Save Button
Clicking the Save button saves any changes you have made in the data on the current object.
The Save button
Keyboard Shortcut Alternate Shortcut
Alt+S Alt+Shift+S
Note: Refer to Shortcut Key Summary for information about the alternate shortcut.
The button does not appear unless:
  • You enter a page in add mode and default values are loaded.
  • You make changes to an object after it is displayed (note that you must tab or click out of the field before the Save button appears).
