Maintaining Preventive Maintenance Schedules
The Maintenance Schedule portal is used to display and maintain a maintenance schedule record.
You can access the portal from Menu, select Preventive Maintenance, then select Maintenance Schedule. You are brought to a query portal with options for searching for a specific record. Once a maintenance schedule has been selected, you are brought to the maintenance portal to view and maintain the selected record.
  • Maintenance Schedule: This zone displays information about the maintenance schedule record.
  • Maintenance Trigger: This zone lists the triggers associated with the maintenance schedule record.
  • Asset List Maintenance Trigger: This zone lists the asset list maintenance triggers associated with the maintenance schedule record.
  • Maintenance Specification: This zone lists the specifications associated with the maintenance schedule record.
  • Activity: This zone lists all the non-finaled activities associated with the maintenance schedule record.
The following zones may appear as part of the portal’s Analytics tab page:
  • Failure Type Analytics: This zone displays a graphical view of analytics for the maintenance schedule where corrective maintenance has occurred for the assets associated to the maintenance schedule with a failure type detailed.
  • Failure Mode Analytics: This zone displays a graphical view of analytics for the maintenance schedule where corrective maintenance has occurred for the assets associated to the maintenance schedule with a failure mode detailed.
  • Failure Type and Failure Mode Analytics: This zone displays a graphical view of analytics for the maintenance schedule where corrective maintenance has occurred for the assets associated to the maintenance schedule with a failure type and mode detailed.
  • Failure Type, Mode and Repair Analytics: This zone displays a graphical view of analytics for the maintenance schedule where corrective maintenance has occurred for the assets associated to the maintenance schedule with a failure type, mode, and repair detailed.
