Extending Asset Statuses
If your implementation needs to create a new Asset Lifecycle BO with a status which differs from the base package, you can choose to create them by extending W1-AssetDisposition. With this extension, note the following:
  • ‘assetRelationship’ on the Asset Disposition has 3 values: Installed, Attached, and Not Installed.
    • Installed is applicable to assets when they are installed in service.
    • Attached is applicable to components when they are attached to an asset.
    • Not Installed is applicable when assets or components are in other statuses (in store, in receipt, in repair, rejected, or retired).
  • Since the assetRelationship is in a Character Large Object (CLOB), the base package uses a naming convention using the asset disposition code. The first two characters should be ‘IN’ for installed, ‘AT’ for attached, and ‘NI’ for not installed.
