Conversion Batch Controls
The following batch controls are delivered with base product:
Batch Control |
Description |
K1-CNVLD |
Conversion - Load Data using SQL Loader. This process facilitates the legacy data extract upload using SQL Loader. The input data files are expected to be uploaded to a file storage location. See Input and Output File Location for more information about file storage locations. One run uploads the data into a single target Table or Maintenance Object. The process is multi-threaded. This process is discussed in more details in the Data Load Batch chapter |
K1-CNVDS |
Conversion - Disable Conversion This process resets the environment indicators and prevents further conversion activities. Once conversion is disabled, the following actions are blocked:
Note: The process should be executed only once and only after
all of the conversion activities are completed and the application
is ready for the real production use.
K1-CNVEN |
Conversion - Enable Conversion This process resets the environment indicators and enables it for conversion activities. It should be executed at the start of the Conversion project. |
K1-DRPIN |
Conversion - Disable Indexes on Production Tables This process can be used in two modes:
K1-SDSIN |
Conversion - Disable Indexes on Staging Tables This process can be used in two modes:
K1-RIUSP |
Conversion - Rebuild Indexes and Update Statistics in Production This process can be used in two modes:
It is recommended to rebuild the indexes and update statistics right after the data upload. |
K1-RIUSS |
Conversion - Rebuild Indexes and Update Statistics in Staging This process can be used in two modes:
K1-CLNTB |
Conversion - Truncate Tables in Production This process can be used in two modes:
K1-SCLTB |
Conversion - Truncate Tables in Staging This process can be used in two modes:
K1-CLNRT |
Conversion — Truncate XML Resolution Tables This process
is allowed to run only in the Staging schema and may be used in two
modes:
K1-CLNKY |
Conversion - Truncate Key Reference Tables This process is allowed to run only in the Staging schema and may be used in two modes:
