Defining Cost Adjustment Types
The Cost Adjustment Type portal is used to display and maintain cost adjustments.
Refer to Understanding Cost Adjustment Types for more information.
You can access the portal from Admin, select C, then select Cost Adjustment Type.
- Cost Adjustment Type List: This zone lists all cost adjustment type records. Broadcast a record to display the details of the selected record.
- Cost Adjustment Type: This zone displays information about the selected cost adjustment.
