Maintaining Contacts
The Contact portal is used to display and maintain contacts.
You can access the portal from Menu, select Asset Management, then select Contact. You are brought to a query portal with options for searching. Once your record has been selected you are brought to the maintenance portal to view and maintain the selected record.
  • Contact: This zone displays information about the contact.
  • Location Referencing Contact: This zone displays location information for the contact.
  • Contact Relationship: This zone displays information on all the records associated with the contact.
  • Communication Log: This zone displays a log of the contact’s communications.
