Maintaining Receipts
The Receipt portal is used to display and maintain receipts.
You can access the portal from Menu, select Inventory, then select Receiving — Receipt. You are brought to a query portal with options for searching. Once your record has been selected you are brought to the maintenance portal to view and maintain the selected record.
  • Receipt Header: This zone provides information about the receipt, such as receipt information, purchase order information, additional processes, and a receipt line status summary.
  • Open Receipt Lines: This zone enables a search for open receipt lines filtered by storeroom and resource type.
  • In Receipt Lines: This zone displays the in receipt lines in a table format. Users are also able to search by storeroom and resource type to filter the results.
  • Accept/Return Detail: This zone displays the receipt line information that has been accepted or returned. Receipt lines also display deficient in red text in the info string if the receipt line includes a deficiency.
  • Purchase Order Line Activity: This zone displays the purchase order lines and receipt lines associated with the purchase order line activity.
  • Notes: This zone lists the notes associated with this entity.
  • Attachments: This zone lists the attachments associated with this entity.
