One Initial State and Multiple Final States
When you set up lifecycle states, you must pick one as the initial state. The initial state is the state assigned to new entities associated with the business object. For example, the above high-bill complaint business object defines an initial state of Lodged, whereas the literature request one defines an initial state of Literature Sent.
You must also define which statuses are considered to be "final". Typically when an entity reaches a "final" state, its lifecycle is considered complete and no further processing is necessary.
Allowing An Entity To Be "Reopened". You can set up your
state transition rules to allow a business entity to be
"reopened" (i.e., to be moved from a final state to a non-final
state). Neither of the above examples allows this, but it is
possible if you configure your business object
accordingly.
