Installing Components and Flows
Make sure to replace the <VERSION> tag with the supported product versions.
This section provides the steps to install components and flows for Core, Mobile Workforce Management, Customer Care and Billing, Customer to Meter, Work and Asset Management, and Meter Data Management. It includes:
Installing Core Components and Flows
To install/import core components and flows:
2. Navigate to <TEMPDIR>/Client/Core/25.4 directory.
3. Import the CORE254_UIComponents.zip and CORE254_WSComponents.zip followed by CORE254_Flows.zip into the Oracle Utilities Testing Accelerator workbench.
4. Import the IWS bundle of your Oracle Utilities Application Framework’s version into the Oracle Utilities application. For instructions refer to
Importing Inbound Web Service Bundles.
Example: If your Oracle Utilities Application Framework’s version is 4.3.0.2.0, import OUAF501_IWS_4302.xml.
Installing Components and Flows for Other Oracle Utilities Applications
The components and flows for supported Oracle Utilities applications are not shipped with the Oracle Utilities Testing Accelerator package. Download them separately from My Oracle Support.
For a list of existing product packs available, refer to
Appendix B: Oracle Utilities Application Product Packs. Instructions on how to install components and flows for these product packs are available in the Readme files of the respective patches.
Important! Make sure to follow the steps in
Installing Core Components and Flows before importing any other Oracle Utilities application components/flows.
