Defining Crews
The Crew portal is used to display and maintain crews.
Refer to Understanding Scheduling for more information.
You can access the portal from Admin, select C, then select Crew. You are brought to a query portal with options for searching. Once your record has been selected you are brought to the maintenance portal to view and maintain the selected record.
- Crew: This zone provides information about the crew, such as primary and secondary crew members, default crew service classes and crew service areas.
- Shift Plan Template: This zone provides details about the shift plan template.
- Crew Calendar: This zone displays a calendar view of the crew’s shifts.
