Oracle Utilities Operational Device Management Components
This section lists the starter components available for Oracle Utilities Operational Device Management.
The Inbound Web Service using the respective business object should be available in the application.
Failure while creating, reading, or updating the component is logged in the test execution report, thus facilitating debugging/analysis of the problem.
The components are categorized under the following functional areas:
Administration Data
| Component | Description |
| W1- AssetAgeBktConfig | Used to create, update, read, or delete AssetAgeBktConfig in the WAM application. This component calls the W1- AssetAgeBktConfig business object using the Inbound Web Service. |
| W1- BasicActivityType | Used to create, update, read, or delete BasicActivityType in the WAM application. This component calls the W1- BasicActivityType business object using the Inbound Web Service. |
| W1- BIExtractParameters | Used to create, update, read, or delete BIExtractParameters in the WAM application. This component calls the W1- BIExtractParameters business object using the Inbound Web Service. |
| W1- ConfigType | Used to create, update, read, or delete ConfigType in the WAM application. This component calls the W1- ConfigType business object using the Inbound Web Service. |
| W1- OutboundActivityType | Used to create, update, read, or delete OutboundActivityType in the WAM application. This component calls the W1-OutboundActivityType business object using the Inbound Web Service. |
| W1- GeneralCommunicationType | Used to create, update, read, or delete GeneralCommunicationType in the WAM application. This component calls the W1-GeneralCommunicationType business object using the Inbound Web Service. |
| W1- AssetInstallAgeBktConfig | Used to create, update, read, or delete AssetInstallAgeBktConfig in the WAM application. This component calls the W1-AssetInstallAgeBktConfig business object using the Inbound Web Service. |
| W1- AssetInstoreAgeBktConfig | Used to create, update, read, or delete AssetInstoreAgeBktConfig in the WAM application. This component calls the W1-AssetInstoreAgeBktConfig business object using the Inbound Web Service. |
| W1- AssetSearchMasterConfig | Used to create, update, read, or delete AssetSearchMasterConfig in the WAM application. This component calls the W1-AssetSearchMasterConfig business object using the Inbound Web Service. |
Asset Management
| W1- Business | Used to create, update, read, or delete Business in the WAM application. This component calls the W1- Business business object using the Inbound Web Service. |
| W1- MDMAsset | Used to create, update, read, or delete MDMAsset in the WAM application. This component calls the W1- MDMAsset business object using the Inbound Web Service. |
| W1-MaintenanceSpecGeneral | Used to create, update, read, or delete MaintenanceSpecGeneral in the WAM application. This component calls the W1-MaintenanceSpecGeneral business object using the Inbound Web Service. |
| W1-AssetTypeConv | Used to create, update, read, or delete AssetTypeConv in the WAM application. This component calls the W1-AssetTypeConv business object using the Inbound Web Service. |
| W1-AssetDposHistInstallations | Used to create, update, read, or delete AssetDposHistInstallations in the WAM application. This component calls the W1-AssetDposHistInstallations business object using the Inbound Web Service. |
| W1-SHInspectionGenrlWeighted | Used to create, update, read, or delete SHInspectionGenrlWeighted in the WAM application. This component calls the W1-SHInspectionGenrlWeighted business object using the Inbound Web Service. |
| W1- Person | Used to create, update, read, or delete Person in the WAM application. This component calls the W1- Person business object using the Inbound Web Service. |
| W1- SynchronizationAddContact | Used to create, update, read, or delete SynchronizationAddContact in the WAM application. This component calls the W1-SynchronizationAddContact business object using the Inbound Web Service. |
| W1- BasicTest | Used to create, update, read, or delete BasicTest in the WAM application. This component calls the W1- BasicTest business object using the Inbound Web Service. |
| W2-SmartTest | Used to create, update, read, or delete SmartTest in the WAM application. This component calls the W2- SmartTest business object using the Inbound Web Service. |
| W1-PeerSpecification | Used to create, update, read, or delete PeerSpecification in the WAM application. This component calls the W2- PeerSpecification business object using the Inbound Web Service. |
Configuration Management
| W1- AssetCompCfgRpt | Used to create, update, read, or delete AssetCompCfgRpt in the WAM application. This component calls the W1- AssetCompCfgRpt business object using the Inbound Web Service. |
| W1- AssetCompCfgWO | Used to create, update, read, or delete AssetCompCfgWO in the WAM application. This component calls the W1- AssetCompCfgWO business object using the Inbound Web Service. |
| W1- AssetCompToAssetCfgRpt | Used to create, update, read, or delete AssetCompToAssetCfgRpt in the WAM application. This component calls the W1-AssetCompToAssetCfgRpt business object using the Inbound Web Service. |
| W1- AssetCompToAssetCfgWO | Used to create, update, read, or delete AssetCompToAssetCfgWO in the WAM application. This component calls the W1-AssetCompToAssetCfgWO business object using the Inbound Web Service. |
| W1- AssetCompToAssetCompCfgRpt | Used to create, update, read, or delete AssetCompToAssetCompCfgRpt in the WAM application. This component calls the W1-AssetCompToAssetCompCfgRpt business object using the Inbound Web Service. |
| W1- AssetCompToAssetCompCfgWO | Used to create, update, read, or delete AssetCompToAssetCompCfgWO in the WAM application. This component calls the W1-AssetCompToAssetCompCfgWO business object using the Inbound Web Service. |
| W1- AssetCompToAssetCompConfig | Used to create, update, read, or delete AssetCompToAssetCompConfig in the WAM application. This component calls the W1-AssetCompToAssetCompConfig business object using the Inbound Web Service. |
| W1- AssetCompToAssetConfig | Used to create, update, read, or delete AssetCompToAssetConfig in the WAM application. This component calls the W1-AssetCompToAssetConfig business object using the Inbound Web Service. |
| W1- AssetToAssetCfgRpt | Used to create, update, read, or delete AssetToAssetCfgRpt in the WAM application. This component calls the W1- AssetToAssetCfgRpt business object using the Inbound Web Service. |
| W1- AssetToAssetCfgWO | Used to create, update, read, or delete AssetToAssetCfgWO in the WAM application. This component calls the W1- AssetToAssetCfgWO business object using the Inbound Web Service. |
| W1- AssetToAssetCompCfgRpt | Used to create, update, read, or delete AssetToAssetCompCfgRpt in the WAM application. This component calls the W1-AssetToAssetCompCfgRpt business object using the Inbound Web Service. |
| W1- AssetToAssetCompCfgWO | Used to create, update, read, or delete AssetToAssetCompCfgWO in the WAM application. This component calls the W1-AssetToAssetCompCfgWO business object using the Inbound Web Service. |
| W1- AssetToAssetCompConfig | Used to create, update, read, or delete AssetToAssetCompConfig in the WAM application. This component calls the W1-AssetToAssetCompConfig business object using the Inbound Web Service. |
| W1- AssetToAssetConfig | Used to create, update, read, or delete AssetToAssetConfig in the WAM application. This component calls the W1- AssetToAssetConfig business object using the Inbound Web Service. |
| W1- SingleAssetCfgRpt | Used to create, update, read, or delete SingleAssetCfgRpt in the WAM application. This component calls the W1- SingleAssetCfgRpt business object using the Inbound Web Service. |
| W1- SingleAssetCfgWO | Used to create, update, read, or delete SingleAssetCfgWO in the WAM application. This component calls the W1- SingleAssetCfgWO business object using the Inbound Web Service. |
| W1- SingleAssetConfig | Used to create, update, read, or delete SingleAssetConfig in the WAM application. This component calls the W1- SingleAssetConfig business object using the Inbound Web Service. |
| W1- AssetCompConfig | Used to create, update, read, or delete AssetCompConfig in the WAM application. This component calls the W1- AssetCompConfig business object using the Inbound Web Service. |
Work Management
| W1- ActivityComplInboundComm | Used to create, update, read, or delete ActivityComplInboundComm in the WAM application. This component calls the W1-ActivityComplInboundComm business object using the Inbound Web Service. |
| W1- AdHocActivityCore | Used to create, update, read, or delete AdHocActivityCore in the WAM application. This component calls the W1- AdHocActivityCore business object using the Inbound Web Service. |
| W1- AssetCriteriaActGenerator | Used to create, update, read, or delete AssetCriteriaActGenerator in the WAM application. This component calls the W1-AssetCriteriaActGenerator business object using the Inbound Web Service. |
| W1- AssetListActGenerator | Used to create, update, read, or delete AssetListActGenerator in the WAM application. This component calls the W1-AssetListActGenerator business object using the Inbound Web Service. |
| W1- BasicWorkOrder | Used to create, update, read, or delete BasicWorkOrder in the WAM application. This component calls the W1- BasicWorkOrder business object using the Inbound Web Service. |
| W1- CompnAssetListActGenerator | Used to create, update, read, or delete CompnAssetListActGenerator in the WAM application. This component calls the W1-CompnAssetListActGenerator business object using the Inbound Web Service. |
| W1- CompnCriteriaActGenerator | Used to create, update, read, or delete CompnCriteriaActGenerator in the WAM application. This component calls the W1-CompnCriteriaActGenerator business object using the Inbound Web Service. |
| W1- CreComActivityInboundComm | Used to create, update, read, or delete CreComActivityInboundComm in the WAM application. This component calls the W1-CreComActivityInboundComm business object using the Inbound Web Service. |
| W1- CreateActivityInboundComm | Used to create, update, read, or delete CreateActivityInboundComm in the WAM application. This component calls the W1-CreateActivityInboundComm business object using the Inbound Web Service. |
| W1- LocalActivityCore | Used to create, update, read, or delete LocalActivityCore in the WAM application. This component calls the W1- LocalActivityCore business object using the Inbound Web Service. |
| W1- NodeCriteriaActGenerator | Used to create, update, read, or delete NodeCriteriaActGenerator in the WAM application. This component calls the W1-NodeCriteriaActGenerator business object using the Inbound Web Service. |
| W2-FirmwareCommandLocal | Used to create, update, read, or delete FirmwareCommandLocal in the WAM application. This component calls the W2-FirmwareCommandLocal business object using the Inbound Web Service. |
| W2-ACfgFirmwareUpgrade | Used to create, update, read, or delete ACfgFirmwareUpgrade in the WAM application. This component calls the W2-ACfgFirmwareUpgrade business object using the Inbound Web Service. |
| W2-ACCfgFirmwareUpgrade | Used to create, update, read, or delete ACCfgFirmwareUpgrade in the WAM application. This component calls the W2-ACCfgFirmwareUpgrade business object using the Inbound Web Service. |
| W2-ACACfgFirmwareUpgrade | Used to create, update, read, or delete ACACfgFirmwareUpgrade in the WAM application. This component calls the W2-ACACfgFirmwareUpgrade business object using the Inbound Web Service. |
| W2-ACACCfgFirmwareUpgrade | Used to create, update, read, or delete ACACCfgFirmwareUpgrade in the WAM application. This component calls the W2-ACACCfgFirmwareUpgrade business object using the Inbound Web Service. |
| W2-AACfgFirmwareUpgrade | Used to create, update, read, or delete AACfgFirmwareUpgrade in the WAM application. This component calls the W2-AACfgFirmwareUpgrade business object using the Inbound Web Service. |
| W2-AACCfgFirmwareUpgrade | Used to create, update, read, or delete AACCfgFirmwareUpgrade in the WAM application. This component calls the W2-AACCfgFirmwareUpgrade business object using the Inbound Web Service. |
| W1-WorkLocation | Used to create, update, read, or delete WorkLocation in the WAM application. This component calls the W1-WorkLocation business object using the Inbound Web Service. |
| W1- OutboundActivityCore | Used to create, update, read, or delete OutboundActivityCore in the WAM application. This component calls the W1-OutboundActivityCore business object using the Inbound Web Service. |
| W1- RTSVSCWOSQL | Used to retrieve/read ServiceSchedule Work Order against the ODM Work Order in the WAM application. This component calls the CM-RTSVSCWO business service using the ATW1RTSVSCWOSQL Inbound Web Service. |
Cloud
| W1-Lookup | Used to create, update, read, or delete Lookup in the WAM application. This component calls the W1-Lookup business object using the Inbound Web Service. |
| W1-InstallationOptions | Used to createInstallationOptions in the WAM application. This component calls the W1-InstallationOptions business object using the Inbound Web Service. |
