Components
This section lists the starter components available for Oracle Utilities Customer Cloud Service.
Pre-requisites: The Inbound Web Service using the respective business object should be available in the application.
Additional Notes: Failure while creating, reading, or updating the component is logged in the test execution report, thus facilitating debugging/analysis of the problem.
The components are categorized under the following functional areas:
• Admin
• Rates
• Usage
ADK Master Data
Component
Description
DG-ConDisconStChgNotification
Used to perform actions such as ADD, READ, UPDATE and DELETE a Connect Disconnect State Change Notification record.
This component invokes the DG-ConnectDisconStateChgNtfBusiness Object using the ATDGConnectDisconStateChgNtf Inbound Web Service.
DG-OutageDetectionEventNotification
Used to perform actions such as ADD, READ, UPDATE and DELETE a Outage Detection Event Notification record.
This component invokes the DG-OutageDetectEvtNotification Business Object using the ATDGOutageDetectEvtNotification Inbound Web Service.
DG-SmartMeter
Used to perform actions such as ADD, READ, UPDATE and DELETE a SmartMeter record.
This component invokes the DG- SmartMeter using the ATDGSmartMeter Inbound Web Service.
DG-ReadingChangedNotification
Used to perform actions such as ADD, READ, UPDATE and DELETE a Reading Change Notification record.
This component invokes the DG-ReadingChgNotificationBusiness Object using the ATDGReadingChgNotification Inbound Web Service.
Admin
Component
Description
C1-AdjustmentTypeAdd
Used to add an Adjustment Type record.
This component invokes the ATC1AdjustmentType Inbound Web Service using the C1-
AdjTypePhysicalBO Business Object.
C1-AdjustmentTypeRead
Used to read an Adjustment Type record.
This component invokes the ATC1AdjustmentType Inbound Web Service using the C1-AdjTypePhysicalBO Business Object.
C1-AdjustmentTypeUpdate
Used to update an Adjustment Type record.
C1-CSRTSvcEligCriteriaAdd
Used to add a CS Request Type Svc Eligibility Criteria record.
This component invokes the ATC1CSRTSvcEligCriteria Inbound Web Service using the C1-CSRTSvcEligCriteria Business Object.
C1-CSRTSvcEligCriteriaDelete
Used to delete a CS Request Type Svc Eligibility Criteria record.
C1-CSRTSvcEligCriteriaRead
Used to read a CS Request Type Svc Eligibility Criteria record.
C1-CSRTSvcEligCriteriaUpdate
Used to update a CS Request Type Svc Eligibility Criteria record
C1-CSRTRelUpdAdd
Used to add a CS Request Type Related Update record.
This component invokes the ATC1CSRTRelUpd Inbound Web Service using the C1-CSRTRelUpd Business Object.
C1-AdjustmentTypeDelete
Used to delete an Adjustment Type record.
C1-NotifTypeTmplIndividualPushAdd
Used to add a Template-Based Individual Push Notification Type.
This component invokes the ATC1NotifTypeTmplIndividualPush Inbound Web Service using the C1-NotifTypeTmplIndividualPush Business Object.
C1-NotifTypeTmplIndividualPushDelete
Used to delete a Template-Based Individual Push Notification Type.
C1-NotifTypeTmplIndividualPushRead
Used to read a Template-Based Individual Push Notification Type.
C1-NotifTypeTmplIndividualPushUpdate
Used to update a Template-Based Individual Push Notification Type.
C1-NotificationTypeAdd
Used to add a Notification Type.
This component invokes the ATC1NotificationType Inbound Web Service using the C1-NotificationType Business Object.
C1-NotificationTypeRead
Used to read a Notification Type.
C1-NotificationTypeDelete
Used to delete a Notification Type.
C1-NotificationTypeUpdate
Used to update a Notification Type.
C1-NotifTypeTmplParentPushAdd
Used to add a Template-Based Parent Push Notification Type.
This component invokes the ATC1NotifTypeTmplParentPush Inbound Web Service using the C1-NotifTypeTmplParentPush Business Object.
C1-NotifTypeTmplParentPushDelete
Used to delete a Template-Based Parent Push Notification Type.
C1-NotifTypeTmplParentPushRead
Used to Read a Template-Based Parent Push Notification Type.
C1-NotifTypeTmplParentPushUpdate
Used to update a Template-Based Parent Push Notification Type.
C1-NotifTypeTmplSubscriptionAdd
Used to add a Template-Based Subscription Notification Type.
This component invokes the ATC1NotifTypeTmplSubscription Inbound Web Service using the C1-NotifTypeTmplSubscription Business Object.
C1-NotifTypeTmplSubscriptionDelete
Used to delete a Template-Based Subscription Notification Type.
C1-NotifTypeTmplSubscriptionRead
Used to read a Template-Based Subscription Notification Type.
C1-NotifTypeTmplSubscriptionUpdate
Used to update a Template-Based Subscription Notification Type.
C1-GetNotificationType
Used for Retrieving Notification Type in Notification.
Notification Master Configuration > Edge Application Notification
This component invokes the ATC1GetNotificationType Inbound Web Service using the C1-GETNTFTYP Business Service.
C1-GetOutboundMsgType
Used for Retrieving Outbound Message Type in Notification Preference Master Configuration > Edge Application Notification.
This component invokes the ATC1GetNotificationType Inbound Web Service using the C1RetOutMsg Service Script.
C1-SATypeAdd
Used to add a SA Type SA Relationship Type record.
This component invokes the ATC1SATypeSARelationshipType Inbound Web Service using the C1-SATypeSARelationshipType Business Object.
C1-SATypeRead
C1-AutoPayRouteTypeAdd
Used to add an Auto Pay Route Type record.
ATC1AutoPayRouteType Inbound Web Service
using the C1-AutoPayRouteTypePhysicalBO
Business Object.
C1-AutoPayRouteRead
Used to read an Auto Pay Route Type record.
Business Object.
C1-AutoPayRouteUpdate
Used to update an Auto Pay Route Type record.
Business Object.
C1-AutoPayRouteDelete
Used to delete an Auto Pay Route Type record.
This component invokes the ATC1AutoPayRouteType Inbound Web Service
Business Object.
C1-AutoPaySourceAdd
Used to add an Auto Pay Source record.
This component invokes the ATC1AutoPaySource Inbound Web Service using the C1-AutoPaySourcePhysicalBO Business Object.
C1-AutoPaySourceDelete
Used to Delete an Auto Pay Source record.
C1-AutoPaySourceRead
Used to read an Auto Pay Source record.
C1-AutoPaySourceUpdate
Used to Update an Auto Pay Source record.
C1-StartServiceRequestTypeAdd
Used to add a Start Service Request Type record.
This component invokes the ATC1StartServiceRequestType Inbound Web Service using the C1-StartServiceRequestType Business Object.
C1-StartServiceRequestTypeDelete
Used to delete a Start Service Request Type record.
C1-StartServiceRequestTypeRead
Used to read a Start Service Request Type record.
C1-StopServiceRequestTypeAdd
C1-StopServiceRequestTypeDelete
C1-StopServiceRequestTypeRead
C1-StopServiceRequestTypeUpdate
Used to update a Start Service Request Type record.
C1-TransferServiceRequestTypeAdd
Used to add a Transfer Service Request Type record.
This component invokes the ATC1TransferServiceRequestType Inbound Web Service using the C1-TransferServiceRequestType Business Object.
C1-TransferServiceRequestTypeDelete
Used to delete a Transfer Service Request Type record.
C1-TransferServiceRequestTypeRead
Used to read a Transfer Service Request Type record.
C1-TransferServiceRequestTypeUpdate
C1-OutageCallWithoutPremAdd
Used to create an Outage Call without Premise record.
This component invokes the ATC1OutageCallWithoutPremInbound Web Service using the C1-OutageCallWithoutPremiseBusiness Object.
C1-OutageCallWithoutPremRead
Used to read an Outage Call without Premise record.
C1-OutageCallWithPremAdd
Used to create an Outage Call with Premise record.
This component invokes the ATC1OutageCallWithPremInbound Web Service using the C1-OutageCallWithPremiseBusiness Object.
C1-OutageCallWithPremRead
Used to read an Outage Call with Premise record.
C1-CaseTypeAdd
Used to add a Case Type record.
This component invokes the ATC1CaseType
CaseTypePhysicalBO Business Object.
C1-CaseTypeRead
Used to read a Case Type record.
C1-CaseTypeUpdate
Used to update a Case Type record.
This component invokes the ATC1CaseType Inbound Web Service using the C1-CaseTypePhysicalBO Business Object.
C1-CaseTypeDelete
Used to delete a Case Type record.
C1-CaseCreate
Used to Create Case.
This component invokes the C1-Case Inbound Web Service using the C1-Case Service Script.
C1-CaseDelete
Used to Delete Case.
This component invokes the C1-Case Inbound Web Service using the C1-DelCase Service Script.
C1-CaseGet
Used to Get Case.
C1-CaseUpdate
Used to Update Case.
C1-AdjustmentTypeProfileAdd
Used to add an Adjustment Type Profile record.
This component invokes the ATC1AdjustmentTypeProfile Inbound Web Service using the C1-AdjTypeProfPhysicalBO Business Object.
C1-AdjustmentTypeProfileDelete
Used to delete an Adjustment Type Profile record.
C1-AdjustmentTypeProfileRead
Used to read an Adjustment Type Profile record.
C1-AdjustmentTypeProfileUpdate
Used to update an Adjustment Type Profile record.
C1-BillRouteTypeAdd
Used to add a Bill Route Type record.
This component invokes the ATC1BillRouteType Inbound Web Service using the C1-BillRouteTypePhysicalBO Business Object.
C1-BillRouteTypeDelete
Used to delete a Bill Route Type record.
C1-BillRouteTypeRead
Used to read a Bill Route Type record.
C1-BillRouteTypeUpdate
Used to update a Bill Route Type record.
C1-CreatePersonForCheckGG_NENE
Used to Create Person For Check.
This component invokes the C1-Person Inbound Web Service using the C1-Person Service Script.
C1-CreatePersonForCheckGL_NENE
C1-CharacteristicTypeAdd
Used to add a Characteristic Type record.
This component invokes the ATC1CharacteristicType Inbound Web Service using the F1-CharTypePhysicalBO Business Object.
C1-CharacteristicTypeDelete
Used to delete a Characteristic Type record.
C1-CharacteristicTypeRead
Used to read a Characteristic Type record.
C1-CharacteristicTypeUpdate
Used to update a Characteristic Type record.
C1-CollectionClassControlAdd
Used to add a Collection Class Control record.
This component invokes the ATC1CollectionClassControl Inbound Web Service using the C1-CollClassControlPhysicalBO Business Object.
C1-CollectionClassControlDelete
Used to delete a Collection Class Control record.
C1-CollectionClassControlRead
Used to read a Collection Class Control record.
C1-CollectionClassControlUpdate
Used to update a Collection Class Control record.
C1-CSRTRelUpdAdd
C1-CSRTRelUpdDelete
Used to delete a CS Request Type Related Update record.
C1-CSRTRelUpdRead
Used to read a CS Request Type Related Update record.
C1-CSRTRelUpdUpdate
Used to update a CS Request Type Related Update record.
C1-CSRTQuestionAdd
Used to add a CSR Type Question record.
This component invokes the ATC1CSRTQuestion Inbound Web Service using the C1-CSRTQuestion Business Object.
C1-CSRTQuestionDelete
Used to delete a CSR Type Question record.
C1-CSRTQuestionRead
Used to read a CSR Type Question record.
C1-CSRTQuestionUpdate
Used to update a CSR Type Question record.
C1-CSRTRelUpdAdd
C1-CSRTRelUpdDelete
C1-CSRTRelUpdRead
C1-CSRTRelUpdUpdate
C1-CustSvcRequestResponseAdd
Used to add a Cust Svc Request Response record.
This component invokes the ATC1CustSvcRequestResponse Inbound Web Service using the C1-CustSvcRequestResponse Business Object.
C1-CustSvcRequestResponseDelete
Used to delete a Cust Svc Request Response record.
C1-CustSvcRequestResponseRead
Used to read a Cust Svc Request Response record.
C1-CustSvcRequestResponseUpdate
Used to update a Cust Svc Request Response record.
C1-MarketAdd
Used to add a Market record.
This component invokes the ATC1Market Inbound Web Service using the C1-MarketPhysicalBO Business Object.
C1-MarketDelete
Used to delete a Market record.
C1-MarketRead
Used to read a Market record.
C1-MarketUpdate
Used to update a Market record.
C1-MktProvConfigOptAdd
Used to add a Mkt Prov Config Opt record.
This component invokes the ATC1MktProvConfigOpt Inbound Web Service using the C1-MktProvConfigOpt Business Object.
C1-MktProvConfigOptDelete
Used to delete a Mkt Prov Config Opt record.
C1-MktProvConfigOptRead
Used to read a Mkt Prov Config Opt record.
C1-MktProvConfigOptUpdate
Used to update a Mkt Prov Config Opt record.
C1-ProviderConfigurationOptionAdd
Used to add a Provider Configuration Option record.
This component invokes the ATC1ProviderConfigurationOption Inbound Web Service using the C1-ProviderConfigurationOptionBusiness Service.
C1-ProviderConfigurationOptionDelete
Used to delete a Provider Configuration Option record.
C1-ProviderConfigurationOptionRead
Used to read a Provider Configuration Option record.
C1-ProviderConfigurationOptionUpdate
Used to update a Provider Configuration Option record.
C1-SARelTypeAdd
Used to add a SA Relationship Type record.
This component invokes the ATC1SARelType Inbound Web Service using the C1-SARelTypePhysicalBO Business Object.
C1-SARelTypeDelete
Used to delete a SA Relationship Type record.
C1-SARelTypeRead
Used to read a SA Relationship Type record.
C1-SARelTypeUpdate
Used to update a SA Relationship Type record.
C1-SvcProvMktOptAdd
Used to add a Svc Prov Mkt Opt record.
This component invokes the ATC1SvcProvMktOpt Inbound Web Service using the C1-SvcProvMktOpt Business Object.
C1-SvcProvMktOptDelete
Used to delete a Svc Prov Mkt Opt record.
C1-SvcProvMktOptRead
Used to read a Svc Prov Mkt Opt record.
C1-SvcProvMktOptUpdate
Used to update a Svc Prov Mkt Opt record.
C1-DistributionCodeAdd
Used to add a Distribution Code record.
This component invokes the ATC1DistributionCode Inbound Web Service using the C1-DistributionCodePhysicalBO Business Object.
C1-DistributionCodeDelete
Used to delete a Distribution Code record.
C1-DistributionCodeRead
Used to read a Distribution Code record.
C1-DistributionCodeUpdate
Used to update a Distribution Code record.
C1-CISDivisionAdd
Used to add a CIS Division record.
This component invokes the ATC1CISDivision
CISDivisionPhysicalBO Business Object.
C1-CISDivisionRead
Used to read a CIS Division record.
C1-CISDivisionUpdate
Used to update a CIS Division record.
C1-CISDivisionDelete
Used to delete a CIS Division record.
C1-DispatchGroupAdd
Used to add a Dispatch Group record.
This component invokes the ATC1DispatchGroup
DispatchGroupPhysicalBO Business Object.
C1-DispatchGroupRead
Used to read a Dispatch Group record.
C1-DispatchGroupUpdate
Used to update a Dispatch Group record.
C1-DispatchGroupDelete
Used to delete a Dispatch Group record.
C1-IdentifierTypeAdd
Used to create an Identifier Type record.
This component invokes the ATC1IdentifierType Inbound Web Service using C1-IdentifierTypePhysicalBO Business Object.
C1-GeographicTypeAdd
Used to add a Geographic Type record.
This component invokes the ATC1GeographicType Inbound Web Service using the F1-GeographicTypePhysicalBO Business Object.
C1-GeographicTypeDelete
Used to delete a Geographic Type record.
C1-GeographicTypeRead
Used to read a Geographic Type record.
C1-GeographicTypeUpdate
Used to update a Geographic Type record.
C1-IdentifierTypeDelete
Used to delete an existing Identifier Type record.
C1-IdentifierTypeRead
Used to query an existing Identifier Type record.
C1-IdentifierTypeUpdate
Used to update an existing Identifier Type record.
C1-InsightGroupAdd
Used to add an Insight Group record.
This component invokes the ATC1InsightGroup Inbound Web Service using the
F1-InsightGroupPhysicalBO Business Object.
C1-InsightGroupDelete
Used to delete an Insight Group record.
C1-InsightGroupRead
Used to read an Insight Group record.
C1-InsightGroupUpdate
Used to update an Insight Group record.
C1-ItemTypeAdd
Used to add an Item Type record.
This component invokes the ATC1ItemType
ItemTypePhysicalBO Business Object.
C1-ItemTypeRead
Used to read an Item Type record.
C1-ItemTypeUpdate
Used to update an Item Type record.
C1-ItemTypeDelete
Used to delete an Item Type record.
Business Object.
Business Object.
C1-PaymentTypeLookupAdd
Used to add a Payment Type Lookup record.
ATC1PaymentTypeLookup Inbound Web Service
using the C1-PaymentTypeLookup Business Object.
C1-PaymentTypeLookupRead
Used to read a Payment Type Lookup record.
C1-PaymentTypeLookupUpdate
Used to update a Payment Type Lookup record.
C1-PaymentTypeLookupDelete
Used to delete a Payment Type Lookup record.
C1-PersonContactTypeAdd
Used to add a Person Contact Type.
ATC1PersonContactType Inbound Web Service
using the C1-PersonContactType Business Object.
C1-PersonContactTypeRead
Used to read a Person Contact Type.
C1-PersonContactTypeUpdate
Used to update a Person Contact Type.
C1-PersonContactTypeDelete
Used to delete a Person Contact Type.
C1-PremiseTypeAdd
Used to read a Premise Type record.
This component invokes the ATC1PremiseType
PremiseTypePhysicalBO Business Object.
C1-PremiseTypeRead
C1-PremiseTypeUpdate
Used to update a Premise Type record.
C1-PremiseTypeDelete
Used to Delete a Premise Type record.
C1-SPTypeAdd
Used to add a SP Type record.
This component invokes the ATC1SPType Inbound
Web Service using the C1-SPTypePhysicalBO
Business Object.
C1-SPTypeRead
Used to read a SP Type record.
Business Object.
C1-SPTypeUpdate
Used to update a SP Type record.
Business Object.
C1-SPTypeDelete
Used to Delete a SP Type record.
Business Object.
C1-StatementCycleAdd
Used to add a Statement Cycle record.
This component invokes the ATC1StatementCycle
C1-StatementCyclePhysicalBO Business Object.
C1-StatementCycleRead
C1-SPTypePhysicalBO Business Object.
C1-StatementCycleUpdate
Used to update a Statement Cycle record.
C1-StatementCycleDelete
Used to delete a Statement Cycle record.
X1-UnitOfMeasureAdd
Used to create a CCB Unit Of Measure record.
This component invokes the ATD1UnitOfMeasure Inbound Web Service using D1-UnitOfMeasure Business Object.
X1-UnitOfMeasureDelete
Used to delete an existing CCB Unit Of Measure record.
D1-CutServiceForNonPaymentTypeAdd
Used to create a Cut Service for Non-Payment Type record.
This component invokes the ATD1CutServiceForNonPaymentType Inbound Web Service using D1-CutServiceForNonPaymentType Business Object.
Delete
Used to delete an existing Cut Service for Non-Payment Type record.
D1-CutServiceForNonPaymentTypeRead
Used to query an existing Cut Service for Non-Payment Type record.
Update
Used to update an existing Cut Service for Non-Payment Type record.
D1-AggregatorRoot
Used to perform actions such as ADD, READ, UPDATE, and DELETE a AggregatorRoot.
This component invokes the D1- AggregatorRoot Business Object using the ATD1AggregatorRoot Inbound Web Service.
D1-ActivityStatsAggregator
Used to perform actions such as ADD, READ, UPDATE, and DELETE a ActivityStatsAggregator.
This component invokes the D1-ActivityStatsAggregatorBusiness Object using the ATD1ActivityStatsAggregator Inbound Service.
D1-StatsAggregator
Used to perform actions such as ADD, READ, UPDATE, and DELETE a StatsAggregator.
This component invokes the D1-StatsAggregator Business Object using the ATD1StatsAggregators Inbound Web Service.
D2-ItemAggregatorPostalSvcType
Used to perform actions such as ADD, READ, UPDATE, and DELETE a ItemAggregatorPostalSvcType.
This component invokes the D1-ItemAggregatorPostalSvcType bo using the ATD1 ItemAggregatorPostalSvcType Inbound Service.
D1-DisableServiceTypeAdd
Used to create a Disable Service Type record.
This component invokes the ATD1DisableServiceType IWS using D1-DisableServiceType Business Object.
D1-DisableServiceTypeDelete
Used to delete an existing Disable Service Type record.
D1-DisableServiceTypeRead
Used to query an existing Disable Service Type record.
D1-DisableServiceTypeUpdate
Used to update an existing Disable Service Type record.
D1-EnableServiceTypeAdd
Used to create an Enable Service Type record.
This component invokes the ATD1EnableServiceType IWS using D1-EnableServiceType Business Object.
D1-EnableServiceTypeDelete
Used to delete an existing Enable Service Type record.
D1-EnableServiceTypeRead
Used to query an existing Enable Service Type record.
D1-EnableServiceTypeUpdate
Used to update an existing Enable Service Type record.
D1-FieldActivityTypeAdd
Used to create a Field Activity Type record.
This component invokes the ATD1FieldActivityType Inbound Web Service using D1-FieldActivityType Business Object.
D1-FieldActivityTypeDelete
Used to delete an existing Field Activity Type record.
D1-FieldActivityTypeRead
Used to query an existing Field Activity Type record.
D1-FieldActivityTypeUpdate
Used to update an existing Field Activity Type record.
C1-PremiseTypeAdd
Used to create a Premise Type record.
This component invokes the ATC1PremiseType Inbound Web Service using the C1-PremiseTypePhysicalBO business object.
Used to delete an existing Premise Type record.
C1-PremiseTypeRead
Used to query an existing Premise Type record.
Used to update an existing Premise Type record.
W1-AssetLocationTypeAdd
Used to create an Asset Location Type record.
This component invokes the ATW1AssetLocationType Inbound Web Service using the W1-AssetLocationType business object.
W1-AssetLocationTypeDelete
Used to delete an existing Asset Location Type record.
W1-AssetLocationTypeRead
Used to query an existing Asset Location Type record.
W1-AssetLocationTypeUpdate
Used to update an existing Asset Location Type record.
This component invokes the ATW1AssetLocationType Inbound Web Service using W1-AssetLocationType business object.
W1-AssetTypeAdd
Used to create an Asset Type record.
This component invokes the ATW1AssetType Inbound Web Service using the W1-AssetType business object.
W1-AssetTypeDelete
Used to delete an existing Asset Type record.
W1-AssetTypeRead
Used to query an existing Asset Type record.
W1-AssetTypeUpdate
Used to update an existing Asset Type record.
This component invokes the ATW1AssetType Inbound Web Service using W1-AssetType business object.
W1-ContactTypeRead
Used to query an existing Contact Type record.
This component invokes the ATW1ContactType Inbound Web Service using the W1-ContactType business object.
W1-ComponentTypeAdd
Used to create an Operational Device Component Type record.
This component invokes the ATW1ComponentType Inbound Web Service using the W1-ComponentType business object.
W1-ComponentTypeDelete
Used to delete an existing Operational Device Component Type record.
W1-ComponentTypeRead
Used to query an existing Operational Device Component Type record.
W1-ComponentTypeUpdate
Used to update an existing Operational Device Component Type record.
This component invokes the ATW1ComponentType Inbound Web Service using W1-ComponentType business object.
W1-OrganizationAdd
Used to create an Organization record.
This component invokes the ATW1Organization Inbound Web Service using the W1-Organization business object.
W1-OrganizationDelete
Used to delete an existing Organization record.
W1-OrganizationRead
Used to query an existing Organization record.
W1-OrganizationUpdate
Used to update an existing Organization record.
This component invokes the ATW1Organization Inbound Web Service using W1-Organization business object.
W1-OrganizationTypeAdd
Used to create an Organization Type record.
This component invokes the ATW1OrganizationType Inbound Web Service using the W1-OrganizationType business object.
W1-OrganizationTypeDelete
Used to delete an existing Organization Type record.
W1-OrganizationTypeRead
Used to query an existing Organization Type record.
W1-OrganizationTypeUpdate
Used to update an existing Organization Type record.
This component invokes the ATW1OrganizationType Inbound Web Service using W1-OrganizationType business object.
W1-ServiceHistoryAdd
Used to create an Operational Device Service History record.
This component invokes the ATW1ServiceHistory Inbound Web Service using the W1-ServiceHistory business object.
W1-ServiceHistoryDelete
Used to delete an existing Operational Device Service History record.
W1-ServiceHistoryRead
Used to query an existing Operational Device Service History record.
W1-ServiceHistoryUpdate
Used to update an existing Operational Device Service History record.
This component invokes the ATW1ServiceHistory Inbound Web Service using W1-ServiceHistory business object.
W1-StorageLocationAdd
Used to create an Out of Service Location record.
This component invokes the ATW1StorageLocation Inbound Web Service using the W1-StorageLocation business object.
W1-StorageLocationDelete
Used to delete an existing Out of Service Location record.
W1-StorageLocationRead
Used to query an existing Out of Service Location record.
W1-StorageLocationUpdate
Used to update an existing Out of Service Location record.
This component invokes the ATW1StorageLocation Inbound Web Service using W1-StorageLocation business object.
W1-StorageLocationTypeAdd
Used to create an Out of Service Location Type record.
This component invokes the ATW1StorageLocationType Inbound Web Service using the W1-StorageLocationType business object.
W1-StorageLocationTypeDelete
Used to delete an existing Out of Service Location Type record.
W1-StorageLocationTypeRead
Used to query an existing Out of Service Location Type record.
W1-StorageLocationTypeUpdate
Used to update an existing Out of Service Location Type record.
This component invokes the ATW1StorageLocationType Inbound Web Service using W1-StorageLocationType business object.
W2-ServicePointRead
Used to query an existing Service Point record.
This component invokes the ATW2ServicePoint Inbound Web Service using the W2-ServicePoint business object.
W2-VehicleAdd
Used to create a Vehicle record.
This component invokes the ATW2Vehicle Inbound Web Service using the W2-Vehicle business object.
W1-VehicleDelete
Used to delete an existing Vehicle record.
W1-VehicleRead
Used to query an existing Vehicle record.
W1-VehicleUpdate
Used to update an existing Vehicle record.
This component invokes the ATW2Vehicle Inbound Web Service using W2-Vehicle business object.
X1-AssetLocationTypeAdd
Used to create a Service Point Type - ODM record.
This component invokes the ATX1AssetLocationType Inbound Web Service using the X1-AssetLocationType business object.
X1-AssetLocationTypeDelete
Used to delete an existing Service Point Type - ODM record.
X1-AssetLocationTypeRead
Used to query an existing Service Point Type - ODM record.
X1-AssetLocationTypeUpdate
Used to update an existing Service Point Type - ODM record.
This component invokes the ATX1AssetLocationType Inbound Web Service using X1-AssetLocationType business object.
X1-ServicePointTypeAdd
Used to create a Service Point Type - CCB record.
This component invokes the ATX1ServicePointType Inbound Web Service using X1-ServicePointType Business Object.
X1-ServicePointTypeDelete
Used to delete an existing Service Point Type - CCB record.
This component invokes the ATX1ServicePointType Inbound Web Service using X1-ServicePointType BO.
X1-ServicePointTypeRead
Used to query an existing Service Point Type - CCB record.
X1-ServicePointTypeUpdate
Used to update an existing Service Point Type - CCB record.
X1-ServiceTypeAdd
Used to create a Service Type - CCB record.
This component invokes the ATX1ServiceType Inbound Web Service using X1-ServiceType BO.
X1-ServiceTypeDelete
Used to delete an existing Service Type - CCB record.
X1-ServiceTypeRead
Used to query an existing Service Type - CCB record.
X1-ServiceTypeUpdate
Used to update an existing Service Type - CCB record.
X1D-ServicePointTypeAdd
Used to create a Service Point Type - MDM record.
This component invokes the ATXD1ServicePointType Inbound Web Service using X1D-ServicePointType BO.
X1D-ServicePointTypeDelete
Used to delete an existing Service Point Type - MDM record.
X1D-ServicePointTypeRead
Used to query an existing Service Point Type - MDM record.
X1D-ServicePointTypeUpdate
Used to update an existing Service Point Type - MDM record.
D1-DeviceEventComRespTypeAdd
Used to create a Device Event Communication Response Type record.
This component invokes the ATD1DeviceEventComRespType Inbound Web Service using D1-DeviceEventComRespType BO.
D1-DeviceEventComRespTypeDel
Used to delete an existing Device Event Communication Response Type record.
D1-DeviceEventComRespTypeRead
Used to query an existing Device Event Communication Response Type record.
D1-DeviceEventComRespTypeUpd
Used to update an existing Device Event Communication Response Type record.
W1-AssetCompCfgRptAdd
Used to create a Component Config Report record.
This component invokes the Business Object W1-AssetCompCfgRpt using the Inbound Web Service of ATW1AssetCompCfgRpt.
W1-AssetCompCfgRptDelete
Used to delete an existing Component Config Report record.
W1-AssetCompCfgRptRead
Used to query an existing Component Config Report record.
W1-AssetCompCfgRptUpdate
Used to update an existing Component Config Report record.
W1-AssetCompConfigAdd
Used to create an Asset Component Config Report record.
This component invokes the ATW1AssetCompConfig Inbound Web Service using W1-AssetCompConfig BO.
W1-AssetCompConfigDelete
Used to delete an Asset Component Config Report record.
W1-AssetCompConfigRead
Used to query an Asset Component Config Report record.
W1-AssetCompConfigUpdate
W1-AssetCompToAssetCompCfgRptAdd
Used to create an Asset Component to Asset Component Config Report record.
This component invokes the W1- ATW1AssetCompToAssetCompCfgRpt Inbound Web Service using W1-AssetCompToAssetCompCfgRpt BO.
Delete
Used to update an existing Asset Component to Asset Component Config Report record.
W1-AssetCompToAssetCompCfgRptRead
Used to update an query Asset Component to Asset Component Config Report record.
Update
Used to delete an query Asset Component to Asset Component Config Report record
W1-AssetCompToAssetConfigAdd
Used to create an Asset Component to Asset Config record.
This component invokes the ATW1AssetCompToAssetConfig Inbound Web Service using W1-AssetCompToAssetConfig BO.
W1-AssetCompToAssetConfigDelete
Used to delete an existing Asset Component to Asset Config record.
W1-AssetCompToAssetConfigRead
Used to update an existing Asset Component to Asset Config record.
W1-AssetCompToAssetConfigUpdate
Used to update an existing Asset Component to Asset Component Config record.
W1-AssetToAssetCompCfgRptAdd
Used to create an Asset to Asset Component Config Report record.
This component invokes the ATW1AssetToAssetCompCfgRpt Inbound Web Service using W1-AssetToAssetCompCfgRpt BO.
W1-AssetToAssetCompCfgRptDelete
Used to delete an existing Asset to Asset Component Config Report record.
W1-AssetToAssetCompCfgRptRead
Used to query an existing Asset to Asset Component Config Report record.
W1-AssetToAssetCompCfgRptUpdate
Used to update an existing Asset to Asset Component Config Report record.
W1-AssetToAssetConfigAdd
Used to create an Asset to Asset record.
This component invokes the ATD8StatusChangedType Inbound Web Service using D8-ReadOnDemandReadResultType BO.
W1-AssetToAssetConfigDelete
Used to delete an existing Asset to Asset record.
This component invokes the ATD8ReadOnDemandReadResultType Inbound Web Service using D8-StatusChangedType BO.
W1-AssetToAssetConfigRead
Used to query an existing Asset to Asset record.
This component invokes the ATD8StatusChangedType Inbound Web Service using D8-StatusChangedType BO.
W1-AssetToAssetConfigUdpate
Used to update an existing Asset to Asset record.
W1-ConfigTypeAdd
Used to create a Config Type record.
This component invokes the ATW1ConfigType Inbound Web Service using W1-ConfigType BO.
W1-ConfigTypeDelete
Used to delete an existing Config Type record.
W1-ConfigTypeRead
Used to query an existing Config Type record.
W1-ConfigTypeUpdate
Used to update an existing Config Type record.
W1-SingleAssetCfgRptAdd
Used to create a Single Asset Config Report record.
This component invokes the ATW1SingleAssetCfgRp Inbound Web Service using W1-SingleAssetCfgRp BO.
W1-SingleAssetCfgRptDelete
Used to delete an existing Single Asset Config Report record.
W1-SingleAssetCfgRptRead
Used to query an existing Single Asset Config Report record
W1-SingleAssetCfgRptUdpate
Used to update an existing Single Asset Config Report record.
W1-SingleAssetConfigAdd
Used to create a Single Asset Config record.
This component invokes the ATW1SingleAssetConfig Inbound Web Service using W1-SingleAssetConfig BO.
W1-SingleAssetConfigDelete
Used to delete an existing Single Asset Config record.
W1-ActivityCompletionEventTypeAdd
Used to create an Activity Completion Event Type record.
This component invokes the ATW1ActivityCompletionEventType Inbound Web Service using W1-ActivityCompletionEventType Business Object.
W1-ActivityCompletionEventTypeDelete
Used to delete an existing Activity Completion Event Type record.
W1-ActivityCompletionEventTypeRead
Used to query an existing Activity Completion Event Type record.
W1-ActivityCompletionEventTypeUpdate
Used to update an existing Activity Completion Event Type record.
W1-AssetDposCmpEvtTypeAdd
Used to create an Asset Disposition Completion Event Type record
This component invokes the ATW1AssetDposCmpEvtType Inbound Web Service using W1-AssetDposCmpEvtType Business Object.
W1-AssetDposCmpEvtTypeDelete
Used to delete an existing Asset Disposition Completion Event Type record.
W1-AssetDposCmpEvtTypeRead
Used to query an existing Asset Disposition Completion Event Type record.
W1-AssetDposCmpEvtTypeUpdate
Used to update an existing Asset Disposition Completion Event Type record
W1-BasicActivityTypeAdd
Used to create a Basic Activity Type record.
This component invokes the ATW1BasicActivityType Inbound Web Service using W1-BasicActivityType Business Object.
W1-BasicActivityTypeDel
Used to delete an existing Basic Activity Type record.
This component invokes the ATW1BasicActivityTypeInbound Web Service using W1-BasicActivityType Business Object.
W1-BasicActivityTypeRead
Used to query an existing Basic Activity Type record.
W1-BasicActivityTypeUpdate
Used to update an existing Basic Activity Type record.
W1-DataAreaCmpEvtTypeAdd
Used to create Data Area Completion Event Type record.
This component invokes the ATW1DataAreaCmpEvtType Inbound Web Service using W1-DataAreaCmpEvtType Business Object.
W1-DataAreaCmpEvtTypeDelete
Used to delete an existing Data Area Completion Event Type record.
W1-DataAreaCmpEvtTypeRead
Used to query an existing Data Area Completion Event Type record
W1-DataAreaCmpEvtTypeUpdate
Used to update an existing Data Area Completion Event Type record
W1-GeneralCommunicationAdd
Used to create a General Inbound Communication Type record.
This component invokes the ATW1GeneralCommunicationType Inbound Web Service using W1-GeneralCommunicationTypeBusiness Object.
W1-GeneralCommunicationDelete
Used to delete an existing General Inbound Communication Type record
This component invokes the ATW1GeneralCommunicationType Inbound Web Service using W1-GeneralCommunicationType Business Object.
W1-GeneralCommunicationRead
Used to query an existing General Inbound Communication Type record
W1-GeneralCommunicationUpdate
Used to update an existing General Inbound Communication Type record.
W1-GeneralCompletionEventTypeAdd
Used to create General Completion Event Type record.
This component invokes the ATW1GeneralCompletionEventType Inbound Web Service using W1-GeneralCompletionEventType Business Object.
W1-GeneralCompletionEventTypeDelete
Used to delete an existing General Completion Event Type record.
W1-GeneralCompletionEventTypeRead
Used to query an existing General Completion Event Type record
W1-GeneralCompletionEventTypeUpdate
Used to update an existing General Completion Event Type record
W1-ManufacturerAdd
Used to create a Manufacturer record.
This component invokes the ATW1Manufacturer Inbound Web Service using W1-Manufacturer Business Object.
W1-ManufacturerDelete
Used to delete an existing Manufacturer record.
W1-ManufacturerRead
Used to query an existing Manufacturer record.
W1-ManufacturerUpdate
Used to update an existing Manufacturer record.
W1-OutboundActivityTypeAdd
Used to create an Outbound Activity Type record.
This component invokes the ATW1OutboundActivityType Inbound Web Service using W1-OutboundActivityType Business Object.
W1-OutboundActivityTypeDelete
Used to delete an existing Outbound Activity Type record.
W1-OutboundActivityTypeRead
Used to query an existing Outbound Activity Type record.
This component invokes the ATW1OutboundActivityType Inbound Web Service W1-OutboundActivityType Business Object.
W1-OutboundActivityTypeUpdate
Used to update an existing Outbound Activity Type record.
W1-ReplicationComplEventTypeAdd
Used to create a Replication Completion Event Type record.
This component invokes the ATW1ReplicationComplEventType Inbound Web Service using W1-ReplicationComplEventType Business Object.
W1-ReplicationComplEventTypeDelete
Used to delete an existing Replication Completion Event Type record
W1-ReplicationComplEventTypeRead
Used to query an existing Replication Completion Event Type record
W1-ReplicationComplEventTypeUpdate
Used to update an existing Replication Completion Event Type record.
W1-ScheduledActivityTypeAdd
Used to create a Scheduled Activity Type record.
This component invokes the ATW1ScheduledActivityType Inbound Web Service using W1-ScheduledActivityType Business Object.
W1-ScheduledActivityTypeDelete
Used to delete an existing Scheduled Activity Type record.
W1-ScheduledActivityTypeRead
Used to query an existing Scheduled Activity Type record.
This component invokes the ATW1ScheduledActivityType Inbound Web Service W1-ScheduledActivityType Business Object.
W1-ScheduledActivityTypeUpdate
Used to update an existing Scheduled Activity Type record.
W1-ServiceHistTypeCmpEvtTypeAdd
Used to create a Service History Completion Event Type record.
This component invokes the ATW1ServiceHistTypeCmpEvtTypeInbound Web Service using W1-ServiceHistTypeCmpEvtType Business Object.
W1-ServiceHistTypeCmpEvtTypeDelete
Used to delete an existing Service History Completion Event Type record.
This component invokes the ATW1ServiceHistTypeCmpEvtTypeInbound Web Service W1-ServiceHistTypeCmpEvtType Business Object.
W1-ServiceHistTypeCmpEvtTypeRead
Used to query an existing Service History Completion Event Type record.
W1-ServiceHistTypeCmpEvtTypeUpdate
Used to update an existing Service History Completion Event Type record.
This component invokes the ATW1ServiceHistTypeCmpEvtType Inbound Web Service using W1-ServiceHistTypeCmpEvtType Business Object.
W1-SvcHistFromActvCmplEvtType
Add
Used to create a Service History From Activity Completion Event Type record.
This component invokes the ATW1SvcHistFromActvCmplEvtType Inbound Web Service W1-SvcHistFromActvCmplEvtType Business Object.
TypeDelete
Used to delete an existing Service History From Activity Completion Event Type record.
Read
Used to query an existing Service History From Activity Completion Event Type record.
TypeUpdate
Used to update an existing Service History From Activity Completion Event Type record.
W1-SOMActivityTypeRead
Used to query a SOM Activity Type record.
This component invokes the ATW1SOMActivityType Inbound Web Service using W1-SOMActivityType Business Object.
D2-SubIntAdjustmentVEE
Performs adjustments to consumption; the changes to consumption will be validated against the readings contained prior to and subsequent to the change made.
This component invokes the D2-SubIntAdjustmentVEE Business Object using the ATD2SubIntAdjustmentVEE Inbound Web Service.
D2-GetSubtractiveInterval
Allows the configuration of subtractive interval data retrieval during usage transaction processing. The rule records service quantities per service point and measuring component - which means that subtractive interval curves for different measuring components.
This component invokes the D2-GetSubtractiveInterval Business Object using the ATD2GetSubtractiveInterval Inbound Web Service.
D1-MeterReadDownloadActType
Used to create a MeterReadDownloadActType Activity Type.
This component invokes the D1-MeterReadDownloadActType Business Object using the ATD1MeterReadDownloadActType Inbound Web Service.
D1-PairedEventLastDvcEvtType
Used to create a PairedEventLastDvcEvtType Device Event Type.
This component invokes the D1-PairedEventLastDvcEvtType Business Object using the ATD1PairedEventLastDvcEvtType Inbound Web Service.
D1-StandardDeviceEventType
Used to create a StandardDeviceEventType Device Event Type.
This component invokes the D1-StandardDeviceEventType Business Object using the ATD1StandardDeviceEventType Inbound Web Service.
D1-UTCorrectnPrcessrActvtyType
Defines the activity BO to use in the creation of a Usage Transaction Correction Processor. This component also defines the general category of these activities as a Correction Processor.
The component invokes the D1-UTCorrectnPrcessrActvtyType Business Object using the ATD1UTCorrectnPrcessrActvtyType Inbound Web Service.
D1-RemoteConnectType
Describes configuration parameters required for the Remote Connect command activity, including automated retry and command time-out options. This component allows the definition of a Service Issue Monitor Type resulting in the creation of a Service Issue Monitor of the configured type if a Remote Connect command activity has failed.
The component invokes the D1-RemoteConnectType Business Object using the ATD1RemoteConnectType Inbound Web Service.
D1-PairedEventFirstDvcEvtType
Describes the Device Event Type - Paired Event (First).
This component invokes the D1-PairedEventFirstDvcEvtType Business Object using the ATD1PairedEventFirstDvcEvtType Inbound Web Service.
D1-DeviceWithDurationActType
Describes the Device Activity with Duration Type.
This component invokes the D1-DeviceWithDurationActType Business Object using the ATD1DeviceWithDurationActType Inbound Web Service.
D2-SubMeasurementAggType
Describes the Sub Measurement Aggregator Type.
This component invokes the D2-SubMeasurementAggType Business Object using the ATD2SubMeasurementAggType Inbound Web Service.
D2-MasterMsrmtAggregatorType
Describes the Master Measurement Aggregator Type.
This component invokes the D2-MasterMsrmtAggregatorType Business Object using the ATD2MasterMsrmtAggregatorType Inbound Web Service.
D2-ActivityTypeAggDimScanner
Describes the Aggregator Dimension Scanner Activity Type.
This component invokes the D2-ActivityTypeAggDimScanner Business Object using the ATD2ActivityTypeAggDimScanner Inbound Web Service.
D2-AggregatorType
Used to create an AggregatorType Measuring Component Type.
This component invokes the D2-AggregatorType Business Object using the ATD2AggregatorType Inbound Web Service.
D1-IntervalChannelTypePhysical
Used to create a IntervalChannelTypePhysical.
This component invokes the D1-IntervalChannelTypePhysical Business Object using the ATD1IntervalChannelTypePhysical Inbound Web Service.
D1-MeasurementCycleSchedule
Used to create a MeasurementCycleSchedule.
This component invokes the D1-MeasurementCycleSchedule Business Object using the ATD1MeasurementCycleSchedule Inbound Web Service.
D1-ReaderRemarkType
Used to create a ReaderRemarkType.
This component invokes the D1-ReaderRemarkType Business Object using the ATD1ReaderRemarkType Inbound Web Service.
D1-ServiceIssueMonitorType
Used to create a ServiceIssueMonitorType.
This component invokes the D1-ServiceIssueMonitorType Business Object using the ATD1ServiceIssueMonitorType Inbound Web Service.
D2-MsrmtQuantityAggScannerType
Used to create a MsrmtQuantityAggScannerType.
This component invokes the D2-MsrmtQuantityAggScannerType Business Object using the ATD2MsrmtQuantityAggScannerType Inbound Web Service.
D2-TOUGroup
Used to create a TOUGroup.
This component invokes the D2-TOUGroup Business Object using the ATD2TOUGroup Inbound Web Service.
D2-VEERuleHighLowCheck
Used to create a VEERuleHighLowCheck.
This component invokes the D2-VEERuleHighLowCheck Business Object using the ATD2VEERuleHighLowCheck Inbound Web Service.
D1-HowToCreateMCInformation
Used to create a HowToCreateMCInformation.
This component invokes the D1-HowToCreateMCInformation Business Object using the ATD1HowToCreateMCInformation Inbound Web Service.
D1-HowToSendActivityResponse
Used to create a HowToSendActivityResponse.
This component invokes the D1-HowToSendActivityResponse Business Object using the ATD1HowToSendActivityResponse Inbound Web Service.
D1-AvgDailyEstItemConsumption
Used to create a AvgDailyEstItemConsumption.
This component invokes the D1-AvgDailyEstItemConsumption Business Object using the ATD1AvgDailyEstItemConsumption Inbound Web Service.
D1-VEEEligibilityCriteria
Used to create a VEEEligibilityCriteria.
This component invokes the D1-VEEEligibilityCriteria Business Object using the ATD1VEEEligibilityCriteria Inbound Web Service.
D2-VerifyUomTouSqiMCExistForUs
Used to create a VerifyUomTouSqiMCExistForUs.
This component invokes the D2-VerifyUomTouSqiMCExistForUs Business Object using the ATD2VerifyUomTouSqiMCExistForUs Inbound Web Service.
D1-DeviceEventSeeder
Used to create a DeviceEventSeeder.
This component invokes the D1-DeviceEventSeeder Business Object using the ATD1DeviceEventSeeder Inbound Web Service.
D1-FieldActivity
Used to create a FieldActivity.
This component invokes the D1-FieldActivity Business Object using the ATD1FieldActivity Inbound Web Service.
D1-ReaderRemark
Used to create a ReaderRemark.
This component invokes the D1-ReaderRemark Business Object using the ATD1ReaderRemark Inbound Web Service.
D1-TimeZoneTranslationLookup
Used to create a TimeZoneTranslationLookup.
This component invokes the D1-ATD1TimeZoneTranslationLookup Business Object using the ATD1ReaderRemark Inbound Web Service.
D2-UsageCalculationGroupLookup
Used to create a UsageCalculationGroupLookup.
This component invokes the D2-UsageCalculationGroupLookup Business Object using the ATD2UsageCalculationGroupLookup Inbound Web Service.
D2-MDMMasterConfig
Used to perform actions such as ADD, READ, UPDATE, and DELETE a MDMMasterConfig.
This component invokes the D2- MDMMasterConfig Business Object using the ATD2MDMMasterConfig Inbound Web Service.
D2-MDMMasterConfig
D2-MtrCommTrckngAggregatorType
Used to perform actions such as ADD, READ, UPDATE, and DELETE a MtrCommTrckngAggregatorType.
This component invokes the D2- MtrCommTrckngAggregatorType Business Object using the ATD2MtrCommTrckngAggregatorType Inbound Web Service.
D1-EstimationSuppressionType
Used to perform actions such as ADD, READ, UPDATE, and DELETE a EstimationSuppressionType.
This component invokes the D1- EstimationSuppressionType Business Object using the ATD1EstimationSuppressionType Inbound Web Service.
D2-InactiveMeasurementCheck
Used to perform actions such as ADD, READ, UPDATE, and DELETE a InactiveMeasurementCheck VEE Rule.
This component invokes the D1- InactiveMeasurementCheck Business Object using the ATD2InactiveMeasurementCheck Inbound Web Service.
D1-ChannelStatisticsType
Used to perform actions such as ADD, READ, UPDATE, and DELETE a ChannelStatisticsType.
This component invokes the D1- ChannelStatisticsType Business Object using the ATD1ChannelStatisticsType Inbound Web Service.
Used to perform actions such as ADD, READ, UPDATE, and DELETE a ChannelStatistics.
This component invokes the D1- ChannelStatistics Business Object using the ATD1ChannelStatistics Inbound Web Service.
D1-FacilityLite
Used to perform actions such as ADD, READ, UPDATE, and DELETE a FacilityLite.
This component invokes the D1- FacilityLite Business Object using the ATD1FacilityLite Inbound Web Service.
D1-SpecificationLookup
Used to perform actions such as ADD, READ, UPDATE, and DELETE a SpecificationLookup.
This component invokes the D1- SpecificationLookup Business Object using the ATD1SpecificationLookup Inbound Web Service.
D1-MeasuringCompTypLite
Used to perform actions such as ADD, READ, UPDATE, and DELETE a MeasuringCompTypLite.
This component invokes the D1- MeasuringCompTypLite Business Object using the ATD1MeasuringCompTypLite Inbound Web Service.
D1-GetDvcFrmIdenTypFlag
Used to retrieve Device ID By Identifier and Type Flag using the ATD1 GetDvcFrmIdenTypFlag Inbound Web Service.
D1-GetSimdIdFromImd
Used to retrieve Simd ID By IMD ID using the ATD1GetSimdIdFromImd Inbound Web Service.
D1-GetMCFrmDvcExtId
Used to retrieve Measuring Component ID from Device External ID using the ATD1GetMCFrmDvcExtId Inbound Web Service.
D1-GetProductKeyFromSync
Used to Get Product Key from Sync Request ID using the ATD1 GetProductKeyFromSync Inbound Web Service.
D1-GetUsageFromExtID
Used to retrieve Usage ID from CCB Usage ID using the ATD1 GetUsageFromExtID Inbound Web Service.
D2-GetUSFromExtID
Used to retrieve US ID from External ID using the ATD1 GetUSFromExtID Inbound Web Service.
D1-GetDCFrmDvcExtId
Used to retrieve DC ID from External ID using the ATD1GetDCFrmDvcExtId Inbound Web Service.
D1-GetInstEvtFromDvcExId
Used to retrieve Install Event ID from Device External ID using ATD1GetInstEvtFromDvcExId Inbound Web Service.
D1-GetInstEvtFrmSPExtId
Used to retrieve Install Event ID from Service Point External ID using the ATD1GetInstEvtFrmSPExtId Inbound Web Service.
D1-GetMCFromExtID
Used to retrieve Measuring Component ID from External ID using the ATD1GetMCFromExtID Inbound Web Service.
D1-GetContactFromExtID
Used to retrieve Contact ID from External ID using the ATD1GetContactFromExtID Inbound Web Service.
D1-GetSpFromExtID
Used to retrieve Service Point ID from External ID using the ATD1GetSpFromExtID Inbound Web Service.
D1-GetSyncReqIdFrmExtId
Used to retrieve Sync Request ID from External ID using the ATD1GetSyncReqIdFrmExtId Inbound Web Service.
C1-MktSATypeSARelationshipTypeAdd
Used to add a Market SA Type SA Relatioship Type.
This component invokes the ATC1MktSATypeSARelationshipType Inbound Web Service the using C1-MktSATypeSARelationshipType Business Object.
C1-MktSATypeSARelationshipTypeDelete
Used to delete a Market SA Type SA Relationship Type.
C1-MktSATypeSARelationshipTypeRead
Used to read a Market SA Type SA Relationship Type.
Update
Used to update a Market SA Type SA Relationship Type.
C1-UserMiscRead
Used to Read a User Miscellaneous record.
This component invokes the ATC1UserMisc Inbound Web Service using the C1-UserMisc Business Object.
C1-UserMiscUpdate
Used to Update a User Miscellaneous record.
C1-WorkCalendarAdd
Used for adding a Work Calendar record.
This component invokes the ATC1WorkCalendar Inbound Web Service using the F1-WorkCalendarPhysicalBO Business Object.
C1-WorkCalendarDelete
Used for deleting a Work Calendar record.
C1-WorkCalendarRead
Used for reading a Work Calendar record.
C1-WorkCalendarUpdate
Used for updating a Work Calendar record.
C1-SATypeSARelationshipTypeAdd
C1-
Used to read a SA Type Relationship Type Record
C1-SATypeSARelationshipTypeUpdate
Used to update a SA Type Relationship Type record.
C1-SATypeSARelationshipTypeDelete
Used to Delete a SA Type Relationship Type record.
Asset Management
Component
Description
W1-SingleAssetConfigRead
Used to query an existing Single Asset Config record.
W1-SingleAssetConfigUpdate
Used to update an existing Single Asset Config record.
W1-AssetLocationAdd
Used to add an Operational Device Asset Location record.
This component invokes the Inbound Web Service ATW1AssetLocation using the W1-AssetLocation Business Object.
W1-AssetLocationDelete
Used to delete an Operational Device Asset Location record.
W1-AssetLocationRead
Used to read an Operational Device Asset Location record.
W1-AssetLocationUpdate
Used to update an Operational Device Asset Location record.
W1-BasicTestAdd
Used to add an Operational Device Basic Test record.
This component invokes the Inbound Web Service ATW1BasicTest using the W1-BasicTest business object.
W1-BasicTestDelete
Used to delete an Operational Device Basic Test record.
W1-BasicTestRead
Used to read an Operational Device Basic Test record.
W1-BasicTestUpdate
Used to update an Operational Device Basic Test record.
Used to add a Service History record.
This component invokes the Inbound Web Service ATW1ServiceHistory using the W1-ServiceHistory business object.
Used to delete a Service History record.
Used to read a Service History record.
Used to update a Service History record.
W2-CommComponentAdd
Used to add a Communication Component record.
This component invokes the Inbound Web Service ATW2CommunicationComponent using the W2-CommunicationComponent Business Object.
W2-CommComponentDelete
Used to delete a Communication Component record.
W2-CommComponentRead
Used to read a Communication Component record.
W2-CommComponentUpdate
Used to update a Communication Component record.
W2-CommCompSpecificationAdd
Used to add a Comm Comp Specification record.
This component invokes the Inbound Web Service ATW2CommunicationComponentSpec using the W2-CommunicationComponentSpec Business Object.
W2-CommCompSpecificationDelete
Used to delete a Comm Comp Specification record.
W2-CommCompSpecificationRead
Used to read a Comm Comp Specification record.
W2-CommCompSpecificationUpdate
Used to update a Comm Comp Specification record.
W2-CommRelaySpecificationAdd
Used to add a Comm Relay Specification record.
This component invokes the Inbound Web Service ATW2CommunicationRelaySpec using the W2-CommunicationRelaySpec Business Object.
W2-CommRelaySpecificationDelete
Used to delete a Comm Relay Specification record.
W2-CommRelaySpecificationRead
Used to read a Comm Relay Specification record.
W2-CommRelaySpecificationUpdate
Used to update a Comm Relay Specification record.
W2-CommunicationRelayAdd
Used to add a Communication Relay record.
This component invokes the Inbound Web Service ATW2CommunicationRelay using the W2-CommunicationRelay Business Object.
W2-CommunicationRelayDelete
Used to delete a Communication Relay record.
W2-CommunicationRelayRead
Used to read a Communication Relay record.
W2-CommunicationRelayUpdate
Used to update a Communication Relay record.
W2-FirmwareSpecificationAdd
Used to add a Firmware Specification record.
This component invokes the Inbound Web Service ATW2FirmwareSpecification using the W2-FirmwareSpecification Business Object.
W2-FirmwareSpecificationDelete
Used to delete a Firmware Specification record.
W2-FirmwareSpecificationRead
Used to read a Firmware Specification record.
W2-FirmwareSpecificationUpdate
Used to update a Firmware Specification record.
W2-FirmwareVersionAdd
Used to add a Firmware Version record.
This component invokes the Inbound Web Service ATW2FirmwareVersion using the W2-FirmwareVersion Business Object.
W2-FirmwareVersionDelete
Used to delete a Firmware Version record.
W2-FirmwareVersionRead
Used to read a Firmware Version record.
W2-FirmwareVersionUpdate
Used to update a Firmware Version record.
W2-ManualMeterAdd
Used to add an Analog Meter record.
This component invokes the Inbound Web Service ATW2ManualMeter using the W2-ManualMeter Business Object.
W2-ManualMeterDelete
Used to delete an existing Analog Meter record.
W2-ManualMeterRead
Used to read an existing Analog Meter record.
W2-ManualMeterUpdate
Used to update an existing Analog Meter record.
W2-ManualMeterSpecificationAdd
Used to add an Analog Meter Specification record.
This component invokes the Inbound Web Service ATW2ManualMeterSpecification using the W2-ManualMeterSpecification Business Object.
W2-ManualMeterSpecificationDelete
Used to delete an Analog Meter Specification record.
W2-ManualMeterSpecificationRead
Used to read an Analog Meter Specification record.
W2-ManualMeterSpecificationUpdate
Used to update an Analog Meter Specification record.
W2-SmartMeterAdd
Used to add a Smart Meter record.
This component invokes the Inbound Web Service ATW2SmartMeter using the W2-SmartMeter Business Object.
W2-SmartMeterDelete
Used to delete an existing Smart Meter record.
W2-SmartMeterRead
Used to read an existing Smart Meter record.
W2-SmartMeterUpdate
Used to update an existing Smart Meter record.
W2-SmartMeterSpecificationAdd
Used to add a Smart Meter Specification record.
This component invokes the Inbound Web Service ATW2SmartMeterSpecification using the W2-SmartMeterSpecification Business Object.
W2-SmartMeterSpecificationDelete
Used to delete a Smart Meter Specification record.
W2-SmartMeterSpecificationRead
Used to read a Smart Meter Specification record.
W2-SmartMeterSpecificationUpdate
Used to update a Smart Meter Specification record.
W2-SmartTestAdd
Used to add a Smart Device Test record.
This component invokes the Inbound Web Service ATW2SmartTest using the W2-SmartTest Business Object.
W2-SmartTestDelete
Used to delete an existing Smart Device Test record.
W2-SmartTestRead
Used to query an existing Smart Device Test record.
W2-SmartTestUpdate
Used to update an existing Smart Device Test record.
W1-AACCfgDeviceUpgradeAdd
Used to add a Configuration - Device - Asset to Component record.
This component invokes the Inbound Web Service ATW1AACCfgDeviceUpgrade using W1-AACCfgDeviceUpgrade Business Object.
W1-AACCfgDeviceUpgradeDelete
Used to delete an existing a Configuration - Device - Asset to Component record.
W1-AACCfgDeviceUpgradeRead
Used to query an existing Configuration - Device - Asset to Component record.
W1-AACCfgDeviceUpgradeUpdate
Used to update an existing Configuration - Device -Asset to Component record.
W1-AACfgDeviceUpgradeAdd
Used to create a Configuration - Device - Asset to Asset record.
This component invokes the Inbound Web Service ATW1AACfgDeviceUpgrade using W1-AACfgDeviceUpgrade Business Object.
W1-AACfgDeviceUpgradeDelete
Used to delete an existing Configuration - Device - Asset to Asset record.
W1-AACfgDeviceUpgradeRead
Used to query an existing Configuration - Device - Asset to Asset record.
W1-AACfgDeviceUpgradeUpdate
Used to update an existing Configuration - Device - Asset to Asset record.
W1-ACACCfgDeviceUpgradeAdd
Used to create a Configuration - Device - Component to Component record.
This component invokes the Inbound Web Service ATW1ACACfgDeviceUpgrade using W1-ACACfgDeviceUpgrade Business Object.
W1-ACACCfgDeviceUpgradeDelete
Used to delete an existing Configuration - Device - Component to Component record.
W1-ACACCfgDeviceUpgradeRead
Used to query an existing Configuration - Device -Component to Component record.
W1-ACACCfgDeviceUpgradeUpdate
Used to update an existing Configuration - Device - Component to Component record.
W1-ACACfgDeviceUpgradeAdd
Used to create a Configuration - Device - Component to Asset record.
W1-ACACfgDeviceUpgradeDelete
Used to delete an existing Configuration - Device - Component to Asset record.
W1-ACACfgDeviceUpgradeRead
Used to query an existing Configuration - Device - Component to Asset record.
W1-ACACfgDeviceUpgradeUpdate
Used to update an existing Configuration - Device - Component to Asset record.
W1-ACCfgDeviceUpgradeAdd
Used to create a Configuration - Device - Component record.
This component invokes the Inbound Web Service ATW1ACCfgDeviceUpgrade using W1-ACCfgDeviceUpgrade Business Object.
W1-ACCfgDeviceUpgradeDelete
Used to delete an existing Device - Component record.
W1-ACCfgDeviceUpgradeRead
Used to query an existing Device - Component record.
W1-ACCfgDeviceUpgradeUpdate
Used to update an existing Device - Component record.
W1-ACfgDeviceUpgradeAdd
Used to create a Configuration - Device Asset record.
This component invokes the Inbound Web Service ATW1ACfgDeviceUpgrade using W1-ACfgDeviceUpgrade Business Object.
W1-ACfgDeviceUpgradeDelete
Used to delete a Configuration - Device Asset record.
W1-ACfgDeviceUpgradeRead
Used to query an existing Configuration - Device Asset record.
W1-ACfgDeviceUpgradeUpdate
Used to update an existing Configuration - Device Asset record.
W1-ActivityComplInboundCommAdd
Used to create an Inbound Communication record.
This component invokes the Inbound Web Service ATW1ActivityComplInboundComm using W1-ActivityComplInboundComm Business Object.
W1-ActivityComplInboundCommDelete
W1-ActivityComplInboundCommRead
Used to query an existing Inbound Communication Record.
W1-ActivityComplInboundCommUpdate
Used to update an existing Inbound Communication Record.
W1-ActivityNotesAdd
Used to create an Activity Notes record.
This component invokes the Inbound Web Service ATW1ActivityNotes W1-ActivityNotes using Business Object.
W1-ActivityNotesDelete
Used to delete an existing Activity Notes record.
This component invokes the Inbound Web Service ATW1ActivityNotes using W1-ActivityNotes Business Object.
W1-ActivityNotesRead
Used to query an existing Activity Notes record.
W1-ActivityNotesUpdate
W1-AdHocActCoreNoLocationAdd
Used to create an Adhoc Activity Core No Location record.
This component invokes the Inbound Web Service ATW1AdHocActCoreNoLocation using W1- AdHocActCoreNoLocation Business Object.
W1-AdHocActCoreNoLocationDelete
Used to delete an existing Adhoc Activity Core No Location record.
This component invokes the Inbound Web Service ATW1AdHocActCoreNoLocation using W1-AdHocActCoreNoLocation Business Object.
W1-AdHocActCoreNoLocationRead
Used to query an existing Adhoc Activity Core No Location record.
W1-AdHocActCoreNoLocationUpdate
W1-AdHocActivityCoreAdd
Used to create an Adhoc Activity Core record.
This component invokes the Inbound Web Service ATW1AdHocActivityCore using W1-AdHocActivityCore Business Object.
W1-AdHocActivityCoreDelete
Used to delete an existing Adhoc Activity Core record.
W1-AdHocActivityCoreRead
Used to query existing Adhoc Activity Core record.
W1-AdHocActivityCoreUpdate
W1-AssetCompCfgWOAdd
Used to create a Configuration - Asset Component record.
This component invokes the Inbound Web Service ATW1AssetCompCfgWO using W1-AssetCompCfgWO Business Object.
W1-AssetCompCfgWODelete
Used to delete an existing Configuration - Asset Component record.
W1-AssetCompCfgWORead
W1-AssetCompCfgWOUpdate
Used to update an existing Configuration - Asset Component record.
W1-AssetCompToAssetCfgWOAdd
Used to create a Configuration - Component to Asset record.
This component invokes the Inbound Web Service ATW1AssetCompToAssetCfgWO using W1-AssetCompToAssetCfgWO Business Object.
W1-AssetCompToAssetCfgWODelete
Used to delete a Configuration - Component to Asset record.
W1-AssetCompToAssetCfgWORead
Used to update an existing Configuration - Component to Asset record.
W1-AssetCompToAssetCfgWOUpdate
This component invokes the Inbound Web Service used to update an existing Configuration - Component using W1-AssetCompToAssetCfgWO Business Object.
W1-ssetCompToAssetCompCfg
WOAdd
Used to create an Configuration - Component to Component record.
This component invokes the Inbound Web Service ATW1AssetCompToAssetCompCfgWO using W1- AssetCompToAssetCompCfgWO Business Object.
W1-AssetCompToAssetCompCfg WODelete
Used to delete an existing Configuration - Component to Component record.
This component invokes the Inbound Web Service ATW1AssetCompToAssetCompCfgWO using W1-AssetCompToAssetCompCfgWO Business Object.
W1-AssetCompToAssetCompCfg WORead
Used to query an existing Configuration - Component to Component record.
W1-AssetCompToAssetCompCfg WOUpdate
Used to update an existing Configuration - Component to Component record.
W1-AssetCriteriaActGeneratorAdd
Used to create an Activity Generator - Asset Criteria record.
This component invokes the Inbound Web Service ATW1AssetCriteriaActGenerator using W1-AssetCriteriaActGenerator Business Object.
W1-AssetCriteriaActGeneratorDelete
Used to delete an existing Activity Generator - Asset Criteria.
W1-AssetCriteriaActGeneratorRead
Used to query an existing Activity Generator - Asset Criteria record.
W1-AssetCriteriaActGeneratorUpdate
W1-AssetListActGeneratorAdd
Used to create an Activity Generator - Asset List record.
This component invokes the Inbound Web Service ATW1AssetListActGenerator using W1-AssetListActGenerator Business Object.
W1-AssetListActGeneratorDelete
Used to delete an existing Activity Generator - Asset List record.
W1-AssetListActGeneratorRead
Used to query an existing Activity Generator - Asset List record.
W1-AssetListActGeneratorUpdate
Used to update an existing Activity Generator - Asset List record.
W1-AssetReplicationActivityAdd
Used to create an Asset Replication Activity record.
This component invokes the Inbound Web Service ATW1AssetReplicationActivity using W1-AssetReplicationActivity Business Object.
W1-AssetReplicationActivityDelete
Used to delete an existing Asset Replication Activity record.
W1-AssetReplicationActivityRead
Used to query an existing Asset Replication Activity record.
W1-AssetReplicationActivityUpdate
Used to update an existing Asset Replication Activity record.
W1-AssetReplicationComplEventAdd
Used to create a Completion Event record.
This component invokes the Inbound Web Service ATW1AssetReplicationComplEvent using W1-AssetReplicationComplEvent Business Object.
W1-AssetReplicationComplEventDelete
Used to delete a Completion Event record.
W1-AssetReplicationComplEventRead
Used to query an existing Completion Event record.
W1-AssetReplicationComplEventUpdate
Used to update an existing Completion Event record.
W1-AssetToAssetCompCfgWOAdd
Used to create a Configuration - Asset to Component record
ATW1AssetToAssetCompCfgWO using W1-AssetToAssetCompCfgWO Business Object.
W1-AssetToAssetCompCfgWODelete
Used to delete an existing Configuration - Asset to Component record.
This component invokes the Inbound Web Service ATD1CutServiceForNonPayment using D1-CutServiceForNonPayment Business Object.
W1-AssetToAssetCompCfgWORead
Used to query an existing Configuration - Asset to Component record
This component invokes the Inbound Web Service ATW1AssetToAssetCompCfgWO using W1-AssetToAssetCompCfgWO Business Object.
W1-AssetToAssetCompCfgWOUpdate
Used to update an existing Configuration - Asset to Component record.
W1-BasicWorkOrderAdd
Used to create a Basic Work Order record.
This component invokes the Inbound Web Service ATW1BasicWorkOrder using W1-BasicWorkOrder Business Object.
W1-BasicWorkOrderDelete
Used to delete an existing a Basic Work Order record.
W1-BasicWorkOrderRead
Used to query an existing a Basic Work Order record.
W1-BasicWorkOrderUpdate
Used to update an existing a Basic Work Order record.
W1-CompnAssetListActGeneratorAdd
Used to create an Activity Generator - Component List record.
This component invokes the Inbound Web Service ATW1CompnAssetListActGenerator using W1-CompnAssetListActGenerator Business Object.
W1-CompnAssetListActGeneratorDelete
Used to update an existing an Activity Generator - Component List record.
W1-CompnAssetListActGeneratorRead
Used to query an existing an Activity Generator -Component List record.
W1-CompnAssetListActGeneratorUpdate
Used to update an existing an Activity Generator -Component List record.
W1-CompnCriteriaActGeneratorAdd
Used to create an Activity Generator - Component Criteria record.
This component invokes the Inbound Web Service ATW1CompnCriteriaActGenerator using W1-CompnCriteriaActGenerator Business Object.
W1-CompnCriteriaActGeneratorDelete
Used to delete an existing Activity Generator -Component Criteria record.
W1-CompnCriteriaActGeneratorRead
Used to query an existing Activity Generator -Component Criteria record.
W1-CompnCriteriaActGeneratorUpdate
Used to update an existing Activity Generator -Component Criteria record.
W1-CrAnyServiceHistoryCmplEvtAdd
Used to creating a Completion Event record.
This component invokes the Inbound Web Service ATW1CrAnyServiceHistoryCmplEvt using W1-CrAnyServiceHistoryCmplEvt Business Object.
W1-CrAnyServiceHistoryCmplEvtDelete
W1-rAnyServiceHistoryCmplEvtRead
W1-CrAnyServiceHistoryCmplEvtUpdate
W1-CreActivityPayCmpEvtAdd
Used to create a Create Specific Activity Completion Event record.
This component invokes the Inbound Web Service ATW1CreActivityPayCmpEvt using W1-CreActivityPayCmpEvt Business Object.
W1-CreActivityPayCmpEvtDelete
Used to delete an existing Create Specific Activity. Event record.
This component invokes the Inbound Web Service ATW1CreActivityPayCmpEvt using W1-CreActivityPayCPayment Business Object.
W1-CreActivityPayCmpEvtRead
Used to query an existing Create Specific Activity. Event record.
W1-CreActivityPayCmpEvtUpdate
Used to query an existing Create Specific Activity Event record.
W1-CreAssetPayCmpEvtAdd
Used to Create Specific Asset Completion Event.
This component invokes the Inbound Web Service ATW1CreAssetPayCmpEvt using W1-CreAssetPayCmpEvt Business Object.
W1-CreAssetPayCmpEvtDelete
Used to delete an existing Specific Asset Completion Event record.
W1-CreAssetPayCmpEvtRead
Used to query an existing Specific Asset Completion Event record.
This component invokes the Inbound Web Service ATW1CreAssetPayCmpEvt using W1-CreAssetPayCmp Business Object.
W1-CreAssetPayCmpEvtUpdate
W1-CreateMobileWOInboundCommAdd
Used to create a Mobile Work Order Inbound Communication record.
This component invokes the Inbound Web Service ATW1CreateMobileWOInboundComm using W1-CreateMobileWOInboundComm Business Object.
Delete
Used to delete an existing Mobile Work Order Inbound Communication record.
W1-CreateMobileWOInboundCommRead
Used to query existing Mobile Work Order Inbound Communication record.
This component invokes the Inbound Web Service ATW1CreateMobileWOInboundComm using W1-CreateMobileWOInbound Business Object.
CommUpdate
W1-CreNodeAttachCmpEvtAdd
Used to create a Location Attachment Completion Event record.
This component invokes the Inbound Web Service ATW1CreNodeAttachCmpEvt using W1-CreNodeAttachCmpEvt Business Object.
W1-CreNodeAttachCmpEvtDelete
Used to delete an existing Location Attachment Completion Event record.
W1-CreNodeAttachCmpEvtRead
Used to query an existing Location Attachment Completion Event record.
W1-CreNodeAttachCmpEvtUpdate
Used to update an existing Location Attachment Completion Event record.
W1-CreServiceHistoryAttCmpEvAdd
Used to create a Service History Attachment Completion Event record.
This component invokes the Inbound Web Service ATW1CreServiceHistoryAttCmpEvt using W1-CreServiceHistoryAttCmpEvt Business Object.
W1-CreServiceHistoryAttCmpEvtDelete
Used to delete an existing Service History Attachment Completion Event record.
W1-CreServiceHistoryAttCmpEvtRead
Used to query an existing Service History Attachment Completion Event record.
This component invokes the Inbound Web ServiceATW1CreServiceHistoryAttCmpEvt using W1-CreServiceHistoryAttCmpEvt Business Object.
W1-CreServiceHistoryAttCmpEvtUpdate
Used to update an existing Service History Attachment Completion Event record.
W1-CreServiceHistoryPayCmpEvtAdd
Used to create a Specific Service History Completion Event record.
This component invokes the Inbound Web Service ATW1CreServiceHistoryPayCmpEvt using W1-CreServiceHistoryPayCmpEvt Business Object.
W1-CreServiceHistoryPayCmpEvtDelete
Used to delete an existing Specific Service History Completion Event record.
W1-CreServiceHistoryPayCmpEvtRead
Used to query an existing Specific Service History Completion Event record.
W1-CreServiceHistoryPayCmpEvtUpdate
Used to update an existing Specific Service History Completion Event record.
W1-CreSvcHistCmpEvtAdd
Used to Create Any Service History Completion Event (Online Only) record.
This component invokes the Inbound Web Service ATW1CreSvcHistCmpEvt using W1-CreSvcHistCmpEvt Business Object.
W1-CreSvcHistCmpEvtDelete
Used to delete existing Create Any Service History Completion Event (Online Only) record.
W1-CreSvcHistCmpEvtRead
Used to query an existing Create Any Service History Completion Event (Online Only) record.
W1-CreSvcHistCmpEvtUpdate
Used to update an existing Create Any Service History Completion Event (Online Only) record.
W1-FollowUpSkippedAssetsCmpEvtAdd
Used to create a Follow-Up Skipped Assets Completion Event record.
This component invokes the Inbound Web Service ATW1FollowUpSkippedAssetsCmpEvt using W1-FollowUpSkippedAssetsCmpEvt Business Object.
EvtDelete
Used to delete an existing a Follow-Up Skipped As Completion Event record.
EvtRead
Used to query an existing a Follow-Up Skipped As Completion Event record.
This component invokes the Inbound Web Service ATW1FollowUpSkippedAssetsCmpEvt W1-FollowUpSkippedAssetsCmpEvt Business Object.
Update
Used to update an existing a Follow-Up Skipped As Completion Event record.
This component invokes the Inbound Web Service ATW1FollowUpSkippedAssetsCmpEvt using W1-FollowUpSkippedAssetsCmpEvBusiness Object.
W1-LocalActivityCoreAdd
Used to create a Local Activity Core record.
This component invokes the Inbound Web Service ATW1LocalActivityCore using ATW1LocalActivityCore Business Object.
W1-LocalActivityCoreDelete
Used to delete an existing Local Activity Core record.
This component invokes the Inbound Web Service ATW1LocalActivityCore using W1-LocalActivityCore Business Object.
W1-LocalActivityCoreRead
Used to query an existing Local Activity Core record.
W1-LocalActivityCoreUpdate
Used to update an existing Local Activity Core record.
W1-MobileUpdWorkedAssetCmpEvtAdd
Used to create a Mobile Update Worked Assets Completion Event record.
This component invokes the Inbound Web Service ATW1MobileUpdWorkedAssetCmpEvt using W1-MobileUpdWorkedAssetCmpEvt Business Object.
Delete
Used to delete an existing Mobile Update Worked Assets Completion Event record.
W1-MobileUpdWorkedAssetCmpEvtRead
Used to query an existing Mobile Update Worked Assets Completion Event record.
W1-MobileUpdWorkedAssetCmpUpdate
Used to update an existing Mobile Update Worked Assets Completion Event record.
W1-NodeCriteriaActGeneratorAdd
Used to create an Activity Generator - Node Criteria record.
This component invokes the Inbound Web Service ATW1NodeCriteriaActGenerator using W1-NodeCriteriaActGenerator Business Object.
W1-NodeCriteriaActGeneratorDelete
Used to delete an existing Activity Generator - Node Criteria record.
W1-NodeCriteriaActGeneratorRead
Used to query an existing Activity Generator - Node Criteria record.
W1-NodeCriteriaActGeneratorUpdate
W1-OutboundActivityCoreAdd
Used to create an Outbound Activity Core record.
This component invokes the Inbound Web Service ATW1OutboundActivityCore using W1-OutboundActivityCore Business Object.
W1-OutboundActivityCoreDelete
Used to delete an existing Outbound Activity Core record.
W1-OutboundActivityCoreRead
Used to query an existing Outbound Activity Core record.
This component invokes the Inbound Web Service ATW1OutboundActivityCore W1-OutboundActivityCore Business Object.
W1-OutboundActivityCoreUpdate
Used to update an existing Outbound Activity Core record.
W1-ReplaceAssetLocalAdd
Used to create a Replace Asset Local record.
This component invokes the Inbound Web Service ATW1ReplaceAssetLocal using W1-ReplaceAssetLocal Business Object.
W1-ReplaceAssetLocalDelete
Used to delete an existing Replace Asset Local record.
W1-ReplaceAssetLocalRead
Used to query an existing Replace Asset Local record.
W1-ReplaceAssetLocalUpdate
Used to update an existing Replace Asset Local record.
W1-ReplaceAssetOutboundAdd
Used to create a Replace Asset Outbound record.
This component invokes the Inbound Web Service ATW1ReplaceAssetOutbound using W1-ReplaceAssetOutbound Business Object.
W1-ReplaceAssetOutboundDelete
Used to delete an existing a Replace Asset Outbound record.
W1-ReplaceAssetOutboundRead
Used to query an existing a Replace Asset Outbound record.
W1-ReplaceAssetOutboundUpdate
Used to update an existing a Replace Asset Outbound record.
W1-SingleAssetCfgWOAdd
Used to create a Configuration - Single Asset record.
This component invokes the Inbound Web Service ATW1SingleAssetCfgWO using W1-SingleAssetCfgWO Business Object.
W1-SingleAssetCfgWODelete
Used to delete an existing Configuration - Single Asset record.
W1-SingleAssetCfgWORead
Used to query an existing Configuration - Single Asset record.
W1-SingleAssetCfgWOUpdate
Used to update an existing Configuration - Single Asset record.
W1-SOMActivityAdd
Used to create a SOM Activity record.
This component invokes the Inbound Web Service ATW1SOMActivity using W1-SOMActivity Business Object.
W1-TrnAssetCmpEventAdd
Used to create a Transition Asset Completion Event record.
This component invokes the Inbound Web Service ATW1TrnAssetCmpEvent using W1-TrnAssetCmpEvent Business Object.
W1-TrnAssetCmpEventDelete
Used to delete an existing Transition Asset Completion Event n Event record.
W1-TrnAssetCmpEventRead
Used to query an existing Transition Asset Completion record.
W1-TrnAssetCmpEventUpdate
Used to update an existing Transition Asset Completion record.
W1-UpdAssetPayCmpEvtAdd
Used to create a Update Asset Using DA Completion Event record.
This component invokes the Inbound Web Service ATW1UpdAssetPayCmpEvt using W1-UpdAssetPayCmpEvt Business Object.
W1-UpdAssetPayCmpEvtDelete
Used to delete an existing Update Asset Using DA Completion Event record.
W1-UpdAssetPayCmpEvtRead
Used to query an existing Update Asset Using DA Completion Event record.
W1-UpdAssetPayCmpEvtUpdate
Used to update an existing Update Asset Using DA Completion Event record.
W1-UpdNodePayCmpEvtAdd
Used to create an Update Location Using DA Completion Event record.
This component invokes the Inbound Web Service ATW1UpdNodePayCmpEvt using W1-UpdNodePayCmpEvt Business Object.
W1-UpdNodePayCmpEvtDelete
Used to delete an existing Update Location Using DA Completion Event record.
W1-UpdNodePayCmpEvtRead
Used to query an existing Update Location Using DA Completion Event record.
W1-UpdNodePayCmpEvtUpdate
W1-WorkOrderNotesAdd
Used to create a Work Order Notes record.
This component invokes the Inbound Web Service ATW1WorkOrderNotes using W1-WorkOrderNotes Business Object.
W1-WorkOrderNotesDelete
Used to delete an existing Work Order Notes record.
W1-WorkOrderNotesRead
Used to query an existing Work Order Notes record.
W1-WorkOrderNotesUpdate
Used to update an existing Work Order Notes record.
W2-AACCfgFirmwareUpgradeAdd
Used to create a Configuration - Firmware - Asset to Component record.
This component invokes the Inbound Web Service ATW2AACCfgFirmwareUpgrade using W2-AACCfgFirmwareUpgrade Business Object.
W2-AACCfgFirmwareUpgradeDelete
Used to delete an existing Configuration - Firmware - Asset to Component record.
W2-AACCfgFirmwareUpgradeRead
Used to query an existing Configuration - Firmware - Asset to Component record.
W2-AACCfgFirmwareUpgradeUpdate
Used to update an existing Configuration - Firmware - Asset to Component record.
This component invokes the Inbound Web Service ATW2AACCfgFirmwareUpgrade using W2-AACCfgFirmwareUpgrad Business Object.
W2-AACfgFirmwareUpgradeAdd
Used to create a Configuration - Firmware - Asset to Asset record.
This component invokes the Inbound Web Service ATW2AACfgFirmwareUpgrade using W2-AACfgFirmwareUpgrade Business Object.
W2-AACfgFirmwareUpgradeDelete
Used to delete an existing Configuration - Firmware - Asset record.
W2-AACfgFirmwareUpgradeRead
Used to query an existing Configuration - Firmware - Asset to Asset record.
W2-AACfgFirmwareUpgradeUpdate
Used to update an existing Configuration - Firmware - Asset to Asset record.
W2-ACACCfgFirmwareUpgradeAdd
Used to create a Configuration - Firmware -Component to Component record.
This component invokes the Inbound Web Service ATW2ACACCfgFirmwareUpgrade using W2-ACACCfgFirmwareUpgrade Business Object.
W2-ACACCfgFirmwareUpgradeDelete
Used to delete an existing Configuration - Firmware - Component to Component record.
W2-ACACCfgFirmwareUpgradeRead
Used to query an existing Configuration - Firmware - Component to Component record.
W2-ACACCfgFirmwareUpgradeUpdate
Used to update an existing Configuration - Firmware Component to Component record.
W2-ACACfgFirmwareUpgradeAdd
Used to create a Configuration - Firmware - Component to Asset record.
This component invokes the Inbound Web Service ATW2ACACfgFirmwareUpgrade using W2-ACACfgFirmwareUpgrade Business Object.
W2-ACACfgFirmwareUpgradeDelete
Used to delete an existing Configuration - Firmware - Component to Asset record.
W2-ACACfgFirmwareUpgradeRead
Used to query an existing Configuration - Firmware Component to Asset record.
W2-ACACfgFirmwareUpgradeUpdate
Used to update an existing Configuration - Firmware Component to Asset record.
W2-ACCfgFirmwareUpgradeAdd
Used to create Configuration - Firmware -Component record.
This component invokes the Inbound Web Service ATW2ACCfgFirmwareUpgrade using W2-ACCfgFirmwareUpgrade Business Object.
W2-ACCfgFirmwareUpgradeDelete
Used to delete an existing Configuration - Firmware - Component record.
W2-ACCfgFirmwareUpgradeRead
Used to query an existing Configuration - Firmware - Component record.
W2-ACCfgFirmwareUpgradeUpdate
Used to update an existing Configuration - Firmware - Component record.
W2-ACfgFirmwareUpgradeAdd
Used to create a Configuration - Firmware - Asset record.
This component invokes the Inbound Web Service ATW2ACfgFirmwareUpgrade using W2-ACfgFirmwareUpgrade Business Object.
W2-ACfgFirmwareUpgradeDelete
W2-ACfgFirmwareUpgradeRead
Used to query an existing Configuration - Firmware - Asset record.
W2-ACfgFirmwareUpgradeUpdate
Used to update an existing Configuration - Firmware - Asset record.
W2-FirmwareCommandLocalAdd
Used to create a Firmware Command Local record.
This component invokes the Inbound Web Service ATW2FirmwareCommandLocal using W2-FirmwareCommandLocal Business Object.
W2-FirmwareCommandLocalDelete
Used to delete an existing Firmware Command Local record.
W2-FirmwareCommandLocalRead
Used to query an existing Firmware Command Local record.
W2-FirmwareCommandLocalUpdate
Used to update an existing Firmware Command Local record.
W2-FirmwareCommandOutboundAdd
Used to create a Firmware Command Outbound record.
This component invokes the Inbound Web Service ATW2FirmwareCommandOutbound using W2-FirmwareCommandOutbound Business Object.
Used to delete a Firmware Command Outbound record.
W2-FirmwareCommandOutboundRead
Used to query an existing Firmware Command Outbound record.
W2-FirmwareCommandOutboundUpdate
Used to update an existing Firmware Command Outbound record.
Bill Determinants
Component
Description
D2-UsgTranSeeder
Used to perform actions such as ADD, READ, UPDATE, and DELETE a Usage Transaction Seeder.
This component invokes the D2-UsgTranSeeder Business Object using the ATD2UsgTranSeeder Inbound Web Service.
D2-UsageTransaction
Used to perform actions such as ADD, READ, UPDATE, and DELETE a Usage Transaction.
This component invokes the D2-UsageTransaction Business Object using the ATD2UsageTransaction Inbound Web Service.
D2-UsageSubscription
Used to create a Usage Subscription.
This component invokes the D2-UsageSubscription Business Object using the ATD2UsageSubscription Inbound Web Service.
D2-TOUMap
Used to create a TOU Map.
This component invokes the D2-TOUMap Business Object using the ATD2TOUMap Inbound Web Service.
D2-DynamicOption
Used to create a Dynamic Option.
This component invokes the D2-DynamicOption Business Object using the ATD2DynamicOption Inbound Web Service.
D2-DynamicOptionEvent
Used to create a Dynamic Option Event.
This component invokes the D2-DynamicOptionEvent Business Object using the ATD2DynamicOptionEvent Inbound Web Service.
D1-UsageGroup
Used to create a Usage Group
This component invokes the D1-UsageGroup Business Object using the ATD1UsageGroup Inbound Web Service.
D2-GetScalar
Used to create a GetScalar Usage Rule.
This component invokes the D2-GetScalar Business Object using the ATD2GetScalar Inbound Web Service.
D1-CalcRollingDemandRule
Used to create a CalcRollingDemandRule.
This component invokes the D1- CalcRollingDemandRule using the ATD1CalcRollingDemandRule IWS Inbound Web Service.
D1-CoincidentPeakSPDemandRule
Used to create a CoincidentPeakSPDemandRule.
This component invokes the D1- CoincidentPeakSPDemandRule Business Object using the ATD1CoincidentPeakSPDemandRule.
D1-CoincidentPeakOperandLookup
Used to create a CoincidentPeakOperandLookup.
This component invokes the D1- CoincidentPeakOperandLookup Business Object using the ATD1CoincidentPeakOperandLookup Inbound Web Service.
D2-GetTOUUsage
Used to create a GetTOUUsage Usage Rule.
This component invokes the D2-GetTOUUsage Business Object using the ATD2GetTOUUsage Inbound Web Service.
D2-DynamicOptionType
Describes the creation of Dynamic Option Type.
This component invokes the D2-DynamicOptionType Business Object using the ATD2DynamicOptionType Inbound Web Service.
D2-GetIntervalData
Allows the configuration of interval data retrieval during usage transaction processing. The rule records service quantities per service point and measuring component - which means that interval curves for different measuring components.
This component invokes the D2-GetIntervalData Business Object using the ATD2GetIntervalData Inbound Web Service.
D2-Math
This component invokes the D2-Math Business Object using the ATD2Math Inbound Web Service.
D2-UsageSubscriptionType
Allows to create a usage subscription type for creating a usage subscription.
This component invokes the D2-UsageSubscriptionType Business Object using the ATD2UsageSubscriptionType Inbound Web Service.
D2-TOUMapType
Describes Time Of Use Map Type.
This component invokes the D2-TOUMapType Business Object using the ATD2TOUMapType Inbound Web Service.
D2-HowToCreateUSInformation
Describes how to create the Usage Subscription related information.
This component invokes the D2-HowToCreateUSInformation Business Object using the ATD2HowToCreateUSInformation Inbound Web Service.
D2-ApplyMathInt
Describes the structure and rules applicable to Apply Math (Interval Data) usage rule.
This component invokes the D2-ApplyMathInt Business Object using the ATD2ApplyMathInt Inbound Web Service.
D1-FactorNumber
Describes the Factor Number.
This component invokes the D1-FactorNumber Business Object using the ATD1FactorNumber Inbound Web Service.
D1-FactorProfile
Used to create a FactorProfile Factor Value.
This component invokes the D1-FactorProfile Business Object using the ATD1FactorProfile Inbound Web Service.
D1-FactorVEEGroup
Used to create a FactorVEEGroup Factor.
This component invokes the D1- FactorVEEGroup Business Object using the ATD1FactorVEEGroup Inbound Web Service.
D2-GetItemCountsConsumption
Used to create a GetItemCountsConsumption Usage Rule.
This component invokes the D2-GetItemCountsConsumption Business Object using the ATD2GetItemCountsConsumption Inbound Web Service.
D2-TOUMapTemplate
Used to create a TOU Map Template.
This component invokes the D2-TOUMapTemplate Business Object using the ATD2TOUMapTemplate Inbound Web Service.
D2-ValAgainstTol
Used to create a Validate Against Tolerance usage rule.
This component invokes the D2-ValAgainstTol Business Object using the ATD2ValAgainstTol Inbound Web Service.
D1-FactorValueNumber
Used to create a Factor Value Number.
This component invokes the D1-FactorValueNumber Business Object using the ATD1FactorValueNumber Inbound Web Service.
D1-FactorValueVEEGroup
Describes the Factor Value VEE Group.
This component invokes the D1-FactorValueVEEGroup Business Object using the ATD1FactorValueVEEGroup Inbound Web Service.
D1-FactorValueProfile
Used to create a FactorValueProfile Factor.
This component invokes the D1-FactorValueProfile Business Object using the ATD1FactorValueProfile Inbound Web Service.
Communication
Component
Description
D1-
CutServiceForNonPaymentTypeAdd
Used to create a Cut Service for Non-Payment Type
record.
ATD1CutServiceForNonPaymentType Inbound
CutServiceForNonPaymentType Business Object.
D1-CutServiceForNonPaymentType
Delete
Used to delete an existing Cut Service for Non-
Payment Type record.
D1-
CutServiceForNonPaymentTypeRead
Used to query an existing Cut Service for Non-Payment Type record.
Update
Used to update an existing Cut Service for Non-
D1-DisableServiceTypeAdd
Used to create a Disable Service Type record.
ATD1DisableServiceType IWS using D1-
DisableServiceType Business Object.
D1-DisableServiceTypeDelete
Used to delete an existing Disable Service Type record.
D1-DisableServiceTypeRead
Used to query an existing Disable Service Type record.
D1-DisableServiceTypeUpdate
Used to update an existing Disable Service Type record.
D1-EnableServiceTypeAdd
Used to create an Enable Service Type record.
ATD1EnableServiceType IWS using D1-
EnableServiceType Business Object.
D1-EnableServiceTypeDelete
Used to delete an existing Enable Service Type record.
D1-EnableServiceTypeRead
Used to query an existing Enable Service Type record.
D1-EnableServiceTypeUpdate
Used to update an existing Enable Service Type record.
D1-FieldActivityTypeAdd
Used to create a Field Activity Type record.
This component invokes the ATD1FieldActivityType Inbound Web Service using D1-FieldActivityType Business Object.
D1-FieldActivityTypeDelete
Used to delete an existing Field Activity Type record.
D1-FieldActivityTypeRead
Used to query an existing Field Activity Type record.
D1-FieldActivityTypeUpdate
Used to update an existing Field Activity Type record.
C1-PremiseTypeAdd
Used to create a Premise Type record.
This component invokes the ATC1PremiseType Inbound Web Service using the C1-PremiseTypePhysicalBO business object.
C1-PremiseTypeDelete
Used to delete an existing Premise Type record.
C1-PremiseTypeRead
Used to query an existing Premise Type record.
C1-PremiseTypeUpdate
Used to update an existing Premise Type record.
W1-AssetLocationTypeAdd
Used to create an Asset Location Type record.
ATW1AssetLocationType Inbound Web Service
using the W1-AssetLocationType business object.
W1-AssetLocationTypeDelete
Used to delete an existing Asset Location Type record.
W1-AssetLocationTypeRead
Used to query an existing Asset Location Type record.
W1-AssetLocationTypeUpdate
Used to update an existing Asset Location Type record.
using W1-AssetLocationType business object.
W1-AssetTypeAdd
Used to create an Asset Type record.
This component invokes the ATW1AssetType
Inbound Web Service using the W1-AssetType
business object.
W1-AssetTypeDelete
Used to delete an existing Asset Type record.
business object.
W1-AssetTypeRead
Used to query an existing Asset Type record.
business object.
W1-AssetTypeUpdate
Used to update an existing Asset Type record.
This component invokes the ATW1AssetType Inbound Web Service using W1-AssetType business object.
W1-ContactTypeRead
Used to query an existing Contact Type record.
This component invokes the ATW1ContactType Inbound Web Service using the W1-ContactType business object.
W1-ComponentTypeAdd
Used to create an Operational Device Component Type record.
This component invokes the ATW1ComponentType Inbound Web Service using the W1-ComponentType business object.
W1-ComponentTypeDelete
Used to delete an existing Operational Device Component Type record.
W1-ComponentTypeRead
Used to query an existing Operational Device Component Type record.
W1-ComponentTypeUpdate
Used to update an existing Operational Device Component Type record.
W1-OrganizationAdd
Used to create an Organization record.
This component invokes the ATW1Organization
Inbound Web Service using the W1-Organization
business object.
W1-OrganizationDelete
Used to delete an existing Organization record.
business object.
W1-OrganizationRead
Used to query an existing Organization record.
business object.
W1-OrganizationUpdate
Used to update an existing Organization record.
Inbound Web Service using W1-Organization
business object.
W1-OrganizationTypeAdd
Used to create an Organization Type record.
ATW1OrganizationType Inbound Web Service
using the W1-OrganizationType business object.
W1-OrganizationTypeDelete
Used to delete an existing Organization Type record.
W1-OrganizationTypeRead
Used to query an existing Organization Type record.
W1-OrganizationTypeUpdate
Used to update an existing Organization Type record.
using W1-OrganizationType business object.
W1-ServiceHistoryAdd
Used to create an Operational Device Service History record.
This component invokes the ATW1ServiceHistory
Inbound Web Service using the W1-ServiceHistory
business object.
W1-ServiceHistoryDelete
Used to delete an existing Operational Device Service History record.
business object.
W1-ServiceHistoryRead
Used to query an existing Operational Device Service History record.
business object.
W1-ServiceHistoryUpdate
Used to update an existing Operational Device Service History record.
Inbound Web Service using W1-ServiceHistory
business object.
W1-StorageLocationAdd
Used to create an Out of Service Location record.
This component invokes the ATW1StorageLocation Inbound Web Service using the W1-StorageLocation business object.
W1-StorageLocationDelete
Used to delete an existing Out of Service Location record.
W1-StorageLocationRead
Used to query an existing Out of Service Location record.
W1-StorageLocationUpdate
Used to update an existing Out of Service Location record.
This component invokes the ATW1StorageLocation Inbound Web Service using W1-StorageLocation business object.
W1-StorageLocationTypeAdd
Used to create an Out of Service Location Type record.
This component invokes the ATW1StorageLocationType Inbound Web Service using the W1-StorageLocationType business object.
W1-StorageLocationTypeDelete
Used to delete an existing Out of Service Location Type record.
W1-StorageLocationTypeRead
Used to query an existing Out of Service Location Type record.
W1-StorageLocationTypeUpdate
Used to update an existing Out of Service Location Type record.
using W1-StorageLocationType business object.
W2-ServicePointRead
Used to query an existing Service Point record.
This component invokes the ATW2ServicePoint
Inbound Web Service using the W2-ServicePoint
business object.
W2-VehicleAdd
Used to create a Vehicle record.
This component invokes the ATW2Vehicle Inbound Web Service using the W2-Vehicle business object.
W1-VehicleDelete
Used to delete an existing Vehicle record.
W1-VehicleRead
Used to query an existing Vehicle record.
W1-VehicleUpdate
Used to update an existing Vehicle record.
Web Service using W2-Vehicle business object.
X1-AssetLocationTypeAdd
Used to create a Service Point Type - ODM record.
ATX1AssetLocationType Inbound Web Service
using the X1-AssetLocationType business object.
X1-AssetLocationTypeDelete
Used to delete an existing Service Point Type -
ODM record.
X1-AssetLocationTypeRead
Used to query an existing Service Point Type - ODM record.
X1-AssetLocationTypeUpdate
Used to update an existing Service Point Type - ODM record.
using X1-AssetLocationType business object.
X1-ServicePointTypeAdd
Used to create a Service Point Type - CCB record.
ATX1ServicePointType Inbound Web Service using
X1-ServicePointType Business Object.
X1-ServicePointTypeDelete
Used to delete an existing Service Point Type - CCB record.
X1-ServicePointType BO.
X1-ServicePointTypeRead
Used to query an existing Service Point Type - CCB record.
X1-ServicePointTypeUpdate
Used to update an existing Service Point Type - CCB record.
X1-ServiceTypeAdd
Used to create a Service Type - CCB record.
This component invokes the ATX1ServiceType Inbound Web Service using X1-ServiceType BO.
X1-ServiceTypeDelete
Used to delete an existing Service Type - CCB record.
X1-ServiceTypeRead
Used to query an existing Service Type - CCB record.
X1-ServiceTypeUpdate
Used to update an existing Service Type - CCB record.
X1D-ServicePointTypeAdd
Used to create a Service Point Type - MDM record.
ATXD1ServicePointType Inbound Web Service
using X1D-ServicePointType BO.
X1D-ServicePointTypeDelete
Used to delete an existing Service Point Type - MDM record.
This component invokes the ATXD1ServicePointType Inbound Web Service using X1D-ServicePointType BO.
X1D-ServicePointTypeRead
Used to query an existing Service Point Type - MDM record.
X1D-ServicePointTypeUpdate
Used to update an existing Service Point Type - MDM record.
D1-DeviceEventComRespTypeAdd
Used to create a Device Event Communication Response Type record.
This component invokes the ATD1DeviceEventComRespType Inbound Web
Service using D1-DeviceEventComRespType BO.
D1-DeviceEventComRespTypeDel
Used to delete an existing Device Event Communication Response Type record.
This component invokes the ATD1DeviceEventComRespType Inbound Web Service using D1-DeviceEventComRespType BO.
D1-DeviceEventComRespTypeRead
Used to query an existing Device Event Communication Response Type record.
D1-DeviceEventComRespTypeUpd
Used to update an existing Device Event Communication Response Type record.
W1-AssetCompCfgRptAdd
Used to create a Component Config Report record.
This component invokes the Business Object W1-
AssetCompCfgRpt using the Inbound Web Service
of ATW1AssetCompCfgRpt.
W1-AssetCompCfgRptDelete
Used to delete an existing Component Config Report record.
W1-AssetCompCfgRptRead
Used to query an existing Component Config Report record.
W1-AssetCompCfgRptUpdate
Used to update an existing Component Config Report record.
W1-AssetCompConfigAdd
Used to create an Asset Component Config Report record.
ATW1AssetCompConfig Inbound Web Service
using W1-AssetCompConfig BO.
W1-AssetCompConfigDelete
Used to delete an Asset Component Config Report record.
W1-AssetCompConfigRead
Used to query an Asset Component Config Report record.
W1-AssetCompConfigUpdate
W1-
AssetCompToAssetCompCfgRptAdd
Used to create an Asset Component to Asset Component Config Report record.
This component invokes the W1-ATW1AssetCompToAssetCompCfgRpt Inbound
AssetCompToAssetCompCfgRpt BO.
W1-AssetCompToAssetCompCfgRpt
Delete
Used to update an existing Asset Component to Asset Component Config Report record.
W1-
AssetCompToAssetCompCfgRptRead
Used to update an query Asset Component to Asset Component Config Report record.
Update
Used to delete an query Asset Component to Asset Component Config Report record.
W1-AssetCompToAssetConfigAdd
Used to create an Asset Component to Asset Config record.
ATW1AssetCompToAssetConfig Inbound Web
Service using W1-AssetCompToAssetConfig BO.
W1-AssetCompToAssetConfigDelete
Used to delete an existing Asset Component to Asset Config record.
W1-AssetCompToAssetConfigRead
Used to update an existing Asset Component to Asset Config record.
W1-AssetCompToAssetConfigUpdate
Used to update an existing Asset Component to Asset Component Config record.
W1-AssetToAssetCompCfgRptAdd
Used to create an Asset to Asset Component Config Report record.
ATW1AssetToAssetCompCfgRpt Inbound Web
Service using W1-AssetToAssetCompCfgRpt BO.
W1-AssetToAssetCompCfgRptDelete
Used to delete an existing Asset to Asset Component Config Report record.
W1-AssetToAssetCompCfgRptRead
Used to query an existing Asset to Asset Component Config Report record.
W1-
AssetToAssetCompCfgRptUpdate
Used to update an existing Asset to Asset Component Config Report record.
W1-AssetToAssetConfigAdd
Used to create an Asset to Asset record.
ATD8StatusChangedType Inbound Web Service
using D8-ReadOnDemandReadResultType BO.
W1-AssetToAssetConfigDelete
Used to delete an existing Asset to Asset record.
ATD8ReadOnDemandReadResultType Inbound
Web Service using D8-StatusChangedType BO.
W1-AssetToAssetConfigUdpate
Used to update an existing Asset to Asset record.
W1-ConfigTypeAdd
Used to create a Config Type record.
This component invokes the ATW1ConfigType
Inbound Web Service using W1-ConfigType BO.
W1-ConfigTypeDelete
Used to delete an existing Config Type record.
W1-ConfigTypeRead
Used to query an existing Config Type record.
W1-ConfigTypeUpdate
Used to update an existing Config Type record.
W1-SingleAssetCfgRptAdd
Used to create a Single Asset Config Report record.
ATW1SingleAssetCfgRp Inbound Web Service
using W1-SingleAssetCfgRp BO.
W1-SingleAssetCfgRptDelete
Used to delete an existing Single Asset Config Report record.
W1-SingleAssetCfgRptRead
Used to query an existing Single Asset Config Report
record.
W1-SingleAssetCfgRptUdpate
Used to update an existing Single Asset Config Report record.
W1-SingleAssetConfigAdd
Used to create a Single Asset Config record.
ATW1SingleAssetConfig Inbound Web Service
using W1-SingleAssetConfig BO.
W1-SingleAssetConfigDelete
record.
W1-
ActivityCompletionEventTypeAdd
Used to create an Activity Completion Event Type record.
ATW1ActivityCompletionEventType Inbound Web
Service using W1-ActivityCompletionEventType
Business Object.
W1-
ActivityCompletionEventTypeDelete
Used to delete an existing Activity Completion Event Type record.
Business Object.
W1-
ActivityCompletionEventTypeRead
Used to query an existing Activity Completion Event Type record.
Business Object.
W1-
ActivityCompletionEventTypeUpdate
Used to update an existing Activity Completion
Event Type record.
Business Object.
W1-AssetDposCmpEvtTypeAdd
Used to create an Asset Disposition Completion Event Type record.
ATW1AssetDposCmpEvtType Inbound Web
Service using W1-AssetDposCmpEvtType Business
Object.
W1-AssetDposCmpEvtTypeDelete
Used to delete an existing Asset Disposition Completion Event Type record.
Object.
W1-AssetDposCmpEvtTypeRead
Used to query an existing Asset Disposition Completion Event Type record.
Object.
W1-AssetDposCmpEvtTypeUpdate
Used to update an existing Asset Disposition Completion Event Type record.
Object.
W1-BasicActivityTypeAdd
Used to create a Basic Activity Type record.
ATW1BasicActivityType Inbound Web Service
using W1-BasicActivityType Business Object.
W1-BasicActivityTypeDel
Used to delete an existing Basic Activity Type record.
ATW1BasicActivityTypeInbound Web Service using
W1-BasicActivityTypeRead
Used to query an existing Basic Activity Type record.
W1-BasicActivityTypeUpdate
Used to update an existing Basic Activity Type record.
W1-DataAreaCmpEvtTypeAdd
Used to create Data Area Completion Event Type record.
ATW1DataAreaCmpEvtType Inbound Web Service
using W1-DataAreaCmpEvtType Business Object.
W1-DataAreaCmpEvtTypeDelete
Used to delete an existing Data Area Completion Event Type record.
W1-DataAreaCmpEvtTypeRead
Used to query an existing Data Area Completion
Event Type record.
W1-DataAreaCmpEvtTypeUpdate
Used to update an existing Data Area Completion
Event Type record.
W1-GeneralCommunicationAdd
Used to create a General Inbound Communication Type record.
ATW1GeneralCommunicationType Inbound Web
Service using W1-
GeneralCommunicationTypeBusiness Object.
W1-GeneralCommunicationDelete
Used to delete an existing General Inbound Communication Type record.
This component invokes the ATW1GeneralCommunicationType Inbound Web Service using W1-GeneralCommunicationType Business Object.
W1-GeneralCommunicationRead
Used to query an existing General Inbound Communication Type record.
Business Object.
W1-GeneralCommunicationUpdate
Used to update an existing General Inbound Communication Type record.
Business Object.
W1-
GeneralCompletionEventTypeAdd
Used to create General Completion Event Type record.
ATW1GeneralCompletionEventType Inbound Web
Service using W1-GeneralCompletionEventType
Business Object.
W1-
GeneralCompletionEventTypeDelete
Used to delete an existing General Completion Event Type record.
This component invokes the ATW1GeneralCompletionEventType Inbound Web Service using W1-GeneralCompletionEventType Business Object.
W1-
GeneralCompletionEventTypeRead
Used to query an existing General Completion Event Type record.
Business Object.
W1-
GeneralCompletionEventTypeUpdate
Used to update an existing General Completion
Event Type record.
Business Object.
W1-ManufacturerAdd
Used to create a Manufacturer record.
This component invokes the ATW1Manufacturer
Inbound Web Service using W1-Manufacturer
Business Object.
W1-ManufacturerDelete
Used to delete an existing Manufacturer record.
Business Object.
W1-ManufacturerRead
Used to query an existing Manufacturer record.
Business Object.
W1-ManufacturerUpdate
Used to update an existing Manufacturer record.
Business Object.
W1-OutboundActivityTypeAdd
Used to create an Outbound Activity Type record.
This component invokes the ATW1OutboundActivityType Inbound Web Service
using W1-OutboundActivityType Business Object.
W1-OutboundActivityTypeDelete
Used to delete an existing Outbound Activity Type
record.
W1-OutboundActivityTypeRead
Used to query an existing Outbound Activity Type record.
W1-OutboundActivityTypeUpdate
Used to update an existing Outbound Activity Type
record.
W1-ReplicationComplEventTypeAdd
Used to create a Replication Completion Event Type
record.
ATW1ReplicationComplEventType Inbound Web
Service using W1-ReplicationComplEventType
Business Object.
W1-
ReplicationComplEventTypeDelete
Used to delete an existing Replication Completion Event Type record.
Business Object.
W1-ReplicationComplEventTypeRead
Used to query an existing Replication Completion
Event Type record.
Business Object.
W1-
ReplicationComplEventTypeUpdate
Used to update an existing Replication Completion
Event Type record.
Business Object.
W1-ScheduledActivityTypeAdd
Used to create a Scheduled Activity Type record.
ATW1ScheduledActivityType Inbound Web Service
using W1-ScheduledActivityType Business Object.
W1-ScheduledActivityTypeDelete
Used to delete an existing Scheduled Activity Type
record.
W1-ScheduledActivityTypeRead
Used to query an existing Scheduled Activity Type
record.
W1-ScheduledActivityTypeUpdate
Used to update an existing Scheduled Activity Type record.
W1-
ServiceHistTypeCmpEvtTypeAdd
Used to create a Service History Completion Event
Type record.
This component invokes the ATW1ServiceHistTypeCmpEvtTypeInbound Web
Service using W1-ServiceHistTypeCmpEvtType
Business Object.
W1-
ServiceHistTypeCmpEvtTypeDelete
Used to delete an existing Service History Completion Event Type record.
Service W1-ServiceHistTypeCmpEvtType Business
Object.
W1-
ServiceHistTypeCmpEvtTypeRead
Used to query an existing Service History Completion Event Type record.
Object.
W1-
ServiceHistTypeCmpEvtTypeUpdate
Used to update an existing Service History Completion Event Type record.
ATW1ServiceHistTypeCmpEvtType Inbound Web
Business Object.
W1-SvcHistFromActvCmplEvtType
Add
Used to create a Service History From Activity Completion Event Type record.
ATW1SvcHistFromActvCmplEvtType Inbound
Web Service W1-SvcHistFromActvCmplEvtType
Business Object.
TypeDelete
Used to delete an existing Service History From Activity Completion Event Type record.
Business Object.
Read
Used to query an existing Service History From Activity Completion Event Type record.
Business Object.
TypeUpdate
Used to update an existing Service History From Activity Completion Event Type record.
Business Object.
W1-SOMActivityTypeRead
Used to query a SOM Activity Type record.
ATW1SOMActivityType Inbound Web Service
using W1-SOMActivityType Business Object.
D2-SubIntAdjustmentVEE
Performs adjustments to consumption; the changes to consumption will be validated against the readings
contained prior to and subsequent to the change made.
SubIntAdjustmentVEE Business Object using the
ATD2SubIntAdjustmentVEE Inbound Web
Service.
D2-GetSubtractiveInterval
Allows the configuration of subtractive interval data retrieval during usage transaction processing. The rule records service quantities per service point and measuring component - which means that subtractive interval curves for different measuring components.
This component invokes the D2-GetSubtractiveInterval Business Object using theATD2GetSubtractiveInterval Inbound Web Service.
D1-MeterReadDownloadActType
Used to create a MeterReadDownloadActType Activity Type.
MeterReadDownloadActType Business Object using
the ATD1MeterReadDownloadActType Inbound
Web Service.
D1-PairedEventLastDvcEvtType
Used to create a PairedEventLastDvcEvtType Device Event Type.
PairedEventLastDvcEvtType Business Object using
the ATD1PairedEventLastDvcEvtType Inbound
Web Service.
D1-StandardDeviceEventType
Used to create a StandardDeviceEventType Device Event Type.
StandardDeviceEventType Business Object using
the ATD1StandardDeviceEventType Inbound Web
Service.
D1-UTCorrectnPrcessrActvtyType
Defines the activity BO to use in the creation of a Usage Transaction Correction Processor. This component also defines the general category of these activities as a Correction Processor.
The component invokes the D1-UTCorrectnPrcessrActvtyType Business Object
using the ATD1UTCorrectnPrcessrActvtyType
D1-RemoteConnectType
Describes configuration parameters required for the Remote Connect command activity, including automated retry and command time-out options.
This component allows the definition of a Service Issue Monitor Type resulting in the creation of a Service Issue Monitor of the configured type if a Remote Connect command activity has failed.
RemoteConnectType Business Object using the
ATD1RemoteConnectType Inbound Web Service.
D1-PairedEventFirstDvcEvtType
Describes the Device Event Type - Paired Event (First).
PairedEventFirstDvcEvtType Business Object using
the ATD1PairedEventFirstDvcEvtType Inbound
Web Service.
D1-DeviceWithDurationActType
Describes the Device Activity with Duration Type.
DeviceWithDurationActType Business Object using
the ATD1DeviceWithDurationActType Inbound
Web Service.
D2-SubMeasurementAggType
Describes the Sub Measurement Aggregator Type.
SubMeasurementAggType Business Object using the
ATD2SubMeasurementAggType Inbound Web
Service.
D2-MasterMsrmtAggregatorType
Describes the Master Measurement Aggregator Type.
MasterMsrmtAggregatorType Business Object using
the ATD2MasterMsrmtAggregatorType Inbound
Web Service.
D2-ActivityTypeAggDimScanner
Describes the Aggregator Dimension Scanner Activity Type.
ActivityTypeAggDimScanner Business Object using
the ATD2ActivityTypeAggDimScanner Inbound
Web Service.
D2-AggregatorType
Used to create an AggregatorType Measuring Component Type.
This component invokes the D2-AggregatorType
Business Object using the ATD2AggregatorType
D1-IntervalPriceType
Used to create a IntervalPriceType.
This component invokes the D1-IntervalPriceType Business Object using the ATD1IntervalPriceType Inbound Web Service.
D1-IntervalChannelTypePhysical
Used to create a IntervalChannelTypePhysical.
IntervalChannelTypePhysical Business Object using
the ATD1IntervalChannelTypePhysical Inbound
Web Service.
D1-MeasurementCycleSchedule
Used to create a MeasurementCycleSchedule.
This component invokes the D1-MeasurementCycleSchedule Business Object using
the ATD1MeasurementCycleSchedule Inbound Web
Service.
D1-ReaderRemarkType
Used to create a ReaderRemarkType.
This component invokes the D1-ReaderRemarkType
Business Object using the ATD1ReaderRemarkType
D1-ServiceIssueMonitorType
Used to create a ServiceIssueMonitorType.
ServiceIssueMonitorType Business Object using the
ATD1ServiceIssueMonitorType Inbound Web
Service.
D2-MsrmtQuantityAggScannerType
Used to create a MsrmtQuantityAggScannerType.
MsrmtQuantityAggScannerType Business Object
using the ATD2MsrmtQuantityAggScannerType
D2-TOUGroup
Used to create a TOUGroup.
This component invokes the D2-TOUGroup Business Object using the ATD2TOUGroup Inbound Web Service.
D2-VEERuleHighLowCheck
Used to create a VEERuleHighLowCheck.
VEERuleHighLowCheck Business Object using the
ATD2VEERuleHighLowCheck Inbound Web
Service.
D1-HowToCreateMCInformation
Used to create a HowToCreateMCInformation.
HowToCreateMCInformation Business Object
using the ATD1HowToCreateMCInformation
D1-HowToSendActivityResponse
Used to create a HowToSendActivityResponse.
HowToSendActivityResponse Business Object using
the ATD1HowToSendActivityResponse Inbound
Web Service.
D1-AvgDailyEstItemConsumption
Used to create a AvgDailyEstItemConsumption.
AvgDailyEstItemConsumption Business Object
using the ATD1AvgDailyEstItemConsumption
D1-VEEEligibilityCriteria
Used to create a VEEEligibilityCriteria.
VEEEligibilityCriteria Business Object using the
ATD1VEEEligibilityCriteria Inbound Web Service.
D2-VerifyUomTouSqiMCExistForUs
Used to create a VerifyUomTouSqiMCExistForUs.
This component invokes the D2- VerifyUomTouSqiMCExistForUs Business Object
using the ATD2VerifyUomTouSqiMCExistForUs
D1-DeviceEventSeeder
Used to create a DeviceEventSeeder.
This component invokes the D1-DeviceEventSeeder
Business Object using the ATD1DeviceEventSeeder
D1-FieldActivity
Used to create a FieldActivity.
This component invokes the D1-FieldActivity
Business Object using the ATD1FieldActivity
D1-ReaderRemark
Used to create a ReaderRemark.
D1-TimeZoneTranslationLookup
Used to create a TimeZoneTranslationLookup.
ATD1TimeZoneTranslationLookup Business
Object using the ATD1ReaderRemark Inbound Web
Service.
D2-UsageCalculationGroupLookup
Used to create a UsageCalculationGroupLookup.
UsageCalculationGroupLookup Business Object
using the ATD2UsageCalculationGroupLookup
D2-MDMMasterConfig
Used to perform actions such as ADD, READ, UPDATE, and DELETE a MDMMasterConfig.
MDMMasterConfig Business Object using the
ATD2MDMMasterConfig Inbound Web Service.
D2-MDMMasterConfig
D2-MtrCommTrckngAggregatorType
Used to perform actions such as ADD, READ, UPDATE, and DELETE a MtrCommTrckngAggregatorType.
MtrCommTrckngAggregatorType Business Object
using the ATD2MtrCommTrckngAggregatorType
D1-EstimationSuppressionType
Used to perform actions such as ADD, READ, UPDATE, and DELETE a EstimationSuppressionType.
EstimationSuppressionType Business Object using
the ATD1EstimationSuppressionType Inbound
Web Service.
D2-InactiveMeasurementCheck
Used to perform actions such as ADD, READ, UPDATE, and DELETE a InactiveMeasurementCheck VEE Rule.
InactiveMeasurementCheck Business Object using
the ATD2InactiveMeasurementCheck Inbound Web
Service.
D1-ChannelStatisticsType
Used to perform actions such as ADD, READ, UPDATE, and DELETE a ChannelStatisticsType.
ChannelStatisticsType Business Object using the
ATD1ChannelStatisticsType Inbound Web Service.
Used to perform actions such as ADD, READ, UPDATE, and DELETE a ChannelStatistics.
This component invokes the D1- ChannelStatistics
Business Object using the ATD1ChannelStatistics
D1-FacilityLite
Used to perform actions such as ADD, READ, UPDATE, and DELETE a FacilityLite.
This component invokes the D1- FacilityLite
Business Object using the ATD1FacilityLite
D1-SpecificationLookup
Used to perform actions such as ADD, READ, UPDATE, and DELETE a SpecificationLookup.
SpecificationLookup Business Object using the
ATD1SpecificationLookup Inbound Web Service.
D1-MeasuringCompTypLite
Used to perform actions such as ADD, READ, UPDATE, and DELETE a MeasuringCompTypLite.
MeasuringCompTypLite Business Object using the
ATD1MeasuringCompTypLite Inbound Web
Service.
D1-GetDvcFrmIdenTypFlag
Used to retrieve Device ID By Identifier and Type Flag using the ATD1 GetDvcFrmIdenTypFlag Inbound Web Service.
D1-GetSimdIdFromImd
Used to retrieve Simd ID By IMD ID using the ATD1GetSimdIdFromImd Inbound Web Service.
D1-GetMCFrmDvcExtId
Used to retrieve Measuring Component ID from Device External ID using the ATD1GetMCFrmDvcExtId Inbound Web Service.
D1-GetProductKeyFromSync
Used to Get Product Key from Sync Request ID using the ATD1 GetProductKeyFromSync Inbound Web Service.
D1-GetUsageFromExtID
Used to retrieve Usage ID from CCB Usage ID using the ATD1 GetUsageFromExtID Inbound Web Service.
D2-GetUSFromExtID
Used to retrieve US ID from External ID using the ATD1 GetUSFromExtID Inbound Web Service.
D1-GetDCFrmDvcExtId
Used to retrieve DC ID from External ID using the ATD1GetDCFrmDvcExtId Inbound Web Service.
D1-GetInstEvtFromDvcExId
Used to retrieve Install Event ID from Device External ID using ATD1GetInstEvtFromDvcExId Inbound Web Service.
D1-GetInstEvtFrmSPExtId
Used to retrieve Install Event ID from Service Point External ID using the ATD1GetInstEvtFrmSPExtId Inbound Web Service.
D1-GetMCFromExtID
Used to retrieve Measuring Component ID from External ID using the ATD1GetMCFromExtID Inbound Web Service.
D1-GetContactFromExtID
Used to retrieve Contact ID from External ID using the ATD1GetContactFromExtID Inbound Web Service.
D1-GetSpFromExtID
Used to retrieve Service Point ID from External ID using the ATD1GetSpFromExtID Inbound Web Service.
D1-GetSyncReqIdFrmExtId
Used to retrieve Sync Request ID from External ID using the ATD1GetSyncReqIdFrmExtId Inbound
Web Service.
Credit and Collection
Component
Description
C1-CollectionProcessAdd
Used to add a Collection Process record.
This component invokes the Inbound Web Service ATC1CollectionProcess using the C1CollectionProcAdd Business Service.
C1-CollectionProcessRead
Used to read a Collection Process record.
This component invokes the Inbound Web Service ATC1CollectionProcess using the C1CollectionProcRead Business Service.
C1-CollectionProcessUpdate
Used to update a Collection Process record.
This component invokes the Inbound Web Service ATC1CollectionProcess using the C1CollectionProcUpdate Business Service.
C1-CutProcessRead
Used to read a Cut Process record.
This component invokes the ATC1CutProcess Inbound Web Service using the C1CutProcRead Business Service.
C1-CutProcessUpdate
Used to update a Cut Process record.
This component invokes the Inbound Web Service ATC1CutProcess using the C1CutProcUpdate Business Service.
C1-OverdueProcessRead
Used to read an Overdue Process record.
This component invokes the Inbound Web Service ATC1OverdueProcess using the C1OverdueProcessRead Business Service.
C1-OverdueProcessUpdate
Used to update an Overdue Process record.
This component invokes the Inbound Web Service ATC1OverdueProcess using the C1OverdueProcessUpdate Business Service.
C1-PayPlanAdd
Used to create a Pay Plan record.
This component invokes the Inbound Web Service ATC1PayPlan using the C1PayPlanAdd Business Service.
C1-PayPlanRead
Used to read a Pay Plan record.
This component invokes the Inbound Web Service ATC1PayPlan using the C1PayPlanRead Business Service.
C1-PayPlanUpdate
Used to update a Pay Plan record.
This component invokes the Inbound Web Service ATC1PayPlan using the C1PayPlanUpdate Business Service.
C1-SeveranceProcessRead
Used to read a Severance Process record.
This component invokes the Inbound Web Service ATC1SeveranceProcess using the C1SeveranceProcessRead Business Service.
C1-SeveranceProcessUpdate
Used to update a Severance Process record.
This component invokes the Inbound Web Service ATC1SeveranceProcess using the C1SeveranceProcessUpdate Business Service.
C1-WriteOffRead
Used to read a Write Off record.
This component invokes the Inbound Web Service ATC1WriteOff using the C1WriteOffRead Business Service.
C1-WriteOffUpdate
Used to update a Write Off record.
C1WriteOffUpdate Business Service.
C1-WriteOffProcessAdd
Used to create a Write Off Process record.
This component invokes the Inbound Web Service ATC1WriteOffProcess using the C1WriteOffProcessAdd Business Service.
C1-WriteOffProcessRead
Used to read a Write Off Process record.
This component invokes the Inbound Web Service ATC1WriteOffProcess using the C1WriteOffProcessRead Business Service.
C1-WriteOffProcessUpdate
Used to update a Write Off Process record.
This component invokes the Inbound Web Service ATC1WriteOffProcess using the C1WriteOffProcessUpdate Business Service.
C1-CollAgencyReferralAdd
Used to create a Collection Agency Referral record.
This component invokes the Inbound Web Service ATC1CollectionAgencyReferral using the C1CollAgencyRefAdd Business Service.
C1-CollAgencyReferralDelete
Used to update a Collection Agency Referral record.
This component invokes the Inbound Web Service ATC1CollectionAgencyReferral using the C1CollAgencyRefDelete Business Service.
C1-CollAgencyReferralRead
Used to read a Collection Agency Referral record.
This component invokes the Inbound Web Service ATC1CollectionAgencyReferral using the C1CollAgencyRefRead Business Service.
C1-CollAgencyReferralUpdate
This component invokes the Inbound Web Service ATC1CollectionAgencyReferral using the C1CollAgencyRefUpdate Business Service.
C1-PayArrangementByBillAdd
Used add a Payment Arrangement by Bill record.
This component invokes the Inbound Web Service ATC1PaymentArrangementByBill using the C1PayArrangeByBillAdd Business Service.
C1-PayArrangementByBillRead
Used to read a Payment Arrangement by Bill record.
This component invokes the Inbound Web Service ATC1PayArrangeByBill using the C1PayArrangeByBillRead Business Service.
C1-PayArrangementByBillUpdate
Used to update a Payment Arrangement by Bill record.
This component invokes the Inbound Web Service ATC1PayArrangeByBill using the C1PayArrangeByBillUpdate Business Service.
C1-PaymentArrangementAdd
Used to add a Payment Arrangement record.
This component invokes the Inbound Web Service ATC1PayArrangement using the C1PayArrangementAdd Business Service.
C1-PaymentArrangementRead
Used to read a Payment Arrangement record.
This component invokes the Inbound Web Service ATC1PayArrangement using the C1PayArrangementRead Business Service.
C1-PaymentArrangementUpdate
Used to update a Payment Arrangement record.
This component invokes the Inbound Web Service ATC1PayArrangement using the C1PayArrangementUpdate Business Service.
Customer Information
Component
Description
C1-AccountAdd
Used to create an Account record.
This component invokes the ATC1Account Inbound Web Service using the C1AccountPhysical Business Object.
C1-AccountUpdate
Used to update an existing Account record.
C1-AccountDelete
Used to delete an existing Account record.
C1-AccountRead
Used to read an existing Account record.
C1-CaseBOAdd
Used to create a Case record.
This component invokes the ATC1CaseBO Inbound Web Service using the C1-Case Business Object.
C1-CaseBOUpdate
Used to update an existing Case record.
C1-CaseBORead
Used to read an existing Case record.
C1-AccountBSRead
This component invokes the ATC1AccountBS Inbound Web Service using the C1-AccountRead Business Service.
C1-AccountBSUpdate
This component invokes the ATC1AccountBS Inbound Web Service using the C1-AccountUpdate Business Service.
C1-ContractOptionAdd
Used to create a Contract Option record.
This component invokes the ATC1ContractOption Inbound Web Service using the C1ContractOptionPhysical Business Object.
C1-ContractOptionDelete
Used to delete an existing Contract Option record.
C1-ContractOptionUpdate
Used to update (Update, Freeze and Cancel) an existing Contract Option record.
C1-ContractOptionRead
Used to read an existing Contract Option record.
C1-StartServiceRequestAdd
Used to add a Start Service Request.
This component invokes the ATC1StartServiceRequest Inbound Web Service using the C1-StartServiceRequest Business Object.
C1-StartServiceRequestDelete
Used to delete a Start Service Request.
C1-StartServiceRequestRead
Used to read a Start Service Request.
C1-StartServiceRequestUpdate
Used to update a Start Service Request.
C1-StopServiceRequestAdd
Used to add a Stop Service Request.
This component invokes the ATC1StopServiceRequest Inbound Web Service using the C1-StopServiceRequest Business Object.
C1-StopServiceRequestDelete
Used to delete a Stop Service Request.
C1-StopServiceRequestRead
Used to read a Stop Service Request.
C1-StopServiceRequestUpdate
Used to update a Stop Service Request.
C1-TransferServiceRequestAdd
Used to add a Transfer Service Request.
This component invokes the ATC1TransferServiceRequest Inbound Web Service using the C1-TransferServiceRequest Business Object.
C1-TransferServiceRequestDelete
Used to delete a Transfer Service Request.
C1-TransferServiceRequestRead
Used to read a Transfer Service Request.
C1-TransferServiceRequestUpdate
Used to update a Transfer Service Request.
C1-CreateSARelationshipSubSA
Used to create SA Relationship Sub SA record.
This component invokes the ATC1CreateSARelationshipSubSA Inbound Web Service using the C1CreateSARelationshipSubSA Service Script.
C1-RecommendBudget
Used to Recommend Budget.
This component invokes the ATC1Recommend Budget Inbound Web Service using the C1-RecommendBudget Business Service.
C1-ContractOptEventAdd
Used to create a Contract Option Event record.
This component invokes the ATC1ContractOptEvent Inbound Web Service using the C1-ContractOptEventAdd Business Service.
C1-ContractOptEventDelete
Used to delete an existing Contract Option Event record.
This component invokes the ATC1ContractOptEvent Inbound Web Service using the C1-ContractOptEventDelete Business Service.
C1-ContractOptEventRead
Used to query an existing Contract Option Event record.
This component invokes the ATC1ContractOptEvent Inbound Web Service using the C1-ContractOptEventRead Business Service.
C1-ContractOptEventUpdate
Used to update an existing Contract Option Event record.
This component invokes the ATC1ContractOptEvent Inbound Web Service using the C1-ContractOptEventUpdate Business Service.
C1-PersonAdd
Used to create a Person record.
This component invokes the ATC1Person Inbound Web Service using the C1PersonPhysical Business Object.
C1-PersonUpdate
Used to update an existing Person record.
C1-PersonDelete
Used to delete an existing Person record.
C1-PersonRead
Used to read an existing Person record.
C1-PersonBSAdd
This component invokes the ATC1PersonBS Inbound Web Service using the C1-PersonAdd Business Service.
C1-PersonBSRead
Used to read a Person record.
This component invokes the ATC1PersonBS Inbound Web Service using the C1-PersonRead Business Service.
C1-PersonBSUpdate
Used to update a Person record.
This component invokes the ATC1PersonBS Inbound Web Service using the C1-PersonUpdate Business Service.
C1-PremiseAdd
Used to create a Premise record.
This component invokes the ATC1Premise Inbound Web Service using the C1PremisePhysical Business Object.
C1-PremiseUpdate
Used to update an existing Premise record.
C1-PremiseDelete
Used to delete an existing Premise record.
C1-PremiseRead
Used to read an existing Premise record.
C1-SARelationshipAdd
Used to create an SA Relationship record.
This component invokes the ATC1SARelationship Inbound Web Service using the C1SARelationshipAdd Business Service.
C1-SARelationshipUpdate
Used to update (update, activate, cancel, create sub SA) an existing SA Relationship record.
This component invokes the ATC1SARelationship Inbound Web Service using the C1SARelationshipUpdate Business Service.
C1-SARelationshipRead
Used to read an existing SA Relationship record.
This component invokes the ATC1SARelationship Inbound Web Service using the C1SARelationshipRead Business Service.
C1-ServiceAgreementAdd
Used to create a Service Agreement record.
This component invokes the ATC1ServiceAgreement Inbound Web Service using the C1ServiceAgreementPhysical Business Object.
C1-ServiceAgreementRead
Used to read an existing Service Agreement record.
C1-ServiceAgreementUpdate
Used to update (activate, apply new start option, cancel, close, cancel proposal SA, accept proposal SA, decline proposal SA, activate proposal SA, reactivate, stop) an existing Service Agreement record.
This component invokes the ATC1ServiceAgreementUpdate Inbound Web Service using the C1ServiceAgreementUpdate Business Service.
C1-StartStopUpdate
Used to invoke the Start Stop functionality including the cancel, stop and start actions.
This component invokes the ATC1StartStop Inbound Web Service using the C1StartStopUpdate Business Service.
C1-StartStopRead
Used to read a Start Stop record.
This component invokes the ATC1StartStop Inbound Web Service using the C1StartStopRead Business Service.
C1-StartStopBSUpdate
This component invokes the ATC1StartStopBS Inbound Web Service using the C1-StartStopMaintenanceRead Business Service.
C1-StartStopBSRead
This component invokes the ATC1StartStopBS Inbound Web Service using the C1-StartStopMaintenanceUpdate Business Service.
C1-StartServiceActionMethodAdd
Used for adding a Start Service Action Method record.
This component invokes the ATC1StartServiceActionMethod Inbound Web Service using the C1-StartStopActionMethod Business Object.
C1-StartServiceActionMethodDelete
Used for deleting a Start Service Action Method record.
C1-StartServiceActionMethodRead
Used for reading a Start Service Action Method record.
C1-StartServiceActionMethodUpdate
Used for updating a Start Service Action Method record.
C1-StopServiceActionMethodAdd
Used for adding a Stop Service Action Method record.
This component invokes the ATC1StopServiceActionMethod Inbound Web Service using the C1-StartStopActionMethod Business Object.
C1-StopServiceActionMethodDelete
Used for deleting a Stop Service Action Method record.
C1-StopServiceActionMethodRead
Used for reading a Stop Service Action Method record.
C1-StopServiceActionMethodUpdate
Used for updating a Stop Service Action Method record.
C1-SATypeStartOptionAdd
Used for adding a SA Type Start Option record.
This component invokes the ATC1SATypeStartOption Inbound Web Service using the C1-SATypeStartOptionPhysicalBO Business Object.
C1-SATypeStartOptionDelete
Used for deleting a SA Type Start Option record.
C1-SATypeStartOptionRead
Used for reading a SA Type Start Option record.
C1-SATypeStartOptionUpdate
Used for updating a SA Type Start Option record.
C1-TransferServiceActionMethodAdd
Used for adding a Transfer Service Action Method record.
This component invokes the ATC1TransferServiceActionMethod Inbound Web Service using the C1-StartStopActionMethod Business Object.
C1-TransferServiceActionMethodDelete
Used for deleting a Transfer Service Action Method record.
C1-TransferServiceActionMethodRead
Used for reading a Transfer Service Action Method record.
C1-TransferServiceActionMethodUpdate
Used for updating a Transfer Service Action Method record.
W1-BusinessRead
Used to query an existing ODM Business Contact record.
This component invokes the ATW1Person Inbound Web Service using the W1-Business Business Object.
W1-PersonRead
Used to query an existing ODM Person Contact record.
This component invokes the ATW1Person Inbound Web Service using the W1-Person Business Object.
X1-ServicePointAdd
Used to create a Service Point record.
This component invokes the ATX1ServicePoint Inbound Web Service using the X1D-ServicePoint Business Object.
X1-ServicePointDelete
Used to delete an existing Service Point record.
X1-ServicePointRead
X1-ServicePointUpdate
Used to update an existing Service Point record.
X1D-ServicePoint
Used to add/edit/read/delete existing Service Point.
This component invokes the ATX1DServicePoint Inbound Web Service using the X1D-ServicePoint Business Object.
Digital Asset Cloud Service
Component
Description
X1-ControllableAssetSpec
Used to create controllable asset specification.
This component invokes the X1- ControllableAssetSpec business object using the ATX1ControllableAssetSpec Inbound Web Service.
Used to create controllable asset.
This component invokes the X1-ControllableAsset business object using the ATX1ControllableAsset Inbound Web Service.
X1-CtrlDvcStatusCheckRespType
Used to create CtrlDvcStatusCheckRespType.
This component invokes the X1- CtrlDvcStatusCheckRespType business object using the ATX1CtrlDvcStatusCheckRespType IWS.
X1-CtrlDvcStatusCheckComm
Used to create CtrlDvcStatusCheckComm.
This component invokes the X1- CtrlDvcStatusCheckComm business object using the ATX1CtrlDvcStatusCheckCommIWS.
Used to create CtrlDvcStatusCheck.
This component invokes the X1- CtrlDvcStatusCheck business object using the ATX1CtrlDvcStatusCheck IWS.
X1-CtrlDvcHeadEndSystem
Used to create CtrlDvcHeadEndSystem.
This component invokes the X1- CtrlDvcHeadEndSystem business object using the ATX1CtrlDvcHeadEndSystemIWS.
X1-HowToSendSvcTaskResponse
Used to create HowToSendSvcTaskResponse.
This invokes the X1-HowToSendSvcTaskResponse business object using the ATX1HowToSendSvcTaskResponseIWS.
X1-CtrlDvcStatusCheckCommType
Used to create CtrlDvcStatusCheckCommType.
This invokes X1-CtrlDvcStatusCheckCommType business object using the ATX1CtrlDvcStatusCheckCommType IWS.
X1-DigitalAssetEnrollTaskType
Used to create DigitalAssetEnrollTaskType.
This component invokes the X1- DigitalAssetEnrollTaskType business object using the ATX1DigitalAssetEnrollTaskType IWS.
Used to create DigitalAssetEnrollTask.
This component invokes the X1- DigitalAssetEnrollTask business object using the ATX1DigitalAssetEnrollTask IWS.
X1-EventSettlementCalcGroup
Used to create EventSettlementCalcGroup.
This component invokes the X1-EventSettlementCalcGroup business object using the ATX1EventSettlementCalcGroup IWS.
X1-EventSettlementCalcRule
Used to create EventSettlementCalcRule.
This component invokes the X1-EventSettlementCalcRule business object using the ATX1EventSettlementCalcRule IWS.
X1-KWhAvdBusinessFlag
Used to create KWhAvdBusinessFlag.
This component invokes the X1-KWhAvdBusinessFlag business object using the ATX1KWhAvdBusinessFlag IWS.
X1-EventParticipation
Used to create EventParticipation.
This component invokes the X1-EventParticipation business object using the ATX1EventParticipation IWS.
X1-EventSettlementTransaction
Used to create EventSettlementTransaction.
This component invokes the X1-EventSettlementTransaction business object using the ATX1EventSettlementTransaction IWS.
X1-CtrlDvcStatusCheckType
This component invokes the X1- CtrlDvcStatusCheckType business object using the ATX1CtrlDvcStatusCheckType IWS.
X1-UpdateCDL
Used to create UpdateCDL.
This component invokes the X1-UpdateCDL business object using the ATX1UpdateCDL IWS.
X1-DeviceLocation
Used to create DeviceLocation.
This component invokes the X1-DeviceLocation business object using the ATX1DeviceLocation IWS.
Used to create CtrlDvcStatusCheckResp.
This component invokes the X1- CtrlDvcStatusCheckResp business object using the ATX1CtrlDvcStatusCheckResp IWS.
X1-ControllableDevice
Used to create ControllableDevice.
This component invokes the X1-ControllableDevice business object using the ATX1ControllableDevice IWS.
X1-ControllableDeviceType
Used to create ControllableDeviceType.
This component invokes the X1- ControllableDeviceType business object using the ATX1ControllableDeviceType IWS.
X1-ControllableAssetType
Used to create ControllableAssetType.
This component invokes the X1- ControllableAssetType business object using the ATX1ControllableAssetType IWS.
X1-DeviceLocationType
Used to create DeviceLocationType.
This component invokes the X1- DeviceLocationType business object using the ATX1DeviceLocationType IWS.
X1-ProgramSubscriptionType
Used to create ProgramSubscriptionType.
This component invokes the X1- ProgramSubscriptionType business object using the ATX1ProgramSubscriptionType IWS.
X1-ProgramCalculationGroup
Used to create ProgramCalculationGroup.
This component invokes the X1- ProgramCalculationGroup business object using the ATX1ProgramCalculationGroup IWS.
Used to create ProgramSubscription.
This component invokes the X1- ProgramSubscription business object using the ATX1ProgramSubscription IWS.
X1-GenericProgramCalcRule
Used to create GenericProgramCalcRule.
This component invokes the X1- GenericProgramCalcRule business object using the ATX1GenericProgramCalcRule IWS.
X1-DigitalAssetUnenrollTaskTyp
Used to create DigitalAssetUnenrollTaskTyp.
This component invokes the X1- DigitalAssetUnenrollTaskTyp business object using the ATX1 DigitalAssetUnenrollTaskTyp IWS.
X1-DAUnenrollActionMethod
Used to create DAUnenrollActionMethod.
This component invokes the X1- DAUnenrollActionMethod business object using the ATX1 DAUnenrollActionMethod IWS.
X1-DAEnrollActionMethod
Used to create DAEnrollActionMethod.
This component invokes the X1- DAEnrollActionMethod business object using the ATX1 DAEnrollActionMethod IWS.
X1-InitiativeDigitalAsset
Used to create InitiativeDigitalAsset.
This component invokes the X1- InitiativeDigitalAsset business object using the ATX1InitiativeDigitalAsset IWS.
X1-MeteredServiceCrit
Used to create MeteredServiceCrit.
This component invokes the X1- MeteredServiceCrit business object using the ATX1MeteredServiceCrit IWS.
X1-DigitalAssetMasterConfig
Used to create DigitalAssetMasterConfig.
This component invokes the X1- DigitalAssetMasterConfig business object using the ATX1DigitalAssetMasterConfig IWS.
Used to create DigitalAssetUnenrollTask.
This component invokes the X1- DigitalAssetUnenrollTask business object using the ATX1DigitalAssetUnenrollTask IWS.
X1-NMSDigitalAssetContact
Used to create NMSDigitalAssetContact.
This component invokes the X1- NMSDigitalAssetContact business object using the ATX1NMSDigitalAssetContact IWS.
X1-NMSDigitalAssetCustSync
Used to create NMSDigitalAssetCustSync.
This component invokes the X1- NMSDigitalAssetCustSync business object using the ATX1NMSDigitalAssetCustSync IWS.
X1-NMSDigitalAssetSubscription
Used to create NMSDigitalAssetSubscription.
This component invokes the X1- NMSDigitalAssetSubscription business object using the ATX1NMSDigitalAssetSubscription IWS.
X1-NMSDigitalAssetLocation
Used to create NMSDigitalAssetLocation.
This component invokes the X1- NMSDigitalAssetLocation business object using the ATX1NMSDigitalAssetLocation IWS.
X1-NMSDigitalAssetFacility
Used to create NMSDigitalAssetFacility.
This component invokes the X1- NMSDigitalAssetFacility business object using the ATX1NMSDigitalAssetFacility IWS.
X1-NMSDigitalAssetCustOutMsg
Used to create NMSDigitalAssetCustOutMsg.
This component invokes the X1- NMSDigitalAssetCustOutMsg business object using the ATX1NMSDigitalAssetCustOutMsg IWS.
X1-CtrlDvcStatusCheckOBMsg
Used to create CtrlDvcStatusCheckOBMsg.
This component invokes the X1- CtrlDvcStatusCheckOBMsg business object using the ATX1CtrlDvcStatusCheckOBMsg IWS.
D1-RemoveIMDObjectCount
Used to perform actions such as ADD, READ, UPDATE, and DELETE of RemoveIMDObjectCount.
This component invokes the D1-RemoveIMDObjectCount using the ATD1RemoveIMDObjectCount Inbound Web Service.
D1-IMDFilter
This is the wrapper for the service that filters out IMD's based on the configuration of the device.
This invokes the D1-IMDFilter Business Service using the ATD1IMDFilter Inbound Web Service.
Used to perform actions such as ADD, READ, UPDATE and DELETE a Read On Demand Read Result Type for Itron.
This component invokes the D8- ReadOnDemandReadResultType Business Object using the ATD8ReadOnDemandReadResultType.
Data Model
Component
Description
D1-SmartMeter
Used to perform actions such as ADD, READ, UPDATE and DELETE a Smart Meter.
This component invokes the D1-SmartMeter Business Object using the ATD1SmartMeter Inbound Web Service.
D1-DvcCommEquipment
Used to create a Device Communication Equipment.
This component invokes the D1- DvcCommEquipment using the ATD1 DvcCommEquipment inbound web service.
D1-DvcCommEquipmentType
Used to create a Device Communication Equipment Type.
This component invokes the D1-DvcCommEquipmentType using ATD1DvcCommEquipmentType Inbound Web Service.
D1-DeviceConfiguration
Used to add Device Configuration to a device.
This component invokes the D1-DeviceConfiguration Business Object using the ATD1DeviceConfigurationSVC Inbound Web Service.
D1-IntervalChannel
Used to add interval measuring components to a device configuration.
This component invokes the D1-IntervalChannel Business Object using the ATD1IntervalChannel Inbound Web Service.
D1-Register
Used to add scalar measuring components to a device configuration.
This component invokes the D1-Register Business Object using the ATD1Register Inbound Web Service.
D1-ServicePoint
Used to create a Service Point.
This component invokes the D1- ServicePoint Business Object using the ATD1ServicePoint Inbound Web Service.
D1-SmartMeterInstallEvent
Used to create an installation event for a Smart Meter.
This component invokes the D1- SmartMeterInstallEvent Business Object using the ATD1SmartMeterInstallEvent Inbound Web Service.
D1-ManualMeterInstallEvent
Used to create an installation event for a Manual Meter.
This component invokes the D1-ManualMeterInstallEvent Business Object using the ATD1ManualMeterInstallEvent Inbound Web Service.
D1-Transformer
Used to create a Facility (Transformer) for a service type.
This component invokes the D1-Transformer Business Object using the ATD1Transformer Inbound Web Service.
D1-ElectricityNetworkLocation
Used to create an Electricity Network Location.
This component invokes the D1- ElectricityNetworkLocation Business Object using the ATD1ElectricityNetworkLocation Inbound Web Service.
D1-IntervalScratchpad
Used to create Interval Scratchpad MC.
This component invokes the D1-IntervalScratchpad Business Object using the ATD1IntervalScratchpad Inbound Web Service.
D1-Person
Used to create a Person.
This component invokes the D1-Person Business Object using the ATD1Person Inbound Web Service.
D1-Business
Used to create a Business.
This component invokes the D1-Business Business Object using the ATD1Business Inbound Web Service.
D1-RegisterAutoRead
Used to add register auto read measuring components to a device configuration.
This component invokes the D1-RegisterAutoRead Business Object using the ATD1RegisterAutoRead Inbound Web Service.
D1-Item
Used to perform actions such as ADD, READ, UPDATE and DELETE an Item.
This component invokes the D1-Item Business Object using the ATD1Item Inbound Web Service.
D1-ItemInstallEvent
This component invokes the D1-ItemInstallEvent Business Object using the ATD1ItemInstallEvent Inbound Web Service.
D1-AutoReadRegisterType
Used to define the properties of measuring components automatically read on a regular basis, but for which only one measurement is received at a time, meaning one measurement per Initial Measurement.
This component invokes the D1-AutoReadRegisterType Business Object using the ATD1AutoReadRegisterType Inbound Web Service.
D1-DeviceConfigurationType
Used to create a device configuration type used to create device configuration for a device.
This component invokes the D1-DeviceConfigurationType Business Object using the ATD1DeviceConfigurationType Inbound Web Service.
D1-ExceptionType
Used to set up VEE Exception Types.
This component invokes the D1-ExceptionType Business Object using the ATD1ExsceptionType Inbound Web Service.
D1-ExternalApplication
Used to create a Service Provider.
This component invokes the D1-ExternalApplication Business Object using the ATD1ExternalApplication Inbound Web Service.
D1-HeadEndSystem
Used to create a Head End system service provider.
This component invokes the D1-HeadEndSystem Business Object using the ATD1HeadEndSystem Inbound Web Service.
D1-ItemConfigurationType
Creates a configuration types for Item Types that can represent badged items.
This component invokes the D1-ItemConfigurationType Business Object using the ATD1ItemConfigurationType Inbound Web Service.
D1-ItemType
Creates an item type applicable to badged and unbadged non-meter devices.
This component invokes the D1-ItemType Business Object using the ATD1ItemType Inbound Web Service.
D1-ManualMeterType
This component invokes the D1-ManualMeterType Business Object using the ATD1ManualMeterType Inbound Web Service.
D1-ServiceType
Used to create a Service Type.
This component invokes the D1-ServiceType Business Object using the ATD1ServiceType Inbound Web Service.
D1-SmartMeterType
Used to create a Device of Smart Meter Type.
This component invokes the D1-SmartMeterType Business Object using the ATD1SmartMeterType Inbound Web Service.
D1-TimeOfUse
Used to create a TOU.
This component invokes the D1-TimeOfUse Business Object using the ATD1TimeOfUse Inbound Web Service.
D1-UnitOfMeasure
Used to create a Unit of Measure.
This component invokes the D1-UnitOfMeasure Business Object using the ATD1 UnitOfMeasure Inbound Web Service.
D1-Manufacturer
Describes the structure and business rules applicable to manufacturers.
This component invokes the D1-Manufacturer Business Object using the ATD1 Manufacturer Inbound Web Service.
D1-MeasurementCycle
Describes the Measurement Cycle creation.
This component invokes the D1-MeasurementCycle Business Object using the ATD1MeasurementCycle Inbound Web Service.
D1- Measurement
Used to perform actions such as ADD, READ, UPDATE, and DELETE a Measurement
This component invokes the D1-Measurement Business Object using the ATD1Measurement Inbound Web Service.
D1-IntervalChannelExternal
Used to add interval external measuring components to a device configuration.
This component invokes the D1-IntervalChannelExternal Business Object using the ATD1IntervalChannelExternal IWS.
D1-ScalarChannelExternal
Used to add scalar external measuring components to a device configuration.
This component invokes the D1-ScalarChannelExternal Business Object using the ATD1ScalarChannelExternal IWS.
D1-RegisterTypePhysical
Used to create Register Type component.
This component invokes the D1-RegisterTypePhysical Business Object using the ATD1RegisterTypePhysical Inbound Web Service.
D1-ServicePointType
A generic component used to create Service point type.
This component invokes the D1- ServicePointType Business Object using the ATD1ServicePointType Inbound Web Service.
D1-MeasurementCycleRoute
Used to create Measurement Cycle Route.
This component invokes the D1- MeasurementCycleRoute Business Object using the ATD1MeasurementCycleRoute Inbound Web Service.
D1-HowToProcessDeviceInfo
Describes how to process the Device Related Information.
This component invokes the D1-HowToProcessDeviceInfo Business Object using the ATD1HowToProcessDeviceInfo Inbound Web Service.
D1-HeadendSQILookup
A non-instantiable Extendable Lookup BO that provides translation between an external SQI sent in via a meter data source/provider, such as a head-end system and SQIs that have been configured within the application. SGG adapter products will deliver instantiable child BOs of this BO if SQI translation is needed.
This component invokes the D1-HeadendSQILookup Business Object using the ATD1HeadendSQILookup Inbound Web Service.
D1-ServiceQuantityIdentifier
Describes the structure and business rules applicable to Service Quantity Identifier definitions.
This component invokes the D1-ServiceQuantityIdentifier Business Object using the ATD1ServiceQuantityIdentifier Inbound Web Service.
D1-Market2
Valid Service Providers are Market Participants.
This component invokes the D1-Market2 Business Object using the ATD1Market2 Inbound Web Service.
D1-ContactType
Describes Contact Type.
This component invokes the D1-ContactType Business Object using the ATD1ContactType Inbound Web Service.
D2-DynCompValidation
Used to perform actions such as ADD, READ, UPDATE, and DELETE a DynCompValidation.
This component invokes the D2- DynCompValidation Business Object using the ATD2DynCompValidation Inbound Web Service.
Data Synchronization
Component
Description
C1-FASyncRequestRead
Used to read an FA Sync Request record.
This component invokes the ATC1FASyncRequestRead Inbound Web Service using the C1-FASyncRequest Business Object.
C1-GetSyncRequestId
Used to get the sync request ID of a given primary key ID (for example: Person, SP, SA, Contract Option, Contract Option Event, etc) using a specific query zone.
The following zones can be used:
• C1-GETSYNCU2 - Get Sync Req ID using Contract Option Event ID
• C1-GETSYNCU3 - Get Sync Req ID using Contract Option ID
• C1-GETPERSYN - Get Sync Request ID using Person ID
• C1-GETSASYNC - Get Sync Request ID using Service Agreement ID
• C1-GETFASYNC - Get Sync Request ID using Field Activity ID
• C1-GETSYNCRQ - Get Sync Request ID using External ID
This component invokes the ATC1GetSyncRequestId Inbound Web Service using C1-GetSyncRequestId Business Service.
C1-MDM2ContOptEvtSyncReqRead
Used to read an MDM2 Contract Option Event Sync Request record.
This component invokes the ATC1MDM2ContrOptEvtSyncReqRead Inbound Web Service using the C1- MDM2ContrOptEvtSyncRequest Business Object.
C1-MDM2ContractOptSyncReqRead
Used to read an MDM2 Contract Option Sync Request record.
This component invokes the ATC1MDM2ContractOptSyncReqRead Inbound Web Service using the C1-MDM2ContractOptSyncRequest Business Object.
C1-NtfContactPreferenceSyncUpdate
Used to update a Notification Contact Preference Sync Request.
This component invokes the ATC1NtfContactPreferenceSyncRead Inbound Web Service using the C1-NtfContactPreferenceSync Business Object.
C1-MDM2PersonSyncRequestRead
Used to read an MDM2 Person Sync Request record.
This component invokes the ATC1MDM2PersonSyncReqRead Inbound Web Service using the C1-MDM2PersonSyncRequest Business Object.
C1-MDM2SARelSyncRequestRead
Used to read an MDM2 SA Relationship Sync Request record.
This component invokes the ATC1MDM2SARelSyncRequestRead Inbound Web Service using the C1-MDM2SARelSyncRequest Business Object.
F1-GenericDataSyncAdd
Used to add a Generic Sync Request record.
This component invokes the ATF1GenericDataSync Inbound Web Service using the F1-GenericDataSync Business Object.
F1-GenericDataSyncDelete
Used to delete a Generic Sync Request record.
F1-GenericDataSyncRead
Used to read a Generic Sync Request record.
This component invokes the ATF1GenericDataSync Inbound Web Service using the F1-GenericDataSynct Business Object.
F1-GenericDataSyncUpdate
Used to update a Generic Sync Request record.
C1-MDM2SASyncRequestRead
Used to read an MDM2 Service Agreement Sync Request record.
This component invokes the ATC1MDM2SASyncRequestRead Inbound Web Service using the C1-MDM2SASyncRequest Business Object.
D1-InstallEventSyncRequestRead
Used to read an ODM Install Event Sync Request record.
This component invokes the ATD1InstallEventSyncRequestRead Inbound Web Service using D1-InstallEventSyncRequest Business Object.
W1-MDMAssetSyncRequestRead
Used to read an MDM Asset Sync Request record.
This component invokes the ATW1MDMAssetSyncRequestRead Inbound Web Service using the W1-MDMAssetSyncRequest Business Object.
W1-OngoingSyncRequestAssetNodeRead
Used to read an Asset-Node Ongoing Sync Request record.
This component invokes the ATW1OngoingSyncRequestAssetNodeRead Inbound Web Service using the W1-OngoingSyncRequestAssetNode Business Object.
X1-GetInboundSyncRequestId
Used to retrieve the Inbound Sync Request Id depending on the query zone used.
• X1-GETSYNCEX - Get Inbound Sync Request ID using External ID
This component invokes the ATX1GetSyncRequestInId Inbound Web Service using the X1-GetSyncRequestInId Business Service.
C1-ExternalRepoPlusBillingSync
Used to read a Billing Data Extract Sync Request record.
This component invokes the ATC1ExternalRepoPlusBillingSync Inbound Web Service using C1-ExternalRepoPlusBillingSync Business Object.
C1-ExternalRepoPlusCusDataSync
Used to read a Customer Data Extract Sync Request record.
This component invokes the ATC1ExternalRepoPlusCusDataSyncRead Inbound Web Service using C1-ExternalRepoPlusCusDataSync Business Object.
C1-ExternalRepoPlusSPMeterSync
Used to read a SP and Meter Data Extract Sync Request record.
This component invokes the ATC1ExternalRepoPlusBillingSyncRead Inbound Web Service using the C1-ExternalRepoPlusSPMeterSync Business Object.
C1-ExternalRepoPlusSASPSyncRead
Used to read a SA/SP Data Sync for DataConnect v1+.
This component invokes the ATC1ExternalRepoPlusSASPSync Inbound Web Service using the C1-ExternalRepoSASPSync Business Object.
C1-ExternalRepoPlusSASPSyncUpdate
Used to update a SA/SP Data Sync for DataConnect v1+
C1-ExternalRepoPlusSPMeterSyncRead
Used to read a Service Point Sync Request record.
This component invokes the ATC1ExternalRepoPlusSPMeterSync Inbound Web Service using the C1-ExternalRepoPlusSPMeterSync Business Object.
C1-ExternalRepoPlusSPMeterSyncUpdate
Used to update a Service Point Sync Request record.
C1-ExternalRepoPlusMailAddSyncRead
Used to read a Mailing Address Data for DataConnect v1+ sync.
This component invokes the ATC1ExternalRepoPlusMailAddSync Inbound Web Service using the C1-ExternalRepoPlusMailAddSync Business Object.
Update
Field Order
Component
Description
C1-AppointmentRead
Used to read an existing Appointment record.
This component invokes the ATC1Appointment Inbound Web Service using the C1AppointmentRead Business Service.
C1-AppointmentUpdate
Used to update an existing Appointment record.
This component invokes the ATC1Appointment Inbound Web Service using the C1AppointmentUpdate Business Service.
C1-DispatchFieldActivityRead
Used to read an existing Dispatch Field Activity record.
This component invokes the ATC1DispatchFA Inbound Web Service using the C1DispatchFARead Business Service.
C1-DispatchFieldActivityUpdate
Used to update an existing Dispatch Field Activity record.
This component invokes the ATC1DispatchFA Inbound Web Service using the C1DispatchFAUpdate Business Service.
C1-GenerateFreezeApprAdjustment
Used to generate and freeze an Approval Adjustment record.
This component invokes the ATC1GenerateFreezeApprAdjustment Inbound Web Service using the C1-CreateAdjustmentWithAppr Business Service
C1-FAUploadStagingAdd
Used to create an FA Upload Staging record.
This component invokes the ATC1FAUploadStaging Inbound Web Service using the C1FAUploadStagingAdd Business Service.
C1-FAUploadStagingRead
Used to read an existing FA Upload Staging record.
This component invokes the ATC1FAUploadStaging Inbound Web Service using the C1FAUploadStagingRead Business Service.
C1-FAUploadStagingUpdate
Used to update an existing FA Upload Staging record.
This component invokes the ATC1FAUploadStaging Inbound Web Service using the C1FAUploadStagingUpdate Business Service.
C1-FAUploadStagingDelete
Used to delete an existing FA Upload Staging record.
This component invokes the ATC1FAUploadStaging Inbound Web Service using the C1FAUploadStagingDelete Business Service.
C1-FieldActivityAdd
Used to create a Field Activity record.
This component invokes the ATC1FieldActivity Inbound Web Service using the C1FieldActivityPhysical Business Object.
C1-FieldActivityRead
Used to read an existing Field Activity record.
C1-FieldActivityUpdate
Used to update an existing Field Activity record.
This component invokes the ATC1FieldActivity Inbound Web Service using the C1FieldActivityUpdate Business Service.
C1-FACompletionByExtSystem
Used to complete a pending Field Activity record.
This component invokes the ATC1FACompletion Inbound Web Service using the C1FACompletion Business Service.
C1-FieldOrderAdd
Used to create a Field Order record.
This component invokes the ATC1FieldOrder Inbound Web Service using the C1FieldOrderPhysical Business Object.
C1-FieldOrderUpdate
Used to update an existing Field Order record.
This component invokes the ATC1FieldOrder Inbound Web Service using the C1FieldOrderUpdate Business Service.
C1-FieldOrderRead
Used to read an existing Field Order record.
D1-EnableService
Used to create a Enable Service.
This component invokes the D1-EnableService Business Object using the ATD1EnableService Inbound Web Service.
D1-DisableService
Used to create a Disable Service.
This component invokes the D1- DisableService Business Object using the ATD1 DisableService Inbound Web Service.
D1-BackToBackService
Used to create a BackToBackService.
This component invokes the D1- BackToBackService Business Object using the ATD1BackToBackService IWS.
D1-CutServiceForNonPayment
Used to create a CutServiceForNonPayment.
This component invokes the D1- CutServiceForNonPayment Business Object using the ATD1 CutServiceForNonPayment.
D1-ReconnectForPayment
Used to create a ReconnectForPayment.
This component invokes the D1- ReconnectForPayment Business Object using the ATD1ReconnectForPayment IWS.
Extendable Lookup
Component
Description
X1-C2MSATypeMappingAdd
Used to create a Customer to Meter SA Type mapping Extendable Lookup record.
This component invokes the ATX1C2MSATypeMapping Inbound Web Service using the X1-C2MSATypeMapping Business Object.
X1-C2MSATypeMappingUpdate
Used to update an existing Customer to Meter SA Type mapping Extendable Lookup record.
X1-C2MSATypeMappingDelete
Used to delete an existing Customer to Meter SA Type mapping Extendable Lookup record.
X1-C2MSATypeMappingRead
Used to query an existing Customer to Meter SA Type mapping Extendable Lookup record.
X1-CCBMDM-MDMCCB-LookupAdd
Used to create the mapping values for each field that requires translation between CCB and MDM Maintenance Objects.
The following lookup value can be used:
• C1_HIGHLIGHT_TYPE_FLG - Highlight Type
• C1_USG_RQST_SA_SKIP_RSN_FLG - SA Skip Reason
• CONT_OPT_TYPE_CD - Contract Option Type
• DISCON_LOC_CD - Disconnect Location
• FA_TYPE_CD - Field Activity Type
• KEY_SW - key
• LS_SL_FLG - Life Support / Sensitive Load
• OK_TO_ENTER_SW - OK to Enter
• PER_OR_BUS_FLG - Contact Type
This component invokes the ATX1CCBMDM-MDMCCB-Lookup Inbound Web Service using the X1-CCBMDM-MDMCCB-Lookup Business Object.
X1-CCBMDM-MDMCCB-LookupUpd
Used to update an existing mapping values for each field that requires translation between CCB and MDM Maintenance Objects.
• KEY_SW - key
X1-CCBMDM-MDMCCB-LookupDel
Used to delete an existing mapping values for each field that requires translation between CCB and MDM Maintenance Objects.
• KEY_SW - key
X1-CCBMDM-MDMCCB-LookupRead
Used to query an existing mapping values for each field that requires translation between CCB and MDM Maintenance Objects.
• KEY_SW - key
X1-ODMMDM-MDMODM-LookupAdd
Used to create the mapping values for each field that requires translation between ODM and MDM maintenance objects.
• ASSET_STATUS (Asset/Device Status)
• ASSET_TYPE_CD (Asset Type/Device Type)
• CONTACT_BUS_OBJ_CD (Contact Business Object)
• DISCONNECT_LOC_FLG (Disconnect Location)
• KEY_SW (Key)
• LIFE_SUPPORT_SENS_LOAD_FLG (Life Support/Sensitive Load)
• MR_INSTR_CD (SP Instruction)
• MR_WARN_CD (SP Warning)
• MTR_LOC_CD (Site Location)
• OK_TO_ENTER_FLG (OK to Enter)
• SVC_TYPE_FLG (Service Type)
This component invokes the ATX1ODMMDM-MDMODM-Lookup Inbound Web Service using X1-ODMMDM-MDMODM-Lookup Business Object.
X1-ODMMDM-MDMODM-LookupDelete
Used to delete an existing mapping values for each field that requires translation between ODM and MDM maintenance objects.
• KEY_SW (Key)
X1-ODMMDM-MDMODM-LookupUpd
Used to update and existing mapping values for each field that requires translation between ODM and MDM maintenance objects.
• KEY_SW (Key)
X1-ODMMDM-MDMODM-LookupRead
Used to query an existing mapping values for each field that requires translation between ODM and MDM maintenance objects.
• KEY_SW (Key)
Financial
Component
Description
C1-AdjustmentAdd
Used to adding an Adjustment record.
This component invokes the ATC1Adjustment Inbound Web Service using the C1AdjustmentAdd Business Service.
C1-AdjustmentDelete
Used to delete an Adjustment.
This component invokes the ATC1Adjustment Inbound Web Service using the C1AdjustmentDelete Business Service.
C1-AdjustmentRead
Used to read an Adjustment.
This component invokes the ATC1Adjustment Inbound Web Service using the C1AdjustmentRead Business Service.
C1-AdjustmentUpdate
Used to update an Adjustment record.
This component invokes the ATC1Adjustment Inbound Web Service using the C1AdjustmentUpdate Business Service.
C1-AdjustmentApprovalRequestAdd
Used to add an Adjustment Approval Request.
This component invokes the ATC1AdjustmentApprovalRequest Inbound Web Service using the C1AdjustmentApprovalRequestAdd Operation.
C1-AdjustmentApprovalRequestDelete
Used to delete an Adjustment Approval Request.
This component invokes the ATC1AdjustmentApprovalRequest Inbound Web Service using the C1AdjustmentApprovalRequestDelete Operation.
C1-AdjustmentApprovalRequestRead
Used to read an Adjustment Approval Request.
This component invokes the ATC1AdjustmentApprovalRequest Inbound Web Service using the C1AdjustmentApprovalRequestRead Operation.
C1-AdjustmentApprovalRequestUpdate
Used to update an Adjustment Approval Request.
This component invokes the ATC1AdjustmentApprovalRequest Inbound Web Service using the C1AdjustmentApprovalRequestUpdate Operation.
C1-PaymentEventBORead
Use to read for Pay Event record.
This component invokes the ATC1PayEventPhysicalBO Inbound Web Service using the C1-PayEventPhysicalBO Business Object.
C1-PaymentEventQuickAddAdd
Used to add a Payment Event Quick Add record.
This component invokes the ATC1PayEventPhysicalBO Inbound Web Service using the C1PaymentEventQuickAddAdd Business Service.
C1-StatementAdd
Used to create a Statement record.
This component invokes the ATC1Statement Inbound Web Service using C1StatementAdd Business Service.
C1-StatementDelete
Used to delete a Statement record.
This component invokes the ATC1Statement Inbound Web Service using C1StatementDelete Business Service.
C1-StatementRead
Used to read a Statement record.
This component invokes the ATC1Statement Inbound Web Service using C1StatementRead Business Service.
C1-StatementUpdate
Used to update a Statement record.
This component invokes the ATC1Statement Inbound Web Service using C1StatementUpdate Business Service.
C1-BankAcctApaySetupTaskAdd
Used to add Bank Account Auto Pay Setup Task record.
This component invokes the ATC1BankAcctApaySetupTask Inbound Web Service using the C1-BankAcctApaySetupTask Business Object.
C1-BankAcctApaySetupTaskDelete
Used to delete Bank Account Auto Pay Setup Task record.
C1-BankAcctApaySetupTaskRead
C1-BankAcctApaySetupTaskUpdate
Used to update Bank Account Auto Pay Setup Task record.
C1-BillAdd
Used to add a Bill record.
This component invokes the ATC1Bill Inbound Web Service using the C1BillAdd Business Service.
C1-BillDelete
Used to delete a Bill record
This component invokes the ATC1Bill Inbound Web Service using the C1BillDelete Business Service.
C1-BillRead
Used to read a Bill record.
This component invokes the ATC1Bill Inbound Web Service using the C1BillRead Business Service.
C1-BillUpdate
Used to update a Bill record.
This component invokes the ATC1Bill Inbound Web Service using the C1BillUpdate Business Service.
C1-BillCorrectionAdd
Used to add a Bill Correction record.
This component invokes the ATC1BillCorrection Inbound Web Service using the C1BillCorrectionAdd Business Object.
C1-BillCorrectionDelete
Used to delete a Bill Correction record.
This component invokes the ATC1BillCorrection Inbound Web Service using the C1BillCorrectionDelete Business Object.
C1-BillCorrectionRead
Used to read a Bill Correction record.
This component invokes the ATC1BillCorrection Inbound Web Service using the C1BillCorrectionRead Business Object.
C1-BillCorrectionUpdate
Used to update a Bill Correction record.
This component invokes the ATC1BillCorrection Inbound Web Service using the C1BillCorrectionUpdate Business Object.
C1-BillSegmentAdd
Used to add a Bill Segment record.
This component invokes the ATC1BillSegment Inbound Web Service using the C1BillSegmentAdd Business Service.
C1-BillSegmentRead
Used to read a Bill Segment record.
This component invokes the ATC1BillSegment Inbound Web Service using the C1BillSegmentRead Business Service.
C1-BillSegmentUpdate
Used to update a Bill Segment record.
This component invokes the ATC1BillSegment Inbound Web Service using the C1BillSegmentUpdate Business Service.
C1-BillableChargeAdd
Used to add a Billable Charge record.
This component invokes the ATC1BillableCharge Inbound Web Service using the C1BillableChargeAdd Business Service.
C1-BillableChargeRead
Used to read a Billable Charge record.
This component invokes the ATC1BillableCharge Inbound Web Service using the C1BillableChargeRead Business Service.
C1-BillableChargeUpdate
Used to update a Billable Charge record.
This component invokes the ATC1BillableCharge Inbound Web Service using the C1BillableChargeUpdate Business Service.
C1-CCBOneTimePaymentTaskAdd
Used to add a One Time Payment Task.
This component invokes the ATC1CCBOneTimePaymentTask Inbound Web Service using the C1-OneTimePaymentTask Business Object.
C1-CCBOneTimePaymentTaskRead
Used to read a One Time Payment Task.
C1-CCBOneTimePaymentTaskUpdate
Used to update a One Time Payment Task.
C1-DepositControlAdd
Used to add a Deposit Control record.
This component invokes the ATC1DepositControl Inbound Web Service using the C1DepositControlAdd Business Service.
C1-DepositControlRead
Used to read a Deposit Control.
This component invokes the ATC1DepositControl Inbound Web Service using the C1DepositControlRead Business Service.
C1-DepositControlUpdate
Used to update a Deposit Control record.
This component invokes the ATC1DepositControl Inbound Web Service using the C1DepositControlUpdate Business Service.
C1-FTRead
Used to read a Financial Transaction record.
This component invokes the ATC1FT Inbound Web Service using the C1FTRead Business Service.
C1-FTUpdate
Used to update a Financial Transaction record.
This component invokes the ATC1FinancialTransaction Inbound Web Service using the C1FTUpdate Business Service.
C1-MatchEventAdd
Used to add a Match Event record.
This component invokes the ATC1MatchEvent Inbound Web Service using the C1MatchEventAdd Business Service.
C1-MatchEventDelete
Used to delete a Match Event record.
This component invokes the ATC1MatchEvent Inbound Web Service using the C1MatchEventDelete Business Service.
C1-MatchEventRead
Used to read a Match Event record.
This component invokes the ATC1MatchEvent Inbound Web Service using the C1MatchEventRead Business Service.
C1-MatchEventUpdate
Used to update a Match Event record.
This component invokes the ATC1MatchEvent Inbound Web Service using the C1MatchEventUpdate Business Service.
C1-MultiCancelRebillRead
Used to read a Multi Cancel Rebill record.
This component invokes the ATC1MultiCancelRebill Inbound Web Service using the C1MultiCancelRebillRead Business Service.
C1-MultiCancelRebillUpdate
Used to update a Multi Cancel Rebill record.
This component invokes the ATC1MultiCancelRebill Inbound Web Service using the C1MultiCancelRebillUpdate Business Service.
C1-OffCycleBillGeneratorAdd
Used to add an Off Cycle Bill Generator record.
This component invokes the ATC1OffCycleBillGenerator Inbound Web Service using the C1OffCycleBillGeneratorAdd Business Service.
C1-OffCycleBillGeneratorDelete
Used to delete an Off Cycle Bill Generator record.
This component invokes the ATC1OffCycleBillGenerator Inbound Web Service using the C1OffCycleBillGeneratorDelete Business Service.
C1-OffCycleBillGeneratorRead
Used to read an Off Cycle Bill Generator record.
This component invokes the ATC1OffCycleBillGenerator Inbound Web Service using the C1OffCycleBillGeneratorRead Business Service.
C1-OffCycleBillGeneratorUpdate
Used to update an Off Cycle Bill Generator record.
This component invokes the ATC1OffCycleBillGenerator Inbound Web Service using the C1OffCycleBillGeneratorUpdate Business Service.
C1-PaymentAdd
Used to add a Payment record.
This component invokes the ATC1Payment Inbound Web Service using the C1PaymentAdd Business Service.
C1-PaymentDelete
Used to delete a Payment.
This component invokes the ATC1Payment Inbound Web Service using the C1PaymentDelete Business Service.
C1-PaymentRead
Used to read a Payment.
This component invokes the ATC1Payment Inbound Web Service using the C1PaymentRead Business Service.
C1-PaymentUpdate
Used to update a Payment record.
This component invokes the ATC1Payment Inbound Web Service using the C1PaymentUpdate Business Service.
C1-PaymentEventAdd
Used to add a Payment Event record.
This component invokes the ATC1PaymentEvent Inbound Web Service using the C1PaymentEventAdd Business Service.
C1-PaymentEventDelete
Used to delete a Payment Event record.
This component invokes the ATC1PaymentEvent Inbound Web Service using the C1PaymentEventDelete Business Service.
C1-PaymentEventRead
Used to read a Payment Event record.
This component invokes the ATC1PaymentEvent Inbound Web Service using the C1PaymentEventRead Business Service.
C1-PaymentEventUpdate
Used to update a Payment Event record.
This component invokes the ATC1PaymentEvent Inbound Web Service using the C1PaymentEventUpdate Business Service.
This component invokes the ATC1PaymentEventQuickAdd Inbound Web Service using the C1PaymentEventQuickAddAdd Business Service.
C1-PaymentQuickAddAdd
Used to add a Payment Quick Add record.
This component invokes the ATC1PaymentEventQuickAdd Inbound Web Service using the C1PaymentQuickAddAdd Business Service.
C1-PARequestAdd
Used to add a PA Request.
This component invokes the ATC1PARequest Inbound Web Service using the C1-PARequest Business Object.
C1-PARequestDelete
Used to delete a PA Request.
C1-PARequestRead
Used to read a PA Request.
C1-PARequestUpdate
Used to update a PA Request.
C1-TenderControlAdd
Used to add a Tender Control record.
This component invokes the ATC1TenderControl Inbound Web Service using the C1TenderControlAdd Business Service.
C1-TenderControlRead
Used to read a Tender Control record.
This component invokes the ATC1TenderControl Inbound Web Service using the C1TenderControlRead Business Service.
C1-TenderControlUpdate
Used to update a Tender Control record.
This component invokes the ATC1TenderControl Inbound Web Service using the C1TenderControlUpdate Business Service.
C1-TenderCtrlSearchByAllUser
Used to search an open Tender Control record.
This component invokes the ATC1TenderCtrlSearchByAllUser Inbound Web Service using the C1TenderCtrlSearchByAllUser Business Service.
General
Component
Description
C1-CtrlCenSearchByAccountId
Used to search Control Central by Account ID.
This component invokes the ATC1CtrlCenSearchByAccountId Inbound Web Service using the C1CtrlCenSearchByAccountId Business Service.
C1-CtrlCenSearchByAddress
Used to search Control Central by Address.
This component invokes the ATC1CtrlCenSearchByAddress Inbound Web Service using the C1CtrlCenSearchByAddress Business Service.
C1-CtrlCenSearchByNameAddress
Used to search Control Central by Name and Address.
This component invokes the ATC1CtrlCenSearchByNameAddress Inbound Web Service using the C1CtrlCenSearchByNameAddress Business Service.
X1-RetrieveAlerts
Used to retrieve Alerts.
This component invokes the ATX1RetrieveAlerts Inbound Web Service using the X1RetrieveAlerts Business Service.
X1-RetrieveGlobalContexts
Used to retrieve Global Contexts.
This component invokes the ATX1RetrieveGlobalContexts Inbound Web Service using the X1RetrieveGlobalContexts Business Service.
C1-RetrieveActiveSA
Used to retrieve Service Agreements on Account.
This Component invokes the ATC1RetrieveActiveSa Inbound Web Service using the C1-RetrieveActiveSa Business Service.
Master Configuration
Component
Description
X1-C2MMasterConfigurationAdd
Used to create a Customer to Meter Master Configuration record.
This component invokes the ATX1C2MMasterConfiguration Inbound Web Service using X1-C2MMasterConfiguration Business Object.
X1-C2MMasterConfigurationRead
Used to query an existing Customer to Meter Master Configuration record.
This component invokes the ATX1C2MMasterConfiguration Inbound Web Service using the X1-C2MMasterConfiguration Business Object.
C1-C360ConfigurationAdd
This component can be used for adding a Billing and Usage Display Configuration record.
This component invokes the Business Object “C1-C360Configuration” using the Inbound Web Service of ATC1C360Configuration.
C1-C360ConfigurationRead
This component can be used for reading a Billing and Usage Display Configuration record.
This component invokes the Business Object "C1-C360Configuration” using the Inbound Web Service of ATC1C360Configuration.
C1-C360ConfigurationUpdate
C1-DisplayIconOverrideConfigAdd
This component can be used for adding a Display Icon Override Configuration record.
This component invokes the Inbound Web Service “ATC1DisplayIconOverrideConfig” using the Business Object “C1-DisplayIconOverrideConfig”.
C1-DisplayIconOverrideConfigRead
This component can be used for reading a Display Icon Override Configuration record.
C1-MigrationAssistantConfigAdd
Used for adding a Migration Assistant Config record.
This component invokes the ATC1MigrationAssistantConfig Inbound Web Service using the F1-MigrationAssistantConfig Business Object.
C1-MigrationAssistantConfigDelete
Used for deleting a Migration Assistant Config record.
C1-MigrationAssistantConfigRead
Used for reading a Migration Assistant Config record.
C1-MigrationAssistantConfigUpdate
Used for updating a Migration Assistant Config record.
C1-DisplayIconOverrideConfigUpdate
This component can be used for updating a Display Icon Override Configuration record.
X1-C2MMasterConfigurationUpdate
Used to update an existing Customer to Meter Master Configuration record.
C1-RateEngineConfigAdd
Used to create a Rate Engine Configuration record.
This component invokes the C1-RateEngineConfig Business Object using the Inbound Web Service ATC1RateEngineConfig.
C1-RateEngineConfigRead
Used to query an existing Rate Engine Configuration record.
C1-RateEngineConfigUpdate
Used to update an existing a Rate Engine Configuration record.
This component invokes the C1-RateEngineConfig Business Object using Inbound Web Service ATC1RateEngineConfig.
Initial Measurement Data
Component
Description
D1-IMDSeeder
Used to perform actions such as ADD, READ, UPDATE, and DELETE of an IMD Seeder.
This component invokes the D1-IMDSeeder Business Object using the ATD1IMDSeeder Inbound Web Service.
D1-ManualIMDInterval
Used to perform actions such as ADD, READ, UPDATE, and DELETE of Manual IMD Interval records.
This component invokes the D1-ManualIMDInterval Business Object using the ATD1ManualIMDInterval Inbound Web Service.
D1-ManualIMDScalar
Used to perform actions such as ADD, READ, UPDATE, and DELETE of Manual IMD Scalar records.
This component invokes the D1-ManualIMDScalar Business Object using the ATD1ManualIMDScalar Inbound Web Service.
D1-InitialLoadIMDInterval
Used to perform actions such as ADD, READ, UPDATE, and DELETE of Initial Load IMD Interval records.
This component invokes the D1- InitialLoadIMDInterval Business Object using the ATD1InitialLoadIMDInterval Inbound Web Service.
D1-InitialLoadIMDScalar
Used to perform actions such as ADD, READ, UPDATE, and DELETE of Initial Load IMD Scalar records.
This component invokes the D1-InitialLoadIMDScalar Business Object using the ATD1InitialLoadIMDScalar Inbound Web Service.
D1-EstimationIMDInterval
Used to perform actions such as ADD, READ, UPDATE, and DELETE of Estimation IMD Interval records.
This component invokes the D1-EstimationIMDInterval Business Object using the ATD1EstimationIMDInterval Inbound Web Service.
D1-EstimationIMDScalar
Used to perform actions such as ADD, READ, UPDATE, and DELETE of Estimation IMD Scalar records.
This component invokes the D1-EstimationIMDScalar Business Object using the ATD1EstimationIMDScalar Inbound Web Service.
Integration
Component
Description
D1-OngoingSyncRequestContact
Used to perform actions such as ADD, READ, UPDATE, and DELETE a OngoingSyncRequestContact.
This component invokes the D1-Ongoing SyncRequestContact Business Object using the ATD1OngoingSyncRequestContact Inbound Web Service.
D1-OngoingSyncRequestSP
Used to perform actions such as ADD, READ, UPDATE, and DELETE a OngoingSyncRequestSP.
This component invokes the D1-OngoingSyncRequestSP Business Object using the ATD1OngoingSyncRequestSP Inbound Web Service.
D1-OngoingSyncRequestDevice
Used to perform actions such as ADD, READ, UPDATE, and DELETE a OngoingSyncRequestDevice.
This component invokes the D1-OngoingSyncRequestDevice Business Object using the ATD1OngoingSyncRequestDevice Inbound Web Service.
D2-OngoingSyncRequestUS
Used to perform actions such as ADD, READ, UPDATE, and DELETE a OngoingSyncRequestUS.
This component invokes the D2-OngoingSyncRequestUS Business Object using the ATD2OngoingSyncRequestUS Inbound Web Service.
D1-OngoingSyncRequestDC
Used to perform actions such as ADD, READ, UPDATE,and DELETE a OngoingSyncRequestDC.
This component invokes the D2-OngoingSyncRequestDC Business Object using the ATD1OngoingSyncRequestDC Inbound Web Service.
D1-CompositeSyncRequestDC
Used to perform actions such as ADD, READ, UPDATE,and DELETE a CompositeSyncRequestDC.
This component invokes the D1-CompositeSyncRequestDC Business Object using the ATD1CompositeSyncRequestDC Inbound Web Service.
D1-OngoingSyncRequestMC
Used to perform actions such as ADD, READ, UPDATE,and DELETE a OngoingSyncRequestMC.
This component invokes the D1-OngoingSyncRequestMC Business Object using the ATD1OngoingSyncRequestMC Inbound Web Service.
D1-OngoingSyncReqScalarMtrRead
Used to perform actions such as ADD, READ, UPDATE,and DELETE a OngoingSyncReqScalarMtrRead.
This component invokes the D1-OngoingSyncReqScalarMtrRead Business Object using the ATD1OngoingSyncReqScalarMtrRead Inbound Web Service.
D1-OngoingSyncRequestIE
Used to perform actions such as ADD, READ, UPDATE,and DELETE a OngoingSyncRequestIE.
This component invokes the D1-OngoingSyncRequestIE Business Object using the ATD1OngoingSyncRequestIE Inbound Web Service.
D2-UsageTran_ValSQHighList
Used to perform actions such as READ on D2-UsageTransaction
This component invokes the D2-UsageTransaction Business Object using the ATD2UsageTransactiion Inbound Web Service.
D2-UsageTran_ValUsgPeriod
D2-InitialSyncRequestDynOpt
Used to perform actions such as ADD, READ, UPDATE,and DELETE a InitialSyncRequestDynOpt.
This component invokes the D2- InitialSyncRequestDynOpt Business Object using the ATD2InitialSyncRequestDynOpt Inbound Web Service.
D2-OngoingSyncRequestDynOpt
Used to perform actions such as ADD, READ, UPDATE,and DELETE a OngoingSyncRequestDynOpt.
This component invokes the D2-OngoingSyncRequestDynOpt Business Object using the ATD2OngoingSyncRequestDynOpt Inbound Web Service.
D2-InitialSyncRequestDynOptEvt
Used to perform actions such as ADD, READ, UPDATE,and DELETE a InitialSyncRequestDynOptEvt.
This component invokes the D2- InitialSyncRequestDynOptEvt Business Object using the ATD2InitialSyncRequestDynOptEvt Inbound Web Service.
D2-OngoingSyncRequestDynOptEvt
Used to perform actions such as ADD, READ, UPDATE,and DELETE a OngoingSyncRequestDynOptEvt.
This component invokes the D2- OngoingSyncRequestDynOptEvt Business Object using the ATD2OngoingSyncRequestDynOptEvt Inbound Web Service.
D2-CCBContractOptionTypeLookup
Used to perform actions such as ADD, READ, UPDATE,and DELETE a CCBContractOptionTypeLookup.
This component invokes the D2- CCBContractOptionTypeLookup Business Object using the ATD2CCBContractOptionTypeLookup Inbound Web Service.
D1-HowToTranslateExternalValue
Used to perform actions such as ADD, READ, UPDATE,and DELETE a HowToTranslateExternalValue.
This component invokes the D1- HowToTranslateExternalValue Business Object using the ATD1HowToTranslateExternalValue Inbound Web Service.
D1-CCBContactTypeLookup
Used to perform actions such as ADD, READ, UPDATE,and DELETE a CCBContactTypeLookup.
This component invokes the D1- CCBContactTypeLookup Business Object using the ATd1CCBContactTypeLookup Inbound Web Service.
D1-CCBLifeSupSensitiveLdLookup
Used to perform actions such as ADD, READ, UPDATE,and DELETE a CCBLifeSupSensitiveLdLookup.
This component invokes the D1- CCBLifeSupSensitiveLdLookup Business Object using the ATD1CCBLifeSupSensitiveLdLookup Inbound Web Service.
D2-CCBSATypeLookup
Used to perform actions such as ADD, READ, UPDATE,and DELETE a CCBSATypeLookup.
This component invokes the D2- CCBSATypeLookup Business Object using the ATD2CCBSATypeLookup Inbound Web Service.
D2-CCBSAStatusLookup
Used to perform actions such as ADD, READ, UPDATE,and DELETE a CCBSAStatusLookup.
This component invokes the D2- CCBSAStatusLookup Business Object using the ATD2CCBSAStatusLookup Inbound Web Service.
D1-InitialSyncRequestDevice
Used to perform actions such as ADD, READ, UPDATE,and DELETE a InitialSyncRequestDevice.
This component invokes the D2- InitialSyncRequestDevice Business Object using the ATD1InitialSyncRequestDevice Inbound Web Service.
Itron Master Data
Component
Description
D8-InitialLoadIMDInterval
Used to ADD Initial Measurement Interval Data for Itron OpenWay Adapter.
ATD8InitialLoadIMDInterval Inbound Web
Service.
D8-InitialLoadIMDScalar
Used to ADD Initial Measurement Scalar Data for Itron OpenWay Adapter.
ATD8InitialLoadIMDScalar Inbound Web Service.
D8-ScheduleRead
Used to perform actions such as ADD, READ, UPDATE and DELETE a Schedule Read for Itron.
This component invokes the D8-ScheduleRead
Business Object using the ATD8ScheduleRead
Itron Admin Data
Component
Description
D8-ReadIntervalType
Used to perform actions such as ADD, READ, UPDATE and DELETE a Itron - Contingency Read Type (Interval) outbound communication type.
This component invokes the D8-ReadIntervalType Business Object using the ATD8ReadIntervalType Inbound Web Service.
D8-ReadScalarType
Used to perform actions such as ADD, READ, UPDATE and DELETE an Itron - Contingency Read Type (Scalar) outbound communication type.
This component invokes the D8-ReadScalarType
Business Object using the ATD8ReadScalarType
D8-ReadResultType
Used to perform actions such as ADD, READ, UPDATE and DELETE an Itron - Contingency Read Result Type inbound communication type.
This component invokes the D8-ReadResultType
Business Object using the ATD8ReadResultType
D8-DeviceEventMappingLookup
Used to perform actions such as ADD, READ, UPDATE and DELETE a Value for Itron - Device Event Mapping extendable Lookup.
This component invokes the D8-DeviceEventMappingLookup Business Object using the ATD8DeviceEventMappingLookup Inbound Web Service.
D8-HeadendUOMLookup
Used to perform actions such as ADD, READ, UPDATE and DELETE a Value for Itron UOM Code to Standard UOM Mapping extendable Lookup.
This component invokes the D8-HeadendUOMLookup Business Object using the ATD8HeadendUOMLookup Inbound Web Service.
D8-ItronVersions
Used to perform actions such as ADD, READ, UPDATE and DELETE a Value for Itron - Versions Lookup extendable Lookup.
This component invokes the D8-ItronVersions
Business Object using the ATD8ItronVersions
D8-JobStatusLookup
Used to perform actions such as ADD, READ, UPDATE and DELETE of an Itron OpenWay Job Status record.
This component invokes the D8-JobStatusLookup Business Object using the ATD8JobStatusLookup Inbound Web Service.
D8-PingByEndpointsMDRespType
Used to perform actions such as ADD, READ, UPDATE and DELETE of an Itron OpenWay Ping By Endpoints MD Response Type record.
This component invokes the D8-PingByEndpointsMDRespType Business Object using the ATD8PingByEndpointsMDRespType Inbound Web Service.
D8-PingByEndpointsResponseType
Used to perform actions such as ADD, READ, UPDATE and DELETE of an Itron OpenWay Ping By Endpoints Response Type record.
PingByEndpointsResponseType Business Object
using the ATD8PingByEndpointsResponseType
D8-PingByEndpointsMultiDvcType
Used to perform actions such as ADD, READ, UPDATE and DELETE of an Itron OpenWay Ping By Endpoints Multi Device Type record.
This component invokes the D8-PingByEndpointsMultiDvcType Business Object using the ATD8PingByEndpointsMultiDvcType Inbound Web Service.
D8-PingByEndpointsType
Used to perform actions such as ADD, READ, UPDATE and DELETE of an Itron OpenWay Ping By Endpoints Type record.
This component invokes the D8-PingByEndpointsType Business Object using the ATD8PingByEndpointsType Inbound Web Service.
D8-AddMeterDefinitionsType
Used to perform actions such as ADD, READ, UPDATE and DELETE an Add Meter Definitions Type for Itron.
This component invokes the D8-AddMeterDefinitionsType Business Object using the ATD8AddMeterDefinitionsType Inbound Web Service.
D8-AppGroupLookup
Used to perform actions such as ADD, READ, UPDATE and DELETE an App Group Lookup for Itron.
This component invokes the D8-AppGroupLookup
Business Object using the ATD8AppGroupLookup
D8-DeregisterMeterType
Used to perform actions such as ADD, READ, UPDATE and DELETE an Deregister Meter Type for Itron.
This component invokes the D8-DeregisterMeterType Business Object using the ATD8DeregisterMeterType Inbound Web Service.
D8-DetLoadSideVolBytMtrRsltTyp
Used to perform actions such as ADD, READ, UPDATE and DELETE an Detect Load Side Voltage By tMeter Result Type for Itron.
This component invokes the D8-DetLoadSideVolBytMtrRsltTyp Business Object using the ATD8DetLoadSideVolBytMtrRsltTyp Inbound Web Service.
D8-DetectLoadSideVoltageMtrTyp
Used to perform actions such as ADD, READ, UPDATE and DELETE a Detect Load Side Voltage Meter Type for Itron.
This component invokes the D8-DetectLoadSideVoltageMtrTyp Business Object using the ATD8DetectLoadSideVoltageMtrTyp Inbound Web Service.
D8-DisconnectMeterResultType
Used to perform actions such as ADD, READ, UPDATE and DELETE a Disconnect Meter Result Type for Itron.
This component invokes the D8-DisconnectMeterResultType Business Object using the ATD8DisconnectMeterResultType Inbound Web Service.
D8-DisconnectMeterType
Used to perform actions such as ADD, READ, UPDATE and DELETE a Disconnect Meter Type for Itron.
This component invokes the D8-DisconnectMeterType Business Object using the ATD8DisconnectMeterType Inbound Web Service.
D8-DisconnectSwitchStateLookup
Used to perform actions such as ADD, READ, UPDATE and DELETE a Disconnect Switch State Lookup for Itron.
This component invokes the D8-DisconnectSwitchStateLookup Business Object using the ATD8DisconnectSwitchStateLookup Inbound Web Service.
D8-DvcStatusMappingLookup
Used to perform actions such as ADD, READ, UPDATE and DELETE a Device Status Mapping Lookup for Itron.
This component invokes the D8-DvcStatusMappingLookup Business Object using the ATD8DvcStatusMappingLookup Inbound Web Service.
D8-FailureReasonLookup
Used to perform actions such as ADD, READ, UPDATE and DELETE a Failure Reason Lookup for Itron.
FailureReasonLookup Business Object using the
ATD8FailureReasonLookup Inbound Web Service.
D8-IntStsCodeToCondMapLookup
Used to perform actions such as ADD, READ, UPDATE and DELETE a IntStsCodeToCondMapLookup for Itron.
IntStsCodeToCondMapLookup Business Object
using the ATD8IntStsCodeToCondMapLookup
D8-InterrogateByGroupRsltType
Used to perform actions such as ADD, READ, UPDATE and DELETE a Interrogate By Group
This component invokes the D8-InterrogateByGroupRsltType Business Object using the ATD8InterrogateByGroupRsltType Inbound Web Service.
D8-InterrogateByGroupType
Used to perform actions such as ADD, READ, UPDATE and DELETE a Interrogate By Group Type for Itron.
This component invokes the D8-InterrogateByGroupType Business Object using the ATD8InterrogateByGroupType Inbound Web Service.
D8-ReadDisconStBytMtrRsltType
Used to perform actions such as ADD, READ, UPDATE and DELETE a Read Disconnect State By Meter Result Type for Itron.
ReadDisconStBytMtrRsltType Business Object using
the ATD8ReadDisconStBytMtrRsltType Inbound
Web Service.
D8-ReadDisconStateByMtrType
Used to perform actions such as ADD, READ, UPDATE and DELETE a Read Disconnect State By Meter Type for Itron.
This component invokes the D8-ReadDisconStBytMtrType Business Object using the ATD8ReadDisconStBytMtrType Inbound Web Service.
D8-ReconnectMeterResultType
Used to perform actions such as ADD, READ, UPDATE and DELETE a Reconnect Meter Result Type for Itron.
ReconnectMeterResultType Business Object using
the ATD8ReconnectMeterResultType Inbound Web
Service.
D8-ReconnectMeterType
Used to perform actions such as ADD, READ, UPDATE and DELETE a Reconnect Meter Type for Itron.
This component invokes the D8-ReconnectMeterType Business Object using the ATD8ReconnectMeterType Inbound Web Service.
D8-ResultLookup
Used to perform actions such as ADD, READ, UPDATE and DELETE a Result Lookup for Itron.
This component invokes the D8-ResultLookup Business Object using the ATD8ResultLookup Inbound Web Service.
D8-ScheduleReadType
Used to perform actions such as ADD, READ, UPDATE and DELETE a Schedule Read Type for Itron.
This component invokes the D8-ScheduleReadType Business Object using the ATD8ScheduleReadType Inbound Web Service.
D8-RptSelfReadOptionLookup
Used to perform actions such as ADD, READ, UPDATE and DELETE a RptSelfReadOptionLookup for Itron.
This component invokes the D8-RptSelfReadOptionLookup Business Object using the ATD8RptSelfReadOptionLookup Inbound Web Service.
D8-AddMeterToHarness
Used to add a meter to the test harness.
D8-SetCommissionRequest
Used to set commission to True/False for a device.
D8-SetVoltage
Used to set voltage for a device.
Landis + Gyr Admin Data
Component
Description
D3-InitMtReadByMtNumType
Used to perform actions such as ADD, READ, UPDATE and DELETE an Initiate Meter Read By Meter (Multispeak) outbound communication type.
This component invokes the D3- InitMtReadByMtNumType Business Object using the ATD3InitMtReadByMtNumType Inbound Web Service.
D3-LGMasterConfig
Used to perform actions such as ADD, READ, UPDATE and DELETE LGMasterConfig.
This component invokes the D3-LGMasterConfig Business Object using the ATD3LGMasterConfig Inbound Web Service.
D3-CIMMeterOnDemandReadDRType
Used to perform actions such as ADD, READ, UPDATE and DELETE CIMMeterOnDemandReadDRType.
This component invokes the D3-CIMMeterOnDemandReadDRType Business Object using the ATD3CIMMeterOnDemandReadDRType IWS.
D3-CIMAsyncReplyMRDRType
Used to perform actions such as ADD, READ, UPDATE and DELETE CIMAsyncReplyMRDRType.
This component invokes the D3- CIMAsyncReplyMRDRType Business Object using the ATD3CIMAsyncReplyMRDRType Inbound Web Service.
D3-IntStsCodeToCondMapLookup
Used to perform actions such as ADD, READ, UPDATE and DELETE a value for L+G Interval Status Code to Condition Mapping extendable lookup.
This component invokes the D3- IntStsCodeToCondMapLookup Business Object using the ATD3IntStsCodeToCondMapLookup Inbound Web Service.
D3-ReadingChgNotificationType
Used to perform actions such as ADD, READ, UPDATE and DELETE a Reading Change Notification inbound communication type.
This component invokes the D3- ReadingChgNotificationType Business Object using the ATD3ReadingChgNotificationType Inbound Web Service.
D3-DeviceEventMappingLookup
Used to perform actions such as ADD, READ, UPDATE and DELETE a Device Event Mapping Lookup record.
This component invokes the D3- DeviceEventMappingLookup Business Object using the ATD3DeviceEventMappingLookup Inbound Web Service.
D6-InitiateMtrRdByMtrIDDRType
Used to perform actions such as ADD, READ, UPDATE and DELETE a InitiateMtrRdByMtrIDDRType.
This component invokes the D6-InitiateMtrRdByMtrIDDRType Business Object using the ATD6InitiateMtrRdByMtrIDDRType Inbound Web Service.
D6-ReadingChgNotifDRType
Used to perform actions such as ADD, READ, UPDATE and DELETE a Value for ReadingChgNotifDRType.
This component invokes the D6-ReadingChgNotifDRType Business Object using the ATD6ReadingChgNotifDRType Inbound Web Service.
D3-HeadendUOMLookup
Used to perform actions such as ADD, READ, UPDATE and DELETE a Head End UOM Lookup record.
This component invokes the D3- HeadendUOMLookup Business Object using the ATD3HeadendUOMLookup Inbound Web Service.
D3-ConnectDisconStateChgNtfTyp
Used to perform actions such as ADD, READ, UPDATE and DELETE a Connect Disconnect State Change Notification Type record.
This component invokes the D3- ConnectDisconStateChgNtfTyp Business Object using the ATD3ConnectDisconStateChgNtfTyp Inbound Web Service.
D3-InitiateConnectDisconType
Used to perform actions such as ADD, READ, UPDATE and DELETE a Initiate Connect Disconnect Type record.
This component invokes the D3- InitiateConnectDisconType Business Object using the ATD3InitiateConnectDisconType Inbound Web Service.
D3-LoadActionCodeLookup
Used to perform actions such as ADD, READ, UPDATE and DELETE a Load Action Code Lookup record.
This component invokes the D3- LoadActionCodeLookup Business Object using the ATD3LoadActionCodeLookup Inbound Web Service.
D3-MeterAddNotificationMSType
Used to perform actions such as ADD, READ, UPDATE and DELETE a Meter Add Notification MS Type record.
This component invokes the D3- MeterAddNotificationMSType Business Object using the ATD3MeterAddNotificationMSType Inbound Web Service.
D3-MtrRmvNotifMultiSpkType
Used to perform actions such as ADD, READ, UPDATE and DELETE a Meter Remove Notification MultiSpk Type record.
This component invokes the D3- MtrRmvNotifMultiSpkType Business Object using the ATD3MtrRmvNotifMultiSpkType Inbound Web Service.
D3-ScheduleDemandResetRespTyp
Used to perform actions such as ADD, READ, UPDATE and DELETE a Schedule Demand Reset Resp Type record.
This component invokes the D3- ScheduleDemandResetRespTyp Business Object using the ATD3ScheduleDemandResetRespTyp Inbound Web Service.
D3-ScheduleDemandResetType
Used to perform actions such as ADD, READ, UPDATE and DELETE a Schedule Demand Reset Type record.
This component invokes the D3- ScheduleDemandResetType Business Object using the ATD3ScheduleDemandResetType Inbound Web Service.
D3-AddMeterTo Harness
Used to perform AddMeterToHarness to the LG test harness.
This component invokes the D3- AddMeterToHarness Business Object using the ATD3AddMeterToHarness Inbound Web Service.
D3-SetCommissionRequest
Used to perform actions such as ADD, READ, UPDATE and DELETE a SetCommissionRequest Type record.
This component invokes the D3- SetCommissionRequest using the ATD3SetCommissionRequest Inbound Web Service.
D3-AddMeterToInventoryMSType
Used to perform actions such as ADD, READ, UPDATE and DELETE a Add Meter To Inventory MS Type record.
This component invokes the D3- AddMeterToInventoryMSType using the ATD3AddMeterToInventoryMSType Inbound Web Service.
D3-MeterRetireNotificationType
Used to perform actions such as ADD, READ, UPDATE and DELETE a MeterRetireNotificationType record.
This component invokes the D3- MeterRetireNotificationType using the ATD3MeterRetireNotificationType Inbound Web Service.
Landis + Gyr Master Data
Component
Description
D3-AddMeterToInventoryMultiSp
Used to perform actions such as ADD, READ, UPDATE and DELETE a Add Meter To Inventory Multi Sp record.
This component invokes the D3- AddMeterToInventoryMultiSp using the ATD3AddMeterToInventoryMultiSp Inbound Web Service.
D3-InitialLoadIMDInterval
L+G Adapter.
This component invokes the D3- InitialLoadIMDInterval Business Object using the ATD3InitialLoadIMDInterval Inbound Web Service.
D3-InitialLoadIMDScalar
Used to ADD Initial Measurement Scalar Data for L+G Adapter.
This component invokes the D3- InitialLoadIMDScalar Business Object using the ATD3InitialLoadIMDScalar Inbound Web Service.
Used to perform actions such as ADD, READ, UPDATE and DELETE a MeterRetireNotification record.
This component invokes the D3- MeterRetireNotification using the ATD3MeterRetireNotification Inbound Web Service.
Rates
Component
Description
C1-ApplyToAdd
Used to add a calculation using Apply To Calculation rule.
This component invokes the ATC1ApplyTo Inbound Web Service using the C1-ApplyTo Business Object.
C1-ApplyToRead
Used to read a calculation using Apply To Calculation rule.
C1-ApplyToUpdate
Used to update a calculation using Apply To Calculation rule.
C1-ApplyToDelete
Used to delete a Bill Factor TOU Value.
This component invokes the ATC1BillFactorTOUValue Inbound Web Service
using the C1-BillFactorTOUValAdd Business
Object.
C1-ApplyCCLChargesAdd
Used to add calculation using Calculate Climate Change Levy and Relief Charges Calculation Rule.
ATC1ApplyCCLCharges Inbound Web Service
using the C1-ApplyCCLCharges Business Object.
C1-ApplyCCLChargesRead
Used to read calculation using Calculate Climate Change Levy and Relief Charges Calculation Rule.
C1-ApplyCCLChargesUpdate
Used to update calculation using Calculate Climate Change Levy and Relief Charges Calculation Rule.
This component invokes the ATC1ApplyCCLCharges Inbound Web Service using the C1-ApplyCCLCharges Business Object.
C1-ApplyCCLChargesDelete
Used to delete calculation using Calculate Climate Change Levy and Relief Charges Calculation Rule.
C1-ApplyVatToCrossRefChargeAdd
Used to add a calculation using Apply VAT to Cross Referenced Charges calculation rule.
using the C1-ApplyVatToCrossRefCharge Business Object.
C1-ApplyVatToCrossRefChargeDelete
Used to delete a calculation using Apply To Calculation rule.
ATC1ApplyVatToCrossRefCharge Inbound Web
Service using the C1-ApplyVatToCrossRefCharge
Business Object.
C1-ApplyVatToCrossRefChargeUpdate
This component invokes the ATC1ApplyVatToCrossRefCharge Inbound Web
Business Object.
C1-ApplyVatToCrossRefChargeRead
Used to read a calculation using Apply To Calculation Rule.
Business Object.
C1-BillFactorAdd
Used to add a Bill Factor Value.
This component invokes the ATC1BillFactor Inbound Web Service using the C1-BillFactorPhysicalBO Physical Business Object.
C1-BillFactorDelete
Used to delete a Bill Factor Value.
C1-BillFactorUpdate
Used to update a Bill Factor Value.
C1-BillFactorRead
Used to read a Bill Factor Value.
C1-BillFactorValueAdd
Used to add a Bill Factor TOU Value.
This component invokes the ATC1BillFactorValue Inbound Web Service using the C1-BillFactorValuePhysicalBO Physical Business Object.
C1-BillFactorValueDelete
C1-BillFactorValueUpdate
Used to update a Bill Factor TOU Value.
C1-BillFactorValueRead
Used to read a Bill Factor TOU Value.
This component invokes the ATC1BillFactorTOUValue Inbound Web Service using the C1-BillFactorTOUValAdd Business Object.
C1-BillFactorTOUValDelete
C1-BillFactorTOUValUpdate
C1-BillFactorTOUValRead
Object.
C1-BillFactorIntervalValueAdd
Used to add a Bill Factor Interval Value.
This component invokes the ATC1IntervaValueSet
C1-IntervalValueSetPhysicalBO Business Object.
C1-BillFactorIntervalValueDelete
Used to delete a Bill Factor Interval Value.
This component invokes the ATC1IntervaValueSet Inbound Web Service using the C1-IntervalValueSetPhysicalBO Business Object.
C1-BillFactorIntervalValueUpdate
Used to update a Bill Factor Interval Value.
C1-BillFactorIntervalValueRead
Used to read a Bill Factor Interval Value.
C1-CalculateServiceQuantityAdd
Used to add Calculate Service Quantity record.
This component invokes the ATC1CalculateServiceQuantity Inbound Web Service using the C1-CalculateServiceQuantity Business Object.
C1-CalculateServiceQuantityDelete
Used to delete a Calculate Service Quantity record.
C1-CalculateServiceQuantityUpdate
Used to update a Calculate Service Quantity record.
C1-CalculateServiceQuantityRead
Used to read a Calculate Service Quantity record.
C1-CalculationGroupAdd
Used to add a Calculation Group.
This component invokes the ATC1CalculationGroup
Inbound Web Service using the C1-CalcGroupPhysicalBO Physical Business Object.
C1-CalculationGroupDelete
Used to delete a Calculation Group.
C1-CalculationGroupRead
Used to read a Calculation Group.
C1-CalculationGroupUpdate
Used to update a Calculation Group.
C1-CalcLineCategoryAdd
Used to add a Calculation Line Category Type
This component invokes the ATC1CalcLineCat Inbound Web Service using the C1-CalcLineCatPhysicalBO Physical Business Object.
C1-CalcLineCategoryDelete
Used to delete a Calculation Line Category Type
C1-CalcLineCategoryUpdate
Used to update a Calculation Line Category Type
C1-CalcLineCategoryRead
Used to read a Calculation Line Category Type
C1-CalcRuleEligibilityCriteriaAdd
Used to add a Calculation Rule Eligibility Criteria.
This component invokes the ATC1CalcRuleElCrt Inbound Web Service using the C1-CalcRuleElCrtPhysicalBO Physical Business Object.
C1-CalcRuleEligibilityCriteriaDelete
Used to delete a Calculation Rule Eligibility Criteria.
C1-CalcRuleEligibilityCriteriaUpdate
C1-CalcRuleEligibilityCriteriaRead
Used to read a Calculation Rule Eligibility Criteria.
ATC1CalcRuleReferredCalcGroup Inbound Web
Used to update a Calculation Rule Eligibility Criteria.
C1-CalculateFinalValueAdd
Used to add a calculation using Calculate final reading values Calculation Rule.
ATC1CalculateFinalValue Inbound Web Service using the C1-CalculateFinalValue Business Object.
C1-CalculateFinalValueDelete
Used to delete a calculation using Calculate final
C1-CalculateFinalValueUpdate
Used to delete a calculation using Calculate final reading values Calculation Rule.
Object.
Object.
C1-CalcMiscellaneousChargeAdd
Used to add a calculation using Miscellaneous Charges Calculation Rule.
ATC1CalculateMiscellaneousCharg Inbound Web
Service using the C1-CalculateMiscellaneousCharg
Business Object.
C1-CalcMiscellaneousChargeDelete
Used to delete a calculation using Miscellaneous Charges Calculation Rule.
Business Object.
C1-CalcMiscellaneousChargeUpdate
Business Object.
C1-CalcMiscellaneousChargeRead
Used to read a calculation using Miscellaneous Charges Calculation Rule.
Business Object.
C1-CopySQFromMasterBillSegmentAdd
This component invokes the ATC1CopySQFromMasterBillSegment Inbound Web Service using the C1-CopySQFromMasterBillSegment Business Object.
C1-CopySQFromMasterBillSegment Delete
C1-CopySQFromMasterBillSegment Update
Used to update a calculation using Miscellaneous Charges Calculation Rule.
C1-CopySQFromMasterBillSegmentRead
This component invokes the ATC1CalculateMiscellaneousCharg Inbound Web Service using the C1-CalculateMiscellaneousCharg Business Object.
Business Object.
Delete
Update
Read
C1-DetermineDemandValueToPrice
Add
Used to add a calculation using Determine
Demand Value To Price Calculation Rule.
This component invokes the ATC1DetermineDemandValueToPrice Inbound Web Service using the C1-DetermineDemandValueToPrice Business Object.
Delete
Used to delete a calculation using Determine
Update
Used to update a calculation using Determine
C1-DetermineDemandValueToPriceRead
Used to read a calculation using Determine
C1-FlatChargeAdd
Used to add a calculation using Flat Charge calculation rule.
This component invokes the ATC1FlatCharge Inbound Web Service using the C1-FlatCharge Business Object.
C1-FlatChargeDelete
Used to delete a calculation using Flat Charge calculation rule.
C1-FlatChargeUpdate
C1-FlatChargeRead
C1-GetSubUsageRequestSQAdd
Used to add a calculation using Get Sub-Usage Request SQ Calculation Rule.
This component invokes the ATC1GetSubUsageRequestSQ Inbound Web Service using the C1-GetSubUsageRequestSQ Business Object.
C1-GetSubUsageRequestSQDelete
Used to delete a calculation using Get Sub-Usage Request SQ Calculation Rule.
C1-GetSubUsageRequestSQUpdate
Used to update a calculation using Get Sub-Usage Request SQ Calculation Rule.
C1-GetSubUsageRequestSQRead
Used to read a calculation using Get Sub-Usage Request SQ Calculation Rule.
C1-ItemTypeChargeAdd
Used to read a calculation using Item Type Charge Calculation rule.
This component invokes the ATC1ItemTypeCharge Inbound Web Service using the C1-ItemType Business Object.
C1-ItemTypeChargeDelete
Used to delete a calculation using Item Type Charge Calculation rule.
C1-ItemTypeChargeUpdate
Used to update a calculation using Item Type Charge Calculation rule.
C1-ItemTypeChargeRead
C1-MathAdd
Used to add a calculation using Math Calculation rule.
This component invokes the ATC1Math Inbound Web Service using the C1-Math Business Object.
C1-MathDelete
Used to delete a calculation using Math Calculation rule.
C1-MathUpdate
Used to update a calculation using Math Calculation rule.
C1-MathRead
Used to read a calculation using Math Calculation rule.
C1-MaximumAdd
Used to read a calculation using maximum Calculation rule.
This component invokes the ATC1Maximum Inbound Web Service using the C1-Maximum Business Object.
C1-MaximumDelete
C1-MaximumUpdate
Used to update a calculation using maximum Calculation rule.
C1-MaximumUpdate
Used to delete a calculation using Maximum Calculation rule.
C1-MinimumAdd
Used to add a calculation using Minimum Calculation rule.
This component invokes the ATC1Minimum Inbound Web Service using the C1-Minimum Business Object.
C1-MinimumDelete
Used to delete a calculation using Minimum Calculation rule.
C1-MinimumUpdate
Used to update a calculation using Minimum Calculation rule.
C1-MinimumRead
Used to read a calculation using Minimum Calculation rule.
C1-RateCheck
Used for Rate Checking.
This component invokes the ATC1RateCheck Inbound Web Service using the C1-RateApplication Business Service.
C1-RateComponentAdd
Used to add a Rate Component record.
This component invokes the ATC1RateComponent Inbound Web Service using the C1-RateComponentPhysicalBO Physical Business Object.
C1-RateComponentDelete
Used to delete a Rate Component record.
Object.
C1-RateComponentRead
Used to read a Rate Component record.
C1-RateComponentUpdate
Used to update a Rate Component record.
C1-RateScheduleV1Add
Used to add a Rate Schedule V1 record.
This component invokes the ATC1RateScheduleV1 Inbound Web Service using the C1-RateSchedulePhysicalBO Physical Business Object.
C1-RateScheduleV1Delete
Used to delete a Rate Schedule V1 record.
C1-RateScheduleV1Read
Used to read a Rate Schedule V1 record.
C1-RateScheduleV1Update
Used to update a Rate Schedule V1 record
C1-RateScheduleV2Add
This component invokes the ATC1RateScheduleV2 Inbound Web Service using the C1-RateScheduleV2 Business Object.
C1-RateScheduleV2Read
C1-RateScheduleV2Update
Used to update a Rate Schedule V1 record.
C1-RateVersionAdd
Used to add a Rate Version record.
This component invokes the ATC1RateVersion Inbound Web Service using the C1-RateVersionPhysicalBO Physical Business Object.
C1-RateVersionDelete
Used to delete a Rate Version record.
C1-RateVersionRead
Used to read a Rate Version record.
C1-RateVersionUpdate
Used to update a Rate Version record.
C1-ServiceQuantityAdd
Used to add a Service Quantity charge record.
This component invokes the ATC1ServiceQuantity Inbound Web Service using the Business Object.
C1-ServiceQuantityDelete
Used to delete a Service Quantity charge record.
C1-ServiceQuantityRead
Used to read a Service Quantity charge record.
C1-ServiceQuantityUpdate
Used to update a Service Quantity charge record.
C1-SimpleSummaryAdd
Used to add a Simple Summary charge record.
This component invokes the ATC1SimpleSummary Inbound Web Service using the Business Object.
C1-SimpleSummaryDelete
Used to delete a Simple Summary charge record.
C1-SimpleSummaryRead
Used to read a Simple Summary charge record.
C1-SimpleSummaryUpdate
Used to update a Simple Summary charge record.
C1-SteppedSQAdd
Used to add a Stepped SQ charge record.
This component invokes the ATC1SteppedSQ Inbound Web Service using the Business Object.
C1-SteppedSQDelete
Used to add read a Stepped SQ charge record.
C1-SteppedSQRead
Used to read a Stepped SQ charge record.
C1-SteppedSQUpdate
Used to update a Stepped SQ charge record.
C1-SummaryAdd
Used to add a Summary charge record.
This component invokes the ATC1Summary Inbound Web Service using the Business Object.
C1-SummaryDelete
Used to delete a Summary charge record.
C1-SummaryRead
Used to read a Summary charge record.
This component invokes the ATC1Summary Inbound Web Service using the Physical Business Object.
C1-SummaryUpdate
Used to update a Summary charge record.
SMDF Admin Data
Component
Description
D2-SubIntAdjustmentVEE
Performs adjustments to consumption; the changes to consumption will be validated against the readings contained prior to and subsequent to the change made.
This component invokes the D2-SubIntAdjustmentVEE Business Object using the ATD2SubIntAdjustmentVEE Inbound Web Service.
D1-VEEGroup
Used to create a VEE Group.
This component invokes the D1-VEEGroup Business Object using the ATD1VEEGroup Inbound Web Service.
D2-NegativeConsumptionCheck
Used to create a Negative-Consumption Check VEE Rule.
This component invokes the D2- NegativeConsumptionCheck Business Object using the ATD2NegativeConsumptionCheck Inbound Web Service.
D2-RegisterMultiplierCheck
Used to create a Multiplier Check VEE Rule.
This component invokes the D2-RegisterMultiplierCheck Business Object using the ATD2RegisterMultiplierCheck Inbound Web Service.
D2-IntervalReplacementRule
Used to create an IntervalReplacementRule VEE rule.
This component invokes the D2-IntervalReplacementRule Business Object using the ATD2IntervalReplacementRule Inbound Web Service.
D2-IntervalSpikeCheck
Used to create an IntervalSpikeCheck VEE rule.
This component invokes the D2-IntervalSpikeCheck Business Object using the ATD2IntervalSpikeCheck Inbound Web Service.
D2-ScalarReplacementRule
Used to create a ScalarReplacementRule VEE rule.
This component invokes the D2-ScalarReplacementRule Business Object using the ATD2ScalarReplacementRule Inbound Web Service.
D1-VEERuleSuccessTermination
Used to create a VEERuleSuccessTermination VEE rule.
This component invokes the D1-VEERuleSuccessTermination Business Object using the ATD1VEERuleSuccessTermination Inbound Web Service.
D2-IntervalAveragingEstimation
Describes Interval Averaging Estimation.
This component invokes the D2-IntervalAveragingEstimation Business Object using the ATD2IntervalAveragingEstimation Inbound Web Service.
D2-IntervalProfileEstimation
Describes Interval Profile Estimation.
This component invokes the D2-IntervalProfileEstimation Business Object using the ATD2IntervalProfileEstimation Inbound Web Service.
D2-IntervalSizeValidation
Describes Interval Size Validation.
This component invokes the D2-IntervalSizeValidation Business Object using the ATD2IntervalSizeValidation Inbound Web Service.
D2-RaiseMissingQuantityExcp
Describes Raise Missing Quantity Exception.
This component invokes the D2-RaiseMissingQuantityExcp Business Object using the ATD2RaiseMissingQuantityExcp Inbound Web Service.
D1-VEERuleReferredVEEGroup
Calls the VEE processor to execute the rules for the VEE group configured on the rule.
This component invokes the D1-VEERuleReferredVEEGroup Business Object using the ATD1VEERuleReferredVEEGroup Inbound Web Service.
D2-SSMeterReadTaskType
Holds the default values such as measurement condition, service provider, and data source used in self-service meter read creation. To Do type and role, if specified will be used when reporting errors that occur during IMD creation.
This component invokes the D2-SSMeterReadTaskType Business Object using the ATD2SSMeterReadTaskType Inbound Web Service.
D2-ProlongedEstimationCheck
Describes ProlongedEstimationCheck.
This component invokes the D2-ProlongedEstimationCheck Business Object using the ATD2 ProlongedEstimationCheck Inbound Web Service.
D1-DuplicateIMDCheck
Checks whether the current IMD is a duplicate of one already received for the same measuring component.
This component produces a VEE exception of the type and severity defined on the rule when it is configured.
It invokes the D1-DuplicateIMDCheck Business Object using the ATD1DuplicateIMDCheck Inbound Web Service.
D1-VEERuleGroupFactor
Describes the VEE Rule group factor.
This component invokes the D1-VEERuleGroupFactor Business Object using the
ATD1VEERuleGroupFactor Inbound Web Service.
D2-FinalMeasurementValidation
Describes the Final Measurement Validation.
This component invokes the D2-FinalMeasurementValidation Business Object using the ATD2FinalMeasurementValidation Inbound Web Service.
D2-ScalarProfileEstimation
Used to create a ScalarProfileEstimation VEE Rule.
This component invokes the D2-ScalarProfileEstimation Business Object using the
ATD2ScalarProfileEstimation Inbound Web
Service.
D2-SumCheck
Used to create a SumCheck VEE Rule.
This component invokes the D2-SumCheck Business Object using the ATD2SumCheck Inbound Web Service.
D2-ScalarCalcFromInterval
Describes Scalar Calculation from Interval.
This component invokes the D2-ScalarCalcFromInterval Business Object using the ATD2ScalarCalcFromInterval Inbound Web Service.
D2-ScalarEstimation
Describes the Describes Scalar Estimation VEE Rule.
This component invokes the D2-ScalarEstimation Business Object using the ATD2ScalarEstimation Inbound Web Service.
D2-UOMCheck
Used to create UOM Check VEE rule.
This component invokes the D2-UOMCheck Business Object using the ATD2UOMCheck Inbound Web Service.
D2-ZeroConsumptionCheck
Used to create Zero Consumption Check VEE rule.
This component invokes the D2-ZeroConsumptionCheck Business Object using the ATD2ZeroConsumptionCheck Inbound Web Service.
D1-VEERuleExceptionHandler
Used to create a VEERuleExceptionHandler VEE Rule.
This component invokes the D1-VEERuleExceptionHandler Business Object using the ATD1VEERuleExceptionHandler Inbound Web Service.
D2-EnsureIMDExistsForSibling
Used to create a EnsureIMDExistsForSibling VEE rule.
This component invokes the D2-EnsureIMDExistsForSibling Business Object using the ATD2EnsureIMDExistsForSibling Inbound Web Service.
D2-IntervalAdjustmentFrmScalar
Used to create a IntervalAdjustmentFrmScalar VEE rule.
This component invokes the D2-IntervalAdjustmentFrmScalar Business Object using the ATD2IntervalAdjustmentFrmScalar Inbound Web Service.
D2-IntervalInterpolationEst
Used to create an IntervalInterpolationEst VEE rule.
This component invokes the D2-IntervalInterpolationEst Business Object using the ATD2IntervalInterpolationEst Inbound Web Service.
D2-GetSubtractiveInterval
Allows the configuration of subtractive interval data retrieval during usage transaction processing. The rule records service quantities per service point and measuring component - which means that subtractive interval curves for different measuring components.
This component invokes the D2-GetSubtractiveInterval Business Object using the ATD2GetSubtractiveInterval Inbound Web Service.
D1-MeterReadDownloadActType
Used to create a MeterReadDownloadActType Activity Type.
This component invokes the D1-MeterReadDownloadActType Business Object using the ATD1MeterReadDownloadActType Inbound Web Service.
D1-PairedEventLastDvcEvtType
Used to create a PairedEventLastDvcEvtType Device Event Type.
This component invokes the D1-PairedEventLastDvcEvtType Business Object using the ATD1PairedEventLastDvcEvtType Inbound Web Service.
D1-StandardDeviceEventType
Used to create a StandardDeviceEventType Device Event Type.
This component invokes the D1-StandardDeviceEventType Business Object using the ATD1StandardDeviceEventType Inbound Web Service.
D1-UTCorrectnPrcessrActvtyType
Defines the activity BO to use in the creation of a Usage Transaction Correction Processor. This component also defines the general category of these activities as a Correction Processor.
The component invokes the D1-UTCorrectnPrcessrActvtyType Business Object using the ATD1UTCorrectnPrcessrActvtyType Inbound Web Service.
D1-RemoteConnectType
Describes configuration parameters required for the Remote Connect command activity, including automated retry and command time-out options.
This component allows the definition of a Service Issue Monitor Type resulting in the creation of a Service Issue Monitor of the configured type if a Remote Connect command activity has failed.
The component invokes the D1-RemoteConnectType Business Object using the ATD1RemoteConnectType Inbound Web Service.
D1-PairedEventFirstDvcEvtType
Describes the Device Event Type - Paired Event (First).
This component invokes the D1-PairedEventFirstDvcEvtType Business Object using the ATD1PairedEventFirstDvcEvtType Inbound Web Service.
D1-DeviceWithDurationActType
Describes the Device Activity with Duration Type.
This component invokes the D1-DeviceWithDurationActType Business Object using the ATD1DeviceWithDurationActType Inbound Web Service.
D2-SubMeasurementAggType
Describes the Sub Measurement Aggregator Type.
This component invokes the D2-SubMeasurementAggType Business Object using the ATD2SubMeasurementAggType Inbound Web Service.
D2-MasterMsrmtAggregatorType
Describes the Master Measurement Aggregator Type.
This component invokes the D2-MasterMsrmtAggregatorType Business Object using the ATD2MasterMsrmtAggregatorType Inbound Web Service.
D2-ActivityTypeAggDimScanner
Describes the Aggregator Dimension Scanner Activity Type.
This component invokes the D2-ActivityTypeAggDimScanner Business Object using the ATD2ActivityTypeAggDimScanner Inbound Web Service.
D2-AggregatorType
Used to create an AggregatorType Measuring Component Type.
This component invokes the D2-AggregatorType Business Object using the ATD2AggregatorType Inbound Web Service.
D1-IntervalPriceType
Used to create a IntervalPriceType.
This component invokes the D1-IntervalPriceType Business Object using the ATD1IntervalPriceType Inbound Web Service.
D1-IntervalChannelTypePhysical
Used to create a IntervalChannelTypePhysical.
This component invokes the D1-IntervalChannelTypePhysical Business Object using the ATD1IntervalChannelTypePhysical Inbound Web Service.
D1-IntervalChannelTypeExternal
Used to create a IntervalChannelTypeExternal.
This component invokes the D1- IntervalChannelTypeExternal Business Object using the ATD1IntervalChannelTypeExternal Inbound Web Service.
D1-ScalarChannelTypeExternal
Used to create a ScalarChannelTypeExternal.
This component invokes the D1-ScalarChannelTypeExternal Business Object using the ATD1ScalarChannelTypeExternal Inbound Web Service.
D1-BulkCommandProcessor
Used to create a Bulk Command Processor.
This component invokes the D1-BulkCommandProcessor Business Object using the ATD1BulkCommandProcessor Inbound Web Service.
D1-ChannelCountMetric
Used to create a ChannelCountMetric.
This component invokes the D1-ChannelCountMetric Business Object using the ATD1ChannelCountMetric Inbound Web Service.
D1-DeviceCountMetric
Used to create a DeviceCountMetric.
This component invokes the D1-DeviceCountMetric Business Object using the ATD1DeviceCountMetric Inbound Web Service.
D1-MeasurementCycleSchedule
Used to create a MeasurementCycleSchedule.
This component invokes the D1-MeasurementCycleSchedule Business Object using the ATD1MeasurementCycleSchedule Inbound Web Service.
D1-ReaderRemarkType
Used to create a ReaderRemarkType.
This component invokes the D1-ReaderRemarkType Business Object using the ATD1ReaderRemarkType Inbound Web Service.
D1-ServiceIssueMonitorType
Used to create a ServiceIssueMonitorType.
This component invokes the D1-ServiceIssueMonitorType Business Object using the ATD1ServiceIssueMonitorType Inbound Web Service.
D2-MsrmtQuantityAggScannerType
Used to create a MsrmtQuantityAggScannerType.
This component invokes the D2-MsrmtQuantityAggScannerType Business Object using the ATD2MsrmtQuantityAggScannerType Inbound Web Service.
D2-TOUGroup
Used to create a TOUGroup.
This component invokes the D2-TOUGroup Business Object using the ATD2TOUGroup Inbound Web Service.
D2-VEERuleHighLowCheck
Used to create a VEERuleHighLowCheck.
VEERuleHighLowCheck Business Object using the
ATD2VEERuleHighLowCheck Inbound Web
Service.
D1-HowToCreateMCInformation
Used to create a HowToCreateMCInformation.
This component invokes the D1-HowToCreateMCInformation Business Object using the ATD1HowToCreateMCInformation Inbound Web Service.
D1-HowToSendActivityResponse
Used to create a HowToSendActivityResponse.
This component invokes the D1-HowToSendActivityResponse Business Object using the ATD1HowToSendActivityResponse Inbound Web Service.
D1-AvgDailyEstItemConsumption
Used to create a AvgDailyEstItemConsumption.
This component invokes the D1-AvgDailyEstItemConsumption Business Object using the ATD1AvgDailyEstItemConsumption Inbound Web Service.
D1-VEEEligibilityCriteria
Used to create a VEEEligibilityCriteria.
This component invokes the D1-VEEEligibilityCriteria Business Object using the
ATD1VEEEligibilityCriteria Inbound Web Service.
D2-VerifyUomTouSqiMCExistForUs
Used to create a VerifyUomTouSqiMCExistForUs.
This component invokes the D2-VerifyUomTouSqiMCExistForUs Business Object using the ATD2VerifyUomTouSqiMCExistForUs Inbound Web Service.
D1-DeviceEventSeeder
Used to create a DeviceEventSeeder.
This component invokes the D1-DeviceEventSeeder Business Object using the ATD1DeviceEventSeeder Inbound Web Service.
D1-FieldActivity
Used to create a FieldActivity.
This component invokes the D1-FieldActivity Business Object using the ATD1FieldActivity Inbound Web Service.
D1-ReaderRemark
Used to create a ReaderRemark.
This component invokes the D1-ReaderRemark Business Object using the ATD1ReaderRemark Inbound Web Service.
D1-TimeZoneTranslationLookup
Used to create a TimeZoneTranslationLookup.
This component invokes the D1-ATD1TimeZoneTranslationLookup Business Object using the ATD1ReaderRemark Inbound Web Service.
D2-UsageCalculationGroupLookup
Used to create a UsageCalculationGroupLookup.
This component invokes the D2-UsageCalculationGroupLookup Business Object using the ATD2UsageCalculationGroupLookup Inbound Web Service.
D2-MDMMasterConfig
Used to perform actions such as ADD, READ, UPDATE, and DELETE a MDMMasterConfig.
This component invokes the D2-MDMMasterConfig Business Object using the ATD2MDMMasterConfig Inbound Web Service.
D2-MDMMasterConfig
D2-MtrCommTrckngAggregatorType
Used to perform actions such as ADD, READ, UPDATE, and DELETE a MtrCommTrckngAggregatorType.
This component invokes the D2-MtrCommTrckngAggregatorType Business Object using the ATD2MtrCommTrckngAggregatorType Inbound Web Service.
D1-EstimationSuppressionType
Used to perform actions such as ADD, READ, UPDATE, and DELETE a EstimationSuppressionType.
This component invokes the D1-EstimationSuppressionType Business Object using the ATD1EstimationSuppressionType Inbound Web Service.
D2-InactiveMeasurementCheck
Used to perform actions such as ADD, READ, UPDATE, and DELETE a InactiveMeasurementCheck VEE Rule.
This component invokes the D1-InactiveMeasurementCheck Business Object using
the ATD2InactiveMeasurementCheck Inbound Web
Service.
D1-ChannelStatisticsType
Used to perform actions such as ADD, READ, UPDATE, and DELETE a ChannelStatisticsType.
This component invokes the D1-ChannelStatisticsType Business Object using the ATD1ChannelStatisticsType Inbound Web Service.
Used to perform actions such as ADD, READ, UPDATE, and DELETE a ChannelStatistics.
This component invokes the D1- ChannelStatistics Business Object using the ATD1ChannelStatistics Inbound Web Service.
D1-FacilityLite
Used to perform actions such as ADD, READ, UPDATE, and DELETE a FacilityLite.
This component invokes the D1- FacilityLite Business Object using the ATD1FacilityLite Inbound Web Service.
D1-SpecificationLookup
Used to perform actions such as ADD, READ, UPDATE, and DELETE a SpecificationLookup.
This component invokes the D1-SpecificationLookup Business Object using the
ATD1SpecificationLookup Inbound Web Service.
D1-MeasuringCompTypLite
Used to perform actions such as ADD, READ, UPDATE, and DELETE a MeasuringCompTypLite.
This component invokes the D1-MeasuringCompTypLite Business Object using the ATD1MeasuringCompTypLite Inbound Web Service.
D1-GetDvcFrmIdenTypFlag
Used to retrieve Device ID By Identifier and Type Flag using the ATD1 GetDvcFrmIdenTypFlag Inbound Web Service.
D1-GetSimdIdFromImd
Used to retrieve Simd ID By IMD ID using the ATD1GetSimdIdFromImd Inbound Web Service.
D1-GetMCFrmDvcExtId
Used to retrieve Measuring Component ID from Device External ID using the ATD1GetMCFrmDvcExtId Inbound Web Service.
D1-GetProductKeyFromSync
Used to Get Product Key from Sync Request ID using the ATD1 GetProductKeyFromSync Inbound
Web Service.
D1-GetUsageFromExtID
Used to retrieve Usage ID from CCB Usage ID using the ATD1 GetUsageFromExtID Inbound Web Service.
D2-GetUSFromExtID
Used to retrieve US ID from External ID using the ATD1 GetUSFromExtID Inbound Web Service.
D1-GetDCFrmDvcExtId
Used to retrieve DC ID from External ID using the ATD1GetDCFrmDvcExtId Inbound Web Service.
D1-GetInstEvtFromDvcExId
Used to retrieve Install Event ID from Device External ID using ATD1GetInstEvtFromDvcExId Inbound Web Service.
D1-GetInstEvtFrmSPExtId
Used to retrieve Install Event ID from Service Point External ID using the ATD1GetInstEvtFrmSPExtId Inbound Web Service.
D1-GetMCFromExtID
Used to retrieve Measuring Component ID from External ID using the ATD1GetMCFromExtID Inbound Web Service.
D1-GetContactFromExtID
Used to retrieve Contact ID from External ID using the ATD1GetContactFromExtID Inbound Web Service.
D1-GetSpFromExtID
Used to retrieve Service Point ID from External ID using the ATD1GetSpFromExtID Inbound Web Service.
D1-GetSyncReqIdFrmExtId
Used to retrieve Sync Request ID from External ID using the ATD1GetSyncReqIdFrmExtId Inbound Web Service.
SMDF Master
Component
Description
D2- MtrCommTrckgDimScanner
Used to perform actions such as ADD, READ, UPDATE, and DELETE a MtrCommTrckgDimScanner.
This component invokes the D2-MtrCommTrckgDimScanner Business Object using the ATD2MtrCommTrckgDimScanner Inbound Web Service.
Used to perform actions such as ADD, READ, UPDATE, and DELETE a EstimationSuppression.
This component invokes the D2-EstimationSuppression Business Object using the ATD2EstimationSuppression Inbound Web Service.
D1-InitialLoadIMDSubtrInterval
Used to perform actions such as ADD, READ, UPDATE, and DELETE a InitialLoadIMDSubtrInterval.
This component invokes the D1-InitialLoadIMDSubtrInterval Business Object using the ATD1InitialLoadIMDSubtrInterval Inbound Web Service.
D1-EstimationIMDSubtrInterval
Used to perform actions such as ADD, READ, UPDATE, and DELETE a EstimationIMDSubtrInterval.
This component invokes the D1-EstimationIMDSubtrInterval Business Object using the ATD1EstimationIMDSubtrInterval Inbound Web Service.
D1-ManualIMDSubtrInterval
Used to perform actions such as ADD, READ, UPDATE, and DELETE a ManualIMDSubtrInterval.
This component invokes the D1-ManualIMDSubtrInterval Business Object using the ATD1ManualIMDSubtrInterval Inbound Web Service.
D1-SystemIMDSubtrInterval
Used to perform actions such as ADD, READ, UPDATE, and DELETE a SystemIMDSubtrInterval.
This component invokes the D1-SystemIMDSubtrInterval Business Object using the ATD1SystemIMDSubtrInterval Inbound Web Service.
D1-IntervalPriceSet
Used to perform actions such as ADD, READ, UPDATE, and DELETE a IntervalPriceSet.
This component invokes the D1-IntervalPriceSetBusiness Object using the ATD1IntervalPriceSet Inbound Web Service.
D1-SubtractveIntvalMeasurement
Used to perform actions such as ADD, READ, UPDATE, and DELETE a SubtractveIntvalMeasurement.
This component invokes the D1-SubtractveIntvalMeasurement Business Object using the ATD1SystemIMDSubtrInterval Inbound Web Service.
D1-IntrvlChanTypPhysSubtractiv
Used to perform actions such as ADD, READ, UPDATE, and DELETE a IntrvlChanTypPhysSubtractiv.
This component invokes the D1-IntrvlChanTypPhysSubtractiv Business Object using the ATD1IntrvlChanTypPhysSubtractiv Inbound Web Service.
D1-IntervalChannelSubtractive
Used to perform actions such as ADD, READ, UPDATE, and DELETE a IntervalChannelSubtractive.
This component invokes the D1-IntervalChannelSubtractive Business Object using the ATD1IntervalChannelSubtractive Inbound Web Service.
X1-RetrieveDeviceConfigId
Used to retrieve Device Configuration ID.
This component invokes the ATX1RetrieveDeviceConfigID Inbound Web Service using the X1-RETDCFGID Business Service.
X1-RetrieveMesuringComponentId
Used to retrieve Measuring Component ID.
This component invokes the ATX1RetrieveMeasuringComponentId Inbound Web Service using D1-RETMEACID Business Service.
X1-CreateIntervalFunction
Used to add/create Override Interval Reads.
This component invokes the ATX1RCreateIntervalFunction Inbound Web Service using D2-OvrIntBck Service Script.
SSN Admin Data
Component
Description
D7-AddMeterReadJobIntervalType
Used to perform actions such as ADD, READ, UPDATE and DELETE a SSN - Add Meter Read Job (Interval) Type outbound communication type.
This component invokes the D7- AddMeterReadJobIntervalType Business Object using the ATD7AddMeterReadJobIntervalType Inbound Web Service.
D7-GetJobStatusDRPType
Used to perform actions such as ADD, READ, UPDATE, and DELETE a GetJobStatusDRPType record.
This component is invoked using the ATD7GetJobStatusDRPType Inbound Web Service.
D7-AddMeterReadJobScalrDRPType
Used to perform actions such as ADD, READ, UPDATE and DELETE a AddMeterReadJobScalrDRPType record.
This component is invoked using ATD7AddMeterReadJobScalrDRPType Inbound Web Service.
D7-AddMeterReadJobScalarType
Used to perform actions such as ADD, READ, UPDATE and DELETE a SSN - Add Meter Read Job (Scalar) Type outbound communication type.
This component invokes the D7- AddMeterReadJobScalarType Business Object using the ATD7AddMeterReadJobScalarType Inbound Web Service.
D7-MeterReadInterRespType
UPDATE and DELETE a SSN - Meter Read Response (Interval) Type inbound communication type.
This component invokes the D7- MeterReadInterRespType Business Object using the ATD7MeterReadInterRespType Inbound Web Service.
D7-MeterReadRespScalarType
Used to perform actions such as ADD, READ, UPDATE and DELETE a SSN - Meter Read Response (Scalar) Type inbound communication type.
This component invokes the D7- MeterReadRespScalarType Business Object using the ATD7MeterReadRespScalarType Inbound Web Service.
D7-DeviceEventMappingLookup
Used to perform actions such as ADD, READ, UPDATE and DELETE a Value for SSN Device Event Mapping extendable lookup.
This component invokes the D7- DeviceEventMappingLookup Business Object using the ATD7DeviceEventMappingLookup Inbound Web Service.
D7-DataTimeZoneLookup
Used to perform actions such as ADD, READ, UPDATE and DELETE a Value for SSN Data Time Zone extendable lookup.
This component invokes the D7- DataTimeZoneLookup Business Object using the ATD7DataTimeZoneLookup Inbound Web Service.
D7-AddPingJobType
Used to perform actions such as ADD, READ, UPDATE and DELETE of an SSN Add Ping Job Type record.
This component invokes the D7-AddPingJobType Business Object using the ATD7AddPingJobType Inbound Web Service.
D7-DeviceStatusLookup
Used to perform actions such as ADD, READ, UPDATE and DELETE of an SSN Device Status record.
This component invokes the D7- DeviceStatusLookup Business Object using the ATD7DeviceStatusLookup Inbound Web Service.
D7-ExecutionStatusLookup
Used to perform actions such as ADD, READ, UPDATE and DELETE of an SSN Execution Status record.
This component invokes the D7- ExecutionStatusLookup Business Object using the ATD7ExecutionStatusLookup Inbound Web Service.
D7-GetStatusResponseType
Used to perform actions such as ADD, READ, UPDATE and DELETE of an SSN Get Status Response Type record.
This component invokes the D7- GetStatusResponseType Business Object using the ATD7GetStatusResponseType Inbound Web Service.
D7-GetStatusType
Used to perform actions such as ADD, READ, UPDATE and DELETE of an SSN Get Status Type record.
This component invokes the D7-GetStatusType Business Object using the ATD7GetStatusType Inbound Web Service.
D7-PingJobRespType
Used to perform actions such as ADD, READ, UPDATE and DELETE of an SSN Ping Job Response Type record.
This component invokes the D7-PingJobRespType Business Object using the ATD7PingJobRespType Inbound Web Service.
D7-PriorityLookup
Used to perform actions such as ADD, READ, UPDATE and DELETE of an SSN Priority record.
This component invokes the D7-PriorityLookup Business Object using the ATD7PriorityLookup Inbound Web Service.
D7-ProvisioningActionLookup
Used to perform actions such as ADD, READ, UPDATE and DELETE of an SSN Provisioning Action record.
This component invokes the D7- ProvisioningActionLookup Business Object using the ATD7ProvisioningActionLookup Inbound Web Service.
D7-ProvisioningCommandStatus
Used to perform actions such as ADD, READ, UPDATE and DELETE of an SSN Provisioning Command Status record.
This component invokes the D7- ProvisioningCommandStatus Business Object using the ATD7ProvisioningCommandStatus Inbound Web Service.
D7-ProvisioningDataType
UPDATE and DELETE of an SSN Provisioning Data Type record.
This component invokes the D7- ProvisioningDataType Business Object using the ATD7ProvisioningDataType Inbound Web Service.
D7-SSNVersionLookup
Used to perform actions such as ADD, READ, UPDATE and DELETE of an SSN SSN Version record.
This component invokes the D7- SSNVersionLookup Business Object using the ATD7SSNVersionLookup Inbound Web Service.
D7-StatusFlagNameLookup
Used to perform actions such as ADD, READ, UPDATE and DELETE of an SSN Status Flag Name record.
This component invokes the D7- StatusFlagNameLookup Business Object using the ATD7StatusFlagNameLookup Inbound Web Service.
D7-ChannelStatusLookup
Used to perform actions such as ADD, READ, and
UPDATE and DELETE a Channel Status Lookup for SSN adapter.
This component invokes the D7- ChannelStatusLookup Business Object using the ATD7ChannelStatusLookup Inbound Web Service.
D7-ConnectDisconRespType
Used to perform actions such as ADD, READ, and UPDATE and DELETE a Connect Disconnect Response Type for SSN adapter.
This component invokes the D7- ConnectDisconRespType Business Object using the ATD7ConnectDisconRespType Inbound Web Service.
D7-ConnectDisconnectType
UPDATE and DELETE a Connect Disconnect Type for SSN adapter.
This component invokes the D7- ConnectDisconType Business Object using the ATD7ConnectDisconType Inbound Web Service.
D7-HeadendSQILookup
Used to perform actions such as ADD, READ, and UPDATE and DELETE a Headend SQI Lookup for SSN adapter.
This component invokes the D7- HeadendSQILookup Business Object using the ATD7HeadendSQILookup Inbound Web Service.
D7-HeadendTOULookup
Used to perform actions such as ADD, READ, and UPDATE and DELETE a Headend TOU Lookup for SSN adapter.
This component invokes the D7- HeadendTOULookup Business Object using the ATD7HeadendTOULookup Inbound Web Service.
D7-HeadendUOMLookup
Used to perform actions such as ADD, READ, and UPDATE and DELETE a Headend UOM Lookup for SSN adapter.
This component invokes the D7- HeadendUOMLookup Business Object using the ATD7HeadendUOMLookup Inbound Web Service.
D7-IntStsCodeToCondMapLookup
Used to perform actions such as ADD, READ, and UPDATE and DELETE a IntStsCodeToCondMapLookup for SSN adapter.
This component invokes the D7- IntStsCodeToCondMapLookup Business Object using the ATD7IntStsCodeToCondMapLookup Inbound Web Service.
D7-IntervalStatusLookup
Used to perform actions such as ADD, READ, and UPDATE and DELETE a Interval Status Lookup for SSN adapter.
This component invokes the D7- IntervalStatusLookup Business Object using the ATD7IntervalStatusLookup Inbound Web Service.
D7-MeterConnectionStatusLookup
Used to perform actions such as ADD, READ, and UPDATE and DELETE a Meter Connection Status Lookup for SSN adapter.
This component invokes the D7- MeterConnectionStatusLookup Business Object using the ATD7MeterConnectionStatusLookup Inbound Web Service.
D7-MeterReadTypeLookup
Used to perform actions such as ADD, READ, and UPDATE and DELETE a Meter Read Type Lookup for SSN adapter.
This component invokes the D7- MeterReadTypeLookup Business Object using the ATD7MeterReadTypeLookup Inbound Web Service.
D7-OldAdminStateNameLookup
Used to perform actions such as ADD, READ, and UPDATE and DELETE an Old Admin State Name Lookup for SSN adapter.
This component invokes the D7- OldAdminStateNameLookup Business Object using the ATD7OldAdminStateNameLookup Inbound Web Service.
D7-ReadModeLookup
Used to perform actions such as ADD, READ, and UPDATE and DELETE a Read Mode Lookup for SSN adapter.
This component invokes the D7-ReadModeLookup Business Object using the ATD7ReadModeLookup Inbound Web Service.
D7-RegisterReadSourceLookup
Used to perform actions such as ADD, READ, and UPDATE and DELETE a Register Read Source Lookup for SSN adapter.
This component invokes the D7- RegisterReadSourceLookup Business Object using the ATD7RegisterReadSourceLookup Inbound Web Service.
D7-RegisterStatusLookup
UPDATE and DELETE a Register Status Lookup for SSN adapter.
This component invokes the D7- RegisterStatusLookup Business Object using the ATD7RegisterStatusLookup Inbound Web Service.
D7-
RepDeviceAtLocForDecommType
Used to perform actions such as ADD, READ, and UPDATE and DELETE a RepDeviceAtLocForDecommType for SSN adapter.
This component invokes the D7- RepDeviceAtLocForDecommType Business Object using the ATD7RepDeviceAtLocForDecommType Inbound Web Service.
D7-ReplaceLocationType
Used to perform actions such as ADD, READ, and UPDATE and DELETE a Replace Location Type for SSN adapter.
This component invokes the D7- ReplaceLocationType Business Object using the ATD7ReplaceLocationType Inbound Web Service.
D7-VersionMasterConfig
Used to perform actions such as ADD, READ, and UPDATE and DELETE a Version Master Configuration for SSN adapter.
This component invokes the D7- VersionMasterConfig Business Object using the ATD7VersionMasterConfig Inbound Web Service.
D7-AddMeterToHarness
Used to perform the AddMeterToHarness action to SSN test harness.
This component invokes the D7- AddMeterToHarness using the ATD7AddMeterToHarness Inbound Web Service.
D7-SetCommissionRequest
This component invokes the D7- SetCommissionRequest using the ATD7SetCommissionRequest Inbound Web Service.
D7-SetVoltage
Used to perform action set voltage on a SSN device in test harness.
This component invokes the D7- SetVoltage using the ATD7SetVoltage Inbound Web Service.
DG-GenericMasterConfig
Used to perform actions on GenericMasterConfig record.
This invokes DG-GenericMasterConfig using ATDGGenericMasterConfig IWS.
DG-HeadendUOMLookup
Used to perform actions on HeadendUOMLookup record.
This invokes DG-HeadendUOMLookup using ATDGHeadendUOMLookup IWS.
DG-CIMGetMtrReadScalarType
Used to perform actions on CIMGetMtrReadScalarType record.
This invokes DG-CIMGetMtrReadScalarType using ATDGCIMGetMtrReadScalarType IWS.
DG-CIMMtrReadResponseDRType
Used to perform actions on CIMMtrReadResponseDRType record.
This invokes DG-CIMMtrReadResponseDRType using ATDGCIMMtrReadResponseDRType IWS.
SSN Master Data
Component
Description
D7-InitialLoadIMDInterval
Used to ADD Initial Measurement Interval Data for SSN Adapter.
This component invokes the D7- InitialLoadIMDInterval Business Object using the ATD7InitialLoadIMDInterval Inbound Web Service.
D7-InitialLoadIMDScalar
Used to ADD Initial Measurement Scalar Data for SSN Adapter.
This component invokes the D7- InitialLoadIMDScalar Business Object using the ATD7InitialLoadIMDScalar Inbound Web Service.
D7-SmartMeter
Used to perform actions such as ADD, READ, and UPDATE and DELETE a Smart Meter for SSN adapter.
This component invokes the D7-SmartMeter Business Object using the ATD7SmartMeter Inbound Web Service.
Sales and Marketing
Component
Description
C1-CampaignAdd
Used to add a Campaign record.
This component invokes the ATC1Campaign Inbound Web Service using the C1-CampaignAdd Business Service.
C1-CampaignRead
Used to read a Campaign record.
This component invokes the ATC1Campaign Inbound Web Service using the C1-CampaignRead Business Service.
C1-CampaignUpdate
Used to update a Campaign record.
This component invokes the ATC1Campaign Inbound Web Service using the C1-Campaign Update Business Service.
C1-CampaignDelete
Used to delete a Campaign record.
This component invokes the ATC1Campaign Inbound Web Service using the C1-CampaignDelete Business Service.
C1-LeadAccountAdd
Used to add a Lead Account record.
This component invokes the ATC1LeadAccount Inbound Web Service using the C1-LeadAccount Business Object.
C1-LeadAccountRead
Used to read a Lead Account record.
C1-LeadAccountUpdate
Used to update a Lead Account record.
C1-LeadAccountDelete
Used to delete a Lead Account record.
C1-PackageAdd
Used to add a Package record.
This component invokes the ATC1PackageBS Inbound Web Service using the C1-PackageAdd Business Service.
C1-PackageRead
Used to read a Package record.
This component invokes the ATC1Package Inbound Web Service using the C1-PackagePhysical Business Object.
C1-PackageUpdate
Used to update a Package record.
This component invokes the ATC1PackageBS Inbound Web Service using the C1-PackagePhysical Business Service.
C1-PackageDelete
Used to delete a Package record.
C1-ThirdPartyRepAdd
Used to add a Third Party Representative record.
This component invokes the ATC1ThirdPartyRep Inbound Web Service using the C1- ThirdPartyRepresentative Business Object.
C1-ThirdPartyRepRead
Used to read a Third Party Representative record.
C1-ThirdPartyRepUpdate
Used to update a Third Party Representative record.
C1-ThirdPartyRepDelete
Used to delete a Third Party Representative record.
This component invokes the ATC1ThirdPartyRep Inbound Web Service using the C1-ThirdPartyRepresentative Business Object.
C1-SalesRepIndividualAdd
Used to add an Individual Sales Representative record.
This component invokes the ATC1SalesRepIndividual Inbound Web Service using the C1-SRpInPost Service Script.
C1-SalesRepIndividualRead
Used to read an Individual Sales Representative record.
This component invokes the ATC1SalesRepIndividualRead Inbound Web Service using the C1-SRInd Service Script.
C1-SalesRepIndividualUpdate
Used to update an Individual Sales Representative record.
C1-SalesRepIndividualDelete
Used to delete an Individual Sales Representative record.
C1-SalesRepGroupAdd
Used to add a Group Sales Representative record.
This component invokes the ATC1SalesRepGroup Inbound Web Service using the C1-SalesRepGroup Business Object.
C1-SalesRepGroupRead
Used to read a Group Sales Representative record.
This component invokes the ATC1SalesRepGroup Inbound Web Service using the C1-SalesRepGroup.
C1-SalesRepGroupUpdate
C1-SalesRepGroupDelete
This component invokes the ATC1SalesRepIndividual Inbound Web Service Business Object.
C1-SalesRepLogsAdd
Used to add a Sales Representative Log record.
This component invokes the ATC1SalesRepLogs Inbound Web Service using the C1-SalesRepLogs Business Object.
C1-SalesRepLogsRead
Used to read a Sales Representative Log record.
C1-CampaignInitiativeAdd
Used to add a Campaign Initiative record.
This component invokes the ATC1CampaignInitiative Inbound Web Service using the C1-InitiativeService Business Object.
C1-CampaignInitiativeRead
Used to read a Campaign Initiative record.
C1-CampaignInitiativeUpdate
Used to update a Campaign Initiative record.
C1-CampaignInitiativeDelete
Used to delete a Campaign Initiative record.
C1-ContractOptInitiativeAdd
Used to add a Contract Option Initiative record.
This component invokes the ATC1ContractOptInitiative Inbound Web Service using the C1-InitiativeService Business Object.
C1-ContractOptInitiativeRead
Used to read a Contract Option Initiative record.
C1-ContractOptinitiativeUpdate
Used to update a Contract Option Initiative record.
C1-ContractOptInitiativeDelete
Used to delete a Contract Option Initiative record.
C1-ConservationInitiativeAdd
Used to add a Conservation Initiative record.
This component invokes the ATC1ConservationInitiative Inbound Web Service using the C1-InitiativeConservationProg Business Object.
C1-ConservationInitiativeRead
Used to read a Conservation Initiative record.
C1-ConservationinitiativeUpd
Used to update a Conservation Initiative record.
C1-ConservationInitiativeDel
Used to delete a Conservation Initiative record.
C1-InitiativeLogsRead
Used to read an Initiative Log record.
This component invokes the ATC1InitiativeLogs Inbound Web Service using the C1-InitiativeLogs Business Object.
C1-InitiativeLogsAdd
Used to add an Initiative Log record.
C1-MyLeads
Used to get the representative link to the user.
This component also retrieves all group representatives linked to the representative. This component invokes the ATC1MyLead Inbound Web Service using the C1-MyLead Service Script.
C1-LeadQuery
Used to get the lead details depending on the search group used, by filling up the correct schema group.
This component invokes the ATC1LeadQuery Inbound Web Service using the C1-LeadQuery Business Service.
C1-InitiativeQuery
Used to get the initiative details based on the C1-INTVQ1 zone.
This component invokes the ATC1InitiativeQuery Inbound Web Service using the C1-InitiativeQuery Business Service.
C1-LeadAdd
Used to create a Lead record.
This component invokes the ATC1LeadAdd Inbound Web Service using the C1LeadPhysical Business Object.
C1-LeadRead
Used to read a Lead record.
This component invokes the ATC1Lead Inbound Web Service using the C1LeadPhysical Business Object.
C1-LeadUpdate
Used to update a Lead record.
C1-LeadDelete
Used to delete a Lead record.
C1-LeadEventAdd
Used to create a Lead Event record.
This component invokes the ATC1LeadEvent Web Service using the C1LeadPhysical Business Object.
C1-LeadEventRead
Used to read a Lead Event record.
C1-LeadEventUpdate
Used to update a Lead Event record.
C1-OrderAdd
Used to create an Order record.
This component invokes the ATC1Order Inbound Web Service using the C1OrderAdd Business Service.
C1-OrderRead
Used to read an existing Order record.
This component invokes the ATC1Order Inbound Web Service using the C1OrderRead Business Service.
C1-OrderUpdate
Used to update an existing Order record.
This component invokes the ATC1Order Inbound Web Service using the C1OrderUpdate Business Service.
C1-QuoteAdd
Used to create a Quote record.
This component invokes the ATC1Quote Inbound Web Service using the C1QuoteAdd Business Service.
C1- QuoteRead
C1-QuoteUpdate
Used to update a Quote record.
C1-QuoteDelete
Used to delete a Quote record.
Self Service
Component
Description
C1-RetrieveServiceTask
Used to retrieve Service Task record.
This component invokes the ATC1RetrieveServiceTask Inbound Web Service using the C1-RETSVCTSK Business Service.
C1-
ThirdPartyAcctVerificationTaskRead
Used to read a Third Party Account Verification Task.
This component invokes the ATC1ThirdPartyAcctVerifTask Inbound Web Service using the C1-ThirdPartyAcctVerifTaskRead Business Object.
C1-StartServiceRequestSAAdd
Used to add a Start Service Request SA record.
This component invokes the ATC1StartServiceRequestSA Inbound Web Service using the C1-StartServiceRequestSA Business Object.
C1-StartServiceRequestSADelete
Used to delete a Start Service Request SA record.
C1-StartServiceRequestSARead
Used to read a Start Service Request SA record.
C1-StartServiceRequestSAUpdate
Used to update a Start Service Request SA record.
C1-StopServiceRequestSAAdd
Used to add a Stop Service Request SA record.
This component invokes the ATC1StopServiceRequestSA Inbound Web Service using the C1-StopServiceRequestSA Business Object.
C1-StopServiceRequestSADelete
Used to delete a Stop Service Request SA record.
C1-StopServiceRequestSAUpdate
Used to update a Stop Service Request SA record.
C1-StopServiceRequestSARead
Used to read a Stop Service Request SA record.
C1-SSStartStopXferServiceTaskAdd
Used to add a Start Stop Transfer Service Task.
This component invokes the ATC1SSStartStopXferServiceTask Inbound Web Service using the C1-SSStartStopXferServiceTask Business Object.
C1-SSStartStopXferServiceTaskDelete
Used to delete a Start Stop Transfer Service Task.
C1-SSStartStopXferServiceTaskRead
Used to read a Start Stop Transfer Service Task.
C1-SSStartStopXferServiceTaskUpdate
Used to update a Start Stop Transfer Service Task.
C1-SSAddServiceRequestTypeAdd
Used to add Self-Service Add Service Request Type.
This component invokes the ATC1-SSAddServiceRequestType Inbound Web Service using the C1-SSAddServiceRequestType Business Object.
C1-SSAddServiceRequestTypeDelete
Used to delete Self-Service Add Service Request Type.
C1-SSAddServiceRequestTypeRead
Used to read Self-Service Add Service Request Type.
C1-SSAddServiceRequestTypeUpdate
Used to update Self-Service Add Service Request Type.
C1-SSNewServiceRequestTypeAdd
Used to add Self-Service New Service Request Type.
This component invokes the ATC1-SSNewServiceRequestType Inbound Web Service using the C1-SSNewServiceRequestType Business Object.
C1-SSNewServiceRequestTypeDelete
Used to delete Self-Service New Service Request Type.
C1-SSNewServiceRequestTypeRead
Used to read Self-Service New Service Request Type.
C1-SSNewServiceRequestTypeUpdate
Used to update Self-Service New Service Request Type.
C1-SSStopServiceRequestTypeAdd
Used to add Self-Service Stop Service Request Type.
This component invokes the ATC1-SSStopServiceRequestType Inbound Web Service using the C1-SSStopServiceRequestType Business Object.
C1-SSStopServiceRequestTypeDelete
Used to delete Self-Service Stop Service Request Type.
C1-SSStopServiceRequestTypeRead
Used to read Self-Service Stop Service Request Type.
C1-SSStopServiceRequestTypeUpdate
Used to Update Self-Service Stop Service Request Type.
C1-SSTransferServiceReqTypeAdd
Used to add Self-Service Transfer Service Request Type.
This component invokes the ATC1-SSTransferServiceReqType Inbound Web Service using the C1-SSTransferServiceReqType Business Object.
C1-SSTransferServiceReqTypeDelete
Used to delete Self-Service Transfer Service Request Type.
C1-SSTransferServiceReqTypeRead
Used to read Self-Service Transfer Service Request Type.
C1-SSTransferServiceReqTypeUpdate
Used to update Self-Service Transfer Service Request Type.
C1-ThirdPartyAutoPaySetupAdd
Used to add a Third Party Auto Pay Setup.
This component invokes the ATC1ThirdPartyAutoPaySetup Inbound Web Service using the C1-TPApaySet Service Script.
C1-ThirdPartyAutoPaySetupCancel
Used to cancel a Third Party Auto Pay Setup.
C1-OneTimePaymentTaskRead
Used to read a One Time Payment Service Task.
This component invokes the ATC1OneTimePaymentTask Inbound Web Service using the WX-OneTimePayTask Business Object.
C1-CCBOneTimeTaskTypeAdd
Used for adding a One Time Task Type record.
This component invokes the ATC1CCBOneTimePaymentTaskType Inbound Web Service using the C1-OneTimePaymentTaskType Business Object.
C1-CCBOneTimeTaskTypeDelete
Used for deleting a One Time Task Type record.
C1-CCBOneTimeTaskTypeRead
Used for reading a One Time Task Type record.
C1-CCBOneTimeTaskTypeUpdate
Used for updating a One Time Task Type record.
C1-SSStartStopXferServiceTaskTypeAdd
Used for adding Start Stop Transfer Service Task Type.
This component invokes the ATC1SSStartStopXferSvcTaskType Inbound Web Service using the C1-SSStartStopXferSvcTaskType Business Object.
Delete
Used for deleting Start Stop Transfer Service Task Type.
C1-SSStartStopXferServiceTaskTypeRead
Used for reading Start Stop Transfer Service Task Type.
C1-ThirdPartyAutoPaySetupUpdate
C1-AutoPayTaskRead
Used to read an Auto Pay Setup Service Task.
This component invokes the ATC1AutoPayTask Inbound Web Service using the WX-AutoPayTask Business Object.
C1-ThirdPartyAutoPayTaskRead
Used to read a Third Party Auto Pay Task.
This component invokes the ATC1ThirdPartyAutoPayTask Inbound Web Service using the C1-ThirdPartyAutoPayTask Business Object.
C1-OneTimePaymentTaskAdd
Used to add One Time Payment Service Task.
This component invokes the WXMakePayment Inbound Web Service using the WX-OneTimePayTask Business Object.
C1-ThirdPartyOneTimePayNotifAdd
Used to add a Third Party One Time Payment.
This component invokes the ATC1ThirdPartyPaymntIntegration Inbound Web Service using the C1-TPPayNotf Service Script.
Sensus Admin Data
Component
Description
D6-DeviceEventMappingLookup
Used to perform actions such as ADD, READ, UPDATE and DELETE a Value for Sensus Device Event Mapping extendable lookup.
This component invokes the D6-DeviceEventMappingLookup Business Object using the ATD6DeviceEventMappingLookup Inbound Web Service.
D6-HeadendUOMLookup
Used to perform actions such as ADD, READ, UPDATE and DELETE a Value for Sensus UOM Code to Standard UOM Mapping extendable lookup.
This component invokes the D6-HeadendUOMLookup Business Object using the ATD6HeadendUOMLookup Inbound Web Service.
D6-InitiateMeterByMeterIdType
Used to perform actions such as ADD, READ, UPDATE and DELETE a Sensus -Initiate Meter Read By Meter ID outbound communication type.
This component invokes the D6-InitiateMeterByMeterIdType Business Object using the ATD6InitiateMeterByMeterIdType Inbound Web Service.
D6-ReadingChgNotificationType
Used to perform actions such as ADD, READ, UPDATE and DELETE a Sensus - Reading Change Notification inbound communication type.
This component invokes the D6-ReadingChgNotificationType Business Object using the ATD6ReadingChgNotificationType Inbound Web Service.
D6-SensusMasterConfig
Used to perform actions such as ADD, READ, UPDATE and DELETE a Sensus Master Configuration.
This component invokes the D6- SensusMasterConfig Business Object using the ATD6SensusMasterConfig Inbound Web Service.
D6-CDCodeReasonLookup
Used to perform actions such as ADD, READ, UPDATE and DELETE of a Sensus CD Reason Code record.
This component invokes the D6-CDCodeReasonLookup Business Object using the ATD6CDCodeReasonLookup Inbound Web Service.
D6-InitiateOutageDetectionType
Used to perform actions such as ADD, READ, UPDATE and DELETE of a Sensus Intitiate Outage Detection Type record.
This component invokes the D6-InitiateOutageDetectionType Business Object using the ATD6InitiateOutageDetectionType Inbound Web Service.
D6-OutageDetectEvtNotifType
Used to perform actions such as ADD, READ, UPDATE and DELETE of a Sensus Outage Detection Event Notification Type record.
This component invokes the D6-OutageDetectEvtNotifType Business Object using the ATD6OutageDetectEvtNotifType Inbound Web Service.
D6-UnsolicitedEventNotifType
Used to perform actions such as ADD, READ, UPDATE and DELETE of a Sensus Unsolicited Event Notification Type record.
This component invokes the D6-UnsolicitedEventNotifType Business Object using the ATD6UnsolicitedEventNotifType Inbound Web Service.
D6-ConnectDisconStateChgNtfTyp
Used to perform actions such as ADD, READ, and UPDATE and DELETE a Connect Disconnect State Change Notify Type for Sensus adapter.
This component invokes the D6-ConnectDisconStateChgNtfTyp Business Object using the ATD6ConnectDisconStateChgNtfTyp Inbound Web Service.
D6-InitiateConnectDisconType
Used to perform actions such as ADD, READ, and UPDATE and DELETE a Initiate Connect Disconnect Type for Sensus adapter.
This component invokes the D6- InitiateConnectDisconType Business Object using the ATD6InitiateConnectDisconType Inbound Web Service.
D6-IntStsCodeToCondMapLookup
Used to perform actions such as ADD, READ, and UPDATE and DELETE a IntStsCodeToCondMapLookup for Sensus adapter.
This component invokes the D6-IntStsCodeToCondMapLookup Business Object using the ATD6IntStsCodeToCondMapLookup Inbound Web Service.
D6-LoadActionCodeLookup
Used to perform actions such as ADD, READ, and UPDATE and DELETE a Load Action Code Lookup for Sensus adapter.
This component invokes the D6- LoadActionCodeLookup Business Object using the ATD6LoadActionCodeLookup Inbound Web Service.
D6-MeterAddNotificationType
Used to perform actions such as ADD, READ, and UPDATE and DELETE a Meter Add Notification Type for Sensus adapter.
This component invokes the D6- MeterAddNotificationType Business Object using the ATD6MeterAddNotificationType Inbound Web Service.
D6-MeterRemoveNotifType
Used to perform actions such as ADD, READ, and UPDATE and DELETE a Meter Remove Notify Type for Sensus adapter.
This component invokes the D6-MeterRemoveNotifType Business Object using the ATD6MeterRemoveNotifType Inbound Web Service.
D6-OutageEventTypeLookup
Used to perform actions such as ADD, READ, and UPDATE and DELETE a Outage Event Type Lookup for Sensus adapter.
This component invokes the D6-OutageEventTypeLookup Business Object using the ATD6OutageEventTypeLookup Inbound Web Service.
D6-SensusTimeUnits
This component can be used to perform actions such as ADD, READ, and UPDATE and DELETE a Sensus Time Units for Sensus adapter.
This component invokes the D6-SensusTimeUnits Business Object using the ATD6SensusTimeUnits Inbound Web Service.
D6-ServiceTypeMappingLookup
Used to perform actions such as ADD, READ, and UPDATE and DELETE a Service Type Mapping Lookup for Sensus adapter.
This component invokes the D6-ServiceTypeMappingLookup Business Object using the ATD6ServiceTypeMappingLookup Inbound Web Service.
D6-AddMeterToHarness
Used to perform the AddMeterToHarness action to Sensus test harness.
This component invokes the D6-AddMeterToHarness Business Object using the ATD6AddMeterToHarness Inbound Web Service.
D6-RemoveMeter
Used to perform the remove meter action from Sensus test harness.
This component invokes the D6-RemoveMeter using the ATD6RemoveMeter Inbound Web Service.
Sensus Master Data
Component
Description
D6-InitialLoadIMDInterval
Used to ADD Initial Measurement Interval Data for Sensus adapter.
This component invokes the D6- InitialLoadIMDInterval Business Object using the ATD6InitialLoadIMDInterval Inbound Web Service.
D6-InitialLoadIMDScalar
Used to ADD Initial Measurement Scalar Data for Sensus adapter.
This component invokes the D6- InitialLoadIMDScalar Business Object using the ATD6InitialLoadIMDScalar Inbound Web Service.
D6-SmartMeter
This component can be used to perform actions such as ADD, READ, and UPDATE and DELETE a Smart Meter for Sensus adapter.
This component invokes the D6-SmartMeter Business Object using the ATD6SmartMeter Inbound Web Service.
Service Order Management
Component
Description
C1-ActivityInformation
Used to read an Activity Information.
This component invokes the ATC1ActivityInformation Inbound Web Service using the C1-ActvtyInf Service Script.
C1-DeviceInformation
Used to retrieving the Device Information.
This component invokes the ATC1DeviceInformation Inbound Web Service using the C1-DeviceInf Service Script.
C1-FACompletionMessage
Used for the FA Completion Message.
This component invokes the ATC1FACompletionMessage Inbound Web Service using the C1-FACmplMsg Service Script.
C1-PremiseFAGTT
Used for inserting the Premise Activities to GTT.
This component invokes the ATC1PremFAGTT Inbound Web Service using the C1-PremFAGTT Service Script.
C1-ServiceRequestUpdate
Used for updating a SOM Request.
This component invokes the ATC1ServiceRequestUpdate Inbound Web Service using the C1-SvcReqUpd Service Script.
Service Task Type
Component
Description
C1-OutageCallTypeAdd
Used to add an Outage Call Type record.
This component invokes the ATC1OutageCallType Inbound Web Service using the C1-OutageCallType Business Object.
C1-OutageCallTypeRead
Used to read an Outage Call Type record.
C1-OutageCallTypeUpdate
Used to update an Outage Call Type record.
C1-OutageCallTypeDelete
Used to delete an Outage Call Type record.
C1-ThirdPartyAcctVerifTaskTypeAdd
Used to add a Third Party Account Verification Task Type.
This component invokes the ATC1ThirdPartyAcctVerificationTaskType Inbound Web Service using the C1- ThirdPartyAcctVerifTaskType Business Object.
C1-
ThirdPartyAcctVerifTaskTypeDelete
Used to delete a Third Party Account Verification Task Type.
C1-ThirdPartyAcctVerifTaskTypeRead
Used to read a Third Party Account Verification Task Type.
C1-ThirdPartyAcctVerifTaskTypeUpdate
Used to update a Third Party Account Verification Task Type.
C1-ThirdPartyAutoPayTaskTypeAdd
Used to add a Third Party Auto Pay Task Type.
This component invokes the ATC1ThirdPartyAutoPayTaskType Inbound Web Service using the C1-ThirdPartyAutoPayTaskType Business Object.
C1-
ThirdPartyAutoPayTaskTypeDelete
Used to delete a Third Party Auto Pay Task Type.
C1-ThirdPartyAutoPayTaskTypeRead
Used to read a Third Party Auto Pay Task Type.
C1-
ThirdPartyAutoPayTaskTypeUpdate
Used to update a Third Party Auto Pay Task Type.
C1-
ThirdPartyOneTimePayTaskTypeAdd
Used to add a Third Party One Time Payment Task Type.
This component invokes the ATC1ThirdPartyOneTimePyTaskType Inbound Web Service using the C1- ThirdPartyOneTimePyTaskType Business Object.
C1-ThirdPartyOneTimePayTaskType
Delete
Used to delete a Third Party One Time Payment Task Type.
C1-ThirdPartyOneTimePayTaskTypeRead
Update
Used to update a Third Party One Time Payment Task Type.
This component invokes the ATC1ThirdPartyOneTimePyTaskType Inbound Web Service using the C1-ThirdPartyOneTimePyTaskType Business Object.
C1-AutoPayTaskTypeAdd
Used to add an Auto Pay Task Type.
This component invokes the ATC1AutoPayTaskType Inbound Web Service using the WX-AutoPayTaskType Business Object.
C1-AutoPayTaskTypeDelete
Used to delete an Auto Pay Task Type.
C1-AutoPayTaskTypeRead
Used to read an Auto Pay Task Type.
C1-AutoPayTaskTypeUpdate
Used to update an Auto Pay Task Type.
C1-OneTimePaymentTaskTypeAdd
Used to add a One Time Payment Task Type.
This component invokes the ATC1OneTimePaymentTaskType Inbound Web Service using the WX-OneTimePayTaskType Business Object.
C1-OneTimePaymentTaskTypeDelete
Used to delete a One Time Payment Task Type.
C1-OneTimePaymentTaskTypeRead
Used to read a One Time Payment Task Type.
C1-OneTimePaymentTaskTypeUpdate
Used to update a One Time Payment Task Type.
C1-BankAcctApaySetupTaskTypeAdd
Used to add a Bank Account Auto Pay Set Up Task Type.
This component invokes the ATC1BankAcctApaySetupTaskType Inbound Web Service using the C1-BankAcctApaySetupTaskType Business Object.
C1-BankAcctApaySetupTaskTypeRead
Used to read a Bank Account Auto Pay Set Up Task Type.
C1-BankAcctApaySetupTaskTypeUpdate
Used to update a Bank Account Auto Pay Set Up Task Type.
C1-BankAcctApaySetupTaskTypeDelete
Used to delete a Bank Account Auto Pay Setup Task Type.
Contract and Products
Component
Description
C1-ConsumerContractAdd
Used to add a Consumer Contract.
This component invokes the ATC1ConsumerContract Inbound Web Service using the C1-ConsumerContract Business Object.
C1-ConsumerContractDelete
Used to delete a Consumer Contract.
C1-ConsumerContractRead
Used to read a Consumer Contract.
C1-ConsumerContractUpdate
Used to update a Consumer Contract.
C1-GetCSRContract
Used for retrieving the Contract ID from Customer Service Request Contract.
This component invokes the ATC1GetCSRContract Inbound Web Service using the C1-GETCSRCON Business Service.
C1-GetCSRContractProduct
Used for retrieving the Contract Product ID from Customer Service Request Contract.
This component invokes the ATC1GetCSRProduct Inbound Web Service using the C1-GETCSRPRO Business Service.
C1-CSRPersonAdd
Used for Customer Service Request Person Add.
This component invokes the ATC1CSRPerson Inbound Web Service using the C1-ContractChangeReqPersnBasic Business Object.
C1-CSRPersonDelete
Used for Customer Service Request Person Delete.
C1-CSRPersonRead
Used for Customer Service Request Person Read.
C1-CSRPersonUpdate
Used for Customer Service Request Person Update.
C1-CSRProductRead
Used for retrieving the Product ID from Customer Service Request Product.
C1-GetCSRPerson
Used for retrieving the Person ID from Customer Service Request Person.
This component invokes the ATC1GetCSRPerson Inbound Web Service using the C1-GETCSRPER Business Service.
C1-CSRAccountAdd
Used for Customer Service Request Account Add.
This component invokes the ATC1CSRAccount Inbound Web Service using the C1-ContractChngeReqAccntBasic Business Object.
C1-CSRAccountDelete
Used for Customer Service Request Account Delete.
C1-CSRAccountRead
Used for Customer Service Request Account Read.
C1-CSRAccountUpdate
Used for Customer Service Request Account Update.
This component invokes the ATC1CSRAccount Inbound Web Service using the C1-ContractChangeReqPersnBasic Business Object.
C1-CSRPremiseAdd
Used for Customer Service Request Premise Add.
This component invokes the ATC1CSRPremise Inbound Web Service using the C1-ContrctChngeReqPremiseBasic Business Object.
C1-CSRPremiseDelete
Used for Customer Service Request Premise Delete.
C1-CSRPremiseRead
Used for Customer Service Request Premise Read.
C1-CSRPremiseUpdate
Used for Customer Service Request Premise Update.
C1-GetCSRPremise
Used for retrieving the Premise ID from Customer Service Request Premise.
This component invokes the ATC1GetCSRPremise Inbound Web Service using the C1-GETCSRPRE Business Service.
C1-AddCSR
Used for adding a Customer Service Request record.
This component invokes the ATC1CreateCSR Inbound Web Service using the C1-AddCoChRe Service Script.
C1-CSRContractAdd
Used for Customer Service Request for Contract Add.
This component invokes the ATC1CSRContract Inbound Web Service using the C1-ContractChangeReqContRoot Business Object.
C1-CSRContractDelete
Used for Customer Service Request for Contract Delete.
C1-CSRContractRead
C1-CSRContractUpdate
Used for Customer Service Request for Contract Update.
C1-CSRContractProductDelete
Used for Customer Service Request for Contract Product Delete.
This component invokes the ATC1CSRContractProduct Inbound Web Service using the C1-ContractChangeReqCnProdRoot Business Object.
C1-CSRContractProductRead
C1-CSRContractProductUpdate
C1-GetCSRAccount
Used for retrieving the Account ID from Customer Service Request Person.
This component invokes the ATC1GetCSRAccount Inbound Web Service using the C1-GETCSRACC Business Service.
C1-CSRContractProductAdd
Used for Customer Service Request for Contract Product Add.
C1-CSRServiceLocationMktProcAdd
Used for Customer Service Request for Service Location Market Process Add.
This component invokes the ATC1CSRServiceLocationMktProc Inbound Web Service using the C1-CsrSvcLocMarketProcessRoot Business Object.
C1-CSRServiceLocationMktProcDelete
Used for Customer Service Request for Service Location Market Process Delete.
C1-CSRServiceLocationMktProcRead
Used for Customer Service Request for Service Location Market Process Read.
C1-CSRServiceLocationMktProcUpdate
Used for Customer Service Request for Service Location Market Process Update.
C1-GetCSRServiceLocation
Used for Update Service Location.
This component invokes the ATC1GetCSRServiceLocation Inbound Web Service using the C1-GETCSRSER Business Service.
C1-GetBOStatus
This business service receives a maintenance object code and primary key(s) and returns its business object along with its lifecycle business object and current status, if applicable.
This component invokes the ATC1GetBOStatus Inbound Web Service using the F1-DetermineBo Business Service.
C1-RegistrationPointAdd
Used to Add Registration Point.
This component invokes the ATC1RegistrationPoint Inbound Web Service using the C1-RegistrationPoint Business Object.
C1-RegistrationPointDelete
Used to Delete Registration Point.
C1-RegistrationPointRead
Used to Read Registration Point.
C1-RegistrationPointUpdate
Used to Update Registration Point.
C1-ContractChangeRequestAdd
Used to Add Contract Change Request.
This component invokes the ATC1ContractChangeRequest Inbound Web Service using the C1-ContractChangeRequest Business Object.
C1-ContractChangeRequestDelete
Used to Delete Contract Change Request.
C1-ContractChangeRequestRead
Used to Read Contract Change Request.
C1-ContractChangeRequestUpdate
Used to Update Contract Change Request.
C1-GetEligibleProductContractType
Used for retrieving the list of Eligible Products for a Contract Type.
This component invokes the ATC1GetEligibleProduct Inbound Web Service using the C1-RetElPdCT Business Service.
C1-GetProdAttributeContract
Used for retrieving the product attributes for a Contract.
This component invokes the ATC1GetProdAttributeContract Inbound Web Service using the C1-RePrAttCt Service Script.
C1-GetProductAttributes
Used for retrieving the product attributes for Operand Values.
This component invokes the ATC1ProdAttOperandValues Inbound Web Service using the C1-RetPAttOV Service Script.
C1-TransitionBOStatus
Used to transition Business Object status.
This component invokes the ATC1TransitionBOStatus Inbound Web Service using the C1-TransitBO Service Script.
Umbrella Agreement
Component
Description
C1-UmbrellaAgreementAdd
Used to create an Umbrella Agreement record.
This component invokes the ATC1UmbrellaAgreement Inbound Web Service using the C1UmbrellaAgreementPhysical Business Object.
C1-UmbrellaAgreementRead
Used to read an existing Umbrella Agreement record.
C1-UmbrellaAgreementUpdate
Used to update an existing Umbrella Agreement record.
This component invokes the ATC1UmbrellaAgreement Inbound Web Service using the C1UmbrellaAgreementUpdate Business Object.
C1-UmbrellaAgreementDelete
Used to delete an existing Umbrella Agreement record.
C1-TermsOfServiceAdd
Used to create a Terms of Service record.
This component invokes the ATC1TermsOfService Inbound Web Service using the C1TermsOfServicePhysical Business Object.
C1-TermsOfServiceRead
Used to read an existing Terms of Service record.
C1-TermsOfServiceUpdate
Used to update an existing Terms of Service record.
This component invokes the ATC1TermsOfService Inbound Web Service using the C1TermsOfServiceUpdate Business Service.
C1-TermsOfServiceDelete
Used to delete an existing Terms of Service record.
Usage
Component
Description
C1-GetUsageId
Used to get the usage request ID of given a person name.
This component invokes the ATC1GetUsageId Inbound Web Service using the C1-GetUsageId Business Service.
C1-UsageReqCyclicalBillingRead
Used to read a Usage Request Cyclical Billing record.
This component invokes the ATC1UsageReqCyclicalBillingRead Inbound Web Service using the C1-UsageRequestCyclicalBilling Business Object.
C1-UsageRequestNonCyclicalRead
Used to read a Usage Request Non-Cyclical Billing record.
This component invokes the ATC1UsageRequestNonCyclical Inbound Web Service using the C1-UsageRequestNonCyclical Business Object.
X1-UsageAndChargeRequestAdd
Used to add a Usage and Charge Request record.
This component invokes the ATX1UsageAndChargeRequest Inbound Web Service using the X1-UsageAndChargeRequest Business Object.
X1-UsageAndChargeRequestDelete
Used to delete a Usage and Charge Request record.
X1-UsageAndChargeRequestRead
Used to read a Usage and Charge Request record.
X1-UsageAndChargeRequestUpdate
Used to update a Usage and Charge Request record.
X1-VectorMathNonMeterAdd
This component invokes the ATX1VectorMathNonMeter Inbound Web Service using the X1-VectorMathNonMeter Business Object.
X1-VectorMathNonMeterDelete
X1-VectorMathNonMeterRead
X1-VectorMathNonMeterUpdate
CX REST API
Component
Description
C1-AccountDataRestIWS
Used to get an Account Financial Data.
This component invokes the C1-AccountData Inbound Web Service using the C1FinDetails Service Script.
C1-ActionBudgetRestIWS
Used to update Budget.
This component invokes the C1-Budget Inbound Web Service using the C1BudgetData Service Script.
D1-InstallEventIWS
Used to get an Install event.
This component invokes the D1-GtInstEve Service Script using the D1-InstallEvent Inbound Web Service.
C1-ActionCutProcessRestIWS
Used to update Cut process.
This component invokes the C1-CutProcess Inbound Web Service using the C1CutProcess Service Script.
C1-ActionOverdueProcessRestIWS
Used to update Overdue process.
This component invokes the C1-OverdueProcess Inbound Web Service using the C1OverduePro Service Script.
C1-AdjustmentSummaryRestIWS
Used to retrieve Adjustment Summary.
This component invokes the C1-Adjustment Inbound Web Service using the C1AdjSumry Service Script.
C1-BillSegmentSummaryRestIWS
Used to retrieve Bill Segment Summary.
This component invokes the C1-BillSegment Inbound Web Service using the C1BilSegSmry Service Script.
C1-ExpandTreeRestIWS
Used to Expand Tree.
This component invokes the F1-ExpandTree Inbound Web Service using the F1-ExpandTree Service Script.
C1-MultiAccountStatisticsRestIWS
Used to Get Multi Account Statistics.
This component invokes the C1-AccountData Inbound Web Service using the C1FinStats Service Script.
C1-MultiAccountUsageSummaryRestIWS
Used to Get Multi Account Usage Summary.
This component invokes the C1-BilledUsageData Inbound Web Service using the C1MlAcUsgSum Service Script.
C1-PaymentSummaryRestIWS
Used to Retrieve the Payment Summary.
This component invokes the C1-Payment Inbound Web Service using the C1-UpdPymt Service Script.
C1-PersonSearchRestIWS
Used to search a Person.
This component invokes the C1-PersonSearch Inbound Web Service using the C1PersonSrch Service Script.
C1-SearchAccountPremisesRestIWS
Used to Search Account Premises.
This component invokes the C1-BillingContext Inbound web Service using the C1-GetPremAcc Service Script.
C1-ServiceAgreementSearchRestIWS
Used to search for Service Agreement.
This component invokes the C1-ServiceAgreement Inbound Web Service using the C1SASearhSer Service Script.
C1-BillSearchRestIWS
Used to search Bill.
This component invokes the C1-Bill Inbound Web Service using the C1BillsForAc Service Script.
C1-BillSegmentsSearchRestIWS
Used to search Bill Segment.
This component invokes the C1-BillSegment Inbound Web Service using the C1BilSegSrch Service Script.
C1-BillSummaryRestIWS
Used to get Bill Summary.
This component invokes the C1-Bill Inbound Web Service using the C1BillSumry Service Script.
C1-BusinessPersonQueriesSummary
RestIWS
Used to retrieve Business Person Queries.
This component invokes the C1PersonQueries Inbound Web Service using the C1PersonSumm Service Script.
C1-BusinessSearch
Used to search CX4U Key Account Mgt. (KAM)
This component invokes the C1-BusinessSearch Inbound Web Service using the C1BusinSrch Service Script.
C1-EntityReferencesRestIWS
Used to support of selected CX4U Entities.
This component invokes the C1-EntityReferences Inbound Web Service using the C1EntRefSumm Service Script.
C1-GetCollectionProcessRestIWS
Used to get a collection process.
This component invokes the C1-CollectionProcess Inbound Web Service using the C1CollProces Service Script.
C1-GetLandlordAgreementRestIWS
Used to get Landlord Agreement.
This component invokes the C1-LandordAgreement Inbound Web Service using the C1LandLordAg Service Script.
C1-DeleteLandlordAgreement
Used to delete a Landlord record.
This component invokes the C1-LandlordAgreement Inbound Web Service using the C1LandlordAg Service Script.
C1-GetSeveranceProcessRestIWs
Used to lead to the severance of a service agreement.
This component invokes the C1-SeveranceProcess Inbound Web Service using the C1SeveraProc Service Script.
C1-PayPlanRestIWS
Used to create a Payment Tender.
This component invokes the C1-PayPlan Inbound Web Service using the C1-PayPlan Service Script.
C1-ServicePointSearchRestIWS
Used to search Service Point.
This component invokes the C1-ServicePointSearch Inbound Web Service using the C1ServPtSrch Script.
C1-UpdateLandlordAgreementRestIWS
Used to update Landlord Agreement.
C1-CaseSearchRestIWS
Used to search Case.
This component invokes the C1-Case Inbound Web Service using the C1CaseSearch Service Script.
C1-GetServiceAgreementStatistics_GG_NEE
Used to Service Agreement Statistics.
This component invokes the C1-ServiceAgreement Inbound Web Service using the C1-ServiceAg Service Script.
C1-GetServiceAgreementStatistics_GG_NENE
Used to Get Service Agreement Statistics.
C1-GetWebUserAccount
Used to Get Web User Account.
This component invokes the C1-WebUserAccount Inbound Web Service using the C1-CxWbUsrAt Service Script.
C1-CreateWebUserAccount
Used to create a Web User Account.
This component invokes the C1-WebUserAccount Inbound Web Service using the C1-CxWbUsrAtService Script.
C1-CreateWriteOffProcessRestIWS
Used to create a Write Off process.
This component invokes the C1-WriteOffProcess Inbound Web Service using the C1WriteOffPr Service Script.
C1-GetAccountFinancialHistory
Used to get Account Financial History.
This component invokes the C1-Bill Inbound Web Service using the C1-CreBill Service Script.
C1-GetBillBillSegmentRestIWS
Used to get a bill’s Bill Segments.
This component invokes the C1-BillSegment Inbound Web Service using the C1-GetBilSeg Service Script.
C1-GetBillRestIWS
Used to get a Bill.
This component invokes the C1-Bill Inbound Web Service using the C1-GetBill Service Script.
C1-GetBillSegmentRestIWS
Used to get Bill Segment.
This component invokes the C1-BillSegment Inbound Web Service using the C1-BillSegm Service Script.
C1-GetBudgetRestIWS
Used to get a Budget.
This component invokes the C1-Budget Inbound Web Service using the C1BudgetDeta Service Script.
C1-GetCutProcessRestIWS
Used to get Cut process.
C1-GetLandlordAgreementsPremisesList
Used to get Land Lord Agreement Premise List.
C1-GetOverdueProcessRestIWS
Used to get Overdue process.
C1-GetPaymentChar
Used to get Payment Characteristics.
This component invokes the C1-Payment Inbound Web Service using the C1-GtPytChar Service Script.
C1-GetPaymentPaySegmentRestIWS
Used to get Payment Segment in payment.
This component invokes the C1-Payment Inbound Web Service using the C1-CxPayment Service Script.
C1-GetWriteOffProcessRestIWS
Used to get Write Off process.
This component invokes the C1-WriteoffProcess Inbound Web Service using the C1WriteOffPr Service Script.
C1-PaymentDelete
Used to Delete Payment.
This component invokes the C1-Payment Inbound Web Service using the C1-DltPaym Service Script.
C1-PayPlanUpdate
Used to Update Pay Plan.
This component invokes the C1-PayPlan Inbound Web Service using the C1PayPlan Service Script.
C1-PaymentEventGet
Used to get Payment Event.
This component invokes the C1-PaymentEvent Inbound Web Service using the C1-PayEvent Service Script.
C1-PaymentEventPaymentsRestIWS
Used to get payments of Payment Event.
This component invokes the C1-PaymentEvent Inbound Web Service using the C1PayEvtPay Service Script.
C1-PaymentEventPost
Used to create Payment Event.
C1-PaymentGet
Used to get Payment.
This component invokes the C1-Payment Inbound Web Service using the C1-GetPaymnt Service Script.
C1-PaymentPost
Used to create Payment.
This component invokes the C1-Payment Inbound Web Service using the C1-CrPymtHdr Service Script.
C1-PaymentPut
Used to update Payment.
C1-PaymentTenderRestIWS
Used to get Payment Tender.
This component invokes the C1-PaymentTender Inbound Web Service using the C1-GetPayTen Service Script.
C1-ServicePointCreate
Used to create a Service Point.
This component invokes the C1-ServicePoint Inbound Web Service using the C1-CreateSP Service Script.
C1-ServicePointDelete
Used to delete a Service Point.
This component invokes the C1-ServicePoint Inbound Web Service using the C1-DeleteSP Service Script.
C1-ServicePointPut
Used to update a Service Point.
This component invokes the C1-ServicePoint Inbound Web Service using the C1-UpdateSP Service Script.
C1-ServicePointRestIWS
Used to get a Service Point and it’s child APIs.
This component invokes the C1-ServicePoint Inbound Web Service using the C1-GetSP Service Script.
C1-UpdateBillCharacteristicRestIWS
Used to update Bill Characteristics.
This component invokes the C1-Bill Inbound Web Service using the C1-CrBilChar Service Script.
C1-UpdateBillMessagesRestIWS
Used to update Bill Messages.
This component invokes the C1-Bill Inbound Web Service using the C1-CrBilMsg Service Script.
C1-UpdateBillRestIWS
Used to update Bill.
C1-UpdateBillRoutingsRestIWS
Used to update Bill Routings.
This component invokes the C1-Bill Inbound Web Service using the C1-CrBilRtng Service Script.
C1-UpdateBillSegmentItems
Used to update Bill Segments Items.
This component invokes the C1-BillSegment Inbound Web Service using the C1ActBillSeg Service Script.
C1-UpdateBillSegmentMessages
Used to update Bill Segments Messages.
C1-UpdateCutProcessRestIWS
C1-UpdateOverdueProcessRestIWS
C1-UpdatePaymentTender
Used to update Payment Tender.
This component invokes the C1-PaymentTender Inbound Web Service using the C1-UpPyTndrs Service Script.
C1-UpdatePaymentTenderChar
Used to update Payment Tender Char.
This component invokes the C1-PaymentTender Inbound Web Service using the C1-UpPyTndCh Service Script.
C1-UpdatePersonCharacteristics
Used to update a Person Characteristics.
This component invokes the C1-Person Inbound Web Service using the C1-UpdPerson Service Script.
C1-UpdatePersonIdentifiers
Used to update a Person Identifiers.
C1-UpdatePersonNames
Used to update a Person Name.
C1-UpdatePersonNameOptions
Used to update Person Name Options.
C1-UpdatePersonPhones
Used to update Person Phones.
C1-UpdatePersonRelationships
Used to update Person Relationships.
C1-UpdatePersonSeasonalAddress
Used to update a Person Seasonal Address.
C1-UpdateServicePointOperationAreas
Used to update Service Point Operation Areas.
C1-UpdateWriteOffProcessRestIWS
Used to update Write Off process.
CX-BillPayHistoryRetriever
Views Bill or Payment History.
This component invokes the CXBillPayHistoryRetriever Inbound Web Service using the WX-BillPayHs Service Script.
CX-BillSegmentHistoryRetriever
Bill Segment History -Amount and Quantity.
This component invokes the CXBillSegmentHistoryRetriever Inbound Web Service using the CX-BsegHist Service Script.
CX-AccountChargesSummaryRetriever
Retrieves Account Charges Summary.
This component invokes the CXAccountChargesSummaryRetriever Inbound Web Service using the
CX-BillView
View Bill.
This component invokes the CXBillView Inbound Web Service using the WX-ViewBill Service Script.
CX-CancelSchedPay
Cancels scheduled One-Time Payment.
This component invokes the CXCancelSchedPay Inbound Web Service using the WX-CanSchPay Service Script.
CX-ConnectedAccountsDetails
Retrieves the List of Connected Accounts.
This component invokes the CXConnectedAccountsDetails Inbound Web Service using the CXConAccDtls Service Script.
CX-ConnectedAccountsWithGuests
Connected accounts with guest users.
This component invokes the CXConnectedAccountsWithGuests Inbound Web Service using the CXConActWGst Service Script.
CX-ContextInfo
Gets Self Service Context Information.
This component invokes the CXContextInfo Inbound Web Service using the CX-CntxtInfo Service Script.
CX-CreateMeterRead
Creates Meter Read.
This component invokes the CXCreateMeterRead Inbound Web Service using the WX-CreSSMR Service Script.
CX-FinancialHistoryDownload
Account's Financial History Download.
This component invokes the CXFinancialHistoryDownload Inbound Web Service using the CX-AcctFinHD Service Script.
CX-FinancialHistoryRetriever
Gets account's Financial History.
This component invokes the CXFinancialHistoryRetriever Inbound Web Service using the CX-AcctFinHs Service Script.
CX-FormsList
Forms List.
This component invokes the CXFormsList Inbound Web Service using the CX-FormsList Service Script.
CX-FormsManagement
Forms Management.
This component invokes the CXFormsManagement Inbound Web Service using the WX-FormsMgmt Service Script.
CX-GetConsumptionSummary
Gets Consumption Summary.
This component invokes the CXGetConsumptionSummary Inbound Web Service using the WX-GetConS Service Script.
CX-GetDSSAlerts
Returns DSS Alerts.
This component invokes the CXGetDSSAlerts Inbound Web Service using the CX-SSAlerts Service Script.
CX-GetMeteredOrBDSAs
List of Metered or Bill Determinant SA.
This component invokes the CXGetMeteredOrBDSAs Inbound Web Service using the CX-RETSASPCL Service Script.
CX-GetSelfServiceLabels
Retrieves Self-Service Field Labels.
This component invokes the CXGetSelfServiceLabels Inbound Web Service using the CX-GetSSLbl Service Script.
CX-AutoPaySetup
Auto Pay Setup.
This component invokes the CXAutoPaySetup Inbound Web Service using the WX-ApaySet Service Script.
CX-GetSelfServiceDropdowns
Retrieve Self-Service Dropdowns.
This component invokes the CXGetSelfServiceDropDowns Inbound Web Service using the WX-GetSSDD Service Script.
CX-GetSelfServiceLabels_upd
Retrieve Self-Service Field Labels.
CX-MakePayment_upd
Multi Account Payments.
This component invokes the CXMakePayment Inbound Web Service using the WX-MakePay Service Script.
CX-MaintainCommPreferences
Maintains Communication Preferences.
This component invokes the CXMaintainCommPreferences Inbound Web Service using the WX-CommPref Service Script.
CX-MaintainMailingAddressInfo
Maintains Mailing Address Information.
This component invokes the CXMaintainMailingAddressInfo Inbound Web Service using the WX-MAddMain Service Script.
CX-MaintainPersonLanguageTimeZone
Maintains Person Language and Time Zone.
This component invokes the CXMaintainPersonLanguageTimeZone Inbound Web Service using the WX-MPerLngTZ Service Script.
CX-MaintainWebUser
Maintains Self Service Web User.
This component invokes the CXMaintainWebUser Inbound Web Service using the CXWebUsrMain Service Script.
CX-MaintainWebUserAccount
Maintains Self Service Web User Account.
This component invokes the CXMaintainWebUserAccount Inbound Web Service using the CXWebUsrAcct Service Script.
CX-MakePayment
CX-ManageCharities
Manages Auto Pay Charities.
This component invokes the CXManageCharities Inbound Web Service using the C1PrcChrtyAP Service Script.
CX-ManagePaymentOptions
Manages Self-Service Payment Options.
This component invokes the CXManagePaymentOptions Inbound Web Service using the C1MngPayOpt Service Script.
CX-PaymentExtensionRequest
Payment Extension Request.
This component invokes the CXPaymentExtensionRequest Inbound Web Service using the C1ProcPayExt Service Script.
CX-PreferredPayDateRequest
Processes Preferred Pay Date Request.
This component invokes the CXPreferredPayDateRequest Inbound Web Service using the C1PrefPayDt Service Script.
CX-PremiseSearch
Premise Search.
This component invokes the CXPremiseSearch Inbound Web Service using the WX-PremSrch Service Script.
CX-ProcessBudgetRequest
Process Budget Request.
This component invokes the CXProcessBudgetRequest Inbound Web Service using the WX-BudgetReq Service Script.
CX-ProcessInvitation
Process Invitation.
This component invokes the CXProcessInvitation Inbound Web Service using the CXProcInvite Service Script.
CX-ProcessPayArrangementRequest
Processes Payment Arrangement Request.
This component invokes the CXProcessPayArrangementRequest Inbound Web Service using the WX-PayArrReq Service Script.
CX-ProcessStartStopRequest
Processes Start Stop Request.
This component invokes the CXProcessStartStopRequest Inbound Web Service using the WX-StrStpReq Service Script.
CX-RateAnalysis
Performs Rate Analysis.
This component invokes the CXRateAnalysis Inbound Web Service using the WX-RateAnlys Service Script.
CX-RetrieveScalarUsage
Retrieves Scalar Usage.
This component invokes the CXRetrieveScalarUsage Inbound Web Service using the WX-RetScaUsg Service Script.
CX-SetBillNotifyPreference
Sets up Billing Notification Preferences.
This component invokes the CXSetBillNotifyPreference Inbound Web Service using the WX-BNPSet Service Script.
CX-SetNotificationPreferences
Sets Notification Preferences.
This component invokes the CXSetNotificationPreferences Inbound Web Service using the WX-SetNtPref Service Script.
CX-UsageChargesProjected
Retrieves Projected Charges.
This component invokes the CXUsageChargesProjected Inbound Web Service using the WX-ProjChrg Service Script.
CX-UsageChargesToDate
Retrieves Usage Charges to Date.
This component invokes the CXUsageChargesToDate Inbound Web Service using the WX-UsgChrgDt Service Script.
CX-VerifyAccount
Account Verification (AND/OR).
This component invokes the CXVerifyAccount Inbound Web Service using the CX-VerAcct Service Script.
CX-WebUserSearch
Web User Search.
This component invokes the CXWebUserSearch Inbound Web Service using the CXWebUsrSrch Service Script.
WX-ProcessStartStopRequest
This component invokes the WXProcessStartStopRequest Inbound Web Service using the WX-StrStpReq Service Script.
D1-CreateInstallEvent
Used to create an Install event.
This component invokes the D1-CrInsEven Service Script using the D1-InstallEvent Inbound Web Service.
D1-UpdateInstallEvent
Used to update an Install Event.
This component invokes the D1-UpdInsEve Service Script using the D1-InstallEvent Inbound Web Service.
D1-DeleteInstallEvents
Used to delete an Install Event.
This component invokes the D1-DelInsEve Service Script using the D1-InstallEvent Inbound Web Service.
D1-GetUsageSubscriptionChildRestIWS
Used to get any Usage Subscription child operation.
This component invokes different service scripts using the D1-UsageSubscription web service.
D1-UpdateUsageSubscriptionRestIWS
Used to update an Usage Subscription operation.
This component invokes D1-UpdateUS Service Script using the D1-UsageSubscription web service.
D1-GetUsageTransactionRestIWS
Used to get an Usage Transaction.
This component invokes D1-GtUsgTran Service Script using the D1-UsageTransaction web service.
D1-MeterIWS
Used to get a Meter.
This component invokes the D1-GetMeter Service Script using the D1-Meter Inbound Web Service.
D1-MeterIWSPost
Used to create a Meter.
This component invokes the D1-CreateMtr Service Script using the D1-Meter Inbound Web Service.
D1-MeterIWSPut
Used to update a Meter.
This component invokes the D1-UpdateMtr Service Script using the D1-Meter Inbound Web Service.
D1-MeterIWSDelete
Used to delete a Meter.
This component invokes the D1-DeleteMtr Service Script using the D1-Meter Inbound Web Service.
D1-ServicePointRestIWS
Used to get a Service Point.
This component invokes the D1-GetSPoint Service Script using the D1-ServicePoint Inbound Web Service.
D1-CreateServicePointRestIWS
This component invokes the D1-CreateSP Service Script using the D1-ServicePoint Inbound Web Service.
D1-UpdateServicePointRestIWS
This component invokes the D1-UpdateSPt Service Script using the D1-ServicePoint Inbound Web Service.
D1-DeleteServicePointRestIWS
This component invokes the D1-DeleteSP Service Script using the D1-ServicePoint Inbound Web Service.
D1-CreateUsageSubscriptionRestIWS
Used to create a Usage Subscription.
This component invokes the D1-CreateUS Service Script using the D1-UsageSubscription Inbound Web Service.
D1-DeleteUsageSubscriptionRestIWS
Used to delete a Usage Subscription.
This component invokes the D1-DeleteUS Service Script using the D1-UsageSubscription Inbound Web Service.
D1-GetUsageSubscriptionRestIWS
Used to get a Usage Subscription.
This component invokes D1-GetUsgSub script using D1-UsageSubscription Web Service.
D1-UsageTransactionDelete
Used to delete a Usage Transaction.
This component invokes the D1-DelUsgTrn Script using the D1-UsageTransaction Inbound Web Service.
D1-UsageTransactionGet
Used to get a Usage Transaction.
This component invokes D1-GtUsgTran Service Script using the D1-UsageTransaction Web Service.
D1-UsageTransactionPost
Used to create a Usage Transaction.
This component invokes D1-CrUsgTran Service Script using the D1-UsageTransaction Inbound Web Service.
D1-UsageTransactionActionRestIWS
Used to update UT status.
This component invokes the D1ActUsgTran Service Script using the D1- UsageTransactionActionRestIWS.
D1-UsageTransactionPut
Used to update a Usage Transaction.
This component invokes D1-UpUsgTran Service Script using the D1-UsageTransaction IWS.
D1-ItemIWS
Used to get an Item.
This component invokes the D1-GetItem Service Script using the D1-Item Inbound Web Service.
D1-ItemIWSPost
Used to create an Item.
This component invokes the D1-CreateItm Service Script using the D1-Item Inbound Web Service.
D1-ItemIWSPut
Used to update an Item.
This component invokes the D1-UpdItem Service Script using the D1-Item Inbound Web Service.
D1-ItemIWSDelete
Used to delete an Item.
This component invokes the D1-DelItem Service Script using the D1-Item Inbound Web Service.
C1-AccountRestIWS
Used to get an Account & it's child API's.
This component invokes the C1-Account Inbound Web Service using the C1-GtAccount Service Script.
C1-AccountSearchNEERestIWS
Used to Search Account.
This component invokes the C1-Account Inbound Web Service using the C1-CXAccount Service Script.
C1-AccountSearchNENERestIWS
C1-CreateAccountRestIWS
Used to create an Account.
This component invokes the C1-Account Inbound Web Service using the C1-CrAccount Service Script.
C1-UpdateAccountRestIWS
Used to update an Account.
This component invokes the C1-Account Inbound Web Service using the C1-UpAccount Service Script.
C1-DeleteAccount
Used to delete an Account.
This component invokes the C1-Account Inbound Web Service using the C1-DelAcc Service Script.
C1-DeleteBill
Used to delete a Bill.
This component invokes the C1-Bill Inbound Web Service using the C1-DeletBill Service Script.
C1-DeleteWebUserAccount
Used to delete a Web User Account.
This component invokes the C1-WebUserAccount Inbound Web Service using the C1-DelWbUsAt Service Script.
C1-PersonRestIWS
Used to get a Person and its child APIs.
This component invokes the C1-Person Inbound Web Service using the C1-GetPerson Service Script.
C1-PersonPost
Used to create a Person.
This component invokes the C1-Person Inbound Web Service using the C1-CrePerson Service Script.
C1-PersonQueriesNEERestIWS
Business Person Query
This component invokes the C1-PersonQueries Inbound Web Service using the C1PersonSumm Service Script.
C1-PersonQueriesNENERestIWS
Business Person Query.
C1-UpdatePerson
Used to update a Person.
C1-DeletePerson
Used to delete a Person.
This component invokes the C1-Person Inbound Web Service using the C1-DelPerson.
C1-CustomerContactRestIWS
Used to get a Customer Contact & it's child API's.
This component invokes the C1-CustomerContact Inbound Web Service using the C1-GetCustCt.
C1-CustomerContactPost
Used to create a Customer Contact.
This component invokes the C1-CustomerContact Inbound Web Service using the C1-CreCustCt Service Script.
C1-CustomerContactPut
Used to update a Customer Contact.
This component invokes the C1-CustomerContact Inbound web Service using the C1-UpdCustCt Service Script.
C1-CustomerContactDelete
Used to delete a Customer Contact.
This component invokes the C1-Person Inbound Web Service using the C1-DelCustCt Service Script.
C1-PremiseRestIWS
Used to get a Premise & its child API's.
This component invokes the C1-Premise Inbound Web Service using the C1-GtPremise Service Script.
C1-CreatePremiseRestIWS
Used to create a Premise.
This component invokes the C1-Premise Inbound Web Service using the C1-CrPremise Service Script.
C1-UpdatePremiseRestIWS
Used to update a Premise.
This component invokes the C1-Premise Inbound Web Service using the C1-UpPremise Service Script.
C1-DeletePremiseRestIWS
Used to delete a Premise.
This component invokes the C1-Premise Inbound Web Service using the C1-DePremise
Service Script.
C1-ServiceAgreementBilledUsage_GL_NEE
Used to Update SA Billed Usage GL NEE.
This component invokes the C1-ServiceAgreement Inbound web Service using the C1-ServiceAg Service Script.
C1-ServiceAgreementBilledUsage_GL_NENE
Used to Update SA Billed Usage GL NENE.
C1-ServiceAgreementRestIWS
Used to get a Service Agreement and the child API's.
This component invokes the C1-ServiceAgreement Inbound Web Service using the C1-GetSA Service Script.
C1-CreateServiceAgreementRestIWS
Used to create a Service Agreement.
This component invokes the C1-ServiceAgreement Inbound Web Service using the C1-CreateSA Service Script.
C1-UpdateServiceAgreementRestIWS
Used to update a Service Agreement.
This component invokes the C1-ServiceAgreement Inbound Web Service using the C1-UpdateSA Service Script.
C1-UpdateWebUserAccount
Used to Update Web User Account.
C1-WebUserCreate
Used to Create Web User.
This component invokes the C1-WebUser Inbound Web Service using the C1-WebUser Service Script.
C1-WebUserDelete
Used to Delete Web User.
This component invokes the C1-WebUser Inbound Web Service using the C1-DelWebUsr Service Script.
C1-WebUserGet
Used to Get Web User.
C1-WebUserUpdate
Used to Update Web User.
C1-DeleteServiceAgreementRestIWS
Used to delete a Service Agreement.
This component invokes the C1-ServiceAgreement Inbound Web Service using the C1-DeleteSA Service Script.
DSS-SST
Component
Description
C1-ServiceEligibility
Used to determine if a customer is eligible to start service.
This component invokes the C1-StartStopTransferTasks Inbound Web Service using the C1SSSvcElig Service Script.
C1-ServicesToStart
Used to Determine Services To Start.
This component invokes the C1-StartStopTransferTasks Inbound Web Service using the C1SSSvcsStrt Service Script.
C1-ServiceToStartProcessing
Used to Process Services To Start.
This component invokes the C1-StartSopTransferTasks Inbound Web Service using the C1SSPreSvcSt Service Script.
C1-StopSASelectionValidation
Used to Validate Stop Service Agreement Selection.
This component invokes the C1-StartSopTransferTasks Inbound Web Service using the C1SSVStopSAS Service Script.
C1-StoppableServiceDetails
Used to Retrieve Services To Stop.
This component invokes the C1-StartSopTransferTasks Inbound Web Service using the C1SSStpSvcsD Service Script.
C1-StopServiceFinalization
Used to Stop Service Finalization.
This component invokes the C1-StartSopTransferTasks Inbound Web Service using the C1SSFinStopS Service Script.
C1-TransferServiceFinalization
Used to Transfer Service Finalization.
This component invokes the C1-StartSopTransferTasks Inbound Web Service using the C1SSFinTranS Service Script.
C1-DepositAssessment
Used to determines the deposit requirements.
This component invokes the C1-StartSopTransferTasks Inbound Web Service using the C1DepositAss Service Script.
C1-OtherPersonProcessing
Used to Process Other Person.
This component invokes the C1-StartSopTransferTasks Inbound Web Service using the C1SSPrcOtPer Service Script.
C1-OtherPersonReset
Used to Clear Other Person.
This component invokes the C1-StartStopTransferTasks Inbound Web Service using the C1SSClrOtPer Service Script.
C1-RequestTypeDetails
Used to Retrieve Request Type Details.
This component invokes the C1-StartStopTransferTasks Inbound Web Service using the C1SSRqTyRead Business Object.
C1-ServiceRelatedCustomerDetails
Used to Retrieve Service-Related Customer Details.
This component invokes the C1-StartStopTransferTasks Inbound Web Service using the C1SSCustRead Service Script.
D1-MeterIWS
D1-MeterIWSPost
D1-MeterIWSPut
D1-MeterIWSDelete
D1-ItemIWS
D1-ItemIWSPost
D1-ItemIWSPut
D1-ItemIWSDelete
C1-AccountRestIWS
C1-DeleteAccount
C1-DeleteBill
C1-PersonRestIWS
C1-PersonPost
C1-UpdatePerson
C1-DeletePerson
C1-PremiseRestIWS
Service Script.
C1-WebUserCreate
C1-WebUserDelete
C1-WebUserGet
C1-WebUserUpdate
Market Settlements Management
Dynamic Aggregation
Component
Description
D1-AggrBilledServiceQuantities
Used to create a Aggregation Billed Service Quantities.
This component invokes the D1- AggrBilledServiceQuantities Business Object using the ATD1 AggrBilledServiceQuantities Inbound Web Service.
D1-AggregationCompositeSet
Used to create a Aggregation Composite Set.
This component invokes the D1- AggregationCompositeSet Business Object using the ATD1 AggregationCompositeSet Inbound Web Service.
D1-AggregationConfig
Used to create a Aggregation Config.
This component invokes the D1-AggregationConfig Business Object using the ATD1AggregationConfig Inbound Web Service.
D1-AggregationFoundationSet
Used to create a Aggregation Foundation Set.
This component invokes the D1- AggregationFoundationSet Business Object using the ATD1AggregationFoundationSet Inbound Web Service.
D1-AggregationGroup
Used to create a Aggregation Group.
This component invokes the D1-AggregationGroup Business Object using the ATD1AggregationGroup Inbound Web Service.
D1-AggregationGroupRun
Used to create a Aggregation Group Run.
This component invokes the D1- AggregationGroupRun Business Object using the ATD1AggregationGroupRun Inbound Web Service.
D1-AggregationIntervalType
Used to create a Aggregation Interval Type.
This component invokes the D1- AggregationIntervalType Business Object using the ATD1AggregationIntervalType Inbound Web Service.
D1-AggregationMasterConfig
Used to create a Aggregation Master Config.
This component invokes the D1-Aggregation Master Config Business Object using the ATD1AggregationMasterConfig Inbound Web Service.
D1-AggregatorComposite
Used to create a Aggregator Composite.
This component invokes the D1- AggregatorComposite Business Object using the ATD1 AggregatorComposite Inbound Web Service.
D1-AggregatorCustomerQuantity
Used to create a Aggregator Customer Quantity.
This component invokes the D1- AggregatorCustomerQuantity Business Object using the ATD1 AggregatorCustomerQuantity Inbound Web Service.
D1-AggregatorInterval
Used to create a AggregatorInterval.
This component invokes the D1-AggregatorInterval Business Object using the ATD1AggregatorInterval Inbound Web Service.
D1-AggregatorItems
Used to create a AggregatorItems.
This component invokes the D1-AggregatorItems Business Object using the ATD1AggregatorItems Inbound Web Service.
D1-AggregatorScalar
Used to create a Aggregator Scalar.
This component invokes the D1-AggregatorScalar Business Object using the ATD1AggregatorScalar Inbound Web Service.
D1-BadgedItemsDataSource
Used to create a Badged Items Data Source.
This component invokes the D1- BadgedItemsDataSource Business Object using the ATD1BadgedItemsDataSource Inbound Web Service.
D1-CriteriaSourceTypeLookup
Used to create a CriteriaSourceTypeLookup.
This component invokes the D1- CriteriaSourceTypeLookup Business Object using the ATD1CriteriaSourceTypeLookup Inbound Web Service.
D1-DataSourceBilledSerQuantity
Used to create a DataSourceBilledSerQuantity.
This component invokes the D1- DataSourceBilledSerQuantity Business Object using the ATD1DataSourceBilledSerQuantity Inbound Web Service.
D1-DataSourceMeasurements
Used to create a DataSourceMeasurements.
This component invokes the D1- DataSourceMeasurements Business Object using the ATD1DataSourceMeasurements Inbound Web Service.
D1-DataSourceSPQuantities
Used to create a DataSourceSPQuantities.
This component invokes the D1- DataSourceSPQuantities Business Object using the ATD1DataSourceSPQuantities Inbound Web Service.
D1-DataSourceMeasurementDirect
Used to create a DataSourceMeasurementDirect.
This component invokes the D1- DataSourceMeasurementDirect Business Object using the ATD1DataSourceMeasurementDirect Inbound Web Service.
D1-DataSourceUnbadgedItems
Used to create a DataSourceUnbadgedItems.
This component invokes the D1- DataSourceUnbadgedItems Business Object using the ATD1DataSourceUnbadgedItems Inbound Web Service.
D1-FormulaProductType
Used to create a FormulaProductType.
This component invokes the D1- FormulaProductType Business Object using the ATD1FormulaProductType Inbound Web Service.
D1-MasterDataSnapshotBillTime
Used to create a MasterDataSnapshotBillTime.
This component invokes the D1- MasterDataSnapshotBillTime Business Object using the ATD1MasterDataSnapshotBillTime Inbound Web Service.
D1-MasterDataSnapshotRealTime
Used to create a MasterDataSnapshotRealTime.
This component invokes the D1- MasterDataSnapshotRealTime Business Object using the ATD1MasterDataSnapshotRealTime Inbound Web Service.
D1-ServicePointQuantity
Used to create a ServicePointQuantity.
This component invokes the D1- ServicePointQuantity Business Object using the ATD1ServicePointQuantity Inbound Web Service.
D1-ServicePointQuantityType
Used to create a ServicePointQuantityType.
This component invokes the D1- ServicePointQuantityType Business Object using the ATD1ServicePointQuantityType Inbound Web Service.
D2-DynamicOptionIntSetType
Used to create a Dynamic Option SetType.
This component invokes the D2- DynamicOptionIntSetType Business Object using the ATD2DynamicOptionIntSetType Inbound Web Service.
D2-ItemAggregatorType
Used to create a ItemAggregatorType.
This component invokes the D1- ItemAggregatorType Business Object using the ATD1ItemAggregatorType Inbound Web Service.
D1-InboundMCSetSyncRequest
Used to create a InboundMCSetSyncRequest.
This component invokes the D1- InboundMCSetSyncRequest Business Object using the ATD1ItemAggregatorType Inbound Web Service.
D1-MCWithCharacteristics
Used to create a MCWithCharacteristics.
This component invokes the D1- MCWithCharacteristics Business Object using the ATD1MCWithCharacteristics Inbound Web Service.
D1-CompleteMCSetBOInbound
Used to create a CompleteMCSetBOInbound.
This component invokes the D1- CompleteMCSetBOInbound Business Object using the ATD1CompleteMCSetBOInbound Inbound Web Service.
D1-CompleteMCSetBO
Used to create a CompleteMCSetBO.
This component invokes the D1- CompleteMCSetBO Business Object using the ATD1CompleteMCSetBO Inbound Web Service.
Forecasting
Component
Description
D1-DailyProcTimetable
Used to create a DailyProcTimetable.
This component invokes the D1- DailyProcTimetable Business Object using the ATD1DailyProcTimetable Inbound Web Service.
D1-DefinedDatesProcSchedule
Used to create a DefinedDatesProcSchedule.
This component invokes the D1- DefinedDatesProcSchedule Business Object using the ATD1DefinedDatesProcSchedule Inbound Web Service.
D1-DimensionCombination
Used to create a DimensionCombination.
This component invokes the D1- DimensionCombination Business Object using the ATD1DimensionCombination Inbound Web Service.
D1-FactorTemperatureProfile
Used to create a FactorTemperatureProfile.
This component invokes the D1- FactorTemperatureProfile Business Object using the ATD1FactorTemperatureProfile Inbound Web Service.
D1-MCComparisonPeriod
Used to create a MCComparisonPeriod.
This component invokes the D1- MCComparisonPeriod Business Object using the ATD1MCComparisonPeriod Inbound Web Service.
D1-MCComparisonTypeStd
Used to create a MCComparisonTypeStd.
This component invokes the D1- MCComparisonTypeStd Business Object using the ATD1MCComparisonTypeStd Inbound Web Service.
D1-MulVarFacNum
Used to create a MulVarFacNum.
This component invokes the D1-MulVarFacNum Business Object using the ATD1MulVarFacNum Inbound Web Service.
D1-MulVarFacNumVal
Used to create a MulVarFacNumVal.
This component invokes the D1-MulVarFacNumVal Business Object using the ATD1MulVarFacNumVal Inbound Web Service.
D1-MulVarFacProf
Used to create a MulVarFacProf.
This component invokes the D1-MulVarFacProf Business Object using the ATD1MulVarFacProf Inbound Web Service.
D1-MulVarFacProfVal
Used to create a MulVarFacProfVal.
This component invokes the D1-MulVarFacProfVal Business Object using the ATD1MulVarFacProfVal Inbound Web Service.
D1-MulVarFacProcessor
Used to create a MulVarFacProcessor.
This component invokes the D1- MulVarFacProcessor Business Object using the ATD1 MulVarFacProcessor Inbound Web Service.
D1-MulVarFacProcessorBS
Used to create a MulVarFacProcessorBS.
This component invokes the D1- MulVarFacProcessorBS Business Object using the ATD1MulVarFacProcessorBS Inbound Web Service.
D1-SettlementUnit
Used to create a SettlementUnit.
This component invokes the D1-SettlementUnit Business Object using the ATD1SettlementUnit Inbound Web Service.
D1-StandaloneComparisonInt
Used to create a StandaloneComparisonInt.
This component invokes the D1- StandaloneComparisonInt Business Object using the ATD1StandaloneComparisonInt Inbound Web Service.
D1-StandaloneInterval
Used to create a StandaloneInterval.
This component invokes the D1-StandaloneInterval Business Object using the ATD1StandaloneInterval Inbound Web Service.
D1-StandaloneIntrvlMCType
Used to create a StandaloneIntrvlMCType.
This component invokes the D1- StandaloneIntrvlMCType Business Object using the ATD1StandaloneIntrvlMCType Inbound Web Service.
D2-IntervalAveragingEstimation
Used to create a IntervalAveragingEstimation.
This component invokes the D2- IntervalAveragingEstimation Business Object using the ATD2IntervalAveragingEstimation Inbound Web Service.
D2-IntervalProxyDayEstimation
Used to create a IntervalProxyDayEstimation.
This component invokes the D2- IntervalProxyDayEstimation Business Object using the ATD2IntervalProxyDayEstimation Inbound Web Service.
Integration Components
Component
Description
D1-InBoundAggGrpSyncReq
Used to create a InBoundAggGrpSyncReq.
This component invokes the D1- InBoundAggGrpSyncReq Business Object using the ATD1InBoundAggGrpSyncReq Inbound Web Service.
D1-MDMSettlementAggrGrpSync
Used to create a MDMSettlementAggrGrpSync.
This component invokes the D1- MDMSettlementAggrGrpSync Business Object using the ATD1MDMSettlementAggrGrpSync Inbound Web Service.
D1-MDMSettlementDCSync
Used to create a MDMSettlementDCSync.
This component invokes the D1- MDMSettlementDCSync Business Object using the ATD1MDMSettlementDCSync Inbound Web Service.
D1-MDMSettlementDeviceSync
Used to create a MDMSettlementDeviceSync.
This component invokes the D1- MDMSettlementDeviceSync Business Object using the ATD1MDMSettlementDeviceSync Inbound Web Service.
D1-MDMSettlementIESync
Used to create a MDMSettlementIESync.
This component invokes the D1- MDMSettlementIESync Business Object using the ATD1MDMSettlementIESync Inbound Web Service.
D1-MDMSettlementMCSync
Used to create a MDMSettlementMCSync.
This component invokes the D1- MDMSettlementMCSync Business Object using the ATD1MCComMDMSettlementMCSync Inbound Web Service.
D1-MDMSettlementSPSync
Used to create a MDMSettlementSPSync.
This component invokes the D1- MDMSettlementSPSync Business Object using the ATD1MDMSettlementSPSync Inbound Web Service.
D1-SettIntegrationMasterConfig
Used to create a SettIntegrationMasterConfig.
This component invokes the D1- SettIntegrationMasterConfig Business Object using the ATD1SettIntegrationMasterConfig Inbound Web Service.
D1-SynchronizationAddDevice
Used to create a SynchronizationAddDevice.
This component invokes the D1- SynchronizationAddDevice Business Object using the ATD1SynchronizationAddDevice Inbound Web Service.
D1-SynchronizationAddDC
Used to create a SynchronizationAddDC.
This component invokes the D1- SynchronizationAddDC Business Object using the ATD1SynchronizationAddDC Inbound Web Service.
Market Entities
Component
Description
D1-FixedProfileAward
Used to create a FixedProfileAward.
This component invokes the D1-FixedProfileAward Business Object using the ATD1FixedProfileAward Inbound Web Service.
D1-Market2
Used to create a Market.
This component invokes the D1-Market2 Business Object using the ATD1Market2 Inbound Web Service.
D1-MarketContract
Used to create a MarketContract.
This component invokes the D1-MarketContract Business Object using the ATD1MarketContract Inbound Web Service.
D1-MarketContractType
Used to create a MarketContractType.
This component invokes the D1- MarketContractType Business Object using the ATD1MarketContractType Inbound Web Service.
D1-MarketParticipant
Used to create a MarketParticipant.
This component invokes the D1- MarketParticipant Business Object using the ATD1MarketParticipant Inbound Web Service.
D1-MarketProduct
Used to create a MarketProduct.
This component invokes the D1- MarketProduct Business Object using the ATD1MarketProduct Inbound Web Service.
D1-MarketProductSet
Used to create a MarketProductSet.
This component invokes the D1-MarketProductSet Business Object using the ATD1MarketProductSet Inbound Web Service.
D1-MarketProductType
Used to create a MarketProductType.
This component invokes the D1- MarketProductType Business Object using the ATD1MarketProductType Inbound Web Service.
D1-MktContractType
Used to create a MktContractType.
This component invokes the D1-MktContractType Business Object using the ATD1MktContractType Inbound Web Service.
D1-MPSet
Used to create a MPSet.
This component invokes the D1-MPSet Business Object using the ATD1MPSet Inbound Web Service.
D1- PercentageAward
Used to create a PercentageAward.
This component invokes the D1-PercentageAward Business Object using the ATD1PercentageAward Inbound Web Service.
D1-TrancheAward
Used to create a TrancheAward.
This component invokes the D1- TrancheAward Business Object using the ATD1TrancheAward Inbound Web Service.
Settlement Calculations
Component
Description
D1-AttributDataSnpshtBillTime
Used to create a AttributDataSnpshtBillTime.
This component invokes the D1- AttributDataSnpshtBillTime Business Object using the ATD1AttributDataSnpshtBillTime Inbound Web Service.
D1-AttributDataSnpshtDaily
Used to create a AttributDataSnpshtDaily
This component invokes the D1- AttributDataSnpshtDaily Business Object using the ATD1AttributDataSnpshtDaily Inbound Web Service.
D1-AttributeDataSnapshotType
Used to create a AttributeDataSnapshotType.
This component invokes the D1- AttributeDataSnapshotType Business Object using the ATD1AttributeDataSnapshotType Inbound Web Service.
D1-AutoReadRegisterType
Used to create a AutoReadRegisterType.
This component invokes the D1- AutoReadRegisterType Business Object using the ATD1AutoReadRegisterType Inbound Web Service.
D1-HowToSendMCInformation
Used to create a HowToSendMCInformation.
This component invokes the D1- HowToSendMCInformation Business Object using the ATD1HowToSendMCInformation Inbound Web Service.
D1-MeasurementDataSnapshotType
Used to create a MeasurementDataSnapshotType.
This component invokes the D1- MeasurementDataSnapshotType Business Object using the ATD1MeasurementDataSnapshotType Inbound Web Service.
D1-MarketProductSet
D1-ServicePointMktPtLite
Used to create a ServicePointMktPtLite.
This component invokes the D1- ServicePointMktPtLite Business Object using the ATD1ServicePointMktPtLite Inbound Web Service.
D1-StandaloneDataRequestMC
Used to create a StandaloneDataRequestMC.
This component invokes the D1- StandaloneDataRequestMC Business Object using the ATD1StandaloneDataRequestMC Inbound Web Service.
D1-StandaloneDataRequestMCType
D1-StandaloneIntrvlComprMCType
Used to create a StandaloneIntrvlComprMCType.
This component invokes the D1- StandaloneIntrvlComprMCType Business Object using the ATD StandaloneIntrvlComprMCType Inbound Web Service.
D1- StandaloneMcDataReqCommType
Used to create a StandaloneMcDataReqCommType.
This component invokes the D1- StandaloneMcDataReqCommType Business Object using the ATD1StandaloneMcDataReqCommType Inbound Web Service.
D1-StandaloneMcDataRequest
Used to create a StandaloneMcDataRequest.
This component invokes the D1- StandaloneMcDataRequest Business Object using the ATD1StandaloneMcDataRequest Inbound Web Service.
D1-UsageSubscriptionQuantity
Used to create a UsageSubscriptionQuantity.
This component invokes the D1- UsageSubscriptionQuantity Business Object using the ATD1UsageSubscriptionQuantity Inbound Web Service.
D1-USQuantityType
Used to create a USQuantityType.
This component invokes the D1-USQuantityType Business Object using the ATD1USQuantityType Inbound Web Service.
D2-CustomerQuantityCalculation
Used to create a CustomerQuantityCalculation.
This component invokes the D2- CustomerQuantityCalculation Business Object using the ATD2CustomerQuantityCalculation Inbound Web Service.
D2-DynamicOptionIntervalEvent
Used to create a DynamicOptionIntervalEvent.
This component invokes the D2- DynamicOptionIntervalEvent Business Object using the ATD2DynamicOptionIntervalEvent Inbound Web Service.
D2-DynamicOptionIntervalSet
Used to create a DynamicOptionIntervalSet.
This component invokes the D2- DynamicOptionIntervalSet Business Object using the ATD2DynamicOptionIntervalSet Inbound Web Service.
D2-DynamicOptionIntervalSetType
Used to create a DynamicOptionIntervalSetType.
This component invokes the D2- DynamicOptionIntervalSetType Business Object using the ATD2DynamicOptionIntervalSetType Inbound Web Service.
D2-ProfileServiceQuantity
Used to create a ProfileServiceQuantity.
This component invokes the D2- ProfileServiceQuantity Business Object using the ATD2ProfileServiceQuantity Inbound Web Service.
D2-SendSettleTransactionIdComm
Used to create a SendSettleTransactionIdComm.
This component invokes the D2- SendSettleTransactionIdComm Business Object using the ATD2SendSettleTransactionIdComm Inbound Web Service.
D2- SendSettleTransactionContractComm
Used to create a SendSettleTransactionContractComm.
This component invokes the D2- SendSettleTransactionContractComm Business Object using the ATD2SendSettleTransactionContractComm Inbound Web Service.
D2- SendSettleTransactionIdCommType
Used to create a SendSettleTransactionIdCommType.
This component invokes the D2- SendSettleTransactionIdCommType Business Object using the ATD2SendSettleTransactionIdCommType Inbound Web Service.
D2- SendSettleTransactionContractComm Type
Used to create a SendSettleTransactionContractCommType.
This component invokes the D2- SendSettleTransactionContractCommType Business Object using the ATD2SendSettleTransactionContractCommType Inbound Web Service.
D2-SettAccountServiceType
Used to create a SettAccountServiceType.
This component invokes the D2- SettAccountServiceType Business Object using the ATD2SettAccountServiceType Inbound Web Service.
D2-SettlementAccountService
Used to create a SettlementAccountService.
This component invokes the D2- SettlementAccountService Business Object using the ATD2SettlementAccountService Inbound Web Service.
D2-SettlementBilledUsage
Used to create a SettlementBilledUsage.
This component invokes the D2- SettlementBilledUsage Business Object using the ATD2SettlementBilledUsage Inbound Web Service.
D2-SettlementItem
Used to create a SettlementItem.
This component invokes the D2-SettlementItem Business Object using the ATD2SettlementItem Inbound Web Service.
D2-SettlementSubscription
Used to create a SettlementSubscription.
This component invokes the D2- SettlementSubscription Business Object using the ATD2SettlementSubscription Inbound Web Service.
D2-UsageCalculationReqType
Used to create a UsageCalculationReqType.
This component invokes the D2- UsageCalculationReqType Business Object using the ATD2UsageCalculationReqType Inbound Web Service.
D2-UsageCalculationRequest
Used to create a UsageCalculationRequest.
This component invokes the D2- UsageCalculationRequest Business Object using the ATD2UsageCalculationRequest Inbound Web Service.
D2-UsageCalculationType
Used to create a UsageCalculationType.
This component invokes the D2- UsageCalculationType Business Object using the ATD2UsageCalculationType Inbound Web Service.
D2-UsgSubsMarketParticipant
Used to create a UsgSubsMarketParticipant.
This component invokes the D2- UsgSubsMarketParticipant Business Object using the ATD2UsgSubsMarketParticipant Inbound Web Service.
