Deleting an Object
If revision control is turned on for an object, you must use the Revision Control zone to delete it.
The object must be checked in before it can be deleted.
To delete a revision controlled object:
  1. Go to the object that you want to delete.
  2. Select Delete in the Revision Control zone.
  3. Provide details regarding the deletion.
  4. Select OK to delete the object.
The system creates a revision record before the object is deleted so that the deleted object can be restored.
