Defining Other Related Options
Oracle Utilities Digital Asset Cloud Service and Oracle Utilities Digital Asset Management both share significant functionality with Oracle Utilities Work and Asset Management. The following administrative options are also available with Oracle Utilities Digital Asset Cloud Service and Oracle Utilities Digital Asset Management.
Organizations
Compliance
Service History
Asset Management
Operational Device Management
Inventory
Purchasing
Work Options
Preventive Maintenance
Scheduling
Approvals
Financials
Configuration Options
Note: Menu items for some features in the above functional areas may may have moved in Oracle Utilities Digital Asset Cloud Service and Oracle Utilities Digital Asset Management. To access to a specific menu item, enter a forward slash ("/") followed by the name of the menu item in the Unified Search field. For instance, to access the "Asset Type, Search" menu item, you could enter "/asset type" (the search is case-insensitive) in the Unified Search field, and select "Asset Type" from the list that appears below the text field.
