Deleting an Object
If revision control is turned on for an object, you must use the Revision Control zone to delete it.
The object must be checked in before it can be deleted.
- Go to the object that you want to delete.
- Select Delete in the Revision Control zone.
- Provide details regarding the deletion.
- Select OK to delete the object.
