Maintaining Facilities
The Facilities portal is used to display and maintain facility records.
Refer to About Facilities for more information.
You can access the portal from Menu, select Device Installation, then select Facility. You are brought to a query portal with options for searching for a specific record. Once a facility has been selected, you are brought to the maintenance portal to view and maintain the selected record.
  • Facility: This zone displays general information about the facility.
  • Network Locations Related to Facility: This zone lists the network locations associated with the facility record.
  • Downstream Service Points Related to Facility: This zone lists the downstream service points associated with the facility record.
