Maintaining Employee Unavailability
This portal is used to view and maintain employee unavailability.
You can access this portal from Menu, select Resource Management, and then select Employee Unavailability. You are brought to a query portal with options for searching for a specific employee unavailability record. Once the employee unavailability has been selected, you are brought to the maintenance portal where you can view and maintain the selected record.
The following zones may appear as part of the portals Main tab page:
  • Employee Unavailability: This zone provides information about an employee’s leave including definitions for creating a timesheet during the unavailability period.
