Defining Measurement Types
The Measurement Type portal is used to display and maintain measurement types.
You can access the portal from Admin, select M, then select Measurement Type.
  • Measurement Type List: This zone lists all measurement type records. Broadcast a record to display the details of the selected record.
  • Measurement Type: This zone provides information about the selected measurement type, including upper and lower threshold limits and inner and outer threshold exceeded details.
