Maintaining ODM Configuration Reports
This portal is used to display and maintain configuration reports.
Refer to About ODM for more information.
You can access the portal from Admin, select C, then select Configuration Report. You are brought to a query portal with options for searching for configuration reports. Once the report has been selected, you are brought to the maintenance portal to view and maintain the selected record.
  • Configuration Report: This zone provides details about the report.
