Components
This section lists the starter components available for Oracle Utilities Meter Solution Cloud Service.
Pre-requisites: The Inbound Web Service using the respective business object should be available in the application.
Additional Notes: Failure while creating, reading, or updating the component is logged in the test execution report, thus facilitating debugging/analysis of the problem.
The components are categorized under the following functional areas:
• Admin
ADK Master Data
Component
Description
DG-ConDisconStChgNotification
Used to perform actions such as ADD, READ, UPDATE and DELETE a Connect Disconnect State Change Notification record.
This component invokes the DG-ConnectDisconStateChgNtfBusiness Object using the ATDGConnectDisconStateChgNtf Inbound Web Service.
DG-OutageDetectionEventNotification
Used to perform actions such as ADD, READ, UPDATE and DELETE a Outage Detection Event Notification record.
This component invokes the DG-OutageDetectEvtNotification Business Object using the ATDGOutageDetectEvtNotification Inbound Web Service.
DG-SmartMeter
Used to perform actions such as ADD, READ, UPDATE and DELETE a SmartMeter record.
This component invokes the DG- SmartMeter using the ATDGSmartMeter Inbound Web Service.
DG-ReadingChangedNotification
Used to perform actions such as ADD, READ, UPDATE and DELETE a Reading Change Notification record.
This component invokes the DG-ReadingChgNotificationBusiness Object using the ATDGReadingChgNotification Inbound Web Service.
Admin
Component
Description
W1-AssetLocationTypeAdd
Used to create an Asset Location Type record.
This component invokes the ATW1AssetLocationType Inbound Web Service using the W1-AssetLocationType business object.
W1-AssetLocationTypeDelete
Used to delete an existing Asset Location Type record.
W1-AssetLocationTypeRead
Used to query an existing Asset Location Type record.
W1-AssetLocationTypeUpdate
Used to update an existing Asset Location Type record.
This component invokes the ATW1AssetLocationType Inbound Web Service using W1-AssetLocationType business object.
D1-AggregatorRoot
Used to perform actions such as ADD, READ, UPDATE, and DELETE a AggregatorRoot.
This component invokes the D1- AggregatorRoot Business Object using the ATD1AggregatorRoot Inbound Web Service.
D1-ActivityStatsAggregator
Used to perform actions such as ADD, READ, UPDATE, and DELETE a ActivityStatsAggregator.
This component invokes the D1-ActivityStatsAggregatorBusiness Object using the ATD1ActivityStatsAggregator Inbound Service.
D1-StatsAggregator
Used to perform actions such as ADD, READ, UPDATE, and DELETE a StatsAggregator.
This component invokes the D1-StatsAggregator Business Object using the ATD1StatsAggregators Inbound Web Service.
D2-ItemAggregatorPostalSvcType
Used to perform actions such as ADD, READ, UPDATE, and DELETE a ItemAggregatorPostalSvcType.
This component invokes the D1-ItemAggregatorPostalSvcType bo using the ATD1 ItemAggregatorPostalSvcType Inbound Service.
W1-AssetTypeAdd
Used to create an Asset Type record.
This component invokes the ATW1AssetType Inbound Web Service using the W1-AssetType business object.
W1-AssetTypeDelete
Used to delete an existing Asset Type record.
W1-AssetTypeRead
Used to query an existing Asset Type record.
W1-AssetTypeUpdate
Used to update an existing Asset Type record.
This component invokes the ATW1AssetType Inbound Web Service using W1-AssetType business object.
W1-ContactTypeRead
Used to query an existing Contact Type record.
This component invokes the ATW1ContactType Inbound Web Service using the W1-ContactType business object.
W1-ComponentTypeAdd
Used to create an Operational Device Component Type record.
This component invokes the ATW1ComponentType Inbound Web Service using the W1-ComponentType business object.
W1-ComponentTypeDelete
Used to delete an existing Operational Device Component Type record.
W1-ComponentTypeRead
Used to query an existing Operational Device Component Type record.
W1-ComponentTypeUpdate
Used to update an existing Operational Device Component Type record.
This component invokes the ATW1ComponentType Inbound Web Service using W1-ComponentType business object.
W1-OrganizationAdd
Used to create an Organization record.
This component invokes the ATW1Organization Inbound Web Service using the W1-Organization business object.
W1-OrganizationDelete
Used to delete an existing Organization record.
W1-OrganizationRead
Used to query an existing Organization record.
W1-OrganizationUpdate
Used to update an existing Organization record.
This component invokes the ATW1Organization Inbound Web Service using W1-Organization business object.
W1-OrganizationTypeAdd
Used to create an Organization Type record.
This component invokes the ATW1OrganizationType Inbound Web Service using the W1-OrganizationType business object.
W1-OrganizationTypeDelete
Used to delete an existing Organization Type record.
W1-OrganizationTypeRead
Used to query an existing Organization Type record.
W1-OrganizationTypeUpdate
Used to update an existing Organization Type record.
This component invokes the ATW1OrganizationType Inbound Web Service using W1-OrganizationType business object.
W1-ServiceHistoryAdd
Used to create an Operational Device Service History record.
This component invokes the ATW1ServiceHistory Inbound Web Service using the W1-ServiceHistory business object.
W1-ServiceHistoryDelete
Used to delete an existing Operational Device Service History record.
W1-ServiceHistoryRead
Used to query an existing Operational Device Service History record.
W1-ServiceHistoryUpdate
Used to update an existing Operational Device Service History record.
This component invokes the ATW1ServiceHistory Inbound Web Service using W1-ServiceHistory business object.
W1-StorageLocationAdd
Used to create an Out of Service Location record.
This component invokes the ATW1StorageLocation Inbound Web Service using the W1-StorageLocation business object.
W1-StorageLocationDelete
Used to delete an existing Out of Service Location record.
W1-StorageLocationRead
Used to query an existing Out of Service Location record.
W1-StorageLocationUpdate
Used to update an existing Out of Service Location record.
This component invokes the ATW1StorageLocation Inbound Web Service using W1-StorageLocation business object.
W1-StorageLocationTypeAdd
Used to create an Out of Service Location Type record.
This component invokes the ATW1StorageLocationType Inbound Web Service using the W1-StorageLocationType business object.
W1-StorageLocationTypeDelete
Used to delete an existing Out of Service Location Type record.
W1-StorageLocationTypeRead
Used to query an existing Out of Service Location Type record.
W1-StorageLocationTypeUpdate
Used to update an existing Out of Service Location Type record.
This component invokes the ATW1StorageLocationType Inbound Web Service using W1-StorageLocationType business object.
W2-ServicePointRead
Used to query an existing Service Point record.
This component invokes the ATW2ServicePoint Inbound Web Service using the W2-ServicePoint business object.
W2-VehicleAdd
Used to create a Vehicle record.
This component invokes the ATW2Vehicle Inbound Web Service using the W2-Vehicle business object.
W1-VehicleDelete
Used to delete an existing Vehicle record.
W1-VehicleRead
Used to query an existing Vehicle record.
W1-VehicleUpdate
Used to update an existing Vehicle record.
This component invokes the ATW2Vehicle Inbound Web Service using W2-Vehicle business object.
W1-AssetCompCfgRptAdd
Used to create a Component Config Report record.
This component invokes the Business Object W1-AssetCompCfgRpt using the Inbound Web Service of ATW1AssetCompCfgRpt.
W1-AssetCompCfgRptDelete
Used to delete an existing Component Config Report record.
W1-AssetCompCfgRptRead
Used to query an existing Component Config Report record.
W1-AssetCompCfgRptUpdate
Used to update an existing Component Config Report record.
W1-AssetCompConfigAdd
Used to create an Asset Component Config Report record.
This component invokes the ATW1AssetCompConfig Inbound Web Service using W1-AssetCompConfig BO.
W1-AssetCompConfigDelete
Used to delete an Asset Component Config Report record.
W1-AssetCompConfigRead
Used to query an Asset Component Config Report record.
W1-AssetCompConfigUpdate
W1-AssetCompToAssetCompCfgRptAdd
Used to create an Asset Component to Asset Component Config Report record.
This component invokes the W1- ATW1AssetCompToAssetCompCfgRpt Inbound Web Service using W1-AssetCompToAssetCompCfgRpt BO.
Delete
Used to update an existing Asset Component to Asset Component Config Report record.
W1-AssetCompToAssetCompCfgRptRead
Used to update an query Asset Component to Asset Component Config Report record.
Update
Used to delete an query Asset Component to Asset Component Config Report record
W1-AssetCompToAssetConfigAdd
Used to create an Asset Component to Asset Config record.
This component invokes the ATW1AssetCompToAssetConfig Inbound Web Service using W1-AssetCompToAssetConfig BO.
W1-AssetCompToAssetConfigDelete
Used to delete an existing Asset Component to Asset Config record.
W1-AssetCompToAssetConfigRead
Used to update an existing Asset Component to Asset Config record.
W1-AssetCompToAssetConfigUpdate
Used to update an existing Asset Component to Asset Component Config record.
W1-AssetToAssetCompCfgRptAdd
Used to create an Asset to Asset Component Config Report record.
This component invokes the ATW1AssetToAssetCompCfgRpt Inbound Web Service using W1-AssetToAssetCompCfgRpt BO.
W1-AssetToAssetCompCfgRptDelete
Used to delete an existing Asset to Asset Component Config Report record.
W1-AssetToAssetCompCfgRptRead
Used to query an existing Asset to Asset Component Config Report record.
W1-AssetToAssetCompCfgRptUpdate
Used to update an existing Asset to Asset Component Config Report record.
W1-AssetToAssetConfigAdd
Used to create an Asset to Asset record.
This component invokes the ATD8StatusChangedType Inbound Web Service using D8-ReadOnDemandReadResultType BO.
W1-AssetToAssetConfigDelete
Used to delete an existing Asset to Asset record.
This component invokes the ATD8ReadOnDemandReadResultType Inbound Web Service using D8-StatusChangedType BO.
W1-AssetToAssetConfigRead
Used to query an existing Asset to Asset record.
This component invokes the ATD8StatusChangedType Inbound Web Service using D8-StatusChangedType BO.
W1-AssetToAssetConfigUdpate
Used to update an existing Asset to Asset record.
W1-ConfigTypeAdd
Used to create a Config Type record.
This component invokes the ATW1ConfigType Inbound Web Service using W1-ConfigType BO.
W1-ConfigTypeDelete
Used to delete an existing Config Type record.
W1-ConfigTypeRead
Used to query an existing Config Type record.
W1-ConfigTypeUpdate
Used to update an existing Config Type record.
W1-SingleAssetCfgRptAdd
Used to create a Single Asset Config Report record.
This component invokes the ATW1SingleAssetCfgRp Inbound Web Service using W1-SingleAssetCfgRp BO.
W1-SingleAssetCfgRptDelete
Used to delete an existing Single Asset Config Report record.
W1-SingleAssetCfgRptRead
Used to query an existing Single Asset Config Report record
W1-SingleAssetCfgRptUdpate
Used to update an existing Single Asset Config Report record.
W1-SingleAssetConfigAdd
Used to create a Single Asset Config record.
This component invokes the ATW1SingleAssetConfig Inbound Web Service using W1-SingleAssetConfig BO.
W1-SingleAssetConfigDelete
Used to delete an existing Single Asset Config record.
W1-ActivityCompletionEventTypeAdd
Used to create an Activity Completion Event Type record.
This component invokes the ATW1ActivityCompletionEventType Inbound Web Service using W1-ActivityCompletionEventType Business Object.
W1-ActivityCompletionEventTypeDelete
Used to delete an existing Activity Completion Event Type record.
W1-ActivityCompletionEventTypeRead
Used to query an existing Activity Completion Event Type record.
W1-ActivityCompletionEventTypeUpdate
Used to update an existing Activity Completion Event Type record.
W1-AssetDposCmpEvtTypeAdd
Used to create an Asset Disposition Completion Event Type record
This component invokes the ATW1AssetDposCmpEvtType Inbound Web Service using W1-AssetDposCmpEvtType Business Object.
W1-AssetDposCmpEvtTypeDelete
Used to delete an existing Asset Disposition Completion Event Type record.
W1-AssetDposCmpEvtTypeRead
Used to query an existing Asset Disposition Completion Event Type record.
W1-AssetDposCmpEvtTypeUpdate
Used to update an existing Asset Disposition Completion Event Type record
W1-BasicActivityTypeAdd
Used to create a Basic Activity Type record.
This component invokes the ATW1BasicActivityType Inbound Web Service using W1-BasicActivityType Business Object.
W1-BasicActivityTypeDel
Used to delete an existing Basic Activity Type record.
This component invokes the ATW1BasicActivityTypeInbound Web Service using W1-BasicActivityType Business Object.
W1-BasicActivityTypeRead
Used to query an existing Basic Activity Type record.
W1-BasicActivityTypeUpdate
Used to update an existing Basic Activity Type record.
W1-DataAreaCmpEvtTypeAdd
Used to create Data Area Completion Event Type record.
This component invokes the ATW1DataAreaCmpEvtType Inbound Web Service using W1-DataAreaCmpEvtType Business Object.
W1-DataAreaCmpEvtTypeDelete
Used to delete an existing Data Area Completion Event Type record.
W1-DataAreaCmpEvtTypeRead
Used to query an existing Data Area Completion Event Type record
W1-DataAreaCmpEvtTypeUpdate
Used to update an existing Data Area Completion Event Type record
W1-GeneralCommunicationAdd
Used to create a General Inbound Communication Type record.
This component invokes the ATW1GeneralCommunicationType Inbound Web Service using W1-GeneralCommunicationTypeBusiness Object.
W1-GeneralCommunicationDelete
Used to delete an existing General Inbound Communication Type record
This component invokes the ATW1GeneralCommunicationType Inbound Web Service using W1-GeneralCommunicationType Business Object.
W1-GeneralCommunicationRead
Used to query an existing General Inbound Communication Type record
W1-GeneralCommunicationUpdate
Used to update an existing General Inbound Communication Type record.
W1-GeneralCompletionEventTypeAdd
Used to create General Completion Event Type record.
This component invokes the ATW1GeneralCompletionEventType Inbound Web Service using W1-GeneralCompletionEventType Business Object.
W1-GeneralCompletionEventTypeDelete
Used to delete an existing General Completion Event Type record.
W1-GeneralCompletionEventTypeRead
Used to query an existing General Completion Event Type record
W1-GeneralCompletionEventTypeUpdate
Used to update an existing General Completion Event Type record
W1-ManufacturerAdd
Used to create a Manufacturer record.
This component invokes the ATW1Manufacturer Inbound Web Service using W1-Manufacturer Business Object.
W1-ManufacturerDelete
Used to delete an existing Manufacturer record.
W1-ManufacturerRead
Used to query an existing Manufacturer record.
W1-ManufacturerUpdate
Used to update an existing Manufacturer record.
W1-OutboundActivityTypeAdd
Used to create an Outbound Activity Type record.
This component invokes the ATW1OutboundActivityType Inbound Web Service using W1-OutboundActivityType Business Object.
W1-OutboundActivityTypeDelete
Used to delete an existing Outbound Activity Type record.
W1-OutboundActivityTypeRead
Used to query an existing Outbound Activity Type record.
This component invokes the ATW1OutboundActivityType Inbound Web Service W1-OutboundActivityType Business Object.
W1-OutboundActivityTypeUpdate
Used to update an existing Outbound Activity Type record.
W1-ReplicationComplEventTypeAdd
Used to create a Replication Completion Event Type record.
This component invokes the ATW1ReplicationComplEventType Inbound Web Service using W1-ReplicationComplEventType Business Object.
W1-ReplicationComplEventTypeDelete
Used to delete an existing Replication Completion Event Type record
W1-ReplicationComplEventTypeRead
Used to query an existing Replication Completion Event Type record
W1-ReplicationComplEventTypeUpdate
Used to update an existing Replication Completion Event Type record.
W1-ScheduledActivityTypeAdd
Used to create a Scheduled Activity Type record.
This component invokes the ATW1ScheduledActivityType Inbound Web Service using W1-ScheduledActivityType Business Object.
W1-ScheduledActivityTypeDelete
Used to delete an existing Scheduled Activity Type record.
W1-ScheduledActivityTypeRead
Used to query an existing Scheduled Activity Type record.
This component invokes the ATW1ScheduledActivityType Inbound Web Service W1-ScheduledActivityType Business Object.
W1-ScheduledActivityTypeUpdate
Used to update an existing Scheduled Activity Type record.
W1-ServiceHistTypeCmpEvtTypeAdd
Used to create a Service History Completion Event Type record.
This component invokes the ATW1ServiceHistTypeCmpEvtTypeInbound Web Service using W1-ServiceHistTypeCmpEvtType Business Object.
W1-ServiceHistTypeCmpEvtTypeDelete
Used to delete an existing Service History Completion Event Type record.
This component invokes the ATW1ServiceHistTypeCmpEvtTypeInbound Web Service W1-ServiceHistTypeCmpEvtType Business Object.
W1-ServiceHistTypeCmpEvtTypeRead
Used to query an existing Service History Completion Event Type record.
W1-ServiceHistTypeCmpEvtTypeUpdate
Used to update an existing Service History Completion Event Type record.
This component invokes the ATW1ServiceHistTypeCmpEvtType Inbound Web Service using W1-ServiceHistTypeCmpEvtType Business Object.
W1-SvcHistFromActvCmplEvtType
Add
Used to create a Service History From Activity Completion Event Type record.
This component invokes the ATW1SvcHistFromActvCmplEvtType Inbound Web Service W1-SvcHistFromActvCmplEvtType Business Object.
TypeDelete
Used to delete an existing Service History From Activity Completion Event Type record.
Read
Used to query an existing Service History From Activity Completion Event Type record.
TypeUpdate
Used to update an existing Service History From Activity Completion Event Type record.
W1-SOMActivityTypeRead
Used to query a SOM Activity Type record.
This component invokes the ATW1SOMActivityType Inbound Web Service using W1-SOMActivityType Business Object.
D2-SubIntAdjustmentVEE
Performs adjustments to consumption; the changes to consumption will be validated against the readings contained prior to and subsequent to the change made.
This component invokes the D2-SubIntAdjustmentVEE Business Object using the ATD2SubIntAdjustmentVEE Inbound Web Service.
D2-GetSubtractiveInterval
Allows the configuration of subtractive interval data retrieval during usage transaction processing. The rule records service quantities per service point and measuring component - which means that subtractive interval curves for different measuring components.
This component invokes the D2-GetSubtractiveInterval Business Object using the ATD2GetSubtractiveInterval Inbound Web Service.
D1-MeterReadDownloadActType
Used to create a MeterReadDownloadActType Activity Type.
This component invokes the D1-MeterReadDownloadActType Business Object using the ATD1MeterReadDownloadActType Inbound Web Service.
D1-PairedEventLastDvcEvtType
Used to create a PairedEventLastDvcEvtType Device Event Type.
This component invokes the D1-PairedEventLastDvcEvtType Business Object using the ATD1PairedEventLastDvcEvtType Inbound Web Service.
D1-StandardDeviceEventType
Used to create a StandardDeviceEventType Device Event Type.
This component invokes the D1-StandardDeviceEventType Business Object using the ATD1StandardDeviceEventType Inbound Web Service.
D1-UTCorrectnPrcessrActvtyType
Defines the activity BO to use in the creation of a Usage Transaction Correction Processor. This component also defines the general category of these activities as a Correction Processor.
The component invokes the D1-UTCorrectnPrcessrActvtyType Business Object using the ATD1UTCorrectnPrcessrActvtyType Inbound Web Service.
D1-RemoteConnectType
Describes configuration parameters required for the Remote Connect command activity, including automated retry and command time-out options. This component allows the definition of a Service Issue Monitor Type resulting in the creation of a Service Issue Monitor of the configured type if a Remote Connect command activity has failed.
The component invokes the D1-RemoteConnectType Business Object using the ATD1RemoteConnectType Inbound Web Service.
D1-PairedEventFirstDvcEvtType
Describes the Device Event Type - Paired Event (First).
This component invokes the D1-PairedEventFirstDvcEvtType Business Object using the ATD1PairedEventFirstDvcEvtType Inbound Web Service.
D1-DeviceWithDurationActType
Describes the Device Activity with Duration Type.
This component invokes the D1-DeviceWithDurationActType Business Object using the ATD1DeviceWithDurationActType Inbound Web Service.
D2-SubMeasurementAggType
Describes the Sub Measurement Aggregator Type.
This component invokes the D2-SubMeasurementAggType Business Object using the ATD2SubMeasurementAggType Inbound Web Service.
D2-MasterMsrmtAggregatorType
Describes the Master Measurement Aggregator Type.
This component invokes the D2-MasterMsrmtAggregatorType Business Object using the ATD2MasterMsrmtAggregatorType Inbound Web Service.
D2-ActivityTypeAggDimScanner
Describes the Aggregator Dimension Scanner Activity Type.
This component invokes the D2-ActivityTypeAggDimScanner Business Object using the ATD2ActivityTypeAggDimScanner Inbound Web Service.
D2-AggregatorType
Used to create an AggregatorType Measuring Component Type.
This component invokes the D2-AggregatorType Business Object using the ATD2AggregatorType Inbound Web Service.
D1-IntervalChannelTypePhysical
Used to create a IntervalChannelTypePhysical.
This component invokes the D1-IntervalChannelTypePhysical Business Object using the ATD1IntervalChannelTypePhysical Inbound Web Service.
D1-BulkCommandProcessor
Used to create a Bulk Command Processor.
This component invokes the D1-BulkCommandProcessor Business Object using the ATD1BulkCommandProcessor Inbound Web Service.
D1-ChannelCountMetric
Used to create a ChannelCountMetric.
This component invokes the D1-ChannelCountMetric Business Object using the ATD1ChannelCountMetric Inbound Web Service.
D1-DeviceCountMetric
Used to create a DeviceCountMetric.
This component invokes the D1-DeviceCountMetric Business Object using the ATD1DeviceCountMetric Inbound Web Service.
D1-MeasurementCycleSchedule
Used to create a MeasurementCycleSchedule.
This component invokes the D1-MeasurementCycleSchedule Business Object using the ATD1MeasurementCycleSchedule Inbound Web Service.
D1-ReaderRemarkType
Used to create a ReaderRemarkType.
This component invokes the D1-ReaderRemarkType Business Object using the ATD1ReaderRemarkType Inbound Web Service.
D1-ServiceIssueMonitorType
Used to create a ServiceIssueMonitorType.
This component invokes the D1-ServiceIssueMonitorType Business Object using the ATD1ServiceIssueMonitorType Inbound Web Service.
D2-MsrmtQuantityAggScannerType
Used to create a MsrmtQuantityAggScannerType.
This component invokes the D2-MsrmtQuantityAggScannerType Business Object using the ATD2MsrmtQuantityAggScannerType Inbound Web Service.
D2-TOUGroup
Used to create a TOUGroup.
This component invokes the D2-TOUGroup Business Object using the ATD2TOUGroup Inbound Web Service.
D2-VEERuleHighLowCheck
Used to create a VEERuleHighLowCheck.
This component invokes the D2-VEERuleHighLowCheck Business Object using the ATD2VEERuleHighLowCheck Inbound Web Service.
D1-HowToCreateMCInformation
Used to create a HowToCreateMCInformation.
This component invokes the D1-HowToCreateMCInformation Business Object using the ATD1HowToCreateMCInformation Inbound Web Service.
D1-HowToSendActivityResponse
Used to create a HowToSendActivityResponse.
This component invokes the D1-HowToSendActivityResponse Business Object using the ATD1HowToSendActivityResponse Inbound Web Service.
D1-AvgDailyEstItemConsumption
Used to create a AvgDailyEstItemConsumption.
This component invokes the D1-AvgDailyEstItemConsumption Business Object using the ATD1AvgDailyEstItemConsumption Inbound Web Service.
D1-VEEEligibilityCriteria
Used to create a VEEEligibilityCriteria.
This component invokes the D1-VEEEligibilityCriteria Business Object using the ATD1VEEEligibilityCriteria Inbound Web Service.
D2-VerifyUomTouSqiMCExistForUs
Used to create a VerifyUomTouSqiMCExistForUs.
This component invokes the D2-VerifyUomTouSqiMCExistForUs Business Object using the ATD2VerifyUomTouSqiMCExistForUs Inbound Web Service.
D1-DeviceEventSeeder
Used to create a DeviceEventSeeder.
This component invokes the D1-DeviceEventSeeder Business Object using the ATD1DeviceEventSeeder Inbound Web Service.
D1-FieldActivity
Used to create a FieldActivity.
This component invokes the D1-FieldActivity Business Object using the ATD1FieldActivity Inbound Web Service.
D1-ReaderRemark
Used to create a ReaderRemark.
This component invokes the D1-ReaderRemark Business Object using the ATD1ReaderRemark Inbound Web Service.
D1-TimeZoneTranslationLookup
Used to create a TimeZoneTranslationLookup.
This component invokes the D1-ATD1TimeZoneTranslationLookup Business Object using the ATD1ReaderRemark Inbound Web Service.
D2-UsageCalculationGroupLookup
Used to create a UsageCalculationGroupLookup.
This component invokes the D2-UsageCalculationGroupLookup Business Object using the ATD2UsageCalculationGroupLookup Inbound Web Service.
D2-MDMMasterConfig
Used to perform actions such as ADD, READ, UPDATE, and DELETE a MDMMasterConfig.
This component invokes the D2- MDMMasterConfig Business Object using the ATD2MDMMasterConfig Inbound Web Service.
D2-MtrCommTrckngAggregatorType
Used to perform actions such as ADD, READ, UPDATE, and DELETE a MtrCommTrckngAggregatorType.
This component invokes the D2- MtrCommTrckngAggregatorType Business Object using the ATD2MtrCommTrckngAggregatorType Inbound Web Service.
D1-EstimationSuppressionType
Used to perform actions such as ADD, READ, UPDATE, and DELETE a EstimationSuppressionType.
This component invokes the D1- EstimationSuppressionType Business Object using the ATD1EstimationSuppressionType Inbound Web Service.
D2-InactiveMeasurementCheck
Used to perform actions such as ADD, READ, UPDATE, and DELETE a InactiveMeasurementCheck VEE Rule.
This component invokes the D1- InactiveMeasurementCheck Business Object using the ATD2InactiveMeasurementCheck Inbound Web Service.
D1-ChannelStatisticsType
Used to perform actions such as ADD, READ, UPDATE, and DELETE a ChannelStatisticsType.
This component invokes the D1- ChannelStatisticsType Business Object using the ATD1ChannelStatisticsType Inbound Web Service.
Used to perform actions such as ADD, READ, UPDATE, and DELETE a ChannelStatistics.
This component invokes the D1- ChannelStatistics Business Object using the ATD1ChannelStatistics Inbound Web Service.
D1-FacilityLite
Used to perform actions such as ADD, READ, UPDATE, and DELETE a FacilityLite.
This component invokes the D1- FacilityLite Business Object using the ATD1FacilityLite Inbound Web Service.
D1-SpecificationLookup
Used to perform actions such as ADD, READ, UPDATE, and DELETE a SpecificationLookup.
This component invokes the D1- SpecificationLookup Business Object using the ATD1SpecificationLookup Inbound Web Service.
D1-MeasuringCompTypLite
Used to perform actions such as ADD, READ, UPDATE, and DELETE a MeasuringCompTypLite.
This component invokes the D1- MeasuringCompTypLite Business Object using the ATD1MeasuringCompTypLite Inbound Web Service.
D1-GetDvcFrmIdenTypFlag
Used to retrieve Device ID By Identifier and Type Flag using the ATD1 GetDvcFrmIdenTypFlag Inbound Web Service.
D1-GetSimdIdFromImd
Used to retrieve Simd ID By IMD ID using the ATD1GetSimdIdFromImd Inbound Web Service.
D1-GetMCFrmDvcExtId
Used to retrieve Measuring Component ID from Device External ID using the ATD1GetMCFrmDvcExtId Inbound Web Service.
D1-GetProductKeyFromSync
Used to Get Product Key from Sync Request ID using the ATD1 GetProductKeyFromSync Inbound Web Service.
D1-GetUsageFromExtID
Used to retrieve Usage ID from CCB Usage ID using the ATD1 GetUsageFromExtID Inbound Web Service.
D2-GetUSFromExtID
Used to retrieve US ID from External ID using the ATD1 GetUSFromExtID Inbound Web Service.
D1-GetDCFrmDvcExtId
Used to retrieve DC ID from External ID using the ATD1GetDCFrmDvcExtId Inbound Web Service.
D1-GetInstEvtFromDvcExId
Used to retrieve Install Event ID from Device External ID using ATD1GetInstEvtFromDvcExId Inbound Web Service.
D1-GetInstEvtFrmSPExtId
Used to retrieve Install Event ID from Service Point External ID using the ATD1GetInstEvtFrmSPExtId Inbound Web Service.
D1-GetMCFromExtID
Used to retrieve Measuring Component ID from External ID using the ATD1GetMCFromExtID Inbound Web Service.
D1-GetContactFromExtID
Used to retrieve Contact ID from External ID using the ATD1GetContactFromExtID Inbound Web Service.
D1-GetSpFromExtID
Used to retrieve Service Point ID from External ID using the ATD1GetSpFromExtID Inbound Web Service.
D1-GetSyncReqIdFrmExtId
Used to retrieve Sync Request ID from External ID using the ATD1GetSyncReqIdFrmExtId Inbound Web Service.
Asset Management
Component
Description
W1-SingleAssetConfigRead
Used to query an existing Single Asset Config record.
W1-SingleAssetConfigUpdate
Used to update an existing Single Asset Config record.
W1-AssetLocationAdd
Used to add an Operational Device Asset Location record.
This component invokes the Inbound Web Service ATW1AssetLocation using the W1-AssetLocation Business Object.
W1-AssetLocationDelete
Used to delete an Operational Device Asset Location record.
W1-AssetLocationRead
Used to read an Operational Device Asset Location record.
W1-AssetLocationUpdate
Used to update an Operational Device Asset Location record.
W1-BasicTestAdd
Used to add an Operational Device Basic Test record.
This component invokes the Inbound Web Service ATW1BasicTest using the W1-BasicTest business object.
W1-BasicTestDelete
Used to delete an Operational Device Basic Test record.
W1-BasicTestRead
Used to read an Operational Device Basic Test record.
W1-BasicTestUpdate
Used to update an Operational Device Basic Test record.
Used to add a Service History record.
This component invokes the Inbound Web Service ATW1ServiceHistory using the W1-ServiceHistory business object.
Used to delete a Service History record.
Used to read a Service History record.
Used to update a Service History record.
W2-CommComponentAdd
Used to add a Communication Component record.
This component invokes the Inbound Web Service ATW2CommunicationComponent using the W2-CommunicationComponent Business Object.
W2-CommComponentDelete
Used to delete a Communication Component record.
W2-CommComponentRead
Used to read a Communication Component record.
W2-CommComponentUpdate
Used to update a Communication Component record.
W2-CommCompSpecificationAdd
Used to add a Comm Comp Specification record.
This component invokes the Inbound Web Service ATW2CommunicationComponentSpec using the W2-CommunicationComponentSpec Business Object.
W2-CommCompSpecificationDelete
Used to delete a Comm Comp Specification record.
W2-CommCompSpecificationRead
Used to read a Comm Comp Specification record.
W2-CommCompSpecificationUpdate
Used to update a Comm Comp Specification record.
W2-CommRelaySpecificationAdd
Used to add a Comm Relay Specification record.
This component invokes the Inbound Web Service ATW2CommunicationRelaySpec using the W2-CommunicationRelaySpec Business Object.
W2-CommRelaySpecificationDelete
Used to delete a Comm Relay Specification record.
W2-CommRelaySpecificationRead
Used to read a Comm Relay Specification record.
W2-CommRelaySpecificationUpdate
Used to update a Comm Relay Specification record.
W2-CommunicationRelayAdd
Used to add a Communication Relay record.
This component invokes the Inbound Web Service ATW2CommunicationRelay using the W2-CommunicationRelay Business Object.
W2-CommunicationRelayDelete
Used to delete a Communication Relay record.
W2-CommunicationRelayRead
Used to read a Communication Relay record.
W2-CommunicationRelayUpdate
Used to update a Communication Relay record.
W2-FirmwareSpecificationAdd
Used to add a Firmware Specification record.
This component invokes the Inbound Web Service ATW2FirmwareSpecification using the W2-FirmwareSpecification Business Object.
W2-FirmwareSpecificationDelete
Used to delete a Firmware Specification record.
W2-FirmwareSpecificationRead
Used to read a Firmware Specification record.
W2-FirmwareSpecificationUpdate
Used to update a Firmware Specification record.
W2-FirmwareVersionAdd
Used to add a Firmware Version record.
This component invokes the Inbound Web Service ATW2FirmwareVersion using the W2-FirmwareVersion Business Object.
W2-FirmwareVersionDelete
Used to delete a Firmware Version record.
W2-FirmwareVersionRead
Used to read a Firmware Version record.
W2-FirmwareVersionUpdate
Used to update a Firmware Version record.
W2-ManualMeterAdd
Used to add an Analog Meter record.
This component invokes the Inbound Web Service ATW2ManualMeter using the W2-ManualMeter Business Object.
W2-ManualMeterDelete
Used to delete an existing Analog Meter record.
W2-ManualMeterRead
Used to read an existing Analog Meter record.
W2-ManualMeterUpdate
Used to update an existing Analog Meter record.
W2-ManualMeterSpecificationAdd
Used to add an Analog Meter Specification record.
This component invokes the Inbound Web Service ATW2ManualMeterSpecification using the W2-ManualMeterSpecification Business Object.
W2-ManualMeterSpecificationDelete
Used to delete an Analog Meter Specification record.
W2-ManualMeterSpecificationRead
Used to read an Analog Meter Specification record.
W2-ManualMeterSpecificationUpdate
Used to update an Analog Meter Specification record.
W2-SmartMeterAdd
Used to add a Smart Meter record.
This component invokes the Inbound Web Service ATW2SmartMeter using the W2-SmartMeter Business Object.
W2-SmartMeterDelete
Used to delete an existing Smart Meter record.
W2-SmartMeterRead
Used to read an existing Smart Meter record.
W2-SmartMeterUpdate
Used to update an existing Smart Meter record.
W2-SmartMeterSpecificationAdd
Used to add a Smart Meter Specification record.
This component invokes the Inbound Web Service ATW2SmartMeterSpecification using the W2-SmartMeterSpecification Business Object.
W2-SmartMeterSpecificationDelete
Used to delete a Smart Meter Specification record.
W2-SmartMeterSpecificationRead
Used to read a Smart Meter Specification record.
W2-SmartMeterSpecificationUpdate
Used to update a Smart Meter Specification record.
W2-SmartTestAdd
Used to add a Smart Device Test record.
This component invokes the Inbound Web Service ATW2SmartTest using the W2-SmartTest Business Object.
W2-SmartTestDelete
Used to delete an existing Smart Device Test record.
W2-SmartTestRead
Used to query an existing Smart Device Test record.
W2-SmartTestUpdate
Used to update an existing Smart Device Test record.
W1-AACCfgDeviceUpgradeAdd
Used to add a Configuration - Device - Asset to Component record.
This component invokes the Inbound Web Service ATW1AACCfgDeviceUpgrade using W1-AACCfgDeviceUpgrade Business Object.
W1-AACCfgDeviceUpgradeDelete
Used to delete an existing a Configuration - Device - Asset to Component record.
W1-AACCfgDeviceUpgradeRead
Used to query an existing Configuration - Device - Asset to Component record.
W1-AACCfgDeviceUpgradeUpdate
Used to update an existing Configuration - Device -Asset to Component record.
W1-AACfgDeviceUpgradeAdd
Used to create a Configuration - Device - Asset to Asset record.
This component invokes the Inbound Web Service ATW1AACfgDeviceUpgrade using W1-AACfgDeviceUpgrade Business Object.
W1-AACfgDeviceUpgradeDelete
Used to delete an existing Configuration - Device - Asset to Asset record.
W1-AACfgDeviceUpgradeRead
Used to query an existing Configuration - Device - Asset to Asset record.
W1-AACfgDeviceUpgradeUpdate
Used to update an existing Configuration - Device - Asset to Asset record.
W1-ACACCfgDeviceUpgradeAdd
Used to create a Configuration - Device - Component to Component record.
This component invokes the Inbound Web Service ATW1ACACfgDeviceUpgrade using W1-ACACfgDeviceUpgrade Business Object.
W1-ACACCfgDeviceUpgradeDelete
Used to delete an existing Configuration - Device - Component to Component record.
W1-ACACCfgDeviceUpgradeRead
Used to query an existing Configuration - Device -Component to Component record.
W1-ACACCfgDeviceUpgradeUpdate
Used to update an existing Configuration - Device - Component to Component record.
W1-ACACfgDeviceUpgradeAdd
Used to create a Configuration - Device - Component to Asset record.
W1-ACACfgDeviceUpgradeDelete
Used to delete an existing Configuration - Device - Component to Asset record.
W1-ACACfgDeviceUpgradeRead
Used to query an existing Configuration - Device - Component to Asset record.
W1-ACACfgDeviceUpgradeUpdate
Used to update an existing Configuration - Device - Component to Asset record.
W1-ACCfgDeviceUpgradeAdd
Used to create a Configuration - Device - Component record.
This component invokes the Inbound Web Service ATW1ACCfgDeviceUpgrade using W1-ACCfgDeviceUpgrade Business Object.
W1-ACCfgDeviceUpgradeDelete
Used to delete an existing Device - Component record.
W1-ACCfgDeviceUpgradeRead
Used to query an existing Device - Component record.
W1-ACCfgDeviceUpgradeUpdate
Used to update an existing Device - Component record.
W1-ACfgDeviceUpgradeAdd
Used to create a Configuration - Device Asset record.
This component invokes the Inbound Web Service ATW1ACfgDeviceUpgrade using W1-ACfgDeviceUpgrade Business Object.
W1-ACfgDeviceUpgradeDelete
Used to delete a Configuration - Device Asset record.
W1-ACfgDeviceUpgradeRead
Used to query an existing Configuration - Device Asset record.
W1-ACfgDeviceUpgradeUpdate
Used to update an existing Configuration - Device Asset record.
W1-ActivityComplInboundCommAdd
Used to create an Inbound Communication record.
This component invokes the Inbound Web Service ATW1ActivityComplInboundComm using W1-ActivityComplInboundComm Business Object.
W1-ActivityComplInboundCommDelete
W1-ActivityComplInboundCommRead
Used to query an existing Inbound Communication Record.
W1-ActivityComplInboundCommUpdate
Used to update an existing Inbound Communication Record.
W1-ActivityNotesAdd
Used to create an Activity Notes record.
This component invokes the Inbound Web Service ATW1ActivityNotes W1-ActivityNotes using Business Object.
W1-ActivityNotesDelete
Used to delete an existing Activity Notes record.
This component invokes the Inbound Web Service ATW1ActivityNotes using W1-ActivityNotes Business Object.
W1-ActivityNotesRead
Used to query an existing Activity Notes record.
W1-ActivityNotesUpdate
W1-AdHocActCoreNoLocationAdd
Used to create an Adhoc Activity Core No Location record.
This component invokes the Inbound Web Service ATW1AdHocActCoreNoLocation using W1- AdHocActCoreNoLocation Business Object.
W1-AdHocActCoreNoLocationDelete
Used to delete an existing Adhoc Activity Core No Location record.
This component invokes the Inbound Web Service ATW1AdHocActCoreNoLocation using W1-AdHocActCoreNoLocation Business Object.
W1-AdHocActCoreNoLocationRead
Used to query an existing Adhoc Activity Core No Location record.
W1-AdHocActCoreNoLocationUpdate
W1-AdHocActivityCoreAdd
Used to create an Adhoc Activity Core record.
This component invokes the Inbound Web Service ATW1AdHocActivityCore using W1-AdHocActivityCore Business Object.
W1-AdHocActivityCoreDelete
Used to delete an existing Adhoc Activity Core record.
W1-AdHocActivityCoreRead
Used to query existing Adhoc Activity Core record.
W1-AdHocActivityCoreUpdate
W1-AssetCompCfgWOAdd
Used to create a Configuration - Asset Component record.
This component invokes the Inbound Web Service ATW1AssetCompCfgWO using W1-AssetCompCfgWO Business Object.
W1-AssetCompCfgWODelete
Used to delete an existing Configuration - Asset Component record.
W1-AssetCompCfgWORead
W1-AssetCompCfgWOUpdate
Used to update an existing Configuration - Asset Component record.
W1-AssetCompToAssetCfgWOAdd
Used to create a Configuration - Component to Asset record.
This component invokes the Inbound Web Service ATW1AssetCompToAssetCfgWO using W1-AssetCompToAssetCfgWO Business Object.
W1-AssetCompToAssetCfgWODelete
Used to delete a Configuration - Component to Asset record.
W1-AssetCompToAssetCfgWORead
Used to update an existing Configuration - Component to Asset record.
W1-AssetCompToAssetCfgWOUpdate
This component invokes the Inbound Web Service used to update an existing Configuration - Component using W1-AssetCompToAssetCfgWO Business Object.
W1-ssetCompToAssetCompCfg
WOAdd
Used to create an Configuration - Component to Component record.
This component invokes the Inbound Web Service ATW1AssetCompToAssetCompCfgWO using W1- AssetCompToAssetCompCfgWO Business Object.
W1-AssetCompToAssetCompCfg WODelete
Used to delete an existing Configuration - Component to Component record.
This component invokes the Inbound Web Service ATW1AssetCompToAssetCompCfgWO using W1-AssetCompToAssetCompCfgWO Business Object.
W1-AssetCompToAssetCompCfg WORead
Used to query an existing Configuration - Component to Component record.
W1-AssetCompToAssetCompCfg WOUpdate
Used to update an existing Configuration - Component to Component record.
W1-AssetCriteriaActGeneratorAdd
Used to create an Activity Generator - Asset Criteria record.
This component invokes the Inbound Web Service ATW1AssetCriteriaActGenerator using W1-AssetCriteriaActGenerator Business Object.
W1-AssetCriteriaActGeneratorDelete
Used to delete an existing Activity Generator - Asset Criteria.
W1-AssetCriteriaActGeneratorRead
Used to query an existing Activity Generator - Asset Criteria record.
W1-AssetCriteriaActGeneratorUpdate
W1-AssetListActGeneratorAdd
Used to create an Activity Generator - Asset List record.
This component invokes the Inbound Web Service ATW1AssetListActGenerator using W1-AssetListActGenerator Business Object.
W1-AssetListActGeneratorDelete
Used to delete an existing Activity Generator - Asset List record.
W1-AssetListActGeneratorRead
Used to query an existing Activity Generator - Asset List record.
W1-AssetListActGeneratorUpdate
Used to update an existing Activity Generator - Asset List record.
W1-AssetReplicationActivityAdd
Used to create an Asset Replication Activity record.
This component invokes the Inbound Web Service ATW1AssetReplicationActivity using W1-AssetReplicationActivity Business Object.
W1-AssetReplicationActivityDelete
Used to delete an existing Asset Replication Activity record.
W1-AssetReplicationActivityRead
Used to query an existing Asset Replication Activity record.
W1-AssetReplicationActivityUpdate
Used to update an existing Asset Replication Activity record.
W1-AssetReplicationComplEventAdd
Used to create a Completion Event record.
This component invokes the Inbound Web Service ATW1AssetReplicationComplEvent using W1-AssetReplicationComplEvent Business Object.
W1-AssetReplicationComplEventDelete
Used to delete a Completion Event record.
W1-AssetReplicationComplEventRead
Used to query an existing Completion Event record.
W1-AssetReplicationComplEventUpdate
Used to update an existing Completion Event record.
W1-AssetToAssetCompCfgWOAdd
Used to create a Configuration - Asset to Component record
ATW1AssetToAssetCompCfgWO using W1-AssetToAssetCompCfgWO Business Object.
W1-AssetToAssetCompCfgWODelete
Used to delete an existing Configuration - Asset to Component record.
This component invokes the Inbound Web Service ATD1CutServiceForNonPayment using D1-CutServiceForNonPayment Business Object.
W1-AssetToAssetCompCfgWORead
Used to query an existing Configuration - Asset to Component record
This component invokes the Inbound Web Service ATW1AssetToAssetCompCfgWO using W1-AssetToAssetCompCfgWO Business Object.
W1-AssetToAssetCompCfgWOUpdate
Used to update an existing Configuration - Asset to Component record.
W1-BasicWorkOrderAdd
Used to create a Basic Work Order record.
This component invokes the Inbound Web Service ATW1BasicWorkOrder using W1-BasicWorkOrder Business Object.
W1-BasicWorkOrderDelete
Used to delete an existing a Basic Work Order record.
W1-BasicWorkOrderRead
Used to query an existing a Basic Work Order record.
W1-BasicWorkOrderUpdate
Used to update an existing a Basic Work Order record.
W1-CompnAssetListActGeneratorAdd
Used to create an Activity Generator - Component List record.
This component invokes the Inbound Web Service ATW1CompnAssetListActGenerator using W1-CompnAssetListActGenerator Business Object.
W1-CompnAssetListActGeneratorDelete
Used to update an existing an Activity Generator - Component List record.
W1-CompnAssetListActGeneratorRead
Used to query an existing an Activity Generator -Component List record.
W1-CompnAssetListActGeneratorUpdate
Used to update an existing an Activity Generator -Component List record.
W1-CompnCriteriaActGeneratorAdd
Used to create an Activity Generator - Component Criteria record.
This component invokes the Inbound Web Service ATW1CompnCriteriaActGenerator using W1-CompnCriteriaActGenerator Business Object.
W1-CompnCriteriaActGeneratorDelete
Used to delete an existing Activity Generator -Component Criteria record.
W1-CompnCriteriaActGeneratorRead
Used to query an existing Activity Generator -Component Criteria record.
W1-CompnCriteriaActGeneratorUpdate
Used to update an existing Activity Generator -Component Criteria record.
W1-CrAnyServiceHistoryCmplEvtAdd
Used to creating a Completion Event record.
This component invokes the Inbound Web Service ATW1CrAnyServiceHistoryCmplEvt using W1-CrAnyServiceHistoryCmplEvt Business Object.
W1-CrAnyServiceHistoryCmplEvtDelete
W1-rAnyServiceHistoryCmplEvtRead
W1-CrAnyServiceHistoryCmplEvtUpdate
W1-CreActivityPayCmpEvtAdd
Used to create a Create Specific Activity Completion Event record.
This component invokes the Inbound Web Service ATW1CreActivityPayCmpEvt using W1-CreActivityPayCmpEvt Business Object.
W1-CreActivityPayCmpEvtDelete
Used to delete an existing Create Specific Activity. Event record.
This component invokes the Inbound Web Service ATW1CreActivityPayCmpEvt using W1-CreActivityPayCPayment Business Object.
W1-CreActivityPayCmpEvtRead
Used to query an existing Create Specific Activity. Event record.
W1-CreActivityPayCmpEvtUpdate
Used to query an existing Create Specific Activity Event record.
W1-CreAssetPayCmpEvtAdd
Used to Create Specific Asset Completion Event.
This component invokes the Inbound Web Service ATW1CreAssetPayCmpEvt using W1-CreAssetPayCmpEvt Business Object.
W1-CreAssetPayCmpEvtDelete
Used to delete an existing Specific Asset Completion Event record.
W1-CreAssetPayCmpEvtRead
Used to query an existing Specific Asset Completion Event record.
This component invokes the Inbound Web Service ATW1CreAssetPayCmpEvt using W1-CreAssetPayCmp Business Object.
W1-CreAssetPayCmpEvtUpdate
W1-CreateMobileWOInboundCommAdd
Used to create a Mobile Work Order Inbound Communication record.
This component invokes the Inbound Web Service ATW1CreateMobileWOInboundComm using W1-CreateMobileWOInboundComm Business Object.
Delete
Used to delete an existing Mobile Work Order Inbound Communication record.
W1-CreateMobileWOInboundCommRead
Used to query existing Mobile Work Order Inbound Communication record.
This component invokes the Inbound Web Service ATW1CreateMobileWOInboundComm using W1-CreateMobileWOInbound Business Object.
CommUpdate
W1-CreNodeAttachCmpEvtAdd
Used to create a Location Attachment Completion Event record.
This component invokes the Inbound Web Service ATW1CreNodeAttachCmpEvt using W1-CreNodeAttachCmpEvt Business Object.
W1-CreNodeAttachCmpEvtDelete
Used to delete an existing Location Attachment Completion Event record.
W1-CreNodeAttachCmpEvtRead
Used to query an existing Location Attachment Completion Event record.
W1-CreNodeAttachCmpEvtUpdate
Used to update an existing Location Attachment Completion Event record.
W1-CreServiceHistoryAttCmpEvAdd
Used to create a Service History Attachment Completion Event record.
This component invokes the Inbound Web Service ATW1CreServiceHistoryAttCmpEvt using W1-CreServiceHistoryAttCmpEvt Business Object.
W1-CreServiceHistoryAttCmpEvtDelete
Used to delete an existing Service History Attachment Completion Event record.
W1-CreServiceHistoryAttCmpEvtRead
Used to query an existing Service History Attachment Completion Event record.
This component invokes the Inbound Web ServiceATW1CreServiceHistoryAttCmpEvt using W1-CreServiceHistoryAttCmpEvt Business Object.
W1-CreServiceHistoryAttCmpEvtUpdate
Used to update an existing Service History Attachment Completion Event record.
W1-CreServiceHistoryPayCmpEvtAdd
Used to create a Specific Service History Completion Event record.
This component invokes the Inbound Web Service ATW1CreServiceHistoryPayCmpEvt using W1-CreServiceHistoryPayCmpEvt Business Object.
W1-CreServiceHistoryPayCmpEvtDelete
Used to delete an existing Specific Service History Completion Event record.
W1-CreServiceHistoryPayCmpEvtRead
Used to query an existing Specific Service History Completion Event record.
W1-CreServiceHistoryPayCmpEvtUpdate
Used to update an existing Specific Service History Completion Event record.
W1-CreSvcHistCmpEvtAdd
Used to Create Any Service History Completion Event (Online Only) record.
This component invokes the Inbound Web Service ATW1CreSvcHistCmpEvt using W1-CreSvcHistCmpEvt Business Object.
W1-CreSvcHistCmpEvtDelete
Used to delete existing Create Any Service History Completion Event (Online Only) record.
W1-CreSvcHistCmpEvtRead
Used to query an existing Create Any Service History Completion Event (Online Only) record.
W1-CreSvcHistCmpEvtUpdate
Used to update an existing Create Any Service History Completion Event (Online Only) record.
W1-FollowUpSkippedAssetsCmpEvtAdd
Used to create a Follow-Up Skipped Assets Completion Event record.
This component invokes the Inbound Web Service ATW1FollowUpSkippedAssetsCmpEvt using W1-FollowUpSkippedAssetsCmpEvt Business Object.
EvtDelete
Used to delete an existing a Follow-Up Skipped As Completion Event record.
EvtRead
Used to query an existing a Follow-Up Skipped As Completion Event record.
This component invokes the Inbound Web Service ATW1FollowUpSkippedAssetsCmpEvt W1-FollowUpSkippedAssetsCmpEvt Business Object.
Update
Used to update an existing a Follow-Up Skipped As Completion Event record.
This component invokes the Inbound Web Service ATW1FollowUpSkippedAssetsCmpEvt using W1-FollowUpSkippedAssetsCmpEvBusiness Object.
W1-LocalActivityCoreAdd
Used to create a Local Activity Core record.
This component invokes the Inbound Web Service ATW1LocalActivityCore using ATW1LocalActivityCore Business Object.
W1-LocalActivityCoreDelete
Used to delete an existing Local Activity Core record.
This component invokes the Inbound Web Service ATW1LocalActivityCore using W1-LocalActivityCore Business Object.
W1-LocalActivityCoreRead
Used to query an existing Local Activity Core record.
W1-LocalActivityCoreUpdate
Used to update an existing Local Activity Core record.
W1-MobileUpdWorkedAssetCmpEvtAdd
Used to create a Mobile Update Worked Assets Completion Event record.
This component invokes the Inbound Web Service ATW1MobileUpdWorkedAssetCmpEvt using W1-MobileUpdWorkedAssetCmpEvt Business Object.
Delete
Used to delete an existing Mobile Update Worked Assets Completion Event record.
W1-MobileUpdWorkedAssetCmpEvtRead
Used to query an existing Mobile Update Worked Assets Completion Event record.
W1-MobileUpdWorkedAssetCmpUpdate
Used to update an existing Mobile Update Worked Assets Completion Event record.
W1-NodeCriteriaActGeneratorAdd
Used to create an Activity Generator - Node Criteria record.
This component invokes the Inbound Web Service ATW1NodeCriteriaActGenerator using W1-NodeCriteriaActGenerator Business Object.
W1-NodeCriteriaActGeneratorDelete
Used to delete an existing Activity Generator - Node Criteria record.
W1-NodeCriteriaActGeneratorRead
Used to query an existing Activity Generator - Node Criteria record.
W1-NodeCriteriaActGeneratorUpdate
W1-OutboundActivityCoreAdd
Used to create an Outbound Activity Core record.
This component invokes the Inbound Web Service ATW1OutboundActivityCore using W1-OutboundActivityCore Business Object.
W1-OutboundActivityCoreDelete
Used to delete an existing Outbound Activity Core record.
W1-OutboundActivityCoreRead
Used to query an existing Outbound Activity Core record.
This component invokes the Inbound Web Service ATW1OutboundActivityCore W1-OutboundActivityCore Business Object.
W1-OutboundActivityCoreUpdate
Used to update an existing Outbound Activity Core record.
W1-ReplaceAssetLocalAdd
Used to create a Replace Asset Local record.
This component invokes the Inbound Web Service ATW1ReplaceAssetLocal using W1-ReplaceAssetLocal Business Object.
W1-ReplaceAssetLocalDelete
Used to delete an existing Replace Asset Local record.
W1-ReplaceAssetLocalRead
Used to query an existing Replace Asset Local record.
W1-ReplaceAssetLocalUpdate
Used to update an existing Replace Asset Local record.
W1-ReplaceAssetOutboundAdd
Used to create a Replace Asset Outbound record.
This component invokes the Inbound Web Service ATW1ReplaceAssetOutbound using W1-ReplaceAssetOutbound Business Object.
W1-ReplaceAssetOutboundDelete
Used to delete an existing a Replace Asset Outbound record.
W1-ReplaceAssetOutboundRead
Used to query an existing a Replace Asset Outbound record.
W1-ReplaceAssetOutboundUpdate
Used to update an existing a Replace Asset Outbound record.
W1-SingleAssetCfgWOAdd
Used to create a Configuration - Single Asset record.
This component invokes the Inbound Web Service ATW1SingleAssetCfgWO using W1-SingleAssetCfgWO Business Object.
W1-SingleAssetCfgWODelete
Used to delete an existing Configuration - Single Asset record.
W1-SingleAssetCfgWORead
Used to query an existing Configuration - Single Asset record.
W1-SingleAssetCfgWOUpdate
Used to update an existing Configuration - Single Asset record.
W1-SOMActivityAdd
Used to create a SOM Activity record.
This component invokes the Inbound Web Service ATW1SOMActivity using W1-SOMActivity Business Object.
W1-TrnAssetCmpEventAdd
Used to create a Transition Asset Completion Event record.
This component invokes the Inbound Web Service ATW1TrnAssetCmpEvent using W1-TrnAssetCmpEvent Business Object.
W1-TrnAssetCmpEventDelete
Used to delete an existing Transition Asset Completion Event n Event record.
W1-TrnAssetCmpEventRead
Used to query an existing Transition Asset Completion record.
W1-TrnAssetCmpEventUpdate
Used to update an existing Transition Asset Completion record.
W1-UpdAssetPayCmpEvtAdd
Used to create a Update Asset Using DA Completion Event record.
This component invokes the Inbound Web Service ATW1UpdAssetPayCmpEvt using W1-UpdAssetPayCmpEvt Business Object.
W1-UpdAssetPayCmpEvtDelete
Used to delete an existing Update Asset Using DA Completion Event record.
W1-UpdAssetPayCmpEvtRead
Used to query an existing Update Asset Using DA Completion Event record.
W1-UpdAssetPayCmpEvtUpdate
Used to update an existing Update Asset Using DA Completion Event record.
W1-UpdNodePayCmpEvtAdd
Used to create an Update Location Using DA Completion Event record.
This component invokes the Inbound Web Service ATW1UpdNodePayCmpEvt using W1-UpdNodePayCmpEvt Business Object.
W1-UpdNodePayCmpEvtDelete
Used to delete an existing Update Location Using DA Completion Event record.
W1-UpdNodePayCmpEvtRead
Used to query an existing Update Location Using DA Completion Event record.
W1-UpdNodePayCmpEvtUpdate
W1-WorkOrderNotesAdd
Used to create a Work Order Notes record.
This component invokes the Inbound Web Service ATW1WorkOrderNotes using W1-WorkOrderNotes Business Object.
W1-WorkOrderNotesDelete
Used to delete an existing Work Order Notes record.
W1-WorkOrderNotesRead
Used to query an existing Work Order Notes record.
W1-WorkOrderNotesUpdate
Used to update an existing Work Order Notes record.
W2-AACCfgFirmwareUpgradeAdd
Used to create a Configuration - Firmware - Asset to Component record.
This component invokes the Inbound Web Service ATW2AACCfgFirmwareUpgrade using W2-AACCfgFirmwareUpgrade Business Object.
W2-AACCfgFirmwareUpgradeDelete
Used to delete an existing Configuration - Firmware - Asset to Component record.
W2-AACCfgFirmwareUpgradeRead
Used to query an existing Configuration - Firmware - Asset to Component record.
W2-AACCfgFirmwareUpgradeUpdate
Used to update an existing Configuration - Firmware - Asset to Component record.
This component invokes the Inbound Web Service ATW2AACCfgFirmwareUpgrade using W2-AACCfgFirmwareUpgrad Business Object.
W2-AACfgFirmwareUpgradeAdd
Used to create a Configuration - Firmware - Asset to Asset record.
This component invokes the Inbound Web Service ATW2AACfgFirmwareUpgrade using W2-AACfgFirmwareUpgrade Business Object.
W2-AACfgFirmwareUpgradeDelete
Used to delete an existing Configuration - Firmware - Asset record.
W2-AACfgFirmwareUpgradeRead
Used to query an existing Configuration - Firmware - Asset to Asset record.
W2-AACfgFirmwareUpgradeUpdate
Used to update an existing Configuration - Firmware - Asset to Asset record.
W2-ACACCfgFirmwareUpgradeAdd
Used to create a Configuration - Firmware -Component to Component record.
This component invokes the Inbound Web Service ATW2ACACCfgFirmwareUpgrade using W2-ACACCfgFirmwareUpgrade Business Object.
W2-ACACCfgFirmwareUpgradeDelete
Used to delete an existing Configuration - Firmware - Component to Component record.
W2-ACACCfgFirmwareUpgradeRead
Used to query an existing Configuration - Firmware - Component to Component record.
W2-ACACCfgFirmwareUpgradeUpdate
Used to update an existing Configuration - Firmware Component to Component record.
W2-ACACfgFirmwareUpgradeAdd
Used to create a Configuration - Firmware - Component to Asset record.
This component invokes the Inbound Web Service ATW2ACACfgFirmwareUpgrade using W2-ACACfgFirmwareUpgrade Business Object.
W2-ACACfgFirmwareUpgradeDelete
Used to delete an existing Configuration - Firmware - Component to Asset record.
W2-ACACfgFirmwareUpgradeRead
Used to query an existing Configuration - Firmware Component to Asset record.
W2-ACACfgFirmwareUpgradeUpdate
Used to update an existing Configuration - Firmware Component to Asset record.
W2-ACCfgFirmwareUpgradeAdd
Used to create Configuration - Firmware -Component record.
This component invokes the Inbound Web Service ATW2ACCfgFirmwareUpgrade using W2-ACCfgFirmwareUpgrade Business Object.
W2-ACCfgFirmwareUpgradeDelete
Used to delete an existing Configuration - Firmware - Component record.
W2-ACCfgFirmwareUpgradeRead
Used to query an existing Configuration - Firmware - Component record.
W2-ACCfgFirmwareUpgradeUpdate
Used to update an existing Configuration - Firmware - Component record.
W2-ACfgFirmwareUpgradeAdd
Used to create a Configuration - Firmware - Asset record.
This component invokes the Inbound Web Service ATW2ACfgFirmwareUpgrade using W2-ACfgFirmwareUpgrade Business Object.
W2-ACfgFirmwareUpgradeDelete
W2-ACfgFirmwareUpgradeRead
Used to query an existing Configuration - Firmware - Asset record.
W2-ACfgFirmwareUpgradeUpdate
Used to update an existing Configuration - Firmware - Asset record.
W2-FirmwareCommandLocalAdd
Used to create a Firmware Command Local record.
This component invokes the Inbound Web Service ATW2FirmwareCommandLocal using W2-FirmwareCommandLocal Business Object.
W2-FirmwareCommandLocalDelete
Used to delete an existing Firmware Command Local record.
W2-FirmwareCommandLocalRead
Used to query an existing Firmware Command Local record.
W2-FirmwareCommandLocalUpdate
Used to update an existing Firmware Command Local record.
W2-FirmwareCommandOutboundAdd
Used to create a Firmware Command Outbound record.
This component invokes the Inbound Web Service ATW2FirmwareCommandOutbound using W2-FirmwareCommandOutbound Business Object.
Used to delete a Firmware Command Outbound record.
W2-FirmwareCommandOutboundRead
Used to query an existing Firmware Command Outbound record.
W2-FirmwareCommandOutboundUpdate
Used to update an existing Firmware Command Outbound record.
Bill Determinants
Component
Description
D2-UsgTranSeeder
Used to perform actions such as ADD, READ, UPDATE, and DELETE a Usage Transaction Seeder.
This component invokes the D2-UsgTranSeeder Business Object using the ATD2UsgTranSeeder Inbound Web Service.
D2-UsageTransaction
Used to perform actions such as ADD, READ, UPDATE, and DELETE a Usage Transaction.
This component invokes the D2-UsageTransaction Business Object using the ATD2UsageTransaction Inbound Web Service.
D2-UsageSubscription
Used to create a Usage Subscription.
This component invokes the D2-UsageSubscription Business Object using the ATD2UsageSubscription Inbound Web Service.
D2-TOUMap
Used to create a TOU Map.
This component invokes the D2-TOUMap Business Object using the ATD2TOUMap Inbound Web Service.
D2-DynamicOption
Used to create a Dynamic Option.
This component invokes the D2-DynamicOption Business Object using the ATD2DynamicOption Inbound Web Service.
D2-DynamicOptionEvent
Used to create a Dynamic Option Event.
This component invokes the D2-DynamicOptionEvent Business Object using the ATD2DynamicOptionEvent Inbound Web Service.
D1-UsageGroup
Used to create a Usage Group.
This component invokes the D1-UsageGroup Business Object using the ATD1UsageGroup Inbound Web Service.
D2-GetScalar
Used to create a GetScalar Usage Rule.
This component invokes the D2-GetScalar Business Object using the ATD2GetScalar Inbound Web Service.
D1-CoincidentPeakSPDemandRule
Used to create a CoincidentPeakSPDemandRule.
This component invokes the D1- CoincidentPeakSPDemandRule Business Object using the ATD1CoincidentPeakSPDemandRule.
D1-CoincidentPeakOperandLookup
Used to create a CoincidentPeakOperandLookup.
This component invokes the D1- CoincidentPeakOperandLookup Business Object using the ATD1CoincidentPeakOperandLookup Inbound Web Service.
D1-IntervalPriceType
Used to create a IntervalPriceType.
This component invokes the D1-IntervalPriceType Business Object using the ATD1IntervalPriceType Inbound Web Service.
D1-IntervalPriceSet
Used to perform actions such as ADD, READ, UPDATE, and DELETE a IntervalPriceSet.
This component invokes the D1-IntervalPriceSetBusiness Object using the ATD1IntervalPriceSet Inbound Web Service.
D1-CalcRollingDemandRule
Used to create a CalcRollingDemandRule.
This component invokes the D1- CalcRollingDemandRule using the ATD1CalcRollingDemandRule IWS Inbound Web Service.
D2-GetTOUUsage
Used to create a GetTOUUsage Usage Rule.
This component invokes the D2-GetTOUUsage Business Object using the ATD2GetTOUUsage Inbound Web Service.
D2-DynamicOptionType
Describes the creation of Dynamic Option Type.
This component invokes the D2-DynamicOptionType Business Object using the ATD2DynamicOptionType Inbound Web Service.
D2-GetIntervalData
Allows the configuration of interval data retrieval during usage transaction processing. The rule records service quantities per service point and measuring component - which means that interval curves for different measuring components.
This component invokes the D2-GetIntervalData Business Object using the ATD2GetIntervalData Inbound Web Service.
D2-Math
This component invokes the D2-Math Business Object using the ATD2Math Inbound Web Service.
D2-UsageSubscriptionType
Allows to create a usage subscription type for creating a usage subscription.
This component invokes the D2-UsageSubscriptionType Business Object using the ATD2UsageSubscriptionType Inbound Web Service.
D2-TOUMapType
Describes Time Of Use Map Type.
This component invokes the D2-TOUMapType Business Object using the ATD2TOUMapType Inbound Web Service.
D2-HowToCreateUSInformation
Describes how to create the Usage Subscription related information.
This component invokes the D2-HowToCreateUSInformation Business Object using the ATD2HowToCreateUSInformation Inbound Web Service.
D2-ApplyMathInt
Describes the structure and rules applicable to Apply Math (Interval Data) usage rule.
This component invokes the D2-ApplyMathInt Business Object using the ATD2ApplyMathInt Inbound Web Service.
D1-FactorNumber
Describes the Factor Number.
This component invokes the D1-FactorNumber Business Object using the ATD1FactorNumber Inbound Web Service.
D1-FactorProfile
Used to create a FactorProfile Factor Value.
This component invokes the D1-FactorProfile Business Object using the ATD1FactorProfile Inbound Web Service.
D1-FactorVEEGroup
Used to create a FactorVEEGroup Factor.
This component invokes the D1- FactorVEEGroup Business Object using the ATD1FactorVEEGroup Inbound Web Service.
D2-GetItemCountsConsumption
Used to create a GetItemCountsConsumption Usage Rule.
This component invokes the D2-GetItemCountsConsumption Business Object using the ATD2GetItemCountsConsumption Inbound Web Service.
D2-TOUMapTemplate
Used to create a TOU Map Template.
This component invokes the D2-TOUMapTemplate Business Object using the ATD2TOUMapTemplate Inbound Web Service.
D2-ValAgainstTol
Used to create a Validate Against Tolerance usage rule.
This component invokes the D2-ValAgainstTol Business Object using the ATD2ValAgainstTol Inbound Web Service.
D1-FactorValueNumber
Used to create a Factor Value Number.
This component invokes the D1-FactorValueNumber Business Object using the ATD1FactorValueNumber Inbound Web Service.
D1-FactorValueVEEGroup
Describes the Factor Value VEE Group.
This component invokes the D1-FactorValueVEEGroup Business Object using the ATD1FactorValueVEEGroup Inbound Web Service.
D1-FactorValueProfile
Used to create a FactorValueProfile Factor.
This component invokes the D1-FactorValueProfile Business Object using the ATD1FactorValueProfile Inbound Web Service.
Communication
Component
Description
D2-AggregatorType
D1-ReaderRemarkType
D2-TOUGroup
D1-FieldActivity
D1-ReaderRemark
D1-TimeZoneTranslationLookupt
D2-MDMMasterConfig
This component invokes the D2-MDMMasterConfig Business Object using the ATD2MDMMasterConfig Inbound Web Service.
D2-MDMMasterConfig
This component invokes the D2-MtrCommTrckngAggregatorType Business Object using the ATD2MtrCommTrckngAggregatorType Inbound Web Service.
This component invokes the D1-EstimationSuppressionType Business Object using the ATD1EstimationSuppressionType Inbound Web Service.
This component invokes the D1-InactiveMeasurementCheck Business Object using the ATD2InactiveMeasurementCheck Inbound Web Service.
This component invokes the D1-ChannelStatisticsType Business Object using the ATD1ChannelStatisticsType Inbound Web Service.
D1-FacilityLite
This component invokes the D1-SpecificationLookup Business Object using the ATD1SpecificationLookup Inbound Web Service.
This component invokes the D1-MeasuringCompTypLite Business Object using the ATD1MeasuringCompTypLite Inbound Web Service.
D1-GetSimdIdFromImd
D1-GetMCFrmDvcExtId
D2-GetUSFromExtID
D1-GetDCFrmDvcExtId
D1-GetMCFromExtID
D1-GetSpFromExtID
Customer Information
Component
Description
W1-BusinessRead
Used to query an existing ODM Business Contact record.
This component invokes the ATW1Person Inbound Web Service using the W1-Business Business Object.
W1-PersonRead
Used to query an existing ODM Person Contact record.
This component invokes the ATW1Person Inbound Web Service using the W1-Person Business Object.
Data Model
Component
Description
D1-SmartMeter
Used to perform actions such as ADD, READ, UPDATE and DELETE a Smart Meter.
This component invokes the D1-SmartMeter Business Object using the ATD1SmartMeter Inbound Web Service.
D1-ManualMeter
Used to perform actions such as ADD, READ, UPDATE and DELETE a Manual Meter.
This component invokes the D1-ManualMeter Business Object using the ATD1ManualMeter Inbound Web Service.
D1-DeviceConfiguration
Used to add Device Configuration to a device.
This component invokes the D1-DeviceConfiguration Business Object using the ATD1DeviceConfigurationSVC Inbound Web Service.
D1-IntervalChannel
Used to add interval measuring components to a device configuration.
This component invokes the D1-IntervalChannel Business Object using the ATD1IntervalChannel Inbound Web Service.
D1-Register
Used to add scalar measuring components to a device configuration.
This component invokes the D1-Register Business Object using the ATD1Register Inbound Web Service.
D1-ServicePoint
Used to create a Service Point.
This component invokes the D1- ServicePoint Business Object using the ATD1ServicePoint Inbound Web Service.
D1-SmartMeterInstallEvent
Used to create an installation event for a Smart Meter.
This component invokes the D1- SmartMeterInstallEvent Business Object using the ATD1SmartMeterInstallEvent Inbound Web Service.
D1-ManualMeterInstallEvent
Used to create an installation event for a Manual Meter.
This component invokes the D1-ManualMeterInstallEvent Business Object using the ATD1ManualMeterInstallEvent Inbound Web Service.
D1-Transformer
Used to create a Facility (Transformer) for a service type.
This component invokes the D1-Transformer Business Object using the ATD1Transformer Inbound Web Service.
D1-ElectricityNetworkLocation
Used to create an Electricity Network Location.
This component invokes the D1- ElectricityNetworkLocation Business Object using the ATD1ElectricityNetworkLocation Inbound Web Service.
D1-IntervalScratchpad
Used to create Interval Scratchpad MC.
This component invokes the D1-IntervalScratchpad Business Object using the ATD1IntervalScratchpad Inbound Web Service.
D1-Person
Used to create a Person.
This component invokes the D1-Person Business Object using the ATD1Person Inbound Web Service.
D1-Business
Used to create a Business.
This component invokes the D1-Business Business Object using the ATD1Business Inbound Web Service.
D1-RegisterAutoRead
Used to add register auto read measuring components to a device configuration.
This component invokes the D1-RegisterAutoRead Business Object using the ATD1RegisterAutoRead Inbound Web Service.
D1-Item
Used to perform actions such as ADD, READ, UPDATE and DELETE an Item.
This component invokes the D1-Item Business Object using the ATD1Item Inbound Web Service.
D1-ItemInstallEvent
This component invokes the D1-ItemInstallEvent Business Object using the ATD1ItemInstallEvent Inbound Web Service.
D1-AutoReadRegisterType
Used to define the properties of measuring components automatically read on a regular basis, but for which only one measurement is received at a time, meaning one measurement per Initial Measurement.
This component invokes the D1-AutoReadRegisterType Business Object using the ATD1AutoReadRegisterType Inbound Web Service.
D1-DeviceConfigurationType
Used to create a device configuration type used to create device configuration for a device.
This component invokes the D1-DeviceConfigurationType Business Object using the ATD1DeviceConfigurationType Inbound Web Service.
D1-ExceptionType
Used to set up VEE Exception Types.
This component invokes the D1-ExceptionType Business Object using the ATD1ExsceptionType Inbound Web Service.
D1-ExternalApplication
Used to create a Service Provider.
This component invokes the D1-ExternalApplication Business Object using the ATD1ExternalApplication Inbound Web Service.
D1-HeadEndSystem
Used to create a Head End system service provider.
This component invokes the D1-HeadEndSystem Business Object using the ATD1HeadEndSystem Inbound Web Service.
D1-EnableService
Used to create a Enable Service.
This component invokes the D1-EnableService Business Object using the ATD1EnableService Inbound Web Service.
D1-DisableService
Used to create a DisableService.
This component invokes the D1- DisableService Business Object using the ATD1 DisableService Inbound Web Service.
D1-BackToBackService
Used to create a BackToBackService.
This component invokes the D1- BackToBackService Business Object using the ATD1BackToBackService IWS.
Used to create a CutServiceForNonPayment.
This component invokes the D1- CutServiceForNonPayment Business Object using the ATD1 CutServiceForNonPayment.
D1-ReconnectForPayment
Used to create a ReconnectForPayment.
This component invokes the D1- ReconnectForPayment Business Object using the ATD1ReconnectForPayment IWS.
D1-ItemConfigurationType
Creates a configuration types for Item Types that can represent badged items.
This component invokes the D1-ItemConfigurationType Business Object using the ATD1ItemConfigurationType Inbound Web Service.
D1-ItemType
Creates an item type applicable to badged and unbadged non-meter devices.
This component invokes the D1-ItemType Business Object using the ATD1ItemType Inbound Web Service.
D1-ManualMeterType
This component invokes the D1-ManualMeterType Business Object using the ATD1ManualMeterType Inbound Web Service.
D1-ServiceType
Used to create a Service Type.
This component invokes the D1-ServiceType Business Object using the ATD1ServiceType Inbound Web Service.
D1-SmartMeterType
Used to create a Device of Smart Meter Type.
This component invokes the D1-SmartMeterType Business Object using the ATD1SmartMeterType Inbound Web Service.
D1-TimeOfUse
Used to create a TOU.
This component invokes the D1-TimeOfUse Business Object using the ATD1TimeOfUse Inbound Web Service.
D1-UnitOfMeasure
Used to create a Unit of Measure.
This component invokes the D1-UnitOfMeasure Business Object using the ATD1 UnitOfMeasure Inbound Web Service.
D1-Manufacturer
Describes the structure and business rules applicable to manufacturers.
This component invokes the D1-Manufacturer Business Object using the ATD1 Manufacturer Inbound Web Service.
D1-MeasurementCycle
Describes the Measurement Cycle creation.
This component invokes the D1-MeasurementCycle Business Object using the ATD1MeasurementCycle Inbound Web Service.
D1-RegisterTypePhysical
Used to create Register Type component.
This component invokes the D1-RegisterTypePhysical Business Object using the ATD1RegisterTypePhysical Inbound Web Service.
D1-ServicePointType
A generic component used to create Service point type.
This component invokes the D1- ServicePointType Business Object using the ATD1ServicePointType Inbound Web Service.
D1-MeasurementCycleRoute
Used to create Measurement Cycle Route.
This component invokes the D1- MeasurementCycleRoute Business Object using the ATD1MeasurementCycleRoute Inbound Web Service.
D1-HowToProcessDeviceInfo
Describes how to process the Device Related Information.
This component invokes the D1-HowToProcessDeviceInfo Business Object using the ATD1HowToProcessDeviceInfo Inbound Web Service.
D1-HeadendSQILookup
A non-instantiable Extendable Lookup BO that provides translation between an external SQI sent in via a meter data source/provider, such as a head-end system and SQIs that have been configured within the application. SGG adapter products will deliver instantiable child BOs of this BO if SQI translation is needed.
This component invokes the D1-HeadendSQILookup Business Object using the ATD1HeadendSQILookup Inbound Web Service.
D1-ServiceQuantityIdentifier
Describes the structure and business rules applicable to Service Quantity Identifier definitions.
This component invokes the D1-ServiceQuantityIdentifier Business Object using the ATD1ServiceQuantityIdentifier Inbound Web Service.
D1-Market2
Valid Service Providers are Market Participants.
This component invokes the D1-Market2 Business Object using the ATD1Market2 Inbound Web Service.
D1-ContactType
Describes Contact Type.
This component invokes the D1-ContactType Business Object using the ATD1ContactType Inbound Web Service.
D2-DynCompValidation
Used to perform actions such as ADD, READ, UPDATE, and DELETE a DynCompValidation.
This component invokes the D2- DynCompValidation Business Object using the ATD2DynCompValidation Inbound Web Service.
Data Synchronization
Component
Description
W1-MDMAssetSyncRequestRead
Used to read an MDM Asset Sync Request record.
This component invokes the ATW1MDMAssetSyncRequestRead Inbound Web Service using the W1-MDMAssetSyncRequest Business Object.
W1-OngoingSyncRequestAssetNodeRead
Used to read an Asset-Node Ongoing Sync Request record.
This component invokes the ATW1OngoingSyncRequestAssetNodeRead Inbound Web Service using the W1-OngoingSyncRequestAssetNode Business Object.
Digital Asset Cloud Service
Component
Description
X1-ControllableAssetSpec
Used to create controllable asset specification.
This component invokes the X1- ControllableAssetSpec business object using the ATX1ControllableAssetSpec Inbound Web Service.
Used to create controllable asset.
This component invokes the X1-ControllableAsset business object using the ATX1ControllableAsset Inbound Web Service.
X1-CtrlDvcStatusCheckRespType
Used to create CtrlDvcStatusCheckRespType.
This component invokes the X1- CtrlDvcStatusCheckRespType business object using the ATX1CtrlDvcStatusCheckRespType IWS.
X1-CtrlDvcStatusCheckComm
Used to create CtrlDvcStatusCheckComm.
This component invokes the X1- CtrlDvcStatusCheckComm business object using the ATX1CtrlDvcStatusCheckCommIWS.
Used to create CtrlDvcStatusCheck.
This component invokes the X1- CtrlDvcStatusCheck business object using the ATX1CtrlDvcStatusCheck IWS.
X1-CtrlDvcHeadEndSystem
Used to create CtrlDvcHeadEndSystem.
This component invokes the X1- CtrlDvcHeadEndSystem business object using the ATX1CtrlDvcHeadEndSystemIWS.
X1-HowToSendSvcTaskResponse
Used to create HowToSendSvcTaskResponse.
This invokes the X1-HowToSendSvcTaskResponse business object using the ATX1HowToSendSvcTaskResponseIWS.
X1-CtrlDvcStatusCheckCommType
Used to create CtrlDvcStatusCheckCommType.
This invokes X1-CtrlDvcStatusCheckCommType business object using the ATX1CtrlDvcStatusCheckCommType IWS.
X1-DigitalAssetEnrollTaskType
Used to create DigitalAssetEnrollTaskType.
This component invokes the X1- DigitalAssetEnrollTaskType business object using the ATX1DigitalAssetEnrollTaskType IWS.
Used to create DigitalAssetEnrollTask.
This component invokes the X1- DigitalAssetEnrollTask business object using the ATX1DigitalAssetEnrollTask IWS.
X1-EventSettlementCalcGroup
Used to create EventSettlementCalcGroup.
This component invokes the X1-EventSettlementCalcGroup business object using the ATX1EventSettlementCalcGroup IWS.
X1-EventSettlementCalcRule
Used to create EventSettlementCalcRule.
This component invokes the X1-EventSettlementCalcRule business object using the ATX1EventSettlementCalcRule IWS.
X1-KWhAvdBusinessFlag
Used to create KWhAvdBusinessFlag.
This component invokes the X1-KWhAvdBusinessFlag business object using the ATX1KWhAvdBusinessFlag IWS.
X1-EventSettlementTransaction
Used to create EventSettlementTransaction.
This component invokes the X1-EventSettlementTransaction business object using the ATX1EventSettlementTransaction IWS.
X1-CtrlDvcStatusCheckType
This component invokes the X1- CtrlDvcStatusCheckType business object using the ATX1CtrlDvcStatusCheckType IWS.
X1-UpdateCDL
Used to create UpdateCDL.
This component invokes the X1-UpdateCDL business object using the ATX1UpdateCDL IWS.
X1-DeviceLocation
Used to create DeviceLocation.
This component invokes the X1-DeviceLocation business object using the ATX1DeviceLocation IWS.
Used to create CtrlDvcStatusCheckResp.
This component invokes the X1- CtrlDvcStatusCheckResp business object using the ATX1CtrlDvcStatusCheckResp IWS.
X1-ControllableDevice
Used to create ControllableDevice.
This component invokes the X1-ControllableDevice business object using the ATX1ControllableDevice IWS.
X1-ControllableDeviceType
Used to create ControllableDeviceType.
This component invokes the X1- ControllableDeviceType business object using the ATX1ControllableDeviceType IWS.
X1-ControllableAssetType
Used to create ControllableAssetType.
This component invokes the X1- ControllableAssetType business object using the ATX1ControllableAssetType IWS.
X1-DeviceLocationType
Used to create DeviceLocationType.
This component invokes the X1- DeviceLocationType business object using the ATX1DeviceLocationType IWS.
X1-ProgramSubscriptionType
Used to create ProgramSubscriptionType.
This component invokes the X1- ProgramSubscriptionType business object using the ATX1ProgramSubscriptionType IWS.
X1-ProgramCalculationGroup
Used to create ProgramCalculationGroup.
This component invokes the X1- ProgramCalculationGroup business object using the ATX1ProgramCalculationGroup IWS.
Used to create ProgramSubscription.
This component invokes the X1- ProgramSubscription business object using the ATX1ProgramSubscription IWS.
X1-GenericProgramCalcRule
Used to create GenericProgramCalcRule.
This component invokes the X1- GenericProgramCalcRule business object using the ATX1GenericProgramCalcRule IWS.
X1-DigitalAssetUnenrollTaskTyp
Used to create DigitalAssetUnenrollTaskTyp.
This component invokes the X1- DigitalAssetUnenrollTaskTyp business object using the ATX1 DigitalAssetUnenrollTaskTyp IWS.
X1-DAUnenrollActionMethod
Used to create DAUnenrollActionMethod.
This component invokes the X1- DAUnenrollActionMethod business object using the ATX1 DAUnenrollActionMethod IWS.
X1-DAEnrollActionMethod
Used to create DAEnrollActionMethod.
This component invokes the X1- DAEnrollActionMethod business object using the ATX1 DAEnrollActionMethod IWS.
X1-InitiativeDigitalAsset
Used to create InitiativeDigitalAsset.
This component invokes the X1- InitiativeDigitalAsset business object using the ATX1InitiativeDigitalAsset IWS.
X1-MeteredServiceCrit
Used to create MeteredServiceCrit.
This component invokes the X1- MeteredServiceCrit business object using the ATX1MeteredServiceCrit IWS.
X1-DigitalAssetMasterConfig
Used to create DigitalAssetMasterConfig.
This component invokes the X1- DigitalAssetMasterConfig business object using the ATX1DigitalAssetMasterConfig IWS.
Used to create DigitalAssetUnenrollTask.
This component invokes the X1- DigitalAssetUnenrollTask business object using the ATX1DigitalAssetUnenrollTask IWS.
X1-NMSDigitalAssetContact
Used to create NMSDigitalAssetContact.
This component invokes the X1- NMSDigitalAssetContact business object using the ATX1NMSDigitalAssetContact IWS.
X1-NMSDigitalAssetCustSync
Used to create NMSDigitalAssetCustSync.
This component invokes the X1- NMSDigitalAssetCustSync business object using the ATX1NMSDigitalAssetCustSync IWS.
X1- DRDigitalAssetCustSync
Used to create DRDigitalAssetCustSync.
This component invokes the X1- DRDigitalAssetCustSync business object using the ATX1DRDigitalAssetCustSync IWS.
X1-NMSDigitalAssetSubscription
Used to create NMSDigitalAssetSubscription.
This component invokes the X1- NMSDigitalAssetSubscription business object using the ATX1NMSDigitalAssetSubscription IWS.
X1-NMSDigitalAssetLocation
Used to create NMSDigitalAssetLocation.
This component invokes the X1- NMSDigitalAssetLocation business object using the ATX1NMSDigitalAssetLocation IWS.
X1-NMSDigitalAssetFacility
Used to create NMSDigitalAssetFacility.
This component invokes the X1- NMSDigitalAssetFacility business object using the ATX1NMSDigitalAssetFacility IWS.
X1-NMSDigitalAssetCustOutMsg
Used to create NMSDigitalAssetCustOutMsg.
This component invokes the X1- NMSDigitalAssetCustOutMsg business object using the ATX1NMSDigitalAssetCustOutMsg IWS.
X1-CtrlDvcStatusCheckOBMsg
Used to create CtrlDvcStatusCheckOBMsg.
This component invokes the X1- CtrlDvcStatusCheckOBMsg business object using the ATX1CtrlDvcStatusCheckOBMsg IWS.
D1-IMDFilter
This is the wrapper for the service that filters out IMD's based on the configuration of the device.
This invokes the D1-IMDFilter Business Service using the ATD1IMDFilter Inbound Web Service.
D1-RemoveIMDObjectCount
Used to perform actions such as ADD, READ, UPDATE, and DELETE of RemoveIMDObjectCount.
This component invokes the D1-RemoveIMDObjectCount using the ATD1RemoveIMDObjectCount Inbound Web Service.
D8-ReadOnDemandReadResultType
Used to perform actions such as ADD, READ, UPDATE and DELETE a Read On Demand Read Result Type for Itron.
This component invokes the D8- ReadOnDemandReadResultType Business Object using the ATD8ReadOnDemandReadResultType.
Initial Measurement Data
Component
Description
D1-IMDSeeder
Used to perform actions such as ADD, READ, UPDATE, and DELETE of an IMD Seeder.
This component invokes the D1-IMDSeeder Business Object using the ATD1IMDSeeder Inbound Web Service.
D1-ManualIMDInterval
Used to perform actions such as ADD, READ, UPDATE, and DELETE of Manual IMD Interval records.
This component invokes the D1-ManualIMDInterval Business Object using the ATD1ManualIMDInterval Inbound Web Service.
D1-ManualIMDScalar
Used to perform actions such as ADD, READ, UPDATE, and DELETE of Manual IMD Scalar records.
This component invokes the D1-ManualIMDScalar Business Object using the ATD1ManualIMDScalar Inbound Web Service.
D1-InitialLoadIMDInterval
Used to perform actions such as ADD, READ, UPDATE, and DELETE of Initial Load IMD Interval records.
This component invokes the D1- InitialLoadIMDInterval Business Object using the ATD1InitialLoadIMDInterval Inbound Web Service.
D1-InitialLoadIMDScalar
Used to perform actions such as ADD, READ, UPDATE, and DELETE of Initial Load IMD Scalar records.
This component invokes the D1-InitialLoadIMDScalar Business Object using the ATD1InitialLoadIMDScalar Inbound Web Service.
D1-EstimationIMDInterval
Used to perform actions such as ADD, READ, UPDATE, and DELETE of Estimation IMD Interval records.
This component invokes the D1-EstimationIMDInterval Business Object using the ATD1EstimationIMDInterval Inbound Web Service.
D1-EstimationIMDScalar
Used to perform actions such as ADD, READ, UPDATE, and DELETE of Estimation IMD Scalar records.
This component invokes the D1-EstimationIMDScalar Business Object using the ATD1EstimationIMDScalar Inbound Web Service.
Integration
Component
Description
D1-OngoingSyncRequestContact
Used to perform actions such as ADD, READ, UPDATE, and DELETE a OngoingSyncRequestContact.
This component invokes the D1-Ongoing SyncRequestContact Business Object using the ATD1OngoingSyncRequestContact Inbound Web Service.
D1-OngoingSyncRequestSP
Used to perform actions such as ADD, READ, UPDATE, and DELETE a OngoingSyncRequestSP.
This component invokes the D1-OngoingSyncRequestSP Business Object using the ATD1OngoingSyncRequestSP Inbound Web Service.
D1-OngoingSyncRequestDevice
Used to perform actions such as ADD, READ, UPDATE, and DELETE a OngoingSyncRequestDevice.
This component invokes the D1-OngoingSyncRequestDevice Business Object using the ATD1OngoingSyncRequestDevice Inbound Web Service.
D2-OngoingSyncRequestUS
Used to perform actions such as ADD, READ, UPDATE, and DELETE a OngoingSyncRequestUS.
This component invokes the D2-OngoingSyncRequestUS Business Object using the ATD2OngoingSyncRequestUS Inbound Web Service.
D1-OngoingSyncRequestDC
Used to perform actions such as ADD, READ, UPDATE,and DELETE a OngoingSyncRequestDC.
This component invokes the D2-OngoingSyncRequestDC Business Object using the ATD1OngoingSyncRequestDC Inbound Web Service.
D1-CompositeSyncRequestDC
Used to perform actions such as ADD, READ, UPDATE,and DELETE a CompositeSyncRequestDC.
This component invokes the D1-CompositeSyncRequestDC Business Object using the ATD1CompositeSyncRequestDC Inbound Web Service.
D1-OngoingSyncRequestMC
Used to perform actions such as ADD, READ, UPDATE,and DELETE a OngoingSyncRequestMC.
This component invokes the D1-OngoingSyncRequestMC Business Object using the ATD1OngoingSyncRequestMC Inbound Web Service.
D1-OngoingSyncReqScalarMtrRead
Used to perform actions such as ADD, READ, UPDATE,and DELETE a OngoingSyncReqScalarMtrRead.
This component invokes the D1-OngoingSyncReqScalarMtrRead Business Object using the ATD1OngoingSyncReqScalarMtrRead Inbound Web Service.
D1-OngoingSyncRequestIE
Used to perform actions such as ADD, READ, UPDATE,and DELETE a OngoingSyncRequestIE.
This component invokes the D1-OngoingSyncRequestIE Business Object using the ATD1OngoingSyncRequestIE Inbound Web Service.
D2-UsageTran_ValSQHighList
Used to perform actions such as READ on D2-UsageTransaction
This component invokes the D2-UsageTransaction Business Object using the ATD2UsageTransactiion Inbound Web Service.
D2-UsageTran_ValUsgPeriod
D2-InitialSyncRequestDynOpt
Used to perform actions such as ADD, READ, UPDATE,and DELETE a InitialSyncRequestDynOpt.
This component invokes the D2- InitialSyncRequestDynOpt Business Object using the ATD2InitialSyncRequestDynOpt Inbound Web Service.
D2-OngoingSyncRequestDynOpt
Used to perform actions such as ADD, READ, UPDATE,and DELETE a OngoingSyncRequestDynOpt.
This component invokes the D2-OngoingSyncRequestDynOpt Business Object using the ATD2OngoingSyncRequestDynOpt Inbound Web Service.
D2-InitialSyncRequestDynOptEvt
Used to perform actions such as ADD, READ, UPDATE,and DELETE a InitialSyncRequestDynOptEvt.
This component invokes the D2- InitialSyncRequestDynOptEvt Business Object using the ATD2InitialSyncRequestDynOptEvt Inbound Web Service.
D2-OngoingSyncRequestDynOptEvt
Used to perform actions such as ADD, READ, UPDATE,and DELETE a OngoingSyncRequestDynOptEvt.
This component invokes the D2- OngoingSyncRequestDynOptEvt Business Object using the ATD2OngoingSyncRequestDynOptEvt Inbound Web Service.
D2-CCBContractOptionTypeLookup
Used to perform actions such as ADD, READ, UPDATE,and DELETE a CCBContractOptionTypeLookup.
This component invokes the D2- CCBContractOptionTypeLookup Business Object using the ATD2CCBContractOptionTypeLookup Inbound Web Service.
D1-HowToTranslateExternalValue
Used to perform actions such as ADD, READ, UPDATE,and DELETE a HowToTranslateExternalValue.
This component invokes the D1- HowToTranslateExternalValue Business Object using the ATD1HowToTranslateExternalValue Inbound Web Service.
D1-CCBContactTypeLookup
Used to perform actions such as ADD, READ, UPDATE,and DELETE a CCBContactTypeLookup.
This component invokes the D1- CCBContactTypeLookup Business Object using the ATd1CCBContactTypeLookup Inbound Web Service.
D1-CCBLifeSupSensitiveLdLookup
Used to perform actions such as ADD, READ, UPDATE,and DELETE a CCBLifeSupSensitiveLdLookup.
This component invokes the D1- CCBLifeSupSensitiveLdLookup Business Object using the ATD1CCBLifeSupSensitiveLdLookup Inbound Web Service.
D2-CCBSATypeLookup
Used to perform actions such as ADD, READ, UPDATE,and DELETE a CCBSATypeLookup.
This component invokes the D2- CCBSATypeLookup Business Object using the ATD2CCBSATypeLookup Inbound Web Service.
D2-CCBSAStatusLookup
Used to perform actions such as ADD, READ, UPDATE,and DELETE a CCBSAStatusLookup.
This component invokes the D2- CCBSAStatusLookup Business Object using the ATD2CCBSAStatusLookup Inbound Web Service.
D1-InitialSyncRequestDevice
Used to perform actions such as ADD, READ, UPDATE,and DELETE a InitialSyncRequestDevice.
This component invokes the D2- InitialSyncRequestDevice Business Object using the ATD1InitialSyncRequestDevice Inbound Web Service.
Itron Master Data
Component
Description
D8-InitialLoadIMDInterval
Used to ADD Initial Measurement Interval Data for Itron OpenWay Adapter.
ATD8InitialLoadIMDInterval Inbound Web
Service.
D8-InitialLoadIMDScalar
Used to ADD Initial Measurement Scalar Data for Itron OpenWay Adapter.
ATD8InitialLoadIMDScalar Inbound Web Service.
D8-ScheduleRead
Used to perform actions such as ADD, READ, UPDATE and DELETE a Schedule Read for Itron.
This component invokes the D8-ScheduleRead
Business Object using the ATD8ScheduleRead
Itron Admin Data
Component
Description
D8-ReadIntervalType
Used to perform actions such as ADD, READ, UPDATE and DELETE a Itron - Contingency Read Type (Interval) outbound communication type.
This component invokes the D8-ReadIntervalType Business Object using the ATD8ReadIntervalType Inbound Web Service.
D8-ReadScalarType
Used to perform actions such as ADD, READ, UPDATE and DELETE an Itron - Contingency Read Type (Scalar) outbound communication type.
This component invokes the D8-ReadScalarType
Business Object using the ATD8ReadScalarType
D8-ReadResultType
Used to perform actions such as ADD, READ, UPDATE and DELETE an Itron - Contingency Read Result Type inbound communication type.
This component invokes the D8-ReadResultType
Business Object using the ATD8ReadResultType
D8-DeviceEventMappingLookup
Used to perform actions such as ADD, READ, UPDATE and DELETE a Value for Itron - Device Event Mapping extendable Lookup.
This component invokes the D8-DeviceEventMappingLookup Business Object using the ATD8DeviceEventMappingLookup Inbound Web Service.
D8-HeadendUOMLookup
Used to perform actions such as ADD, READ, UPDATE and DELETE a Value for Itron UOM Code to Standard UOM Mapping extendable Lookup.
This component invokes the D8-HeadendUOMLookup Business Object using the ATD8HeadendUOMLookup Inbound Web Service.
D8-ItronVersions
Used to perform actions such as ADD, READ, UPDATE and DELETE a Value for Itron - Versions Lookup extendable Lookup.
This component invokes the D8-ItronVersions
Business Object using the ATD8ItronVersions
D8-JobStatusLookup
Used to perform actions such as ADD, READ, UPDATE and DELETE of an Itron OpenWay Job Status record.
This component invokes the D8-JobStatusLookup Business Object using the ATD8JobStatusLookup Inbound Web Service.
D8-PingByEndpointsMDRespType
Used to perform actions such as ADD, READ, UPDATE and DELETE of an Itron OpenWay Ping By Endpoints MD Response Type record.
This component invokes the D8-PingByEndpointsMDRespType Business Object using the ATD8PingByEndpointsMDRespType Inbound Web Service.
D8-PingByEndpointsResponseType
Used to perform actions such as ADD, READ, UPDATE and DELETE of an Itron OpenWay Ping By Endpoints Response Type record.
PingByEndpointsResponseType Business Object
using the ATD8PingByEndpointsResponseType
D8-PingByEndpointsMultiDvcType
Used to perform actions such as ADD, READ, UPDATE and DELETE of an Itron OpenWay Ping By Endpoints Multi Device Type record.
This component invokes the D8-PingByEndpointsMultiDvcType Business Object using the ATD8PingByEndpointsMultiDvcType Inbound Web Service.
D8-PingByEndpointsType
Used to perform actions such as ADD, READ, UPDATE and DELETE of an Itron OpenWay Ping By Endpoints Type record.
This component invokes the D8-PingByEndpointsType Business Object using the ATD8PingByEndpointsType Inbound Web Service.
D8-AddMeterDefinitionsType
Used to perform actions such as ADD, READ, UPDATE and DELETE an Add Meter Definitions Type for Itron.
This component invokes the D8-AddMeterDefinitionsType Business Object using the ATD8AddMeterDefinitionsType Inbound Web Service.
D8-AppGroupLookup
Used to perform actions such as ADD, READ, UPDATE and DELETE an App Group Lookup for Itron.
This component invokes the D8-AppGroupLookup
Business Object using the ATD8AppGroupLookup
D8-DeregisterMeterType
Used to perform actions such as ADD, READ, UPDATE and DELETE an Deregister Meter Type for Itron.
This component invokes the D8-DeregisterMeterType Business Object using the ATD8DeregisterMeterType Inbound Web Service.
D8-DetLoadSideVolBytMtrRsltTyp
Used to perform actions such as ADD, READ, UPDATE and DELETE an Detect Load Side Voltage By tMeter Result Type for Itron.
This component invokes the D8-DetLoadSideVolBytMtrRsltTyp Business Object using the ATD8DetLoadSideVolBytMtrRsltTyp Inbound Web Service.
D8-DetectLoadSideVoltageMtrTyp
Used to perform actions such as ADD, READ, UPDATE and DELETE a Detect Load Side Voltage Meter Type for Itron.
This component invokes the D8-DetectLoadSideVoltageMtrTyp Business Object using the ATD8DetectLoadSideVoltageMtrTyp Inbound Web Service.
D8-DisconnectMeterResultType
Used to perform actions such as ADD, READ, UPDATE and DELETE a Disconnect Meter Result Type for Itron.
This component invokes the D8-DisconnectMeterResultType Business Object using the ATD8DisconnectMeterResultType Inbound Web Service.
D8-DisconnectMeterType
Used to perform actions such as ADD, READ, UPDATE and DELETE a Disconnect Meter Type for Itron.
This component invokes the D8-DisconnectMeterType Business Object using the ATD8DisconnectMeterType Inbound Web Service.
D8-DisconnectSwitchStateLookup
Used to perform actions such as ADD, READ, UPDATE and DELETE a Disconnect Switch State Lookup for Itron.
This component invokes the D8-DisconnectSwitchStateLookup Business Object using the ATD8DisconnectSwitchStateLookup Inbound Web Service.
D8-DvcStatusMappingLookup
Used to perform actions such as ADD, READ, UPDATE and DELETE a Device Status Mapping Lookup for Itron.
This component invokes the D8-DvcStatusMappingLookup Business Object using the ATD8DvcStatusMappingLookup Inbound Web Service.
D8-FailureReasonLookup
Used to perform actions such as ADD, READ, UPDATE and DELETE a Failure Reason Lookup for Itron.
FailureReasonLookup Business Object using the
ATD8FailureReasonLookup Inbound Web Service.
D8-IntStsCodeToCondMapLookup
Used to perform actions such as ADD, READ, UPDATE and DELETE a IntStsCodeToCondMapLookup for Itron.
IntStsCodeToCondMapLookup Business Object
using the ATD8IntStsCodeToCondMapLookup
D8-InterrogateByGroupRsltType
Used to perform actions such as ADD, READ, UPDATE and DELETE a Interrogate By Group
This component invokes the D8-InterrogateByGroupRsltType Business Object using the ATD8InterrogateByGroupRsltType Inbound Web Service.
D8-InterrogateByGroupType
Used to perform actions such as ADD, READ, UPDATE and DELETE a Interrogate By Group Type for Itron.
This component invokes the D8-InterrogateByGroupType Business Object using the ATD8InterrogateByGroupType Inbound Web Service.
D8-ReadDisconStBytMtrRsltType
Used to perform actions such as ADD, READ, UPDATE and DELETE a Read Disconnect State By Meter Result Type for Itron.
ReadDisconStBytMtrRsltType Business Object using
the ATD8ReadDisconStBytMtrRsltType Inbound
Web Service.
D8-ReadDisconStateByMtrType
Used to perform actions such as ADD, READ, UPDATE and DELETE a Read Disconnect State By Meter Type for Itron.
This component invokes the D8-ReadDisconStBytMtrType Business Object using the ATD8ReadDisconStBytMtrType Inbound Web Service.
D8-ReconnectMeterResultType
Used to perform actions such as ADD, READ, UPDATE and DELETE a Reconnect Meter Result Type for Itron.
ReconnectMeterResultType Business Object using
the ATD8ReconnectMeterResultType Inbound Web
Service.
D8-ReconnectMeterType
Used to perform actions such as ADD, READ, UPDATE and DELETE a Reconnect Meter Type for Itron.
This component invokes the D8-ReconnectMeterType Business Object using the ATD8ReconnectMeterType Inbound Web Service.
D8-ResultLookup
Used to perform actions such as ADD, READ, UPDATE and DELETE a Result Lookup for Itron.
This component invokes the D8-ResultLookup Business Object using the ATD8ResultLookup Inbound Web Service.
D8-ScheduleReadType
Used to perform actions such as ADD, READ, UPDATE and DELETE a Schedule Read Type for Itron.
This component invokes the D8-ScheduleReadType Business Object using the ATD8ScheduleReadType Inbound Web Service.
D8-RptSelfReadOptionLookup
Used to perform actions such as ADD, READ, UPDATE and DELETE a RptSelfReadOptionLookup for Itron.
This component invokes the D8-RptSelfReadOptionLookup Business Object using the ATD8RptSelfReadOptionLookup Inbound Web Service.
D8-AddMeterToHarness
Used to add a meter to the test harness.
D8-SetCommissionRequest
Used to set commission to True/False for a device.
D8-SetVoltage
Used to set voltage for a device.
Landis + Gyr Admin Data
Component
Description
D3-InitMtReadByMtNumType
Used to perform actions such as ADD, READ, UPDATE, and DELETE an Initiate Meter Read By Meter (Multispeak) outbound communication type.
This component invokes the D3- InitMtReadByMtNumType Business Object using the ATD3InitMtReadByMtNumType Inbound Web Service.
D3-LGMasterConfig
Used to perform actions such as ADD, READ, UPDATE, and DELETE LGMasterConfig.
This component invokes the D3-LGMasterConfig Business Object using the ATD3LGMasterConfig Inbound Web Service.
D3-CIMMeterOnDemandReadDRType
Used to perform actions such as ADD, READ, UPDATE, and DELETE CIMMeterOnDemandReadDRType.
This component invokes the D3-CIMMeterOnDemandReadDRType Business Object using the ATD3CIMMeterOnDemandReadDRType Inbound Web Service.
D3-CIMAsyncReplyMRDRType
Used to perform actions such as ADD, READ, UPDATE and DELETE CIMAsyncReplyMRDRType.
This component invokes the D3- CIMAsyncReplyMRDRType Business Object using the ATD3CIMAsyncReplyMRDRType Inbound Web Service.
D3-IntStsCodeToCondMapLookup
Used to perform actions such as ADD, READ, UPDATE and DELETE a value for L+G Interval Status Code to Condition Mapping extendable lookup.
This component invokes the D3- IntStsCodeToCondMapLookup Business Object using the ATD3IntStsCodeToCondMapLookup Inbound Web Service.
D3-ReadingChgNotificationType
Used to perform actions such as ADD, READ, UPDATE and DELETE a Reading Change Notification inbound communication type.
This component invokes the D3- ReadingChgNotificationType Business Object using the ATD3ReadingChgNotificationType Inbound Web Service.
D3-DeviceEventMappingLookup
Used to perform actions such as ADD, READ, UPDATE and DELETE a Device Event Mapping Lookup record.
This component invokes the D3- DeviceEventMappingLookup Business Object using the ATD3DeviceEventMappingLookup Inbound Web Service.
D3-HeadendUOMLookup
Used to perform actions such as ADD, READ, UPDATE and DELETE a Head End UOM Lookup record.
This component invokes the D3- HeadendUOMLookup Business Object using the ATD3HeadendUOMLookup Inbound Web Service.
D3-ConnectDisconStateChgNtfTyp
Used to perform actions such as ADD, READ, UPDATE and DELETE a Connect Disconnect State Change Notification Type record.
This component invokes the D3- ConnectDisconStateChgNtfTyp Business Object using the ATD3ConnectDisconStateChgNtfTyp Inbound Web Service.
D3-InitiateConnectDisconType
Used to perform actions such as ADD, READ, UPDATE and DELETE a Initiate Connect Disconnect Type record.
This component invokes the D3- InitiateConnectDisconType Business Object using the ATD3InitiateConnectDisconType Inbound Web Service.
D3-LoadActionCodeLookup
Used to perform actions such as ADD, READ, UPDATE and DELETE a Load Action Code Lookup record.
This component invokes the D3- LoadActionCodeLookup Business Object using the ATD3LoadActionCodeLookup Inbound Web Service.
D3-MeterAddNotificationMSType
Used to perform actions such as ADD, READ, UPDATE and DELETE a Meter Add Notification MS Type record.
This component invokes the D3- MeterAddNotificationMSType Business Object using the ATD3MeterAddNotificationMSType Inbound Web Service.
D3-MtrRmvNotifMultiSpkType
Used to perform actions such as ADD, READ, UPDATE and DELETE a Meter Remove Notification MultiSpk Type record.
This component invokes the D3- MtrRmvNotifMultiSpkType Business Object using the ATD3MtrRmvNotifMultiSpkType Inbound Web Service.
D3-ScheduleDemandResetRespTyp
Used to perform actions such as ADD, READ, UPDATE and DELETE a Schedule Demand Reset Resp Type record.
This component invokes the D3- ScheduleDemandResetRespTyp Business Object using the ATD3ScheduleDemandResetRespTyp Inbound Web Service.
D3-ScheduleDemandResetType
Used to perform actions such as ADD, READ, UPDATE and DELETE a Schedule Demand Reset Type record.
This component invokes the D3- ScheduleDemandResetType Business Object using the ATD3ScheduleDemandResetType Inbound Web Service.
D3-AddMeterTo Harness
Used to perform AddMeterToHarness to the LG test harness.
This component invokes the D3- AddMeterToHarness Business Object using the ATD3AddMeterToHarness Inbound Web Service.
D3-SetCommissionRequest
Used to perform actions such as ADD, READ, UPDATE and DELETE a SetCommissionRequest Type record.
This component invokes the D3- SetCommissionRequest using the ATD3SetCommissionRequest Inbound Web Service.
D3-AddMeterToInventoryMSType
Used to perform actions such as ADD, READ, UPDATE and DELETE a Add Meter To Inventory MS Type record.
This component invokes the D3- AddMeterToInventoryMSType using the ATD3AddMeterToInventoryMSType Inbound Web Service.
D3-MeterRetireNotificationType
Used to perform actions such as ADD, READ, UPDATE and DELETE a MeterRetireNotificationType record.
This component invokes the D3- MeterRetireNotificationType using the ATD3MeterRetireNotificationType Inbound Web Service.
Landis + Gyr Master Data
Component
Description
D3-AddMeterToInventoryMultiSp
Used to perform actions such as ADD, READ, UPDATE and DELETE a Add Meter To Inventory Multi Sp record.
This component invokes the D3- AddMeterToInventoryMultiSp using the ATD3AddMeterToInventoryMultiSp Inbound Web Service.
D3-InitialLoadIMDInterval
L+G Adapter.
This component invokes the D3- InitialLoadIMDInterval Business Object using the ATD3InitialLoadIMDInterval Inbound Web Service.
D3-InitialLoadIMDScalar
Used to ADD Initial Measurement Scalar Data for L+G Adapter.
This component invokes the D3- InitialLoadIMDScalar Business Object using the ATD3InitialLoadIMDScalar Inbound Web Service.
Used to perform actions such as ADD, READ, UPDATE and DELETE a MeterRetireNotification record.
This component invokes the D3- MeterRetireNotification using the ATD3MeterRetireNotification Inbound Web Service.
SMDF Admin Data
Component
Description
D2-SubIntAdjustmentVEE
Performs adjustments to consumption; the changes to consumption will be validated against the readings contained prior to and subsequent to the change made.
This component invokes the D2-SubIntAdjustmentVEE Business Object using the ATD2SubIntAdjustmentVEE Inbound Web Service.
D1-VEEGroup
Used to create a VEE Group.
This component invokes the D1-VEEGroup Business Object using the ATD1VEEGroup Inbound Web Service.
D2-NegativeConsumptionCheck
Used to create a Negative-Consumption Check VEE Rule.
This component invokes the D2- NegativeConsumptionCheck Business Object using the ATD2NegativeConsumptionCheck Inbound Web Service.
D2-RegisterMultiplierCheck
Used to create a Multiplier Check VEE Rule.
This component invokes the D2-RegisterMultiplierCheck Business Object using the ATD2RegisterMultiplierCheck Inbound Web Service.
D2-IntervalReplacementRule
Used to create an IntervalReplacementRule VEE rule.
This component invokes the D2-IntervalReplacementRule Business Object using the ATD2IntervalReplacementRule Inbound Web Service.
D2-IntervalSpikeCheck
Used to create an IntervalSpikeCheck VEE rule.
This component invokes the D2-IntervalSpikeCheck Business Object using the ATD2IntervalSpikeCheck Inbound Web Service.
D2-ScalarReplacementRule
Used to create a ScalarReplacementRule VEE rule.
This component invokes the D2-ScalarReplacementRule Business Object using the ATD2ScalarReplacementRule Inbound Web Service.
D1-VEERuleSuccessTermination
Used to create a VEERuleSuccessTermination VEE rule.
This component invokes the D1-VEERuleSuccessTermination Business Object using the ATD1VEERuleSuccessTermination Inbound Web Service.
D2-IntervalAveragingEstimation
Describes Interval Averaging Estimation.
This component invokes the D2-IntervalAveragingEstimation Business Object using the ATD2IntervalAveragingEstimation Inbound Web Service.
D2-IntervalProfileEstimation
Describes Interval Profile Estimation.
This component invokes the D2-IntervalProfileEstimation Business Object using the ATD2IntervalProfileEstimation Inbound Web Service.
D2-IntervalSizeValidation
Describes Interval Size Validation.
This component invokes the D2-IntervalSizeValidation Business Object using the ATD2IntervalSizeValidation Inbound Web Service.
D2-RaiseMissingQuantityExcp
Describes Raise Missing Quantity Exception.
This component invokes the D2-RaiseMissingQuantityExcp Business Object using the ATD2RaiseMissingQuantityExcp Inbound Web Service.
D1-VEERuleReferredVEEGroup
Calls the VEE processor to execute the rules for the VEE group configured on the rule.
This component invokes the D1-VEERuleReferredVEEGroup Business Object using the ATD1VEERuleReferredVEEGroup Inbound Web Service.
D2-SSMeterReadTaskType
Holds the default values such as measurement condition, service provider, and data source used in self-service meter read creation. To Do type and role, if specified will be used when reporting errors that occur during IMD creation.
This component invokes the D2-SSMeterReadTaskType Business Object using the ATD2SSMeterReadTaskType Inbound Web Service.
D2-ProlongedEstimationCheck
Describes ProlongedEstimationCheck.
This component invokes the D2-ProlongedEstimationCheck Business Object using the ATD2 ProlongedEstimationCheck Inbound Web Service.
D1-DuplicateIMDCheck
Checks whether the current IMD is a duplicate of one already received for the same measuring component.
This component produces a VEE exception of the type and severity defined on the rule when it is configured.
It invokes the D1-DuplicateIMDCheck Business Object using the ATD1DuplicateIMDCheck Inbound Web Service.
D1-VEERuleGroupFactor
Describes the VEE Rule group factor.
This component invokes the D1-VEERuleGroupFactor Business Object using the
ATD1VEERuleGroupFactor Inbound Web Service.
D2-FinalMeasurementValidation
Describes the Final Measurement Validation.
This component invokes the D2-FinalMeasurementValidation Business Object using the ATD2FinalMeasurementValidation Inbound Web Service.
D2-ScalarProfileEstimation
Used to create a ScalarProfileEstimation VEE Rule.
This component invokes the D2-ScalarProfileEstimation Business Object using the
ATD2ScalarProfileEstimation Inbound Web
Service.
D2-SumCheck
Used to create a SumCheck VEE Rule.
This component invokes the D2-SumCheck Business Object using the ATD2SumCheck Inbound Web Service.
D2-ScalarCalcFromInterval
Describes Scalar Calculation from Interval.
This component invokes the D2-ScalarCalcFromInterval Business Object using the ATD2ScalarCalcFromInterval Inbound Web Service.
D2-ScalarEstimation
Describes the Describes Scalar Estimation VEE Rule.
This component invokes the D2-ScalarEstimation Business Object using the ATD2ScalarEstimation Inbound Web Service.
D2-UOMCheck
Used to create UOM Check VEE rule.
This component invokes the D2-UOMCheck Business Object using the ATD2UOMCheck Inbound Web Service.
D2-ZeroConsumptionCheck
Used to create Zero Consumption Check VEE rule.
This component invokes the D2-ZeroConsumptionCheck Business Object using the ATD2ZeroConsumptionCheck Inbound Web Service.
D1-VEERuleExceptionHandler
Used to create a VEERuleExceptionHandler VEE Rule.
This component invokes the D1-VEERuleExceptionHandler Business Object using the ATD1VEERuleExceptionHandler Inbound Web Service.
D2-EnsureIMDExistsForSibling
Used to create a EnsureIMDExistsForSibling VEE rule.
This component invokes the D2-EnsureIMDExistsForSibling Business Object using the ATD2EnsureIMDExistsForSibling Inbound Web Service.
D2-IntervalAdjustmentFrmScalar
Used to create a IntervalAdjustmentFrmScalar VEE rule.
This component invokes the D2-IntervalAdjustmentFrmScalar Business Object using the ATD2IntervalAdjustmentFrmScalar Inbound Web Service.
D2-IntervalInterpolationEst
Used to create an IntervalInterpolationEst VEE rule.
This component invokes the D2-IntervalInterpolationEst Business Object using the ATD2IntervalInterpolationEst Inbound Web Service.
D2-GetSubtractiveInterval
Allows the configuration of subtractive interval data retrieval during usage transaction processing. The rule records service quantities per service point and measuring component - which means that subtractive interval curves for different measuring components.
This component invokes the D2-GetSubtractiveInterval Business Object using the ATD2GetSubtractiveInterval Inbound Web Service.
D1-MeterReadDownloadActType
Used to create a MeterReadDownloadActType Activity Type.
This component invokes the D1-MeterReadDownloadActType Business Object using the ATD1MeterReadDownloadActType Inbound Web Service.
D1-PairedEventLastDvcEvtType
Used to create a PairedEventLastDvcEvtType Device Event Type.
This component invokes the D1-PairedEventLastDvcEvtType Business Object using the ATD1PairedEventLastDvcEvtType Inbound Web Service.
D1-StandardDeviceEventType
Used to create a StandardDeviceEventType Device Event Type.
This component invokes the D1-StandardDeviceEventType Business Object using the ATD1StandardDeviceEventType Inbound Web Service.
D1-UTCorrectnPrcessrActvtyType
Defines the activity BO to use in the creation of a Usage Transaction Correction Processor. This component also defines the general category of these activities as a Correction Processor.
The component invokes the D1-UTCorrectnPrcessrActvtyType Business Object using the ATD1UTCorrectnPrcessrActvtyType Inbound Web Service.
D1-RemoteConnectType
Describes configuration parameters required for the Remote Connect command activity, including automated retry and command time-out options.
This component allows the definition of a Service Issue Monitor Type resulting in the creation of a Service Issue Monitor of the configured type if a Remote Connect command activity has failed.
The component invokes the D1-RemoteConnectType Business Object using the ATD1RemoteConnectType Inbound Web Service.
D1-PairedEventFirstDvcEvtType
Describes the Device Event Type - Paired Event (First).
This component invokes the D1-PairedEventFirstDvcEvtType Business Object using the ATD1PairedEventFirstDvcEvtType Inbound Web Service.
D1-DeviceWithDurationActType
Describes the Device Activity with Duration Type.
This component invokes the D1-DeviceWithDurationActType Business Object using the ATD1DeviceWithDurationActType Inbound Web Service.
D2-SubMeasurementAggType
Describes the Sub Measurement Aggregator Type.
This component invokes the D2-SubMeasurementAggType Business Object using the ATD2SubMeasurementAggType Inbound Web Service.
D2-MasterMsrmtAggregatorType
Describes the Master Measurement Aggregator Type.
This component invokes the D2-MasterMsrmtAggregatorType Business Object using the ATD2MasterMsrmtAggregatorType Inbound Web Service.
D2-ActivityTypeAggDimScanner
Describes the Aggregator Dimension Scanner Activity Type.
This component invokes the D2-ActivityTypeAggDimScanner Business Object using the ATD2ActivityTypeAggDimScanner Inbound Web Service.
D2-AggregatorType
Used to create an AggregatorType Measuring Component Type.
This component invokes the D2-AggregatorType Business Object using the ATD2AggregatorType Inbound Web Service.
D1-IntervalChannelTypePhysical
Used to create a IntervalChannelTypePhysical.
This component invokes the D1-IntervalChannelTypePhysical Business Object using the ATD1IntervalChannelTypePhysical Inbound Web Service.
D1-MeasurementCycleSchedule
Used to create a MeasurementCycleSchedule.
This component invokes the D1-MeasurementCycleSchedule Business Object using the ATD1MeasurementCycleSchedule Inbound Web Service.
D1-ReaderRemarkType
Used to create a ReaderRemarkType.
This component invokes the D1-ReaderRemarkType Business Object using the ATD1ReaderRemarkType Inbound Web Service.
D1-ServiceIssueMonitorType
Used to create a ServiceIssueMonitorType.
This component invokes the D1-ServiceIssueMonitorType Business Object using the ATD1ServiceIssueMonitorType Inbound Web Service.
D2-MsrmtQuantityAggScannerType
Used to create a MsrmtQuantityAggScannerType.
This component invokes the D2-MsrmtQuantityAggScannerType Business Object using the ATD2MsrmtQuantityAggScannerType Inbound Web Service.
D2-TOUGroup
Used to create a TOUGroup.
This component invokes the D2-TOUGroup Business Object using the ATD2TOUGroup Inbound Web Service.
D2-VEERuleHighLowCheck
Used to create a VEERuleHighLowCheck.
VEERuleHighLowCheck Business Object using the
ATD2VEERuleHighLowCheck Inbound Web
Service.
D1-HowToCreateMCInformation
Used to create a HowToCreateMCInformation.
This component invokes the D1-HowToCreateMCInformation Business Object using the ATD1HowToCreateMCInformation Inbound Web Service.
D1-HowToSendActivityResponse
Used to create a HowToSendActivityResponse.
This component invokes the D1-HowToSendActivityResponse Business Object using the ATD1HowToSendActivityResponse Inbound Web Service.
D1-AvgDailyEstItemConsumption
Used to create a AvgDailyEstItemConsumption.
This component invokes the D1-AvgDailyEstItemConsumption Business Object using the ATD1AvgDailyEstItemConsumption Inbound Web Service.
D1-VEEEligibilityCriteria
Used to create a VEEEligibilityCriteria.
This component invokes the D1-VEEEligibilityCriteria Business Object using the
ATD1VEEEligibilityCriteria Inbound Web Service.
D2-VerifyUomTouSqiMCExistForUs
Used to create a VerifyUomTouSqiMCExistForUs.
This component invokes the D2-VerifyUomTouSqiMCExistForUs Business Object using the ATD2VerifyUomTouSqiMCExistForUs Inbound Web Service.
D1-DeviceEventSeeder
Used to create a DeviceEventSeeder.
This component invokes the D1-DeviceEventSeeder Business Object using the ATD1DeviceEventSeeder Inbound Web Service.
D1-FieldActivity
Used to create a FieldActivity.
This component invokes the D1-FieldActivity Business Object using the ATD1FieldActivity Inbound Web Service.
D1-ReaderRemark
Used to create a ReaderRemark.
This component invokes the D1-ReaderRemark Business Object using the ATD1ReaderRemark Inbound Web Service.
Used to create a TimeZoneTranslationLookup.
This component invokes the D1-ATD1TimeZoneTranslationLookup Business Object using the ATD1ReaderRemark Inbound Web Service.
D2-UsageCalculationGroupLookup
Used to create a UsageCalculationGroupLookup.
This component invokes the D2-UsageCalculationGroupLookup Business Object using the ATD2UsageCalculationGroupLookup Inbound Web Service.
D2-MDMMasterConfig
Used to perform actions such as ADD, READ, UPDATE, and DELETE a MDMMasterConfig.
D2-MDMMasterConfig
Used to perform actions such as ADD, READ, UPDATE, and DELETE a MtrCommTrckngAggregatorType.
Used to perform actions such as ADD, READ, UPDATE, and DELETE a EstimationSuppressionType.
D2-InactiveMeasurementCheck
Used to perform actions such as ADD, READ, UPDATE, and DELETE a InactiveMeasurementCheck VEE Rule.
Service.
Used to perform actions such as ADD, READ, UPDATE, and DELETE a ChannelStatisticsType.
Used to perform actions such as ADD, READ, UPDATE, and DELETE a ChannelStatistics.
This component invokes the D1- ChannelStatistics Business Object using the ATD1ChannelStatistics Inbound Web Service.
D1-FacilityLite
Used to perform actions such as ADD, READ, UPDATE, and DELETE a FacilityLite.
This component invokes the D1- FacilityLite Business Object using the ATD1FacilityLite Inbound Web Service.
Used to perform actions such as ADD, READ, UPDATE, and DELETE a SpecificationLookup.
Used to perform actions such as ADD, READ, UPDATE, and DELETE a MeasuringCompTypLite.
D1-GetDvcFrmIdenTypFlag
Used to retrieve Device ID By Identifier and Type Flag using the ATD1 GetDvcFrmIdenTypFlag Inbound Web Service.
D1-GetSimdIdFromImd
Used to retrieve Simd ID By IMD ID using the ATD1GetSimdIdFromImd Inbound Web Service.
D1-GetMCFrmDvcExtId
Used to retrieve Measuring Component ID from Device External ID using the ATD1GetMCFrmDvcExtId Inbound Web Service.
D1-GetProductKeyFromSync
Used to Get Product Key from Sync Request ID using the ATD1 GetProductKeyFromSync Inbound
Web Service.
D1-GetUsageFromExtID
Used to retrieve Usage ID from CCB Usage ID using the ATD1 GetUsageFromExtID Inbound Web Service.
D2-GetUSFromExtID
Used to retrieve US ID from External ID using the ATD1 GetUSFromExtID Inbound Web Service.
D1-GetDCFrmDvcExtId
Used to retrieve DC ID from External ID using the ATD1GetDCFrmDvcExtId Inbound Web Service.
D1-GetInstEvtFromDvcExId
Used to retrieve Install Event ID from Device External ID using ATD1GetInstEvtFromDvcExId Inbound Web Service.
D1-GetInstEvtFrmSPExtId
Used to retrieve Install Event ID from Service Point External ID using the ATD1GetInstEvtFrmSPExtId Inbound Web Service.
D1-GetMCFromExtID
Used to retrieve Measuring Component ID from External ID using the ATD1GetMCFromExtID Inbound Web Service.
D1-GetContactFromExtID
Used to retrieve Contact ID from External ID using the ATD1GetContactFromExtID Inbound Web Service.
D1-GetSpFromExtID
Used to retrieve Service Point ID from External ID using the ATD1GetSpFromExtID Inbound Web Service.
D1-GetSyncReqIdFrmExtId
Used to retrieve Sync Request ID from External ID using the ATD1GetSyncReqIdFrmExtId Inbound Web Service.
SMDF Master Data
Component
Description
D2- MtrCommTrckgDimScanner
Used to perform actions such as ADD, READ, UPDATE, and DELETE a MtrCommTrckgDimScanner.
This component invokes the D2-MtrCommTrckgDimScanner Business Object using the ATD2MtrCommTrckgDimScanner Inbound Web Service.
Used to perform actions such as ADD, READ, UPDATE, and DELETE a EstimationSuppression.
This component invokes the D2-EstimationSuppression Business Object using the ATD2EstimationSuppression Inbound Web Service.
D1-InitialLoadIMDSubtrInterval
Used to perform actions such as ADD, READ, UPDATE, and DELETE a InitialLoadIMDSubtrInterval.
This component invokes the D1-InitialLoadIMDSubtrInterval Business Object using the ATD1InitialLoadIMDSubtrInterval Inbound Web Service.
D1-EstimationIMDSubtrInterval
Used to perform actions such as ADD, READ, UPDATE, and DELETE a EstimationIMDSubtrInterval.
This component invokes the D1-EstimationIMDSubtrInterval Business Object using the ATD1EstimationIMDSubtrInterval Inbound Web Service.
D1-ManualIMDSubtrInterval
Used to perform actions such as ADD, READ, UPDATE, and DELETE a ManualIMDSubtrInterval.
This component invokes the D1-ManualIMDSubtrInterval Business Object using the ATD1ManualIMDSubtrInterval Inbound Web Service.
D1-SystemIMDSubtrInterval
Used to perform actions such as ADD, READ, UPDATE, and DELETE a SystemIMDSubtrInterval.
This component invokes the D1-SystemIMDSubtrInterval Business Object using the ATD1SystemIMDSubtrInterval Inbound Web Service.
D1-SubtractveIntvalMeasurement
Used to perform actions such as ADD, READ, UPDATE, and DELETE a SubtractveIntvalMeasurement.
This component invokes the D1-SubtractveIntvalMeasurement Business Object using the ATD1SystemIMDSubtrInterval Inbound Web Service.
D1-IntrvlChanTypPhysSubtractiv
Used to perform actions such as ADD, READ, UPDATE, and DELETE a IntrvlChanTypPhysSubtractiv.
This component invokes the D1-IntrvlChanTypPhysSubtractiv Business Object using the ATD1IntrvlChanTypPhysSubtractiv Inbound Web Service.
D1-IntervalChannelSubtractive
Used to perform actions such as ADD, READ, UPDATE, and DELETE a IntervalChannelSubtractive.
This component invokes the D1-IntervalChannelSubtractive Business Object using the ATD1IntervalChannelSubtractive Inbound Web Service.
SSN Admin Data
Component
Description
D7-AddMeterReadJobIntervalType
Used to perform actions such as ADD, READ, UPDATE and DELETE a SSN - Add Meter Read Job (Interval) Type outbound communication type.
This component invokes the D7- AddMeterReadJobIntervalType Business Object using the ATD7AddMeterReadJobIntervalType Inbound Web Service.
D7-AddMeterReadJobScalarType
Used to perform actions such as ADD, READ, UPDATE and DELETE a SSN - Add Meter Read Job (Scalar) Type outbound communication type.
This component invokes the D7- AddMeterReadJobScalarType Business Object using the ATD7AddMeterReadJobScalarType Inbound Web Service.
D7-MeterReadInterRespType
UPDATE and DELETE a SSN - Meter Read Response (Interval) Type inbound communication type.
This component invokes the D7- MeterReadInterRespType Business Object using the ATD7MeterReadInterRespType Inbound Web Service.
D7-MeterReadRespScalarType
Used to perform actions such as ADD, READ, UPDATE and DELETE a SSN - Meter Read Response (Scalar) Type inbound communication type.
This component invokes the D7- MeterReadRespScalarType Business Object using the ATD7MeterReadRespScalarType Inbound Web Service.
D7-DeviceEventMappingLookup
Used to perform actions such as ADD, READ, UPDATE and DELETE a Value for SSN Device Event Mapping extendable lookup.
This component invokes the D7- DeviceEventMappingLookup Business Object using the ATD7DeviceEventMappingLookup Inbound Web Service.
D7-DataTimeZoneLookup
Used to perform actions such as ADD, READ, UPDATE and DELETE a Value for SSN Data Time Zone extendable lookup.
This component invokes the D7- DataTimeZoneLookup Business Object using the ATD7DataTimeZoneLookup Inbound Web Service.
D7-AddPingJobType
Used to perform actions such as ADD, READ, UPDATE and DELETE of an SSN Add Ping Job Type record.
This component invokes the D7-AddPingJobType Business Object using the ATD7AddPingJobType Inbound Web Service.
D7-DeviceStatusLookup
Used to perform actions such as ADD, READ, UPDATE and DELETE of an SSN Device Status record.
This component invokes the D7- DeviceStatusLookup Business Object using the ATD7DeviceStatusLookup Inbound Web Service.
D7-ExecutionStatusLookup
Used to perform actions such as ADD, READ, UPDATE and DELETE of an SSN Execution Status record.
This component invokes the D7- ExecutionStatusLookup Business Object using the ATD7ExecutionStatusLookup Inbound Web Service.
D7-GetStatusResponseType
Used to perform actions such as ADD, READ, UPDATE and DELETE of an SSN Get Status Response Type record.
This component invokes the D7- GetStatusResponseType Business Object using the ATD7GetStatusResponseType Inbound Web Service.
D7-GetStatusType
Used to perform actions such as ADD, READ, UPDATE and DELETE of an SSN Get Status Type record.
This component invokes the D7-GetStatusType Business Object using the ATD7GetStatusType Inbound Web Service.
D7-PingJobRespType
Used to perform actions such as ADD, READ, UPDATE and DELETE of an SSN Ping Job Response Type record.
This component invokes the D7-PingJobRespType Business Object using the ATD7PingJobRespType Inbound Web Service.
D7-PriorityLookup
Used to perform actions such as ADD, READ, UPDATE and DELETE of an SSN Priority record.
This component invokes the D7-PriorityLookup Business Object using the ATD7PriorityLookup Inbound Web Service.
D7-ProvisioningActionLookup
Used to perform actions such as ADD, READ, UPDATE and DELETE of an SSN Provisioning Action record.
This component invokes the D7- ProvisioningActionLookup Business Object using the ATD7ProvisioningActionLookup Inbound Web Service.
D7-ProvisioningCommandStatus
Used to perform actions such as ADD, READ, UPDATE and DELETE of an SSN Provisioning Command Status record.
This component invokes the D7- ProvisioningCommandStatus Business Object using the ATD7ProvisioningCommandStatus Inbound Web Service.
D7-ProvisioningDataType
UPDATE and DELETE of an SSN Provisioning Data Type record.
This component invokes the D7- ProvisioningDataType Business Object using the ATD7ProvisioningDataType Inbound Web Service.
D7-SSNVersionLookup
Used to perform actions such as ADD, READ, UPDATE and DELETE of an SSN SSN Version record.
This component invokes the D7- SSNVersionLookup Business Object using the ATD7SSNVersionLookup Inbound Web Service.
D7-StatusFlagNameLookup
Used to perform actions such as ADD, READ, UPDATE and DELETE of an SSN Status Flag Name record.
This component invokes the D7- StatusFlagNameLookup Business Object using the ATD7StatusFlagNameLookup Inbound Web Service.
D7-ChannelStatusLookup
Used to perform actions such as ADD, READ, and
UPDATE and DELETE a Channel Status Lookup for SSN adapter.
This component invokes the D7- ChannelStatusLookup Business Object using the ATD7ChannelStatusLookup Inbound Web Service.
D7-ConnectDisconRespType
Used to perform actions such as ADD, READ, and UPDATE and DELETE a Connect Disconnect Response Type for SSN adapter.
This component invokes the D7- ConnectDisconRespType Business Object using the ATD7ConnectDisconRespType Inbound Web Service.
D7-ConnectDisconnectType
UPDATE and DELETE a Connect Disconnect Type for SSN adapter.
This component invokes the D7- ConnectDisconType Business Object using the ATD7ConnectDisconType Inbound Web Service.
D7-HeadendSQILookup
Used to perform actions such as ADD, READ, and UPDATE and DELETE a Headend SQI Lookup for SSN adapter.
This component invokes the D7- HeadendSQILookup Business Object using the ATD7HeadendSQILookup Inbound Web Service.
D7-HeadendTOULookup
Used to perform actions such as ADD, READ, and UPDATE and DELETE a Headend TOU Lookup for SSN adapter.
This component invokes the D7- HeadendTOULookup Business Object using the ATD7HeadendTOULookup Inbound Web Service.
D7-HeadendUOMLookup
Used to perform actions such as ADD, READ, and UPDATE and DELETE a Headend UOM Lookup for SSN adapter.
This component invokes the D7- HeadendUOMLookup Business Object using the ATD7HeadendUOMLookup Inbound Web Service.
D7-IntStsCodeToCondMapLookup
Used to perform actions such as ADD, READ, and UPDATE and DELETE a IntStsCodeToCondMapLookup for SSN adapter.
This component invokes the D7- IntStsCodeToCondMapLookup Business Object using the ATD7IntStsCodeToCondMapLookup Inbound Web Service.
D7-IntervalStatusLookup
Used to perform actions such as ADD, READ, and UPDATE and DELETE a Interval Status Lookup for SSN adapter.
This component invokes the D7- IntervalStatusLookup Business Object using the ATD7IntervalStatusLookup Inbound Web Service.
D7-MeterConnectionStatusLookup
Used to perform actions such as ADD, READ, and UPDATE and DELETE a Meter Connection Status Lookup for SSN adapter.
This component invokes the D7- MeterConnectionStatusLookup Business Object using the ATD7MeterConnectionStatusLookup Inbound Web Service.
D7-MeterReadTypeLookup
Used to perform actions such as ADD, READ, and UPDATE and DELETE a Meter Read Type Lookup for SSN adapter.
This component invokes the D7- MeterReadTypeLookup Business Object using the ATD7MeterReadTypeLookup Inbound Web Service.
D7-OldAdminStateNameLookup
Used to perform actions such as ADD, READ, and UPDATE and DELETE an Old Admin State Name Lookup for SSN adapter.
This component invokes the D7- OldAdminStateNameLookup Business Object using the ATD7OldAdminStateNameLookup Inbound Web Service.
D7-ReadModeLookup
Used to perform actions such as ADD, READ, and UPDATE and DELETE a Read Mode Lookup for SSN adapter.
This component invokes the D7-ReadModeLookup Business Object using the ATD7ReadModeLookup Inbound Web Service.
D7-RegisterReadSourceLookup
Used to perform actions such as ADD, READ, and UPDATE and DELETE a Register Read Source Lookup for SSN adapter.
This component invokes the D7- RegisterReadSourceLookup Business Object using the ATD7RegisterReadSourceLookup Inbound Web Service.
D7-RegisterStatusLookup
UPDATE and DELETE a Register Status Lookup for SSN adapter.
This component invokes the D7- RegisterStatusLookup Business Object using the ATD7RegisterStatusLookup Inbound Web Service.
D7-
RepDeviceAtLocForDecommType
Used to perform actions such as ADD, READ, and UPDATE and DELETE a RepDeviceAtLocForDecommType for SSN adapter.
This component invokes the D7- RepDeviceAtLocForDecommType Business Object using the ATD7RepDeviceAtLocForDecommType Inbound Web Service.
D7-ReplaceLocationType
Used to perform actions such as ADD, READ, and UPDATE and DELETE a Replace Location Type for SSN adapter.
This component invokes the D7- ReplaceLocationType Business Object using the ATD7ReplaceLocationType Inbound Web Service.
D7-VersionMasterConfig
Used to perform actions such as ADD, READ, and UPDATE and DELETE a Version Master Configuration for SSN adapter.
This component invokes the D7- VersionMasterConfig Business Object using the ATD7VersionMasterConfig Inbound Web Service.
D7-AddMeterToHarness
Used to perform the AddMeterToHarness action to SSN test harness.
This component invokes the D7- AddMeterToHarness using the ATD7AddMeterToHarness Inbound Web Service.
D7-SetCommissionRequest
This component invokes the D7- SetCommissionRequest using the ATD7SetCommissionRequest Inbound Web Service.
D7-GetJobStatusDRPType
Used to perform actions such as ADD, READ, UPDATE, and DELETE a GetJobStatusDRPType record.
This component is invoked using the ATD7GetJobStatusDRPType Inbound Web Service.
D7-AddMeterReadJobScalrDRPType
Used to perform actions such as ADD, READ, UPDATE and DELETE a AddMeterReadJobScalrDRPType record.
This component is invoked using ATD7AddMeterReadJobScalrDRPType Inbound Web Service.
D7-SetVoltage
Used to perform action set voltage on a SSN device in test harness.
This component invokes the D7- SetVoltage using the ATD7SetVoltage Inbound Web Service.
DG-GenericMasterConfig
Used to perform actions on GenericMasterConfig record.
This invokes DG-GenericMasterConfig using ATDGGenericMasterConfig Inbound Web Service.
DG-HeadendUOMLookup
Used to perform actions on HeadendUOMLookup record.
This invokes DG-HeadendUOMLookup using ATDGHeadendUOMLookup Inbound Web Service.
DG-CIMGetMtrReadScalarType
Used to perform actions on CIMGetMtrReadScalarType record.
This invokes DG-CIMGetMtrReadScalarType using ATDGCIMGetMtrReadScalarType Inbound Web Service.
DG-CIMMtrReadResponseDRType
Used to perform actions on CIMMtrReadResponseDRType record.
This invokes DG-CIMMtrReadResponseDRType using ATDGCIMMtrReadResponseDRType Inbound Web Service.
SSN Master Data
Component
Description
D7-InitialLoadIMDInterval
Used to ADD Initial Measurement Interval Data for SSN Adapter.
This component invokes the D7- InitialLoadIMDInterval Business Object using the ATD7InitialLoadIMDInterval Inbound Web Service.
D7-InitialLoadIMDScalar
Used to ADD Initial Measurement Scalar Data for SSN Adapter.
This component invokes the D7- InitialLoadIMDScalar Business Object using the ATD7InitialLoadIMDScalar Inbound Web Service.
D7-SmartMeter
Used to perform actions such as ADD, READ, and UPDATE and DELETE a Smart Meter for SSN adapter.
This component invokes the D7-SmartMeter Business Object using the ATD7SmartMeter Inbound Web Service.
D6-DeviceEventMappingLookup
Used to perform actions such as ADD, READ, UPDATE and DELETE a Value for Sensus Device Event Mapping extendable lookup.
This component invokes the D6- DeviceEventMappingLookup Business Object using the ATD6DeviceEventMappingLookup Inbound Web Service.
D6-InitiateMtrRdByMtrIDDRType
Used to perform actions such as ADD, READ, UPDATE and DELETE a InitiateMtrRdByMtrIDDRType.
This component invokes the D6-InitiateMtrRdByMtrIDDRType Business Object using the ATD6InitiateMtrRdByMtrIDDRType Inbound Web Service.
D6-ReadingChgNotifDRType
Used to perform actions such as ADD, READ, UPDATE and DELETE a Value for ReadingChgNotifDRType.
This component invokes the D6-ReadingChgNotifDRType Business Object using the ATD6ReadingChgNotifDRType Inbound Web Service.
D6-HeadendUOMLookup
Used to perform actions such as ADD, READ, UPDATE and DELETE a Value for Sensus UOM Code to Standard UOM Mapping extendable lookup.
This component invokes the D6- HeadendUOMLookup Business Object using the ATD6HeadendUOMLookup Inbound Web Service.
D6-InitiateMeterByMeterIdType
Used to perform actions such as ADD, READ, UPDATE and DELETE a Sensus -Initiate Meter Read By Meter ID outbound communication type.
This component invokes the D6- InitiateMeterByMeterIdType Business Object using the ATD6InitiateMeterByMeterIdType Inbound Web Service.
D6-ReadingChgNotificationType
Used to perform actions such as ADD, READ, UPDATE and DELETE a Sensus - Reading Change Notification inbound communication type.
This component invokes the D6- ReadingChgNotificationType Business Object using the ATD6ReadingChgNotificationType Inbound Web Service.
D6-SensusMasterConfig
Used to perform actions such as ADD, READ, UPDATE and DELETE a Sensus Master Configuration.
This component invokes the D6- SensusMasterConfig Business Object using the ATD6SensusMasterConfig Inbound Web Service.
D6-CDCodeReasonLookup
Used to perform actions such as ADD, READ, UPDATE and DELETE of a Sensus CD Reason Code record.
This component invokes the D6- CDCodeReasonLookup Business Object using the ATD6CDCodeReasonLookup Inbound Web Service.
D6-InitiateOutageDetectionType
Used to perform actions such as ADD, READ, UPDATE and DELETE of a Sensus Intitiate Outage Detection Type record.
This component invokes the D6- InitiateOutageDetectionType Business Object using the ATD6InitiateOutageDetectionType Inbound Web Service.
D6-OutageDetectEvtNotifType
Used to perform actions such as ADD, READ, UPDATE and DELETE of a Sensus Outage Detection Event Notification Type record.
This component invokes the D6- OutageDetectEvtNotifType Business Object using the ATD6OutageDetectEvtNotifType Inbound Web Service.
D6-UnsolicitedEventNotifType
Used to perform actions such as ADD, READ, UPDATE and DELETE of a Sensus Unsolicited Event Notification Type record.
This component invokes the D6- UnsolicitedEventNotifType Business Object using the ATD6UnsolicitedEventNotifType Inbound Web Service.
D6-ConnectDisconStateChgNtfTyp
Used to perform actions such as ADD, READ, and UPDATE and DELETE a Connect Disconnect State Change Notify Type for Sensus adapter.
This component invokes the D6- ConnectDisconStateChgNtfTyp Business Object using the ATD6ConnectDisconStateChgNtfTyp Inbound Web Service.
D6-InitiateConnectDisconType
Used to perform actions such as ADD, READ, and UPDATE and DELETE a Initiate Connect Disconnect Type for Sensus adapter.
This component invokes the D6- InitiateConnectDisconType Business Object using the ATD6InitiateConnectDisconType Inbound Web Service.
D6-IntStsCodeToCondMapLookup
Used to perform actions such as ADD, READ, and UPDATE and DELETE a IntStsCodeToCondMapLookup for Sensus adapter.
This component invokes the D6- IntStsCodeToCondMapLookup Business Object using the ATD6IntStsCodeToCondMapLookup Inbound Web Service.
D6-LoadActionCodeLookup
Used to perform actions such as ADD, READ, and UPDATE and DELETE a Load Action Code Lookup for Sensus adapter.
This component invokes the D6- LoadActionCodeLookup Business Object using the ATD6LoadActionCodeLookup Inbound Web Service.
D6-MeterAddNotificationType
Used to perform actions such as ADD, READ, and UPDATE and DELETE a Meter Add Notification Type for Sensus adapter.
This component invokes the D6- MeterAddNotificationType Business Object using the ATD6MeterAddNotificationType Inbound Web Service.
D6-MeterRemoveNotifType
Used to perform actions such as ADD, READ, and UPDATE and DELETE a Meter Remove Notify Type for Sensus adapter.
This component invokes the D6- MeterRemoveNotifType Business Object using the ATD6MeterRemoveNotifType Inbound Web Service.
D6-OutageEventTypeLookup
Used to perform actions such as ADD, READ, and UPDATE and DELETE a Outage Event Type Lookup for Sensus adapter.
This component invokes the D6- OutageEventTypeLookup Business Object using the ATD6OutageEventTypeLookup Inbound Web Service.
D6-SensusTimeUnits
This component can be used to perform actions such as ADD, READ, and UPDATE and DELETE a Sensus Time Units for Sensus adapter.
This component invokes the D6-SensusTimeUnits Business Object using the ATD6SensusTimeUnits Inbound Web Service.
D6-ServiceTypeMappingLookup
This component can be used to perform actions such as ADD, READ, and UPDATE and DELETE a Service Type Mapping Lookup for Sensus adapter.
This component invokes the D6- ServiceTypeMappingLookup Business Object using the ATD6ServiceTypeMappingLookup Inbound Web Service.
D6-AddMeterToHarness
Used to perform the AddMeterToHarness action to Sensus test harness.
This component invokes the D6- AddMeterToHarness Business Object using the ATD6AddMeterToHarness Inbound Web Service.
D6-RemoveMeter
Used to perform the remove meter action from Sensus test harness.
This component invokes the D6-RemoveMeter using the ATD6RemoveMeter Inbound Web Service.
Sensus Master Data
Component
Description
D6-InitialLoadIMDInterval
Used to ADD Initial Measurement Interval Data for Sensus adapter.
This component invokes the D6- InitialLoadIMDInterval Business Object using the ATD6InitialLoadIMDInterval Inbound Web Service.
D6-InitialLoadIMDScalar
Used to ADD Initial Measurement Scalar Data for Sensus adapter.
This component invokes the D6- InitialLoadIMDScalar Business Object using the ATD6InitialLoadIMDScalar Inbound Web Service.
D6-SmartMeter
This component can be used to perform actions such as ADD, READ, and UPDATE and DELETE a Smart Meter for Sensus adapter.
This component invokes the D6-SmartMeter Business Object using the ATD6SmartMeter Inbound Web Service.
Market Settlements Management
Dynamic Aggregation
Component
Description
D1-AggrBilledServiceQuantities
Used to create a Aggregation Billed Service Quantities.
This component invokes the D1- AggrBilledServiceQuantities Business Object using the ATD1 AggrBilledServiceQuantities Inbound Web Service.
D1-AggregationCompositeSet
Used to create a Aggregation Composite Set.
This component invokes the D1- AggregationCompositeSet Business Object using the ATD1 AggregationCompositeSet Inbound Web Service.
D1-AggregationConfig
Used to create a Aggregation Config.
This component invokes the D1-AggregationConfig Business Object using the ATD1AggregationConfig Inbound Web Service.
D1-AggregationFoundationSet
Used to create a Aggregation Foundation Set.
This component invokes the D1- AggregationFoundationSet Business Object using the ATD1AggregationFoundationSet Inbound Web Service.
D1-AggregationGroup
Used to create a Aggregation Group.
This component invokes the D1-AggregationGroup Business Object using the ATD1AggregationGroup Inbound Web Service.
D1-AggregationGroupRun
Used to create a Aggregation Group Run.
This component invokes the D1- AggregationGroupRun Business Object using the ATD1AggregationGroupRun Inbound Web Service.
D1-AggregationIntervalType
Used to create a Aggregation Interval Type.
This component invokes the D1- AggregationIntervalType Business Object using the ATD1AggregationIntervalType Inbound Web Service.
D1-AggregationMasterConfig
Used to create a Aggregation Master Config.
This component invokes the D1-Aggregation Master Config Business Object using the ATD1AggregationMasterConfig Inbound Web Service.
D1-AggregatorComposite
Used to create a Aggregator Composite.
This component invokes the D1- AggregatorComposite Business Object using the ATD1 AggregatorComposite Inbound Web Service.
D1-AggregatorCustomerQuantity
Used to create a Aggregator Customer Quantity.
This component invokes the D1- AggregatorCustomerQuantity Business Object using the ATD1 AggregatorCustomerQuantity Inbound Web Service.
D1-AggregatorInterval
Used to create a AggregatorInterval.
This component invokes the D1-AggregatorInterval Business Object using the ATD1AggregatorInterval Inbound Web Service.
D1-AggregatorItems
Used to create a AggregatorItems.
This component invokes the D1-AggregatorItems Business Object using the ATD1AggregatorItems Inbound Web Service.
D1-AggregatorScalar
Used to create a Aggregator Scalar.
This component invokes the D1-AggregatorScalar Business Object using the ATD1AggregatorScalar Inbound Web Service.
D1-BadgedItemsDataSource
Used to create a Badged Items Data Source.
This component invokes the D1- BadgedItemsDataSource Business Object using the ATD1BadgedItemsDataSource Inbound Web Service.
D1-CriteriaSourceTypeLookup
Used to create a CriteriaSourceTypeLookup.
This component invokes the D1- CriteriaSourceTypeLookup Business Object using the ATD1CriteriaSourceTypeLookup Inbound Web Service.
D1-DataSourceBilledSerQuantity
Used to create a DataSourceBilledSerQuantity.
This component invokes the D1- DataSourceBilledSerQuantity Business Object using the ATD1DataSourceBilledSerQuantity Inbound Web Service.
D1-DataSourceMeasurements
Used to create a DataSourceMeasurements.
This component invokes the D1- DataSourceMeasurements Business Object using the ATD1DataSourceMeasurements Inbound Web Service.
D1-DataSourceSPQuantities
Used to create a DataSourceSPQuantities.
This component invokes the D1- DataSourceSPQuantities Business Object using the ATD1DataSourceSPQuantities Inbound Web Service.
D1-DataSourceUnbadgedItems
Used to create a DataSourceUnbadgedItems.
This component invokes the D1- DataSourceUnbadgedItems Business Object using the ATD1DataSourceUnbadgedItems Inbound Web Service.
D1-FormulaProductType
Used to create a FormulaProductType.
This component invokes the D1- FormulaProductType Business Object using the ATD1FormulaProductType Inbound Web Service.
D1-MasterDataSnapshotBillTime
Used to create a MasterDataSnapshotBillTime.
This component invokes the D1- MasterDataSnapshotBillTime Business Object using the ATD1MasterDataSnapshotBillTime Inbound Web Service.
D1-MasterDataSnapshotRealTime
Used to create a MasterDataSnapshotRealTime
This component invokes the D1- MasterDataSnapshotRealTime Business Object using the ATD1MasterDataSnapshotRealTime Inbound Web Service.
D1-ServicePointQuantity
Used to create a ServicePointQuantity.
This component invokes the D1- ServicePointQuantity Business Object using the ATD1ServicePointQuantity Inbound Web Service.
D1-ServicePointQuantityType
Used to create a ServicePointQuantityType.
This component invokes the D1- ServicePointQuantityType Business Object using the ATD1ServicePointQuantityType Inbound Web Service.
D2-DynamicOptionIntSetType
Used to create a Dynamic Option SetType.
This component invokes the D2- DynamicOptionIntSetType Business Object using the ATD2DynamicOptionIntSetType Inbound Web Service.
D2-ItemAggregatorType
Used to create a ItemAggregatorType.
This component invokes the D1- ItemAggregatorType Business Object using the ATD1ItemAggregatorType Inbound Web Service.
D1-InboundMCSetSyncRequest
Used to create a InboundMCSetSyncRequest.
This component invokes the D1- InboundMCSetSyncRequest Business Object using the ATD1ItemAggregatorType Inbound Service.
D1-MCWithCharacteristics
Used to create a MCWithCharacteristics.
This component invokes the D1- MCWithCharacteristics Business Object using the ATD1MCWithCharacteristics Inbound Service.
D1-CompleteMCSetBOInbound
Used to create a CompleteMCSetBOInbound.
This component invokes the D1- CompleteMCSetBOInbound Business Object using the ATD1CompleteMCSetBOInbound IWS.
D1-CompleteMCSetBO
Used to create a CompleteMCSetBO.
This component invokes the D1- CompleteMCSetBO Business Object using the ATD1CompleteMCSetBO Inbound Web Service.
Forecasting
Component
Description
D1-DailyProcTimetable
Used to create a DailyProcTimetable.
This component invokes the D1- DailyProcTimetable Business Object using the ATD1DailyProcTimetable Inbound Web Service.
D1-DefinedDatesProcSchedule
Used to create a DefinedDatesProcSchedule
This component invokes the D1- DefinedDatesProcSchedule Business Object using the ATD1DefinedDatesProcSchedule Inbound Web Service.
D1-DimensionCombination
Used to create a DimensionCombination.
This component invokes the D1- DimensionCombination Business Object using the ATD1DimensionCombination Inbound Web Service.
D1-FactorTemperatureProfile
Used to create a FactorTemperatureProfile.
This component invokes the D1- FactorTemperatureProfile Business Object using the ATD1FactorTemperatureProfile Inbound Web Service.
D1-MCComparisonPeriod
Used to create a MCComparisonPeriod.
This component invokes the D1- MCComparisonPeriod Business Object using the ATD1MCComparisonPeriod Inbound Web Service.
D1-MCComparisonTypeStd
Used to create a MCComparisonTypeStd.
This component invokes the D1- MCComparisonTypeStd Business Object using the ATD1MCComparisonTypeStd Inbound Web Service.
D1-MulVarFacNum
Used to create a MulVarFacNum.
This component invokes the D1-MulVarFacNum Business Object using the ATD1MulVarFacNum Inbound Web Service.
D1-MulVarFacNumVal
Used to create a MulVarFacNumVal.
This component invokes the D1-MulVarFacNumVal Business Object using the ATD1MulVarFacNumVal Inbound Web Service.
D1-MulVarFacProf
Used to create a MulVarFacProf.
This component invokes the D1-MulVarFacProf Business Object using the ATD1MulVarFacProf Inbound Web Service.
D1-MulVarFacProfVal
Used to create a MulVarFacProfVal.
This component invokes the D1-MulVarFacProfVal Business Object using the ATD1MulVarFacProfVal Inbound Web Service.
D1-MulVarFacProcessor
Used to create a MulVarFacProcessor.
This component invokes the D1- MulVarFacProcessor Business Object using the ATD1 MulVarFacProcessor Inbound Web Service.
D1-MulVarFacProcessorBS
Used to create a MulVarFacProcessorBS.
This component invokes the D1- MulVarFacProcessorBS Business Object using the ATD1MulVarFacProcessorBS Inbound Web Service.
D1-SettlementUnit
Used to create a SettlementUnit.
This component invokes the D1-SettlementUnit Business Object using the ATD1SettlementUnit Inbound Web Service.
D1-StandaloneComparisonInt
Used to create a StandaloneComparisonInt.
This component invokes the D1- StandaloneComparisonInt Business Object using the ATD1StandaloneComparisonInt Inbound Web Service.
D1-StandaloneInterval
Used to create a StandaloneInterval.
This component invokes the D1-StandaloneInterval Business Object using the ATD1StandaloneInterval Inbound Web Service.
D1-StandaloneIntrvlMCType
Used to create a StandaloneIntrvlMCType.
This component invokes the D1- StandaloneIntrvlMCType Business Object using the ATD1StandaloneIntrvlMCType Inbound Web Service.
Used to create a IntervalAveragingEstimation.
This component invokes the D2- IntervalAveragingEstimation Business Object using the ATD2IntervalAveragingEstimation Inbound Web Service.
D2-IntervalProxyDayEstimation
Used to create a IntervalProxyDayEstimation.
This component invokes the D2- IntervalProxyDayEstimation Business Object using the ATD2IntervalProxyDayEstimation Inbound Web Service.
Integration Components
Component
Description
D1-InBoundAggGrpSyncReq
Used to create a InBoundAggGrpSyncReq.
This component invokes the D1- InBoundAggGrpSyncReq Business Object using the ATD1InBoundAggGrpSyncReq Inbound Web Service.
D1-MDMSettlementAggrGrpSync
Used to create a MDMSettlementAggrGrpSync.
This component invokes the D1- MDMSettlementAggrGrpSync Business Object using the ATD1MDMSettlementAggrGrpSync Inbound Web Service.
D1-MDMSettlementDCSync
Used to create a MDMSettlementDCSync.
This component invokes the D1- MDMSettlementDCSync Business Object using the ATD1MDMSettlementDCSync Inbound Web Service.
D1-MDMSettlementDeviceSync
Used to create a MDMSettlementDeviceSync.
This component invokes the D1- MDMSettlementDeviceSync Business Object using the ATD1MDMSettlementDeviceSync Inbound Web Service.
D1-MDMSettlementIESync
Used to create a MDMSettlementIESync.
This component invokes the D1- MDMSettlementIESync Business Object using the ATD1MDMSettlementIESync Inbound Web Service.
D1-MDMSettlementMCSync
Used to create a MDMSettlementMCSync.
This component invokes the D1- MDMSettlementMCSync Business Object using the ATD1MCComMDMSettlementMCSync Inbound Web Service.
D1-MDMSettlementSPSync
Used to create a MDMSettlementSPSync.
This component invokes the D1- MDMSettlementSPSync Business Object using the ATD1MDMSettlementSPSync Inbound Web Service.
D1-SettIntegrationMasterConfig
Used to create a SettIntegrationMasterConfig.
This component invokes the D1- SettIntegrationMasterConfig Business Object using the ATD1SettIntegrationMasterConfig Inbound Web Service.
D1-SynchronizationAddDevice
Used to create a SynchronizationAddDevice.
This component invokes the D1- SynchronizationAddDevice Business Object using the ATD1SynchronizationAddDevice Inbound Web Service.
D1-SynchronizationAddDC
Used to create a SynchronizationAddDC.
This component invokes the D1- SynchronizationAddDC Business Object using the ATD1SynchronizationAddDC Inbound Web Service.
Market Entities
Component
Description
D1-FixedProfileAward
Used to create a FixedProfileAward.
This component invokes the D1-FixedProfileAward Business Object using the ATD1FixedProfileAward Inbound Web Service.
D1-Market2
Used to create a Market.
This component invokes the D1-Market2 Business Object using the ATD1Market2 Inbound Web Service.
D1-MarketContract
Used to create a MarketContract.
This component invokes the D1-MarketContract Business Object using the ATD1MarketContract Inbound Web Service.
D1-MarketContractType
Used to create a MarketContractType.
This component invokes the D1- MarketContractType Business Object using the ATD1MarketContractType Inbound Web Service.
D1-MarketParticipant
Used to create a MarketParticipant.
This component invokes the D1- MarketParticipant Business Object using the ATD1MarketParticipant Inbound Web Service.
D1-MarketProduct
Used to create a MarketProduct.
This component invokes the D1- MarketProduct Business Object using the ATD1MarketProduct Inbound Web Service.
D1-MarketProductSet
Used to create a MarketProductSet.
This component invokes the D1-MarketProductSet Business Object using the ATD1MarketProductSet Inbound Web Service.
D1-MarketProductType
Used to create a MarketProductType.
This component invokes the D1- MarketProductType Business Object using the ATD1MarketProductType Inbound Web Service.
D1-MktContractType
Used to create a MktContractType.
This component invokes the D1-MktContractType Business Object using the ATD1MktContractType Inbound Web Service.
D1-MPSet
Used to create a MPSet.
This component invokes the D1-MPSet Business Object using the ATD1MPSet Inbound Web Service.
D1- PercentageAward
Used to create a PercentageAward.
This component invokes the D1-PercentageAward Business Object using the ATD1PercentageAward Inbound Web Service.
D1-TrancheAward
Used to create a TrancheAward.
This component invokes the D1- TrancheAward Business Object using the ATD1TrancheAward Inbound Web Service.
Settlement Calculations
Component
Description
D1-AttributDataSnpshtBillTime
Used to create a AttributDataSnpshtBillTime.
This component invokes the D1- AttributDataSnpshtBillTime Business Object using the ATD1AttributDataSnpshtBillTime Inbound Web Service.
D1-AttributDataSnpshtDaily
Used to create a AttributDataSnpshtDaily.
This component invokes the D1- AttributDataSnpshtDaily Business Object using the ATD1AttributDataSnpshtDaily Inbound Web Service.
D1-AttributeDataSnapshotType
Used to create a AttributeDataSnapshotType.
This component invokes the D1- AttributeDataSnapshotType Business Object using the ATD1AttributeDataSnapshotType Inbound Web Service.
D1-AutoReadRegisterType
Used to create a AutoReadRegisterType.
This component invokes the D1- AutoReadRegisterType Business Object using the ATD1AutoReadRegisterType Inbound Web Service.
D1-HowToSendMCInformation
Used to create a HowToSendMCInformation.
This component invokes the D1- HowToSendMCInformation Business Object using the ATD1HowToSendMCInformation Inbound Web Service.
D1-MeasurementDataSnapshotType
Used to create a MeasurementDataSnapshotType.
This component invokes the D1- MeasurementDataSnapshotType Business Object using the ATD1MeasurementDataSnapshotType Inbound Web Service.
D1-MarketProductSet
D1-ServicePointMktPtLite
Used to create a ServicePointMktPtLite.
This component invokes the D1- ServicePointMktPtLite Business Object using the ATD1ServicePointMktPtLite Inbound Web Service.
D1-StandaloneDataRequestMC
Used to create a StandaloneDataRequestMC.
This component invokes the D1- StandaloneDataRequestMC Business Object using the ATD1StandaloneDataRequestMC Inbound Web Service.
D1-StandaloneDataRequestMCType
D1-StandaloneIntrvlComprMCType
Used to create a StandaloneIntrvlComprMCType.
This component invokes the D1- StandaloneIntrvlComprMCType Business Object using the ATD StandaloneIntrvlComprMCType Inbound Web Service.
D1- StandaloneMcDataReqCommType
Used to create a StandaloneMcDataReqCommType.
This component invokes the D1- StandaloneMcDataReqCommType Business Object using the ATD1StandaloneMcDataReqCommType Inbound Web Service.
D1-StandaloneMcDataRequest
Used to create a StandaloneMcDataRequest.
This component invokes the D1- StandaloneMcDataRequest Business Object using the ATD1StandaloneMcDataRequest Inbound Web Service.
D1-UsageSubscriptionQuantity
Used to create a UsageSubscriptionQuantity.
This component invokes the D1- UsageSubscriptionQuantity Business Object using the ATD1UsageSubscriptionQuantity Inbound Web Service.
D1-USQuantityType
Used to create a USQuantityType.
This component invokes the D1-USQuantityType Business Object using the ATD1USQuantityType Inbound Web Service.
D2-CustomerQuantityCalculation
Used to create a CustomerQuantityCalculation.
This component invokes the D2- CustomerQuantityCalculation Business Object using the ATD2CustomerQuantityCalculation Inbound Web Service.
D2-DynamicOptionIntervalEvent
Used to create a DynamicOptionIntervalEvent.
This component invokes the D2- DynamicOptionIntervalEvent Business Object using the ATD2DynamicOptionIntervalEvent Inbound Web Service.
D2-DynamicOptionIntervalSet
Used to create a DynamicOptionIntervalSet.
This component invokes the D2- DynamicOptionIntervalSet Business Object using the ATD2DynamicOptionIntervalSet Inbound Web Service.
D2-DynamicOptionIntervalSetType
Used to create a DynamicOptionIntervalSetType.
This component invokes the D2- DynamicOptionIntervalSetType Business Object using the ATD2DynamicOptionIntervalSetType Inbound Web Service.
D2-ProfileServiceQuantity
Used to create a ProfileServiceQuantity.
This component invokes the D2- ProfileServiceQuantity Business Object using the ATD2ProfileServiceQuantity Inbound Web Service.
D2-SendSettleTransactionIdComm
Used to create a SendSettleTransactionIdComm.
This component invokes the D2- SendSettleTransactionIdComm Business Object using the ATD2SendSettleTransactionIdComm Inbound Web Service.
D2- SendSettleTransactionContractComm
Used to create a SendSettleTransactionContractComm.
This component invokes the D2- SendSettleTransactionContractComm Business Object using the ATD2SendSettleTransactionContractComm Inbound Web Service.
D2- SendSettleTransactionIdCommType
Used to create a SendSettleTransactionIdCommType.
This component invokes the D2- SendSettleTransactionIdCommType Business Object using the ATD2SendSettleTransactionIdCommType Inbound Web Service.
D2- SendSettleTransactionContractComm Type
Used to create a SendSettleTransactionContractCommType.
This component invokes the D2- SendSettleTransactionContractCommType Business Object using the ATD2SendSettleTransactionContractCommType Inbound Web Service.
D2-SettAccountServiceType
Used to create a SettAccountServiceType.
This component invokes the D2- SettAccountServiceType Business Object using the ATD2SettAccountServiceType Inbound Web Service.
D2-SettlementAccountService
Used to create a SettlementAccountService.
This component invokes the D2- SettlementAccountService Business Object using the ATD2SettlementAccountService Inbound Web Service.
D2-SettlementBilledUsage
Used to create a SettlementBilledUsage.
This component invokes the D2- SettlementBilledUsage Business Object using the ATD2SettlementBilledUsage Inbound Web Service.
D2-SettlementItem
Used to create a SettlementItem.
This component invokes the D2-SettlementItem Business Object using the ATD2SettlementItem Inbound Web Service.
D2-SettlementSubscription
Used to create a SettlementSubscription.
This component invokes the D2- SettlementSubscription Business Object using the ATD2SettlementSubscription Inbound Web Service.
D2-UsageCalculationReqType
Used to create a UsageCalculationReqType.
This component invokes the D2- UsageCalculationReqType Business Object using the ATD2UsageCalculationReqType Inbound Web Service.
D2-UsageCalculationRequest
Used to create a UsageCalculationRequest.
This component invokes the D2- UsageCalculationRequest Business Object using the ATD2UsageCalculationRequest Inbound Web Service.
D2-UsageCalculationType
Used to create a UsageCalculationType.
This component invokes the D2- UsageCalculationType Business Object using the ATD2UsageCalculationType Inbound Web Service.
D2-UsgSubsMarketParticipant
Used to create a UsgSubsMarketParticipant.
This component invokes the D2- UsgSubsMarketParticipant Business Object using the ATD2UsgSubsMarketParticipant Inbound Web Service.
CX REST API
Component
Description
D1-InstallEventIWS
Used to get an Install event.
This component invokes the D1-GtInstEve Service Script using the D1-InstallEvent Inbound Web Service.
D1-CreateInstallEvent
Used to create an Install event.
This component invokes the D1-CrInsEven Service Script using the D1-InstallEvent Inbound Web Service.
D1-UpdateInstallEvent
Used to update an Install Event.
This component invokes the D1-UpdInsEve Service Script using the D1-InstallEvent Inbound Web Service.
D1-DeleteInstallEvents
Used to delete an Install Event.
This component invokes the D1-DelInsEve Service Script using the D1-InstallEvent Inbound Web Service.
D1-MeterIWS
Used to get a Meter.
This component invokes the D1-GetMeter Service Script using the D1-Meter Inbound Web Service.
D1-MeterIWSPost
Used to create a Meter.
This component invokes the D1-CreateMtr Service Script using the D1-Meter Inbound Web Service.
D1-MeterIWSPut
Used to update a Meter.
This component invokes the D1-UpdateMtr Service Script using the D1-Meter Inbound Web Service.
D1-MeterIWSDelete
Used to delete a Meter.
This component invokes the D1-DeleteMtr Service Script using the D1-Meter Inbound Web Service.
D1-ServicePointRestIWS
Used to get a Service Point.
This component invokes the D1-GetSPoint Service Script using the D1-ServicePoint Inbound Web Service.
D1-CreateServicePointRestIWS
Used to create a Service Point.
This component invokes the D1-CreateSP Service Script using the D1-ServicePoint Inbound Web Service.
D1-UpdateServicePointRestIWS
Used to update a Service Point.
This component invokes the D1-UpdateSPt Service Script using the D1-ServicePoint Inbound Web Service.
D1-DeleteServicePointRestIWS
Used to delete a Service Point.
This component invokes the D1-DeleteSP Service Script using the D1-ServicePoint Inbound Web Service.
D1-CreateUsageSubscriptionRestIWS
Used to create a Usage Subscription.
This component invokes the D1-CreateUS Service Script using the D1-UsageSubscription Inbound Web Service.
D1-DeleteUsageSubscriptionRestIWS
Used to delete a Usage Subscription.
This component invokes the D1-DeleteUS Service Script using the D1-UsageSubscription Inbound Web Service.
D1-UsageTransactionDelete
Used to delete a Usage Transaction.
This component invokes the D1-DelUsgTrn Script using the D1-UsageTransaction IWS.
D1-UsageTransactionGet
Used to get a Usage Transaction.
This component invokes D1-GtUsgTran Service Script using the D1-UsageTransaction Web Service.
D1-UsageTransactionPost
Used to create a Usage Transaction.
This component invokes D1-CrUsgTran Service Script using the D1-UsageTransaction IWS.
D1-UsageTransactionActionRestIWS
Used to update UT status.
This component invokes the D1ActUsgTran Service Script using the D1- UsageTransactionActionRestIWS.
D1-UsageTransactionPut
Used to update a Usage Transaction.
This component invokes D1-UpUsgTran Service Script using the D1-UsageTransaction IWS.
D1-ItemIWS
Used to get an Item.
This component invokes the D1-GetItem Service Script using the D1-Item Inbound Web Service.
D1-ItemIWSPost
Used to create an Item.
This component invokes the D1-CreateItm Service Script using the D1-Item Inbound Web Service.
D1-ItemIWSPut
Used to update an Item.
This component invokes the D1-UpdItem Service Script using the D1-Item Inbound Web Service.
D1-ItemIWSDelete
Used to delete an Item.
This component invokes the D1-DelItem Service Script using the D1-Item Inbound Web Service.
