Defining Employee Types
The Employee Type portal is used to display and maintain employee types.
Refer to Understanding Resource Requirements for more information.
You can access the portal from Admin, select E, then select Employee Type.
- Employee Type List: This zone lists all employee type records. Broadcast a record to display the details of the selected record.
- Employee Type: This zone provides information about the selected employee type.
