application.
This component calls the W1-InitialSyncReqServiceHist business object using the Inbound Web Service.
W1-InitialSyncReqSpecification
Used to create, update, read, or delete InitialSyncReqSpecification in the WAM application.
This component calls the W1-InitialSyncReqSpecification business object using the Inbound Web Service.
W1-InitialSyncReqTmplActivity
Used to create, update, read, or delete InitialSyncReqTmplActivity in the WAM application.
This component calls the W1-InitialSyncReqTmplActivity business object using the Inbound Web Service.
W1-InitialSyncReqTmplWorkOrder
Used to create, update, read, or delete InitialSyncReqTmplWorkOrder in the WAM application.
This component calls the W1-InitialSyncReqTmplWorkOrder business object using the Inbound Web Service.
W1-InitialSyncReqWorkOrder
Used to create, update, read, or delete InitialSyncReqWorkOrder in the WAM application.
This component calls the W1-InitialSyncReqWorkOrder business object using the Inbound Web Service.
W1-InitialSyncRequestAsset
Used to create, update, read, or delete InitialSyncRequestAsset in the WAM application.
This component calls the W1-InitialSyncRequestAsset business object using the Inbound Web Service.
W1-InitialSyncRequestContact
Used to create, update, read, or delete InitialSyncRequestContact in the WAM application.
This component calls the W1-InitialSyncRequestContact business object using the Inbound Web Service.
W1-InitialSyncRequestLocation
Used to create, update, read, or delete InitialSyncRequestLocation in the WAM application.
This component calls the W1-InitialSyncRequestLocation business object using the Inbound Web Service.
W1-InterfaceODCInboundComm
Used to create, update, read, or delete InterfaceODCInboundComm in the WAM application.
This component calls the W1-InterfaceODCInboundComm business object using the Inbound Web Service.
W1-InvoiceIntegInbound
Used to create, update, read, or delete InvoiceIntegInbound in the WAM application.
This component calls the W1-InvoiceIntegInbound business object using the Inbound Web Service.
W1-MDMAssetSyncReqOutMsg
Used to create, update, read, or delete MDMAssetSyncReqOutMsg in the WAM application.
This component calls the W1-MDMAssetSyncReqOutMsg business object using the Inbound Web Service.
W1-MDMAssetSyncRequest
Used to create, update, read, or delete MDMAssetSyncRequest in the WAM application.
This component calls the W1-MDMAssetSyncRequest business object using the Inbound Web Service.
W1-MaterialReqIntegOutbound
Used to create, update, read, or delete MaterialReqIntegOutbound in the WAM application.
This component calls the W1-MaterialReqIntegOutbound business object using the Inbound Web Service.
W1-ReceiptLineIntegration
Used to create, update, read, or delete ReceiptLineIntegration in the WAM application.
This component calls the W1-ReceiptLineIntegration business object using the Inbound Web Service.
W1-UpgDeviceOutboundMessage
Used to create, update, read, or delete UpgDeviceOutboundMessage in the WAM application.
This component calls the W1-UpgDeviceOutboundMessage business object using the Inbound Web Service.
W1-VendorLocIntegOutMsg
Used to create, update, read, or delete VendorLocIntegOutMsg in the WAM application.
This component calls the W1-VendorLocIntegOutMsg business object using the Inbound Web Service.
W2-FirmwareCommandOutbound
Used to create, update, read, or delete FirmwareCommandOutbound in the WAM application.
This component calls the W2-FirmwareCommandOutbound business object using the Inbound Web Service.
W1-SyncRequest
W1-ReceiptIntegInbound
Used to create, update, read, or delete ReceiptInboundIntegration in the WAM application.
This component calls the W1- ReceiptIntegInbound business object using Inbound Web Service.
W1- InterfaceTSDInboundComm
Used to create, update, read, or delete InterfaceTSDInboundComm in the WAM application.
This component calls the W1-InterfaceTSDInboundComm business object using Inbound Web Service.
W1-LeaveInt
Used to create, update, read, or delete LeaveInt in the WAM application.
This component calls the W1-LeaveInt business object using Inbound Web Service.
W1-OngoingSyncRequestCostCtr
Used to create, update, read, or delete OngoingSyncRequestCostCtr in the WAM application.
This component calls the W1-OngoingSyncRequestCostCtr business object using Inbound Web Service.
W1-OngoingSyncRequestEmployee
Used to create, update, read, or delete OngoingSyncRequestEmployeein the WAM application.
This component calls the W1-OngoingSyncRequestEmployee business object using Inbound Web Service.
W1-OngoingSyncRequestAssetNode
Used to create, update, read, or delete OngoingSyncRequestAssetNode in the WAM application.
This component calls the W1-OngoingSyncRequestAssetNode business object using Inbound Web Service.
W1-OngoingSyncRequestStockItem
Used to create, update, read, or delete OngoingSyncRequestStockItem in the WAM application.
This component calls the W1-OngoingSyncRequestStockItem business object using Inbound Web Service.
W1-PurchaseOrderIntegInbound
Used to create, update, read, or delete PurchaseOrderIntegInbound in the WAM application.
This component calls the W1-PurchaseOrderIntegInbound business object using Inbound Web Service.
W1-IntODCDtl
Used to create Other direct charges from Oracle Field Service (OFS).
This component calls W1-IntCODtl script using an inbound web service.
W1-CreateMobileWorkOrder
Used to create Mobile Work Order from OFS with Work It flag.
This component calls W1-CreMobWo script using an inbound web service.
W1-IntTMSDtl
Used to create time sheet from OFS.
This component calls W1-IntCTMSDt script using an inbound web service.
W1-SyncReqStockItemByExternalId
Used to retrieve sync request id by External Reference ID and External System.
This component calls the CM-OngoingSyncRequestStockItem business service using Inbound Web Service.
Construction Work Management
Component
Description
W1-ActivityReconciliation
Used to create, update, read, or delete ActivityReconciliation in the WAM application.
This component calls the W1-ActivityReconciliation business object using the ATW1ActivityReconciliation Inbound Web Service.
W1-RTNCSVCCL
Used to read RTNCSVCCL in the WAM application.
This component calls the W1-RTNCSVCCL business service using the Inbound Web Service.
W1-RTASSETCU
Used to read RTASSETCU in the WAM application.
This component calls the W1-RTASSETCU business service using the Inbound Web Service.
W1-ConstructionLoc
Used to create, update, read, or delete Construction Location in the WAM application.
This component calls the W1-Construction Location business object using the ATW1ConstructionLocation Inbound Web Service.
W1-ConstructionWorkActivity
Used to create, update, read, or delete ConstructionWorkActivity in the WAM application.
This component calls the W1-ConstructionWorkActivity business object using the ATW1ConstructionWorkActivity Inbound Web Service.
W1-TmplConstructionActivity
Used to create, update, read, or delete Template ConstructionWorkActivity in the WAM application.
This component calls the W1-TmplConstructionActivity business object using the ATW1TmplConstructionActivity Inbound Web Service.
W1-ConstructionWorkOrder
Used to create, update, read, or delete ConstructionWorkOrder in the WAM application.
This component calls the W1-ConstructionWorkOrder business object using the ATW1ConstructionWorkActivity Inbound Web Service.
W1-TmplConstructionWorkOrder
Used to create, update, read, or delete Template Construction Work Order in the WAM application.
This component calls the W1-TmplConstructionWorkOrder business object using ATW1TmplConstructionWorkOrder inbound web service.
W1-ConstrWorkActivityType
Used to create, update, read, or delete ConstrWorkActivityType in the WAM application.
This component calls the W1-ConstrWorkActivityType business object using the ATW1ConstrWorkActivityType Inbound Web Service.
W1-ContractorBid
Used to create, update, read, or delete ContractorBid in the WAM application.
This component calls the W1-ContractorBid business object using the ATW1ContractorBid Inbound Web Service.
W1-ContractorBidNotes
Used to create, update, read, or delete ContractorBidNotes in the WAM application.
This component calls the W1-ContractorBidNotes business object using the ATW1ContractorBidNotes Inbound Web Service.
W1-ContractorBidRefAttachments
Used to create, update, read, or delete ContractorBidRefAttachments in the WAM application.
This component calls the W1- ContractorBidRefAttachments business object using the ATW1ContractorBidRefAttachments Inbound Web Service.
W1-CrewTypeCUEquipmentProfile
Used to create, update, read, or delete CrewTypeCUEquipmentProfile in the WAM application.
This component calls the W1- CrewTypeCUEquipmentProfile business object using the ATW1CrewTypeCUEquipmentProfile Inbound Web Service.
W1-CrewTypeCULaborProfile
Used to create, update, read, or delete CrewTypeCULaborProfile in the WAM application.
This component calls the W1-CrewTypeCULaborProfile business object using the ATW1CrewTypeCULaborProfile Inbound Web Service.
W1-CrewTypeCUProfile
Used to create, update, read, or delete CrewTypeCUProfile in the WAM application.
This component calls the W1- CrewTypeCUProfile business object using the ATW1CrewTypeCUProfile Inbound Web Service.
W1-CU
Used to create, update, read, or delete Compatibility Unit in the WAM application.
This component calls the W1- CU business object using the ATW1CU Inbound Web Service.
W1-CUCategory
Used to create, update, read, or delete CUCategory in the WAM application.
This component calls the W1- CUCategory business object using the ATW1CUCategory Inbound Web Service.
W1-CULaborAndEquipment
Used to create, update, read, or delete CULaborAndEquipment in the WAM application.
This component calls the W1- CULaborAndEquipment business object using the ATW1CULaborAndEquipment Inbound Web Service.
W1-CUMaterialResources
Used to create, update, read, or delete CUMaterialResources in the WAM application.
This component calls the W1- CUMaterialResources business object using the ATW1CUMaterialResources Inbound Web Service.
W1-CUMaterialsForRemoval
Used to create, update, read, or delete CUMaterialsForRemoval in the WAM application.
This component calls the W1- CUMaterialsForRemoval business object using the ATW1CUMaterialsForRemoval Inbound Web Service.
W1-CUNotes
Used to create, update, read, or delete CUNotes in the WAM application.
This component calls the W1- CUNotes business object using the ATW1CUNotes Inbound Web Service.
W1-CURefAttachments
Used to create, update, read, or delete CURefAttachments in the WAM application.
This component calls the W1-CURefAttachments business object using the ATW1CURefAttachments Inbound Web Service.
W1-CompatibleUnitSet
Used to create, update, read, or delete CUSET in the WAM application.
This component calls the W1- CUSET business object using the ATW1CUSET Inbound Web Service.
W1-CUSetNotes
Used to create, update, read, or delete CUSetNotes in the WAM application.
This component calls the W1- CUSetNotes business object using the ATW1CUSetNotes Inbound Web Service.
W1-CUSetRefAttachments
Used to create, update, read, or delete CUSetRefAttachments in the WAM application.
This component calls the W1- CUSetRefAttachments business object using the ATW1CUSetRefAttachments Inbound Web Service.
W1-CUUsage
Used to create, update, read, or delete CUUsage in the WAM application.
This component calls the W1- CUUsage business object using the ATW1CUUsage Inbound Web Service.
W1-DeleteGeneralProcessRecord
Used to read DeleteGeneralProcessRecord in the WAM application.
This component calls the W1-DeleteGeneralProcessRecord business service using the ATW1DeleteGeneralProcessRecord Inbound Web Service.
W1-DesignElement
Used to create, update, read, or delete DesignElement in the WAM application.
This component calls the W1-DesignElement business object using the ATW1DesignElement Inbound Web Service.
W1-DesignElementCU
Used to create, update, read, or delete DesignElementCU in the WAM application.
This component calls the W1-DesignElementCU business object using the ATW1DesignElementCU Inbound Web Service.
W1-DesignElementItems
Used to create, update, read, or delete DesignElementItems in the WAM application.
This component calls the W1- DesignElementItems business object using the ATW1DesignElementItems Inbound Web Service.
W1-EquipmentGroup
Used to create, update, read, or delete EquipmentGroup in the WAM application.
This component calls the W1- EquipmentGroup business object using the ATW1EquipmentGroup Inbound Web Service.
W1-Overhead
Used to create, update, read, or delete Overhead in the WAM application.
This component calls the W1- Overhead business object using the ATW1Overhead Inbound Web Service.
W1-PropUnit
Used to create, update, read, or delete Property Unit in the WAM application.
This component calls the W1-PropUnit object using the ATW1PropUnit Inbound Web Service.
W1-PropUnitBundlingAddBO
Used to create, update, read, or delete Property Unit Bundling in the WAM application.
This component calls the W1-PropUnitBundlingAddBO object using the ATW1PropUnitBundlingAddBO Inbound Web Service.
W1-PropUnitPhysicalBO
Used to create, update, read, or delete Property Unit physical in the WAM application.
This component calls the W1- PropUnitPhysicalBO object using the ATW1PropUnitPhysicalBO Inbound Web Service.
W1-RETCLCUCC
Used to read/retrieve Construction Location Expanded CU/Cost Center in the WAM application.
This component calls the W1-RETCLCUCC business service using the ATW1RETCLCUCC Inbound Web Service.
W1-RETCUHIER
Used to read/retrieve CU Hierarchy in the WAM application.
This component calls the W1-RETCUHIER business service using the ATW1RETCUHIER Inbound Web Service.
W1-RETCURESO
Used to read/retrieve CU Resources in the WAM application.
This component calls the W1-RETCURESO business service using the ATW1RETCURESO Inbound Web Service.
W1-RETDEHIER
Used to read/retrieve Design Element Hierarchy in the WAM application.
This component calls the W1-RETDEHIER business service using the ATW1RETDEHIER Inbound Web Service.
W1-RETREFCU
Used to read/retrieve Referencing CU with Property Unit in the WAM application.
This component calls the W1-RETREFCU business service using the ATW1RETREFCU Inbound Web Service.
W1-RETREFDCU
W1-RETWDDE
Used to read/retrieve Design in the WAM application.
This component calls the W1-RETWDDE business service using the ATW1RETWDDE Inbound Web Service.
W1-RNCACTRRQ
Used to read/retrieve Non-Cancelled Activity Resource Requirement for Resource Type/Stock Item in the WAM application.
This component calls the W1- RNCACTRRQ business service using the ATW1RNCACTRRQ Inbound Web Service.
W1-RSTITAUPR
Used to read/retrieve Stock Item Average Unit Price in the WAM application.
This component calls the W1-RSTITAUPR business service using the ATW1RSTITAUPR Inbound Web Service.
W1-RTACONLAS
Used to read/retrieve Activity Construction Location Assets in the WAM application.
This component calls the W1-RTACONLAS business service using the ATW1RTACONLAS Inbound Web Service.
W1-RTACTACGL
Used to read/retrieve Activity Actual Cost Grouped by GL Entry in the WAM application.
This component calls the W1-RTACTACGL business service using the ATW1RTACTACGL Inbound Web Service.
W1-RTACTACRC
This component calls the W1-RTACTACRC business service using the ATW1RTACTACRC Inbound Web Service.
W1-RTACTRCON
Used to read/retrieve Activity Reconciliation for an Activity in the WAM application.
This component calls the W1-RTACTRCON business service using the ATW1RTACTRCON Inbound Web Service.
W1-RTCBASTPU
Used to read/retrieve Contributed Asset Property Unit in the WAM application.
This component calls the W1-RTCBASTPU business service using the ATW1RTCBASTPU Inbound Web Service.
W1-RTCCCUUSG
Used to read/retrieve Cost Center for Usage in the WAM application.
This component calls the W1-RTCCCUUSG business service using the ATW1RTCCCUUSG Inbound Web Service.
W1-RTCNASTPU
Used to read/retrieve Constructed Asset for a Property Unit in the WAM application.
This component calls the W1- RTCNASTPU business service using the ATW1RTCNASTPU Inbound Web Service.
W1-RTCONLACU
Used to read/retrieve Construction Location Applicable CU's in the WAM application.
This component calls the W1- RTCONLACU business service using the ATW1RTCONLACU Inbound Web Service.
W1-RTCRACTTY
Used to read/retrieve Construction Related Activity Types in the WAM application.
This component calls the W1-RTCRACTTY business service using the ATW1RTCRACTTY Inbound Web Service.
W1-RTCUSTCU
Used to read/retrieve CU Set CU's in the WAM application.
This component calls the W1- RTCUSTCU business service using the ATW1RTCUSTCU Inbound Web Service.
W1-RTEASTISD
Used to read/Retrieve Earliest Asset In Service Date in the WAM application.
This component calls the W1- RTEASTISD business service using the ATW1RTEASTISD Inbound Web Service.
W1-RTNFODCDT
Used to read/retrieve Non-Final ODC Details in the WAM application.
This component calls the W1-RTNFODCDT business service using the ATW1RTNFODCDT Inbound Web Service.
W1-RTNFTSDTL
Used to read/retrieve Non-Final Timesheet Details in the WAM application.
This component calls the W1-RTNFTSDTL business service using the ATW1RTNFTSDTL Inbound Web Service.
W1-RTNFWOACT
Used to read/retrieve Non-Final Non-Overhead Activities in the WAM application.
This component calls the W1- RTNFWOACT business service using the ATW1RTNFWOACT Inbound Web Service.
W1-RTPRCPAST
Used to read/retrieve Pre-Capitalized Assets in the WAM application.
This component calls the W1- RTPRCPAST business service using the ATW1RTPRCPAST Inbound Web Service.
W1-RTVLTASTY
Used to read/retrieve Valid Location Type for Asset Type in the WAM application.
This component calls the W1- RTVLTASTY business service using the ATW1RTVLTASTY Inbound Web Service.
W1-WDRefAttachments
Used to create, update, read, or delete Work Design RefAttachments in the WAM application.
This component calls the W1-WDRefAttachments object using the ATW1WDRefAttachments Inbound Web Service.
W1-WorkDesign
Used to create, update, read, or delete Work Design in the WAM application.
This component calls the W1-WorkDesign object using the ATW1WorkDesign Inbound Web Service.
W1-WorkDesignNotes
Used to create, update, read, or delete WorkDesignNotes in the WAM application.
This component calls the W1-WorkDesignNotes object using the ATW1WorkDesignNotes Inbound Web Service.
W1-CWM-RetriveReconID
Used to read/retrieving Activity Reconcilition ID from Activity in the WAM application.
This component calls the ATW1RTARID business service using the ATW1RTARID Inbound Web Service.
W1-DTOHCSTSQL
Used to read/retrieve Direct Overhead Cost for Activity in the WAM application.
This component calls the CM-DTOHCST business service using the ATW1DTOHCST Inbound Web Service.
W1- IDTOHCSTSQL
Used to read/retrieve InDirect Overhead cost for the activity in the WAM Application.
This component calls the CM-IDTOHCST business service using the ATW1IDTOHCST Inbound Web Service.
W1-CUAccessory
Used to create, update, read, or delete Accessory CU in the WAM application.
This component calls the W1-CUAccessory object using the ATW1CUAccessory Inbound Web Service.
W1-CUFunction
Used to create, update, read, or delete Functional CU in the WAM application.
This component calls the W1-CUFunction object using the ATW1CUFunction Inbound Web Service.
